Passat 2016 steering column module issue (no cruise control after new sensor)
KARL
C?ID=150991
Hi,
I've replaced the steering angle sensor 5Q0953569A on a 2016 Passat. Which has cured the initial faults of airbag light, abs light and clicking when turning the wheel.
But now I have a open circuit fault for the cruise control switch buttons on the steering wheel. I've re-stripped it and checked to make sure its connected properly and also no damaged wires etc but all ok.
So I'm not sure if I've not coded the new one in correctly or if I need the new VCDS system as I'm currently on the older system at present.
I've attached the log file and some images of the laptop screen from the VCDS system. Can someone advise and help please.
Tuesday,11,March,2025,10:37:22:43311
VCDS Version: 25.3.0.3 (x64)
Data version: 20250301 DS365.0
Dealer/Shop Name: nedging autos
VIN: WVWZZZ3CZGE208410   License Plate: GL16JYK
Mileage: 157534   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZGE208410   Mileage: 253532km-157537miles
21472 - Databus
          U1122 00 [00101111] - Implausible Message
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Engine speed: 747.50 /min
                    Normed load value: 25.5 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 13.340 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 33
                    ACC variants (coding)-Bits 0-7: 2
                    Acceleration: 0.000 m/s²
17165 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Engine speed: 746.00 /min
                    Normed load value: 25.9 %
                    Voltage terminal 30: 13.400 V
16697 - Implausible Data Received from Steering Column Control Module
          U0429 00 [00101110] - -
                    Fault Frequency: 23
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:18
                    Engine speed: 753.00 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 13.380 V
18875 - Cruise Control Switch (E45)
          P0568 00 [00100111] - Implausible Signal
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Engine speed: 747.00 /min
                    Coolant temperature: 68 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 14.560 V
17166 - Cruise Control Switch (E45)
          P0568 00 [00101111] - Implausible Signal
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Engine speed: 741.00 /min
                    Normed load value: 26.7 %
Derek
UK (ilexa)
C?ID=56983
Hello
Please post a full autoscan as the full details of the car are needed to check coding
The problem is probably coding related, so please also post the autoscan from when the old unit was fitted before any changes were made to the vehicle so we can see the original coding
Best regards
Derek
KARL
C?ID=150991
Hi,
This is the original with the faulty part, see below;
Tuesday,11,March,2025,12:31:53:43311
VIN: WVWZZZ3CZGE208410   License Plate: GL16JYK  (2)
Mileage: 253532km-157537mi   Repair Order: with old faulty part
Chassis Type: 5Q0
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H22 1989
   Revision: B5H22---    CVN: 7FCF0AFE
   Coding: 0119001203451D083000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026FK.rod
   VCID: 7F07364CE6545363B9-802A
   VINID: 9E69EAAAA0D3A975420081010070CE975E
21472 - Databus
          U1122 00 [00101100] - Implausible Message
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
17165 - Databus
          U1123 00 [00101100] - Received Error Message
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
          U0429 00 [01101100] - -
                    Fault Frequency: 32
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:18
4714 - Steering Column Control Module
          U0212 00 [00100111] - No Communications
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:23:54
                    Engine speed: 0.00 /min
                    Coolant temperature: 51 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.600 V
                    Cruise Control System (CCS): status-Bits 0-7: 1
                    selected gear-Bits 0-7: 0
          P0568 00 [00100100] - Implausible Signal
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
          P0568 00 [00101100] - Implausible Signal
                    Fault Frequency: 8
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60836000001720
   Coding: 0FEC928F34200B74077B060141C349F0492CD0E0608292F11460F078C002
   VCID: 7EF9CB48E15E5A6BB2-802A
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0398273964 Dataset Number: V03935228XM 0001
   Coding: 000F0F0E03
   VCID: 39731854B8F0BD53C7-806C
   Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
   Component: AC Manuell    H03 1202
   Revision: 00001K06    Dataset Number: 0000
   Coding: 12120104202100001000400000000002
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACManueBHBVW37X 003129
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 6FE7E60CB63423E329-803A
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Component: BCM PQ37BOSCH 028 0163
   Revision: --------    Serial number: 8658100316015C Dataset Number: V03935235HB 0001
   Coding: 03010842C2C1027F0FA44094B10407281880000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0005B5B09BAA2C9BC0-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160301  043 0607
   Serial number:         160308200227
   Subsystem 2 - Part No SW: 8UD 955 559 A    HW: 8UD 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 30037863
   Coding: 00006E
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 18 12 2015  10000339
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY112500AE3
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065072443
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391606905780 Dataset Number: V03935227HD 0001
   Coding: 0071051801
   Shop #: WSC 05311 115 00075
   VCID: 448D79A0CF32F0BBA4-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Dataset Number: V03935229RW 0001
   Coding: 2A00608251FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346D29609F92403B14-8060
2165 - Steering Column Control Module
          B105D 00 [00001000] - -
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:34:05
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 14.3 V
2064 - Databus
          U1122 00 [00001000] - Implausible Message
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:34:05
2127 - Databus
                    Fault Frequency: 100
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:34:22
1076 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:23:56
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 12.4 V
                    Status_ACC_System: ACC_Init
1116 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:24:26
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 12.2 V
2068 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:34:05
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP4RTTDE Dataset Number: 3G0003V____ 0036
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   Left seat belt tensioner:
   Serial number: 3G2857705E0084Q01674
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G2857706E0079Q00586
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 003 16
   Serial number: 3576U00000052B6CD91O
   Subsystem 4 - Part No SW: -----------    HW: 454 001 903 16
   Serial number: 3586U0000007510DD91F
   Subsystem 5 - Part No SW: -----------    HW: 454 802 602 16
   Serial number: 3516R36B4550A0000000
   Subsystem 6 - Part No SW: -----------    HW: 454 802 602 16
   Serial number: 3526R2113010A000000I
   Subsystem 7 - Part No SW: -----------    HW: 454 802 802 16
   Serial number: 3556V540F440A0000006
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:23:56
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160222500222
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BFFC25CF24C4F4395-802E
226827 - Turn Signal Switch
          B1144 13 [00001001] - Open Circuit
                    Reset counter: 106
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:07:26
                    Ubat 30 Voltage: 14.90 V
                    Ignition State: On
                    Terminal 15: 14.10 V
                    A/D #1: 96.86 %
                    A/D #2: 97.65 %
                    A/D #3: 97.25 %
227339 - Windshield Wiper Switch
          B1145 13 [00001001] - Open Circuit
                    Reset counter: 106
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:07:26
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 106
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:07:26
                    Ubat 30 Voltage: 14.80 V
                    Ignition State: On
                    Terminal 15: 14.00 V
                    A/D #1: 97.65 %
                    A/D #2: 97.65 %
                    A/D #3: 0.00 %
   Part No SW: 3G0 920 941 A    HW: 3G0 920 941 A
   Component: KOMBI         201 6421
   Coding: 27A409102780260001886B011000000000000000
   VCID: 244DD9202F72D0BB84-8070
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 17031610800730 Dataset Number: V03935232SX 0001
   Coding: 0B0300045F087300FB00005C080F00010001070000000000000000000000
   GVL: 01543C0000000600400C80000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79F3D854F8707D5387-802C
   Generator:
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 4552169503
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0213358
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
131596 - Steering Column Control Module
          U0212 00 [00001000] - No Communications
                    Reset counter: 147
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:21:44
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
197169 - Controls in Steering Wheel
          U108E 00 [00001000] - No Communications
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 12:21:48
                    Terminal 15: OFF
   Serial number: 16000036424005
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71E3E074A00035133F-8024
   Serial number: 010216EAV05609 Dataset Number: V03935234RN 0001
   Coding: 00350A20D001028000001000
   VCID: 438F7ABCCA3CF7839D-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003314022
   Coding: 0D0000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Dataset Number: 3G0074V____ 0230
   Coding: 8103
   Shop #: WSC 00015 115 00311
   Serial number: 050216EB40620A Dataset Number: V03935234TC 0001
   Coding: 00350020D001028000001000
   VCID: 42817FB8D526FE8B96-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003308207
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0624
   Serial number:                Dataset Number: V03935233XZ 0001
   Coding: 02840201FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 306525706B8A7C1B70-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9S0860381
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
End-------------------------(Elapsed Time: 04:30)--------------------------
------------------------------18 Faults Found------------------------------
That the hardware part number of the old one in the scan from what you're saying is the faulty part. But hardware part numbers are not how you choose replacement parts. Software part numbers are, so the part you need is actually: 3Q0 953 521 DJ
Can we get a scan with the new, replacement part please?
Oh, and you picture links to attachment.outlook.live.net have no prayer of being visible to anyone but you.
KARL
C?ID=150991
Hi, Thanks for the reply. Apologies I'll change the way to upload the images in the future.
So this is the logfile with the new part fitted. Also the part number you have noted doesn't show applicable for our vehicle?
21472 - Databus
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
17165 - Databus
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Fault Frequency: 23
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:18
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:31
   Coding: 000F0F0E03
   Coding: 00006E
   Coding: 0071051801
8 Faults Found:
          B105D 00 [00001001] - -
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 13.2 V
2060 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
2062 - Databus
                    Reset counter: 147
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:28:58
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 14.4 V
2064 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:26:58
                    Control Module temperature: 15 °C
2127 - Databus
                    Fault Frequency: 80
                    Reset counter: 147
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:37:10
0836 - Databus
                    Reset counter: 147
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:58:38
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: -1.09 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.28 m/s²
1116 - Databus
                    Reset counter: 147
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 10:27:29
                    Control Module temperature: 16 °C
2068 - Databus
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
   Coding: 80000D
   Coding: 80000D
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20241112500428
   Coding: 6400
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   VCID: 3C7D0140B7C2887BDC-8068
229131 - Cruise Control Switch
          B1154 13 [00001001] - Open Circuit
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
                    Ubat 30 Voltage: 13.40 V
                    Ignition State: On
                    Terminal 15: 12.60 V
                    A/D #1: 97.25 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
229147 - Cruise Control Switch
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
                    Ubat 30 Voltage: 13.50 V
                    Ignition State: On
                    Terminal 15: 12.70 V
                    A/D #1: 97.65 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
229160 - Cruise Control Switch
          B1154 29 [00001001] - Signal Implausible
                    Reset counter: 107
                    Mileage: 253532 km
                    Date: 2025.03.11
                    Time: 09:34:19
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 100.00 %
                    A/D #3: 0.00 %
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000515860076114
   Coding: 2CFFFF
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
End-------------------------(Elapsed Time: 04:58)--------------------------
------------------------------16 Faults Found------------------------------
Derek
UK (ilexa)
C?ID=56983
Unless I'm reading that wrong, the original unit was coded without cruise control, but the parts catalogue says it has Adaptive Cruise Control which is how you've coded the new unit
Does it definitely have ACC?
Best regards
Derek
  • Agree
Old software part number: 3Q0 953 521 DJ
New software part number: 5Q0 953 569 A
Both modules have the same hardware part number, but the question is: What's the correct software for this vehicle?
KARL
C?ID=150991
Best regards
Derek
Hi, Yeah it definitely has ACC. It was working before the I replaced the steering angle sensor unit. Now its showing the codes above and won't work. Is this the case I'll need the system recalibrated with a ADAS company?
I don't think so; the sensor doesn't have an faults related to calibration.
I'm still questioning whether the the software in your new steering column module is correct for this application.
