No Ignition, Skoda Kodiaq keyless Start, after Accident
gernster
C?ID=491801
Hi guys, I know you probably hate accident damage related questions (and this is my first) but I've just picked up a 2020 Skoda kodiaq 2.0 TDI DSG.
Front end damage, airbags deployed, but can't communicate with the OBD because the ignition is not coming on. There is power to the main and secondary fuseboxes, but the keyless ignition isn't lighting up when I press the start button.
I've been trying to Google if they have a pyro fuse or interia cutoff but drawing a blank.
Do any of you guys know if there is any master crash shut down system on these?
Thanks,
Andy
gernster
C?ID=491801
I can see the mileage and door open etc on the dash and the media unit works
downtime
Finland
C?ID=280813
Try this, turn on hazard lights. That should activate the CAN bus and you should be able to connect to the gateway.
Other option is to connect with dealer tool online and remotely turn ignition on to the car
Third one is that put the key on the right side of the steering column where the IMMO reader is. You can see the etched diagram of key and waves. On that spot. Keep the key there and press start button
gernster
C?ID=491801
Thanks mate, hazard warning lights is a good hack,.I'll.try that when I go back to the car later I, had the key next to the ignition column, done that with golfs with keyless start before to get a response.
I have a mate with fully authorised genuine ODIS, so he's my last resort if I can't find the issue
downtime
Finland
C?ID=280813
Yeah, that latter option definitely works
Spacewalker
Poland
C?ID=159607
start checking voltage , must be some kind of Proactive crash fuse
davisev5225
C?ID=263265
It's usually more than the hazard lights, you usually have to do the following combination to "wake up" the immobilizer-related modules and the CAN gateway:
  • Hazard lights
  • High beams
  • Hold brake pedal
downtime
Finland
C?ID=280813
Usually the hazards are enough. That is how VW officially guides as well :)
But no harm in doing the additional actions as well
gernster
C?ID=491801
Took a scan with the hazards on, a few systems are talking but a lot still are not. I've checked the kessy fuses, and there is power to the main lines coming off the SA fuses (main rad fan feed is blown but that shouldn't affect startup) / and there is power into SB fuse box and power going to the SC fuse box. I cant see any reference to a pyro fuse on the wiring diagrams i've looked at (not mentioned in the airbag system) so even though ebay lists them for the kodiaq, i dont think its got one and cant see it anywhere on the main battery lines.
It csan read the kessy system and reports no fault found oddly
There is some wiring damage on the engine loom so I'll get that repaired as it might be a dependency for the kessy system firing up. will report back after the weekend when ive done some more work on it. Here's the VCDS scan so far:
Wednesday,12,March,2025,16:06:58:49859
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: TMBMJ7NS7M8503372   License Plate: KODIAQ NO IGN
Mileage: 81460km-50616mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 42 44 52 5F 75 BB BC
VIN: TMBMJ7NS7M8503372   Mileage: 81460km-50616miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
22-AWD -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0556722167 Dataset Number: V03935312FW 0001
   Coding: 000F0F0723
   Shop #: WSC 00033 790 00158
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 44D1443E2E17F31AEB8-8010
   Part No SW: 565 907 044 CE    HW: 565 907 044 CE
   Component: Climatronic   H04 2202
   Revision: 00001K00
   Coding: 16110104002110011005000800101034
   Shop #: WSC 00033 790 00145
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   VCID: 6099A8AE9ACF8F3AEF0-8034
1048839 - Function limitation due to crash signal
          B1397 00 [00001001] - -
                    Reset counter: 38
                    Mileage: 81460 km
                    Date: 2025.03.12
                    Time: 00:02:48
   Part No SW: 5Q0 937 086 CJ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F1809200525 Dataset Number: V03935332JH 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW27.rod
   VCID: 0451843E6E97331AAB8-8050
   Subsystem 1 - Part No SW: 567 955 119 A    HW: 567 955 119 A
   Component: J400FRWISCH  067 0070
   Serial number: 907353F0302020403070
   Coding: 104D0D
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: S4Y20M09D30H16M33S59
   Coding: 00885D
   Serial number: 000000000ZY202352KK7
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001281141
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 GC    HW: 5Q1 953 569 E
   Component: Lenks.Modul  H14 0180
   Serial number: 0100031020200C301411
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [00001001] - Open or Short to Plus
                    Reset counter: 38
                    Mileage: 81460 km
                    Date: 2025.03.12
                    Time: 00:02:49
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 5.0  C
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [00001001] - Open or Short to Plus
                    Reset counter: 38
                    Mileage: 81460 km
                    Date: 2025.03.12
                    Time: 00:02:49
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Address 15: Airbags
   Part No SW: 565 920 941 D    HW: 565 920 941 D
   Component: KOMBI         203 8400
   Coding: 27A4001CA380A60001886A011001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   VCID: 1D67D15AED3DE2D2846-8048
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 29092011601473 Dataset Number: V03935335ZA 0001
   Coding: 030100045F08730023100240100F00010001070000000000000000000000
   GVL: 01C43C0000000600400C80008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74B1D4FE3E37039A9B8-8020
Address 22: AWD
   Component: ELV-MQBB      H06 0020
   Serial number: 20000232338005
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333317E27BB944A2422-8066
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0485
   Serial number: 0000414365323  Dataset Number: V03935315PZ 0001
   Coding: 001000208001020000001100
   VCID: 4BC36F0203493C622A2-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000044038351
   Coding: 1D0200
Address 44: Steering Assist
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0485
   Serial number: 0000412957694  Dataset Number: V03935315QF 0001
   VCID: 4ACD6A060C33256A114-801E
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000043830713
   Coding: 050200
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0139
   Serial number: 0000000009VIHJ1 Dataset Number: V03935370UB 0001
   Coding: 032610101969A8809025460161052607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW41.rod
   VCID: 48C9500E123FD77A070-801C
          U1400 00 [00001000] - -
          [Functional restrictiondue to insufficient voltage]
                    Fault Frequency: 12
                    Mileage: 81461 km
                    Date: 2023.09.03
                    Time: 12:55:01
                    Voltage terminal 30: 5.5 V
1644017 - Online Services
          B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Mileage: 58399 km
                    Date: 2023.03.12
                    Time: 15:45:11
                    Voltage terminal 30: 10.7 V
                    Remaining long term energy budget: 3443 mAh
                    Remaining short term energy budget: 4 mAh
                    Wake up cycles counter: 2735
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltagetoo low]
                    Mileage: 81461 km
                    Date: 2023.09.03
                    Time: 12:55:01
12866049 - Databus
          [Airbag: Error value received]
                    Mileage: 81460 km
                    Date: 2023.09.03
                    Time: 12:41:25
                    Voltage terminal 30: 12.4 V
1644276 - Backup Battery
          B1916 F4 [00001001] - Service Life Critical
          [Backup battery Service life critical]
                    Mileage: 58044 km
                    Date: 2023.03.06
                    Time: 11:59:17
End----(Elapsed Time: 01:01, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
------------------------------8 Faults Found-------------------------------
downtime
Finland
C?ID=280813
There's no pyro fuse on VW, Skoda or Seat afaik. Bigger Audi's have them.
kessy, bcm and instruments are all communicating so at least you should get ignition on
siLc
Tallinn, Estonia
C?ID=330192
Key battery OK?
TTT
C?ID=547002
Why would that matter with key next to immo coil?
gernster
C?ID=491801
New battery in keyfob. It's a bit of a head scratcher!
gernster
C?ID=491801
Elsawin does show a pyro fuse up to 2021, but I can't find it!
TTT
C?ID=547002
Which supply are you missing at the ecu and where is it connected to on the other side?
downtime
Finland
C?ID=280813
What is the part number and in which section it's mentioned? I have never encountered a pyro fuse on these cars and I've worked with quite a few of them. So for me this is new as well that there's one and I would be very interested to find it as well.
davisev5225
C?ID=263265
ElsaWin was a dealer-only piece of software that doesn't exist outside of dealerships except via piracy. It's also discontinued, and I don't believe a vehicle datapack was ever put together for 2021 vehicles, so I doubt you're going to get any sort of reliable information.
downtime
Finland
C?ID=280813
I have other means to access that data. I'm not using Elsawin
Spacewalker
Poland
C?ID=159607
Simple take out one connector from DSG for example, and measure KL30, Kl15 to see which one is gone
then track it
then track CAN , just to see if is going to GW , ecu , abs use this same CAN bus , I am almost sure Kl30 also for engine bay is this same
then swap GW if p[ower are ok, to see if they start communicate
you said you did few of them , so you should know little more than beginners
  • Agree
Reactions: TTT
downtime
Finland
C?ID=280813
If you meant me, I never wrote about crash-damaged cars. I've done two which have been in crash damage and neither had a pyro-fuse. I was mainly commenting on that.
Looks like the OPs car has had front-end collision damage, so most likely some of the voltage feeds are damaged that come from the engine bay fuse box (which is the main voltage distribution as well). So you're right that measuring what is coming to GW is correct.
I don't think GW itself is damaged. There is crash shutdown bit that activates but that can be cleared from GW without really any bigger hurdle. And that does not impact on ignition behaviour.
