2017 Audi A3 Quattro Premium Plus (POST ACCIDENT) & MOTOR SWAP
JohnFrost
Wausau, WI, USA
C?ID=512610
Alright, so...I have a headache and a half guys. After quite a long wait, I finally got the money together and got a used engine (same model) for my car. Everything went smooth. Now however, i have plenty of faults. Most if not all of these codes were present BEFORE the motor swap, so that part isnt really relevant. However, where im mad, is i took it today to an auto body shop who has the equipment etc to calibrate my sensors an A-Z. They charged me 500 dollars and honestly nothing has changed. My car was in an accident with airbags and everything else. NO i didnt replace them yet and i understand with that some safety features will not work. but adaptive cruise control, brake booster, hill climb, and basically every sensor i have isnt working properly. i also have a very weird pulsating in my brake pedal and its very inconsistent. PLEASE help me. Here is an auto scan. (Worth noting) I sent my seatbealts in for repair and they currently are not in the car. they should be back in the mail within the next day or two. Sorry for the novel. Thank You in advance
Wednesday,12,March,2025,18:59:39:48745
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WAUJ8GFF7H1034988   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 07 08 09 10 11 31 13 15 16 17 19 22 2B 3C 42 44
          52 5F 61 6C BB BC CF
VIN: WAUJ8GFF7H1034988   Mileage: 122397km-76053miles
04-Steering Angle -- Status: Cannot be reached 0100
07-Control Head -- Status: Cannot be reached 0100
11-Engine II -- Status: Cannot be reached 0100
31-Engine other -- Status: Cannot be reached 0100
61-Battery Regul. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 0F61BC97
   Coding: 0A1D00124426010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372B2590FFC662227EA-8062
   VINID: 9D195A2175961D80400C4248207B2FED60
23648 - Heater support pump
          P16C1 00 [00101111] - Open circuit
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 20:58:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 74 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 11.992 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 98 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 1350.0 kPa
17178 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 21:52:18
                    Engine speed: 977.75 /min
                    Normed load value: 14.5 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.367 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
14916 - Catalyst System; Bank 1
          P0420 00 [01101000] - Efficiency Below Threshold
                    Mileage: 120772 km
                    Date: 2025.02.21
                    Time: 15:05:23
                    Engine speed: 2681.00 /min
                    Normed load value: 18.8 %
                    Vehicle speed: 111 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 1 °C
                    Voltage terminal 30: 14.589 V
                    Unlearning counter according OBD: 11
                    Engine: operating status: PL
                    TEMP_CAT_UP_1_SAE: 696.2 °C
                    Cat. ageing: bank 1: actual: 1.133
                    LAMB_DELTA_I_LAM_ADJ[1]: -0.00018
                    Lambda probes actual: bank1: 1.0781
                    VLS_DOWN_SAE[1]: 0.175 V
                    T_AST_SAE: 277 s
   Part No SW: 0D9 300 014 N    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5002
   Revision: 06454104    Serial number: TFK01609250776 CVN: 00000389
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E1C05B5E1E82B22-8076
   Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
   Component: ESC           H62 0642
   Revision: 00000000    Serial number: 62806000000493
   Coding: 13FF6A923423227089800B0880CB29C8562C4491D0019476124100548288420000000012121212B835351919323200
   VCID: 015F8B48E182EC9280E-8054
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 127
                    Mileage: 122381 km
0338 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
          [inlet valve calibration data missing]
                    Reset counter: 127
                    Mileage: 122381 km
4166 - Function Restriction
          C10C2 F1 [00001000] - due to Overload
          [eHBV counter has reached maximum duration]
                    Reset counter: 128
                    Mileage: 122381 km
4235 - Vacuum sensor
          C10A3 01 [10001001] - Electrical Failure
          [No frames received from the vacuum sensor or Invalid data received from the sensor]
                    Reset counter: 127
                    Mileage: 122381 km
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420178739 Dataset Number: 8V0909577D  0010
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B2339A0C3EE46429A2-806E
Address 07: Control Head
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001068592
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D94E4CAA08259ACF0-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: 4H0907658B  H01 0005
   Serial number: F938C15800PAG0MUFU03
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001627901174 Dataset Number: 8V0909514Q  0035
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5F0B4907C936AFDC-802A
   Component: WWS371 160729  043 0585
   Serial number:         160805164043
   Coding: 0A47F7
   Serial number: 62351461
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 01 08 2016  00001616
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036653978
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0018CUJY00000
   Coding: 101F00
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418616280 Dataset Number: 8V0909526G  0058
   Coding: 0430155011
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   VCID: 094F9368D9B2A4D2D8E-805C
13637426 - Databus
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:53
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:53
Address 11: Engine II
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: 8V1909863J  0031
   Coding: B500000218F78428949C8055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:35
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 12.0 V
   Serial number: 003GCR06EAUW Dataset Number: 8V0909602R  0002
   Shop #: WSC 10936 002 1048576
   VCID: 47CB55508F2612A20EA-8012
   Left seat belt tensioner:
   Right seat belt tensioner:
   Serial number: 694000000000001JGZJN
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 000 610 16
   Serial number: 35700000000A8C7C4E1/
   Subsystem 5 - Part No SW: -----------    HW: 480 000 610 16
   Serial number: 358000000007E6253F1Q
   Subsystem 6 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3510001B123204C1E60N
   Subsystem 7 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3520001C12303C9683C$
   Subsystem 8 - Part No SW: -----------    HW: 480 400 909 16
   Serial number: 3550002B9215E1E1F0EG
   Subsystem 9 - Part No SW: -----------    HW: 480 400 909 16
   Serial number: 3560002BD215E1E1E19G
17 Faults Found:
9438481 - Igniter for Driver head airbag
          B1005 11 [10001001] - Short to Ground
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9440282 - Driver side knee airbag igniter
          B100C 1A [10001001] - Resistance Too Low
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9440794 - Front Passenger's Knee Airbag Igniter
          B100E 1A [10001001] - Resistance Too Low
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
          B1006 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [10001001] - Resistance Too High
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Reset counter: 130
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:03:45
13679104 - Local Data Bus
          U10BA 00 [00001001] - No Communication
          [PreCrash LIN no communication]
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:26
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 13101604400566
   Coding: A018
   VCID: 0D47A778ADDAB8F2F46-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890     HW: 8V0 920 890
   Component: FBenUSA       H13 0045
   Coding: 00E518512398CF050285E8001800000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 7AADFCA48C54BF4AC14-802E
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 13101610800850 Dataset Number: 8V0909515L  0078
   Coding: 030100043F085A005B00024C180B00000001010000000000000000000000
   GVL: 01D43C0000000600404C82000002C80100440010000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA1FABC8660817AD38-8028
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0002
   Serial number: 20160930113149 00631
   Serial number: 75410803001610132164
131665 - No Communications with Undefined Control Module
          U1126 00 [00001001] - -
          [Timeout Knoten 0x51]
                    Reset counter: 130
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:05
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
131704 - No Communications with Undefined Control Module
          [Timeout Knoten 0x78]
                    Reset counter: 130
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:05
                    Terminal 15: On
131726 - No Communications with Undefined Control Module
          [Timeout Knoten 0x8E]
                    Reset counter: 130
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:05
                    Terminal 15: On
131740 - Battery Energy Control Module 2
          U014A 00 [00001001] - No Communication
          [Timeout Knoten 0x9C / 21 - Steuergerät für Batterieenergiemanagement 2]
                    Reset counter: 130
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:05
                    Terminal 15: On
   Serial number: HA1-00009.09.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACD6C649C34EFCA114-801E
   Revision: 00000000    Serial number: 16000160652008
   Coding: 5D00000000000000
   VCID: 3431129CEEB0893A5B8-8060
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------    Dataset Number: 8V0909535F  0005
   Coding: 040002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 392F23A8C9D2745288E-806C
729349 - Control Module for Lane Change Assistance
          C1114 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
                    Control Module temperature: 30 °C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 12.00 V
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
1192062 - Databus
          [databus error value received - PH_Systemzustand]
                    Reset counter: 170
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:10:36
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 11.90 V
1192264 - Databus
          [databus error value received - PH_Tongeber_H_verfuegbar]
                    Reset counter: 170
                    Mileage: 122397 km
                    Date: 2025.03.12
                    Time: 18:21:53
                    Control Module temperature: 29 °C
                    Vehicle speed: 2.05 km/h
                    Voltage terminal 15: 13.00 V
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 220916EIL16137 Dataset Number: 8V0909872H  0038
   Coding: 00141B204000048000000002
   VCID: 41DF4B48A1022C92C0E-8014
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: 8V0909852P  0026
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75F58B52A00B2FC6-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 200916EIJ06441 Dataset Number: 8V0909873H  0038
   Coding: 001413204C00048000000002
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 890     HW: 8V1 035 890
   Component: MU-P-LNS-US   052 0694
   Serial number: A703H0G7502554 Dataset Number: 8V2909545M  0017
   Coding: 01730102FF0A000011220001041A00102F002BE5017001047E
   Shop #: WSC 47485 002 1048576
   VCID: 78A9E6ACB258AD5AB70-802C
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Multimedia display unit 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY20800U
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL109091600010251
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
                    Reset counter: 128
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 13:03:12
                    Voltage terminal 30: 12.7 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 61: Battery Regul.
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 041016EJ307034 Dataset Number: 8V0909897G  0026
   Coding: 000013204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   VCID: 43D34140BB1E3E82D22-8016
   Serial number: 041016EJ307132 Dataset Number: 8V0909896G  0026
   ROD: EV_DCURearPasseMAXKLO.rod
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 36352894F8CC9B2A65C-8062
End----------(Elapsed Time: 01:53, VBatt start/end: 12.3V/12.3V)-----------
------------------------------36 Faults Found------------------------------
JohnFrost
Wausau, WI, USA
C?ID=512610
Is there any coding or low hanging fruit ideas that I can maybe start to try and eliminate some of these? Considering my sensors are positioned correctly (according to the shop)
Let's start with the obvious:
[Select]
[19-CAN Gateway]
Scroll down to the following and remove the check-marks next to them:
- 07-Control Head
- 11-Engine II
- 31-Engine other
- 61-Battery Regul
[Write Coding]
The cycle ignition, clear all faults, and re-scan.
JohnFrost
Wausau, WI, USA
C?ID=512610
Under CAN Gateway the only one i couldnt seem to find and uncheck was 31-Engine Other. However i did the rest and here is my scan
Thursday,13,March,2025,19:26:10:48745
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C
          BB BC CF
VIN: WAUJ8GFF7H1034988   Mileage: 122496km-76115miles
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 20:58:02
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 98 kPa
17178 - Databus
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 21:52:18
          P0420 00 [11101101] - Efficiency Below Threshold
                    Mileage: 120772 km
                    Date: 2025.02.21
                    Time: 15:05:23
                    T_AST_SAE: 277 s
                    Reset counter: 127
                    Mileage: 122381 km
                    Reset counter: 127
                    Mileage: 122381 km
                    Reset counter: 170
                    Mileage: 122381 km
                    Reset counter: 127
                    Mileage: 122381 km
   Coding: 030C0C
   Component: AQ_Hum_Sensor  H01 0005
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0430155011
13637426 - Databus
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:53
13688835 - Databus
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:53
2101 - Databus
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:35
   Coding: 303333
17 Faults Found:
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:03:45
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:26
   Coding: A018
   GVL: 01D43C0000000600404C82000002C80000040000000000000000000000000000
   Generator:
                    Reset counter: 134
                    Mileage: 122496 km
                    Date: 2025.03.13
                    Time: 19:21:51
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: On
   Coding: 0001
   Coding: 040002
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
1192062 - Databus
                    Fault Frequency: 16
                    Reset counter: 174
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:10:36
1192264 - Databus
                    Reset counter: 174
                    Mileage: 122397 km
                    Date: 2025.03.12
                    Time: 18:21:53
   Coding: 0107
                    Reset counter: 128
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 13:03:12
   Revision: --------
   Coding: 040002
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.3V)-----------
------------------------------33 Faults Found------------------------------
It's possible that one is an artifact of having 11 checked.
Looks like you have a bunch of things to fix now.
JohnFrost
Wausau, WI, USA
C?ID=512610
Can you elaborate? I’m not too advanced with things like this. Where would you start?
JohnFrost
Wausau, WI, USA
C?ID=512610
Friday,14,March,2025,19:05:19:48745
          BB BC CF
VIN: WAUJ8GFF7H1034988   Mileage: 122549km-76148miles
15-Airbags -- Status: Not registered 0011
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 20:58:02
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 98 kPa
17178 - Databus
                    Mileage: 120533 km
                    Date: 2025.02.18
                    Time: 21:52:18
          P0420 00 [11101000] - Efficiency Below Threshold
                    Mileage: 120772 km
                    Date: 2025.02.21
                    Time: 15:05:23
                    T_AST_SAE: 277 s
          P1734 00 [00000010] - -
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:09:08
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:09:20
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0430155011
13637426 - Databus
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:00:01
13688835 - Databus
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:00:02
2101 - Databus
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:35
   Coding: 303333
17 Faults Found:
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:24
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:25
                    Fault Frequency: 28
                    Reset counter: 138
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:03:45
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:01:26
   Coding: A018
   GVL: 01D41C0000000600404C82000002C80000040000000000000000000000000000
   Generator:
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:21:35
                    Terminal 15: On
65793 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
          U0009 00 [00001000] - -
          [Eindrahtfehler CAN-Antrieb]
                    Reset counter: 178
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:28:20
                    Terminal 30 power supply: 13.3 V
                    Terminal 15: On
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 138
                    Mileage: 122541 km
                    Date: 2025.03.14
                    Time: 18:21:35
                    Terminal 15: On
   Coding: 0001
   Coding: 040002
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
                    Reset counter: 127
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:02:26
1192062 - Databus
                    Fault Frequency: 25
                    Reset counter: 178
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 11:10:36
1192264 - Databus
                    Fault Frequency: 8
                    Reset counter: 178
                    Mileage: 122397 km
                    Date: 2025.03.12
                    Time: 18:21:53
   Coding: 0107
                    Reset counter: 128
                    Mileage: 122381 km
                    Date: 2025.03.12
                    Time: 13:03:12
   Revision: --------
   Coding: 040002
End----------(Elapsed Time: 01:47, VBatt start/end: 12.6V/12.5V)-----------
------------------------------34 Faults Found------------------------------
I have no personal experience with engine swaps or post-crash rebuilds, so I'm probably not the person to ask.
JohnFrost
Wausau, WI, USA
C?ID=512610
okay maybe i am in the wrong category of the threads? I am just looking to get my sensors calibrated, and trying to get my cruise control back. I dont believe any of this due to the recent problems, but more so because cleared codes with my parking brake module or something in my ABS module. I cannot seem to get my steering angle sensor calibrated
