Golf 7 Gti cluster wont turn on
josh@jlttech
South Africa
C?ID=564690
Good day, could someone offer me some assistance. i have a golf 7 Gti that we replaced the ecu of and after taking out the cluster to extract the immo data from the cluster, it wont turn on the cluster at all now only when you open the door.
Wednesday,12,March,2025,12:11:51:01547
Dealer/Shop Name: JLT Auto electrical engineering
Workshop Code: 000 00000 000002
VIN: WVWZZZAUZFW302706   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 20 2B 32 42 44 52 55 5F
          A9
VIN: WVWZZZAUZFW302706   Mileage: 139142km-86458miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
09-Cent. Elect. -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
14-Susp. Elect. -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
16-Steering wheel -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
20-High Beam Assist. -- Status: Cannot be reached 0100
2B-Steer. Col. Lock -- Status: Cannot be reached 0100
32-Differential Locks -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 10: Park/Steer Assist
Address 14: Susp. Elect.
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003238989 Dataset Number: 5G0067V____ 2013
   Coding: 030100042F085900EF00026B9C0F00010001050000000000000000000000
   GVL: 01543C5000000700400C10000000CC0000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72B91647742F412A59F-8026
   Generator:
Address 20: High Beam Assist.
Address 2B: Steer. Col. Lock
Address 32: Differential Locks
Address 44: Steering Assist
Address 52: Door Elect, Pass.
Address 55: Headlight Range
Address A9: Struct. Borne Sound
End----(Elapsed Time: 00:41, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
Looks like absolutely nothing is powered on except the Gateway.
I wouldn't expect that to happen even if the cluster was dead...?
Got a wiring diagram?
josh@jlttech
South Africa
C?ID=564690
Hi, yes the basics of it i should say buy no power to the terminal 15 voltage supply relay and when we give it power it brings up "Starter System Faulty. Workshop!"
2kaa52
Ceska Republica, Praha
C?ID=319193
You f*cked the Cluster by extract Immo Data.
Derek
UK (ilexa)
C?ID=56983
If you run a scan with it powered up, do the other modules show up?
Best regards
Derek
josh@jlttech
South Africa
C?ID=564690
cluster still comes on when you open doors and that, so i highly doubt that, we have found tampering with wires from the previous people who worked on the car. However thats also the only way to extract immo data for the MQB keys.
josh@jlttech
South Africa
C?ID=564690
Best regards
Derek
thanks Derek for this, I've also thought of doing this just haven't had the chance yet but im going to give it a try shortly.
Spacewalker
Poland
C?ID=159607
flllow fuses, cables for Kl15 , nobody know what exactly you did
if you do ECU swap , you must know little bit more than kinds from High school , so start use your brain
Spacewalker
Poland
C?ID=159607
maybe not, but I love people who think ECU is like a...hmm...bulb..... tur out, turn in...bingo
Africa enginners comming ...... from stone edge to Component protection, Immo, OTP within a minute
josh@jlttech
South Africa
C?ID=564690
none the less the ECU is coded correctly however we did find that the main relay inside wasn't getting power, and came to the conclusion after looking at diagrams and found that its the power supply control module. Is the power supply control module incorperated into the BCM on these cars?
What's the component identifier for that module on the diagram?
josh@jlttech
South Africa
C?ID=564690
After checking some wires its the BCM that is responsible for the power supply to the control units.
