Mil light triggers
ahidley
Pennsylvania, USA
C?ID=549110
Hopefully this is a simple question. There are many mil lights, aka check engine lights. Some are triggered after one fault and others are triggered after several. For clairty let's say 4 fails out of 10 tests causes the mil to light up. So, if I clear fault codes does this reset the triggers to zero also? Or does it just extinguish the mil light. If that's the case then a mil could be triggered the next time the car is started, vs the next 10 times and 4 fails as listed above.
davisev5225
C?ID=263265
If you want a precise answer, you're going to need to provide a full, unedited and unabridged auto-scan. That said, generally speaking, any single code can cause a MIL light to illuminate. The codes that do so will generally say "MIL ON" somewhere in their fault description.
Ziddywerks
Northern NJ USA
C?ID=208579
Most codes will not return unless a fail result is entered during a test consistently usually after 3-10 key cycles. In other cases the fault are intermittent.
It really isn't. Various fault conditions will have different criteria for setting the MIL.
ahidley
Pennsylvania, USA
C?ID=549110
Perhaps I can simplify my question with more detail. Let's say u have 2 pending mils. We'll call them mil A and mil B . Both mils require multiple Faults to trigger the mil light. I'm not too concerned about what causes it just the amount of failures adding up. So say mil A and B are triggered after 5 fails out of 10 tests. Now A and B are differant Faults as well as differant tests and are not related to each other. So in this example mil A gets triggered and mil B only has 4 fails out of the 10 cycles. So I go into vcds and delete milA . What has happened?
The mil light for A is extinguished.
Has the fault list been reset to zero out of zero tries for mil A?
Has it also reset the 4 fails for mil B? I assume not.
What happens if I disconnect power from the battery ? Does that reset the milA light and reset the fails on A and B?
Just trying to understand what's actually happening..
Based on what I've experienced, you cannot selectively clear codes.... you wipe everything....
Correct. But just to be clear, not everything in the whole car, just everything within a particular control module, because there isn't any way to selectively clear faults in a control module.
