2009 Audi B8 Bluetooth/Tele/Voice Control issue
tofast2belast
C?ID=207897
so Im not sure when this issue started, but it was a few months ago to say the least.
I can pair my phone with Bluetooth.
If I make a call, I can hear it ringing and hear the person... however the other person cannot hear me...
second part of this issue is on my steering wheel,
the tele button works and brings up info on the DIS. the other side of the steering wheel. the button where volume control is, there is a voice control. before when clicking this button it would say possible commands and what not... pressing the volume scroll(pressing not scrolling) it would say Navi not active or something..
now it just says Button inactive when I hit the Voice control button...
any ideas where I could start?
Friday,27,November,2015,12:33:48:12681
VCDS Version 15.7.1.0 (x64)
Data version: 20150904
VIN: WAURV78T59A011130   License Plate:
Mileage: 188660km-117227mi   Repair Order:
Chassis Type: 8T (8T - Audi A5/S5/RS5 (2008 >))
Scan: 01 03 04 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42
          46 47 52 53 55 56 67 6C 77
VIN: WAURV78T59A011130   Mileage: 188660km-117227miles
Address 01: Engine (J623-CAUB)       Labels: 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 K    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0002
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 64847 128 16448
   VCID: 428B4E12DDBE582E0B-8017
               P0300 - 001 -  - MIL ON
                    Fault Status: 11100001
                    Mileage: 188657 km
                    Date: 2015.11.27
                    Time: 12:16:18
                    RPM: 706 /min
                    Load: 29.4 %
                    Temperature: 45.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected - MIL ON
                    Mileage: 188657 km
                    Date: 2015.11.27
                    Time: 12:16:18
                    RPM: 706 /min
                    Load: 29.4 %
                    Temperature: 45.0°C
                    Temperature: 42.0°C
                    Voltage: 13.843 V
004874 - Cylinder Disabling
               P130A - 001 -
                    Fault Status: 01100001
                    Mileage: 188657 km
                    Date: 2015.11.27
                    Time: 12:17:16
                    RPM: 3676 /min
                    Load: 39.6 %
                    Speed: 75.0 km/h
                    Temperature: 93.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 H04 00600060
   Coding: 110500
   Shop #: WSC 06325 000 00000
   VCID: 79F9E9FEF0E8DBF61A-802D
No Faults Found
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H71 0134
   Coding: 0F0000
   VCID: 75E1E5CEDCF0BF967E-8021
   Subsystem 1 - Part No SW: 8T0 959 754 S    HW: 8T0 959 754 S
   Component: ELVAUDIB8  H36 0041
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001117716
   Coding: 00017025002C00000000
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0116.07.080364
   Coding: 48022000
   VCID: 72EBDED2AD9EA8AE5B-8027
03023 - Running-in Requirement
                    Fault Status: 01100101
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:15
                    Fault Status: 01101000
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:15
                    Temperature: 9.0°C
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:15
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000188211
   Coding: 26081095003CAF251700000300003D3D4F94138800010161000000
   VCID: 306F14DA6312DABEED-8065
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160708  H13 0040
   Coding: 00F531
   Component: RLS  H04 0003
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
                    Fault Status: 00101100
                    Reset counter: 115
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 18:36:00
                    Reset counter: 115
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 18:36:00
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:00
03207 - Charisma Switch Module
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8511003
   VCID: 2A5B06B285CEA06E23-807F
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0372487
   Coding: 0000100
   VCID: 316911DEA818D3B6E2-8065
            000 -  -
                    Reset counter: 74
                    Mileage: 188580 km
                    Date: 2015.11.26
                    Time: 09:50:27
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 D    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0020
   Revision: 11001001    Serial number: 52930821000661
   Coding: 200002
   VCID: 3A7B36F2B56E10EE53-806F
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0039GD1287N$
   Coding: 303333333730303030304A55304C38543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3D713DEEAC4027D676-8069
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0800001LF9
   Serial number: 6334MSME3E36014AE
   Serial number: 6344MSME3E155A63L
   Serial number: 6352QSME78767A11O
   Serial number: 6362QSME78764F2F%
   Serial number: 63732SME77081E575
   Serial number: 63832SME6E7638337
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 E    HW: 8T0 920 981 E
   Component: KOMBIINSTR.   H30 0221
   Revision: 00000000    Serial number: 97S743R78
   Coding: 832D01000B00D705020201
   VCID: 3E733AE2A9463CCE6F-806B
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001116631
   Coding: 00197B25002C00000000
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 341GH087510612
   Shop #: WSC 01114 444 53357
   VCID: 387F2CFA4B6202FEA5-806D
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000004
   VCID: 366322C24176F48EB7-8063
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F29.07.0800H010003CD10227ÿ
   Subsystem 4 - Serial number: D10227ÿ
   Revision: 00002001    Serial number: 0113135222
   Coding: 0106069A007A444700F000
   Subsystem 1 - Part No: 8K0 959 719
   Component: GTO BF  H06 0040
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814002235801
   Coding: 030101
   Shop #: WSC 12336 024 394758
   VCID: 3F8D47E6AE4C35C664-806B
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number:  "E
   Coding: 011C13224E002201
   VCID: 7CF7F0EAFFDAEEDE01-8029
                    Fault Status: 01101100
                    Reset counter: 75
                    Mileage: 188608 km
                    Date: 2015.11.27
                    Time: 06:48:37
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000181836
   VCID: 316911DE6818D3B6E2-8065
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000017
   Shop #: WSC 06324 000 00000
   VCID: 306F14DAA312DABEED-8065
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000807080620
   VCID: 346718CA570AE69E89-8061
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J879083
   Coding: 1000008
   VCID: 377D2FC6467C0D86AC-8063
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005053055
   Coding: 0010970
   VCID: 285FFCBA9BC2927E35-807D
End-------------------------(Elapsed Time: 05:48)--------------------------
d1anony
C?ID=239079
did u change ur battery within those couple of months or did the battery die ?
tofast2belast
C?ID=207897
battery died. cleared the BM fault since the autoscan
d1anony
C?ID=239079
its got to be programmed
tofast2belast
C?ID=207897
no the battery management kicked on because I left lights on and battery voltage dropped. I did not have to change battery. I recharged battery and cleared the fault code
tofast2belast
C?ID=207897
for some reason its working now out of the blue
