Quick question on generator load mvb
Gozzy
Northwich, UK
C?ID=546157
Hi,
In the engine module there is an advanced measuring block called Generator Load but whether the engine is idling or with full revs the value doesn't change from 0%.
As I understand it its the dfm wire that connects from the alternator to the bcm and ecu which is wired correctly and I can see voltage on it when backprobed.
Is this option only available on certain models?
Wednesday,12,March,2025,12:49:02:43604
VIN: WVWZZZ1FZ9V019551   License Plate:
                Address 01: Engine  (03L 906 022 PM)
12:49:00
  0.0 %   Generator Load
Gozzy
Northwich, UK
C?ID=546157
Hi, thanks for taking a look.
I've attached a scan below.
I also don't get access to the fuel pressure basic settings module same as the generator load?
https://ibb.co/j9qmxYQ9
But I can see fuel pressure information so maybe the basic settings option isn't available for my model?
14:53:55
  100.0 %   Exhaust Gas Recirc. Duty Cycle
  1162.8 mbar   Boost Pressure (specified)
  2193.0 mbar   Boost Pressure (actual)
  9.8 %   Charge Pressure Control Duty Cycle
  12.62 V   Supply Voltage (Terminal 30)
  0.0   High Fuel Pressure Control Status
  232.05   High Fuel Pressure Control Deviation
  7.1 %   High Fuel Pressure Control Valve
  240.0 bar   High Fuel Pressure (specified)
  0.0 bar   High Fuel Pressure (actual)
Full scan:
Tuesday,28,January,2025,13:52:11:43604
VIN: WVWZZZ1FZ9V021916   License Plate:
Mileage: 580820km-360904mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WVWZZZ1FZ9V021916   Mileage: 580820km-360904miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 PM    HW: 03L 906 022 G
   Component: R4 2.0l TDI 0000SG  9979
   Revision: 13H01---    Serial number: VWX7Z0HN3NR7V2
   Coding: 0001032
   Shop #: WSC 84296 154 591528
   VCID: 7F5B10439BF7D9B2261-802A
   VINID: 9E69EAAAA056A8998008124118586701C3
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - MIL ON
                    Fault Status: 11100000
                    Mileage: 580821 km
                    Time: 02:34:47
                    Voltage: 12.24 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 680.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
001552 - Engine Control Unit Incorrectly Coded
               P0610 - 000 -  - MIL ON
                    Mileage: 580821 km
                    Time: 02:34:47
                    Voltage: 12.24 V
                    Voltage: 12.24 V
                    Voltage: 12.24 V
                    Voltage: 12.24 V
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.clb
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 35110 377 00161
   VCID: 3FDB5043DB7719B2661-806A
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BA3E4538FEFC5920A9-802E
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005096278
   Coding: 00004E130004100000000000000000000008FB075C
   Shop #: WSC 12345 111 45725
   VCID: 2A0D111730F58C1A21F-807E
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 211207 021  0501
   Coding: 00038805
   Shop #: WSC 12345
7 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.00 V
                    Fault Status: 01111100
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.05 V
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.00 V
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.00 V
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 01101010
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.00 V
                    Reset counter: 11
                    Mileage: 580821 km
                    Voltage: 12.00 V
                    Fault Frequency: 13
                    Reset counter: 51
                    Mileage: 580821 km
                    Voltage: 12.20 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD081LB7
   Coding: 0012345
   VCID: 7DA7EA4B91FBCBA234D-8028
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenksäulenmodul 034 0070
   Coding: 0000001
   Shop #: WSC 35110 377 08192
   VCID: 75B7F26BA9CB93E27CD-8020
   Part No: 2K0 920 942 C
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0017401
   Shop #: WSC 00391 067 57207
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105922036E
   Coding: 3D0F0300079001
                    Reset counter: 51
                    Mileage: 580821 km
                    Time: 00:11:28
   Component: IMMO            VDD 1012
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2302
   Coding: 0000693
   Shop #: WSC 12345 111 45799
   VCID: 36353567F44DD8FAB57-8062
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   Shop #: WSC 00288 210 98634
   VCID: 34310F6FE231CAEA8B3-8060
            000 - - - MIL ON
                    Mileage: 580821 km
                    Time: 00:09:05
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 10.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No: 1K0 959 433 AK
   Coding: 4F8A000080008505481A0D0011C0
   VCID: 79AFFE5B85D3F782185-802C
   Part No: 1T0 959 702 B
   Coding: 0000693
   VCID: 372B3863F34721F2AE1-8062
End----------(Elapsed Time: 00:51, VBatt start/end: 13.9V/13.7V)-----------
I don't think this car has the means for the ECU to actually monitor generator load.
My guess is you have to reset it first in Adaptations, but I do not recommend messing with it unless you have a good reason to, and certainly not while there are obvious, unrelated faults.
What's the back-story here; how did the ECU get to be "Incorrectly Coded"?
Gozzy
Northwich, UK
C?ID=546157
Thanks for the reply.
I've done an engine swap in my Caddy from SDI BST to TDI CBAB and wired it all in and only have one error code which is the ECU one.
The immobiliser has been disabled on the ecu which is causing this and the G70, lights etc are all unplugged which is why theres a few dtcs.
The main issue is with boost and the MAP sensor (glowplug light flashing)
I took a video of a few tests I did with the MAP sensor unplugged which lets me complete the turbo basic settings without issue.
These are the results when the MAP is plugged in (it shows that the duty cycle for egr and turbo idles at 100% rather than 5%ish)
It's hard to explain but hopefully someone can spot something.
I've confirmed voltages at the map plug, tried a new map even though its actually working as it showing boost increasing and checked every ecu pin to every plug for continuity.
Absolutely bonkers why its doing this.
Gozzy
Northwich, UK
C?ID=546157
Ended up getting a new alternator and now its seeing a generator load value and charging correctly.
