VW Sharan 4714 - ECU - Steering Module U0212 00 - No Communications
krisv
Poland
C?ID=326234
Hi guys,
Ive replaced in following car:
Sharan 2 2012 Manual gearbox 2.0 TDI 140 HP CFFB
Steering Wheel Control Module:
old : 5K0-953-569-J midline
new: 5K0-953-569-AP highline + added multifunction steering wheel
Old coding bevore change:
Saturday,01,March,2025,10:04:36:00332
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WVWZZZ7NZCV019224   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56 61
          62 72
VIN: WVWZZZ7NZCV019224   Mileage: 321320km-199658miles
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H24 9980
   Revision: 44H24---    Serial number:                CVN: 7BAB641738D3FF82
   Coding: 0019001A040401080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 77BE07A0CECC082EFA-8022
   VINID: 9E69EAAAA1DEA9398004908210D58F8E0E
4807 - EGR System
          P0401 00 [01100000] - Insufficient Flow
4891 - EGR System
          P042F 00 [00100000] - Stuck Closed
          [EGR "A" Control Stuck Closed]
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
   Component: J104   C3 450M VD25 0021
   Revision: --H07---    Serial number: 00000004426457
   Coding: 0018967
   Shop #: WSC 00020 790 00000
   VCID: 383CC49C4B52C75633-806C
   Part No SW: 5K0 907 044 H    HW: 5K0 907 044 H
   Component: Clima-Sharan  H11 0104
   Revision: 00001002
   Coding: 0000000009
   Shop #: WSC 00020 999 00000
   VCID: 302CFCBC6B221F167B-8064
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 40180A3B81251AC0400800C0100000E443011308424D29626480872000C1
   VCID: 3522CDA89C403A3E28-8060
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110911  31  0032
   Serial number:         110922110004
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M09D21h23m46s27S1
   Coding: 4280BB
                    Fault Status: 00101010
                    Reset counter: 61
                    Mileage: 319467 km
                    Date: 2019.07.23.
                    Time: 19:15:39
                    Voltage: 12.00 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261126200208
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 393AC198B858DE5ECC-806C
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01X H07 0013
   Serial number: 003GFPK32626 Dataset Number: 7N0003v____ 0267
   Coding: 003158
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E30D284A176F966F9-806A
   Serial number: 3493ETS60689D05159D-
   Serial number: 3503ETS60E12EEE14DD6
   Serial number: 3513ETS60C91706159DN
   Serial number: 3523ETS60A384D9149DZ
   Serial number: 35540TS608021DE149DG
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 321318 km
                    Date: 2025.03.01.
                    Time: 19:22:26
   Part No SW: 5K0 953 501 BD    HW: 5K0 953 569 J
   Revision: FF010040    Serial number: 20110809300089
   Coding: 5180040000
   VCID: 6D9225C8BC90B2FE10-8038
   Part No SW: 7N0 920 870 E    HW: 7N0 920 870 E
   Coding: 140F01
   VCID: 3424F0AC9F3A23361F-8060
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031142
   VCID: 3326F3B05234240E06-8066
00664 - Fuel gauge
                    Fault Frequency: 8
                    Reset counter: 191
                    Mileage: 195753 km
                    Date: 2016.09.25.
                    Time: 00:15:54
01410 - Heater Over-Temp
                    Reset counter: 163
                        After-Run
                    Temperature: 148.0 C
                    Temperature: 49.0 C
                    Voltage: 12.00 V
02251 - Heater Unit Locked
                    Reset counter: 163
                    Mileage: 198484 km
                    Date: 2017.05.14.
                    Time: 21:38:51
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 260911F1003417
   Coding: 468002
   VCID: 373EC7A0864CC82E3A-8062
   VCID: 6A982ED48D7EA5C675-803E
   Revision: A1001003    Serial number: 7660955220
   VCID: 291A11D840F86EDEBC-807C
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000120077284
   Coding: 011006208000411011
   VCID: 43C6A370C294948E96-8016
01705 - Selection Switch for Mirror-Adjust (E48)
                    Fault Frequency: 12
                    Reset counter: 71
                    Mileage: 316914 km
                    Date: 2019.07.23.
                    Time: 15:05:52
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.323 1002
   Revision: 1AH03734    Serial number: 00112640017901
   Coding: 0000258
   VCID: 3C34D88C7F6AEB76D7-8068
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000120059251
   VCID: 42C8A674DD8E9D869D-8016
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000273849
   Coding: 0024166
   VCID: 3522CDA85C403A3E28-8060
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  031 0075
   Revision: 01000001    Serial number: VWZ1Z2L3531840
   Coding: 0100040004000D
   VCID: 3326F3B09234240E06-8066
   Component: Batt.regelung H43 1620
   Coding: 030B085A
   VCID: 71AA39B8A8A8561E34-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900566613
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000119798624
   Coding: 010004200000411001
   VCID: 45C2BD68CCA0AABEB8-8010
                    Reset counter: 38
                    Mileage: 318463 km
                    Date: 2019.07.23.
                    Time: 12:36:24
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000119798460
                    Fault Status: 01101000
                    Reset counter: 37
                    Mileage: 321319 km
                    Date: 2019.07.23.
                    Time: 09:45:31
End----------(Elapsed Time: 01:26, VBatt start/end: 15.0V/15.1V)-----------
Here all changes and two error msg in the ECU and Parking Assistent
Tuesday,11,March,2025,20:15:27:00332
VCDS Version: 25.3.0.3 (x64)  HEX-NET CB: 0.4660.4
Data version: 20250301 DS365.0
          62 72
VIN: WVWZZZ7NZCV019224   Mileage: 321400km-199708miles
   Coding: 0019001A042401080000
   VCID: 77BE07A0CECC0823F1-8022
4714 - Steering Column Control Module
          U0212 00 [00100111] - No Communications
                    Mileage: 321406 km
                    Date: 2025.03.11.
                    Time: 20:11:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 67 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.460 V
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 8
                    selected gear-Bits 0-7: 0
   Component: J104   C3 450M VD29 0021
   Coding: 0018967
   VCID: 383CC49C4B52C75B38-806C
   Revision: 00001002
   Coding: 0000000009
   VCID: 302CFCBC6B221F1B70-8064
   Revision: BA011001
   Coding: 40180A3B81251AC0404800C0100000E443011308424D29626480872000C1
   Shop #: WSC 00020 790 12345
   VCID: 3522CDA89C403A3323-8060
   Coding: 004DBD
   Coding: 4280BB
   Coding: 118001
   Shop #: WSC 00020 999 12345
   VCID: 393AC198B858DE53C7-806C
12718592 - Databus
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Reset counter: 41
                    Mileage: 321406 km
                    Date: 2025.03.11.
                    Time: 20:11:00
   Coding: 003158
   VCID: 3E30D284A176F96BF2-806A
   Part No SW: 5K0 953 501 DP    HW: 5K0 953 569 AP
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150407300384
   Coding: 110A240000
   VCID: 7BB61B90F2E42C4395-802E
   Serial number: 40000000000000374567
   Coding: E20000
   Coding: 140F01
   VCID: 3424F0AC9F3A233B14-8060
   Coding: 0031142
   VCID: 3326F3B0523424030D-8066
   Coding: 468002
   VCID: 373EC7A0864CC82331-8062
   VCID: 6A982ED48D7EA5CB7E-803E
   VCID: 291A11D840F86ED3B7-807C
   VCID: 43C6A370C29494839D-8016
   Coding: 0000258
   VCID: 3C34D88C7F6AEB7BDC-8068
   VCID: 42C8A674DD8E9D8B96-8016
   Coding: 0024166
   VCID: 3522CDA85C403A3323-8060
   VCID: 3326F3B0923424030D-8066
   Coding: 030B085A
   VCID: 71AA39B8A8A856133F-8024
   VCID: 45C2BD68CCA0AAB3B3-8010
End----------(Elapsed Time: 01:23, VBatt start/end: 14.6V/14.5V)-----------
------------------------------2 Faults Found------------------------
I was able to calibrate g85 and all modules, there is no error msg on dash.
But the parking system stopped to work due to the error in the ECU .
Ive checked also all fuses and they are fine.
Ive tried also to update the ECU to the latest version but the error is still present.
The multifunction steering wheel work.
Cruise Control works.
ECU // 4714 - Steering Column Control Module
Parking Aid // 1 Fault Found:
12718592 - Databus
Please help :)
myounus
Northwest UK
C?ID=321059
Sounds like the Squibb’s wiring is different. I’ve not retrofitted MFSW on a sharan before, however, I’d advise downloading and checking the wiring diagrams for both versions, I.e. with and without MFSW. You may need to add and/or alter some of the connections.
If you’ve still got the old one, you can compare the pins to see if they’re the same or different.
krisv
Poland
C?ID=326234
Here is a pic from the harness on the car and a part which came with the new steering module.
AP1GczPtCMDGooItuOH8Rf3PsNnmce2JYjXPmy9MrfWjlxHmf-lBzP8yUr8BPiKUs1n-XhRSxwrBgRuKMNaN2WQ86fkqt7Oi9BdG-mk5hEkSf3sTUGdBVKKspo13WCmtr4DIFcyI2FCGMsATcbAJx34IT1DGeA=w683-h911-s-no-gm
AP1GczOwLWq1ZNiQH4e9BfWHzNFJstLaAhO00mJ0Jd-IPVp4vQWIz73Mf3sYtq-cgjJDzj22Fsz-ViB9tvCEonnkzSzMXw_iJNtHiEiKRjK9a1v1zyKU3FYii_OkO1HcoU48v7alylY0URKEVjaXJnkYaW-NQA=w683-h911-s-no-gm
Any advices?
TTT
C?ID=547002
They are not the same, aren't they?
krisv
Poland
C?ID=326234
The new model is highline the previous was middle line , Ive added multifunction steering wheel and Cruise Control Switch.
myounus
Northwest UK
C?ID=321059
You need wiring diagrams. It’s impossible to guess
  • Agree
