Audi A4 B8.5 Auto Hold without button
Alibarnett
Leamington, UK
C?ID=260662
Posting here while I await my verification.
I've read a lot of post on various websites about the coding and adaptation for auto hold without the button but none seem to fit with my car. Auto-scan below.
I've checked I have the 1AT module needed for this to be enabled, the adaptation security code in VCDS didn't seem to let me view the adaptation channels. However in the long coding helper there was a box relating to auto hold, which I ticked but didn't seem to do much. I don't seem to have as many Bytes in the coding as most posts go on about, I'll double check later and see if I can post what coding I do have in there if that would be helpful.
Instructions I've seen are:
1) 03-ABS -> Security-16 -> Code "20103" -> Adaptation-10 -> AUTO HOLD functional status, always active
2) 03-ABS -> Security-16 -> Code "24990" -> Adaptation-10 -> AUTO HOLD functionality, active
3) 03-ABS -> Coding-07:
  • Byte 08 = 03
  • Byte 19 = C0
  • Byte 23 = F7
  • Byte 25 = 41 (Auto transmission) or 43 (manual transmission)
but i don't think this is for my ABS module, security codes don't work and Adaptation-10 doesn't seem to have anything in it. The alternative is:
Select Address 03 (ABS)
Access authorization -> Enter access code 61378
Coding -> Byte 8, Activate bit 4, 7 and deactivate bit 6.
But in the long coder I don't appear to have 8 Bytes...
If anyone has done this or knows about this any help would be helpful. Hoping this can be done as I'd love to have auto hold on my brakes.
Thanks,
Alastair
Monday,10,March,2025,12:35:37:40482
VCDS Version: 24.7.0.0 (x64)
VIN: WAUZZZ8K6FA081013   License Plate: LY64 DZR
Mileage: 171170km-106360mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
VIN: WAUZZZ8K6FA081013   Mileage: 171170km-106360miles
Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264 B    HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H09 0001
   Revision: --H09---    CVN: CD8E792C
   Coding: 12190032242501022000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0218K0906264B 001001
   ROD: EV_ECM18TFS021_AU48.rod
   VCID: 306F4EDC6BBD711673-8064
   VINID: 9D196AAAA21B1964402010010C6F820D62
15447 - Thermostat for Transmission
          P19A2 00 [01101101] - Open Circuit
                    Fault Frequency: 23
                    Mileage: 170109 km
                    Date: 2025.02.17
                    Time: 17:23:47
                    Engine RPM: 2519.00 /min
                    Normed load value: 27.8 %
                    Vehicle speed: 24 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.531 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 265 s
                    MAP_MES_SAE: 92 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.021 V
                    FAC_TPS_1_SAE: 31.640625 %
                    FUP_H_SAE: 18240.0 kPa
15451 - Thermostat for Transmission
          P19A1 00 [01100100] - Short to GND
                    Mileage: 170384 km
                    Date: 2025.02.24
                    Time: 08:18:00
                    Engine RPM: 2239.75 /min
                    Normed load value: 30.2 %
                    Vehicle speed: 118 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 14.609 V
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 718 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.012 V
                    FAC_TPS_1_SAE: 35.937500 %
                    FUP_H_SAE: 19910.0 kPa
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 031DC401
   Shop #: WSC 06335 000 00000
   VCID: 071DC500B6B316AE82-8052
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 03B24040000000000000
   VCID: 7F0D5DE0EE635E6EBA-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000150917002
   Serial number: 3214000162836005
00956 - Key 2
                    Reset counter: 142
                    Mileage: 170375 km
                    Date: 2025.02.23
                    Time: 10:58:33
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01241120141140
   Coding: 642402C000
   VCID: 78FFB6FCCB4D6956FB-802C
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000925532801
   Coding: 290000308034A7C00081000300001F1F001D060827080201000008004000020000000024000000
   VCID: 74E782CCD7250D36D7-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 181114  H06 0080
   Serial number: SWF14111186007
   Coding: 00FD11
   Serial number: 20002353
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001811140163
   Serial number: E9284D57000000000001
04008 - Voltage supply for front parking aid sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 93
                    Mileage: 170362 km
                    Date: 2025.02.19
                    Time: 17:37:10
                    Fault Status: 00101100
                    Reset counter: 139
                    Mileage: 170375 km
                    Date: 2025.02.23
                    Time: 19:33:11
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC4UE1Q   Dataset Number: 8K0909602Q  0001
   Coding: 30534435363030303030554A3052384B3053
   VCID: 489F063CF32DD9D64B-801C
   Serial number: 6334MSME4A6A4A09Q
   Serial number: 6344MSME4B1A3160A
   Serial number: 6352QSME7F495770V
   Serial number: 6362QSME7A474F68$
   Serial number: 63732SME174A17781
   Serial number: 63832SME064A3A44+
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NKI000VW
   Coding: 000017
   VCID: 489F063CFB2DD9D64B-801C
   Part No SW: 8K0 920 983 E    HW: 8K0 920 983 E
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61B61JCCF
   Coding: 33A4100003012600010000
   VCID: 377D75C086D3A62E32-8062
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y14B180678
   Coding: 80CF07FF00
   VCID: 4A9B3C34E5212BC65D-801E
   Serial number: 6612675003
   Serial number: 14035004166011200181
                    Reset counter: 146
                    Mileage: 170375 km
                    Date: 2025.02.22
                    Time: 10:48:50
                    Bin. Bits:    10000
                    Voltage: 11.60 V
                    Count: 17
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000126357870
   Coding: 011002205C01410001
   VCID: 4FAD2D201E430EEE0A-801A
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H55 0702
   Revision: 00000002    Serial number: 0000191556 Dataset Number: 8K0909852M  0028
   Coding: 100000000001
   Shop #: WSC 46403 005 1048576
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 3F8D1DE0A6E39E6EFA-806A
   Revision: 00002001    Serial number: 0353175640
   Coding: 013B0622A0B930C08330023680000047
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000127463829
   Coding: 011002205E01410001
   VCID: 4E933024194907E601-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000466128
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B6CF4BDC1BB46CD-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109KB0E7993582
   Coding: 010103020100000001
   VCID: 2B5559B04A9B12CE46-807E
   Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0897
   Revision: --------    Serial number: 515K10E7503629
   Coding: 0F0101010006A1ED01808B5E00000403E40000020000000000
   VCID: 3E7360E4A9E99766F1-806A
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130KF0E3202003
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002067165
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000127624830
   Coding: 010002204001210001
   VCID: 46830804F139CFA6B9-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000127360121
End-------------------------(Elapsed Time: 03:43)--------------------------
