Resolved 2005 Audi S4 Cabriolet Battery Coding;
Resolved
Sebas
Toronto, ON, Canada
C?ID=610702
I replaced my battery with an "original battery" from the dealer and try to code in the new battery. I followed the videos from VCDS to perform the operation. No matter what I do, I get that message "NO RESPONSE FROM CONTROLER". Help MOMY...
After running engine 30 minutes, hot, temp 99c still has 2 fault codes
Tuesday,11,March,2025,12:52:35:61611
VCDS Version: Release 25.3.0 Running on Windows 10 x64
                Address 01: Engine       Labels: 079-910-560-BBK.lbl
Control Module Part Number: 8H0 910 560 G    HW: 8E0 907 560
  Component and/or Version: 4.2L V8/5V      G   0020
           Software Coding: 0007774
            Work Shop Code: WSC 00000 000 08192
                      VCID: 2C0A7688CA143DDA039-5160
16440 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
            P0056 - 004 - Malfunction / Open Circuit
17548 - Oxygen (Lambda) Sensor; B2 S2
            P1140 - 004 - Internal Resistance too High
Readiness: 0110 1101
Tuesday,11,March,2025,13:08:41:61611
VCDS Version: 25.3.0.2  HEX-NET2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: WUARL48H85K900806   License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WUARL48H85K900806   Mileage: 211990km-131724miles
   Part No SW: 8H0 910 560 G    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0020
   Revision: 00000000    Serial number: AUZ6Z0D0254749
   Coding: 0007774
   Shop #: WSC 00000 000 08192
   VINID: 9E54627042182056C9000200182898D15F
   Part No SW: 8E0 910 156 R    HW: 09L 927 156
   Component: AG6 09L 4.2L5V USA  0060
   Revision: --H01---    Serial number:        0037460
   Coding: 0001002
   Shop #: WSC 00672 785 00200
   VCID: 353C53EC195E7C126C7-5160
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Status: 00110000
                    Reset counter: 39
                    Mileage: 211992 km
                    (no units): 30.0
                    (no units): 81.0
                    Temperature: 2.0°C
                    T.B. Angle: 0.0°
18289 - Powertrain Data Bus: Missing Message
            P1881 - 000 - Acceleration Request - Intermittent
                    Reset counter: 39
                    Mileage: 211992 km
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 Q
   Component: ABS/ESP allrad      4533
   Coding: 04597
   Shop #: WSC 02116
   VCID: 363E54E00158770A65D-51A8
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
            35-00 - -
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1424
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6398DDB4E24AB2A2F23-5160
00796 - Fan for Interior Temp Sensor (V42)
            42-10 - Speed Deviation too High - Intermittent
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  KAN 0517
   Coding: 01014
   Shop #: WSC 12112
   VCID: 353C53EC1C5E7C126C7-4AE0
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No: 8E0 035 593 A
   Component: SDAR XM            0010
   VCID: 270089A4D6C21E82EEB-5066
00003 - Control Module
            37-10 - Faulty - Intermittent
02617 - Satellite Antenna (R170)
            29-00 - Short to Ground
02633 - Antenna for Satellite Tuner
            31-10 - Open or Short to Ground - Intermittent
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 D
   Component: Airbag 8.4EC        0015
   Coding: 0010105
   VCID: 3B2845D43F7AAA629A3-5160
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 02041
   Shop #: WSC 00672
   VCID: 3E2E4CC02968BF4ABDD-4AE0
            52-10 - Supply Voltage Too High - Intermittent
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8H0 920 980 M
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 03301
   Shop #: WSC 12345
   VCID: 39245FDC3046987288F-5160
   WUARL48H85K900806     AUZ6Z0D0254749
Address 26: Auto Roof        Labels: 8H0-959-255.clb
   Part No: 8H0 959 255
   Component:  VSG  B6 CABRIO     6386
   VCID: 73B8ADF457AA2222823-5160
02000 - Switch Position
   Part No: 8H0 959 760
   Component: Sitzmemory EE H06   0010
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74BAAEE85794251A9B9-4B1E
02010 - Left Entry Assistance Control Module (J572)
            79-00 - Please Check Fault Codes
   Part No: 8H0 959 433 E
   Component: Komfortgerát T7B    3320
   Coding: 11788
   Shop #: WSC 00672
   VCID: 363E54E00158770A65D-4AE0
   Subsystem 1 - Part No: 8H1959801B
   Component: Tõrsteuer.FS BRM 3020
   Subsystem 2 - Part No: 8H1959802B
   Component: Tõrsteuer.BF BRM 3020
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
20 Faults Found:
00962 - Alarm via. Tilt Sensor
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01373 - Alarm triggered by Radio Ground Contact
            35-00 - -
00956 - Key 2
            35-10 - - - Intermittent
EuroX
Northern NJ USA
C?ID=208579
2005 will not have a gateway. Nor does it have a way to code in a new battery. This is not a thing on this vehicle.
Sebas
Toronto, ON, Canada
C?ID=610702
Thank you. I was going crazy.
Problem solved.
