2009 GTI Trouble codes????
ddyson3
C?ID=31436
the first scan showed the Cam Position sensor had intermittent signal faults so i replaced it and cleared the fault codes. Test drove the car and ran fine, no new codes. Then last night my Fiance was driving home and all the bells and whisles went off on the dash and the car shut down. She was able to restart the car and drive the rest of the way home. Please take a look at these two scans and any info would help. Thank you
First Scan:
Tuesday,08,December,2015,17:09:57:48853
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVWHD71K99W027627   License Plate: CHRISTY GTI
Mileage: 214300km-133159mi   Repair Order: 12/8/15
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65
          72
VIN: WVWHD71K99W027627   Mileage: 214300km-133159miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AF    HW: 1K0 907 115 AD
   Revision: E3H12---    Serial number: VWX7Z0H53N37TK
   Coding: 040301081C070160
   Shop #: WSC 01279 785 00200
   VCID: 6ADB8A7345C13C71D0B-803F
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
                    Mileage: 212236 km
                    Time: 18:26:50
                    RPM: 1620 /min
                    Load: 58.0 %
                    Speed: 32.0 km/h
                    Temperature: 94.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.208 V
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 214298 km
                    Time: 07:09:01
                    RPM: 1554 /min
                    Load: 16.9 %
                    Temperature: 14.0°C
                    Temperature: 14.0°C
                    Voltage: 10.795 V
Second Scan:
Tuesday,15,December,2015,10:25:51:48853
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.2.0
Data version: 20151124
VIN: WVWHD71K99W027627   License Plate: CHRISTY'S
Mileage: 214850km-133501mi   Repair Order: 12/15/15
          72
VIN: WVWHD71K99W027627   Mileage: 214850km-133501miles
   VCID: 6ADB8A7345C13C6ED5-803E
7 Faults Found:
                    Mileage: 212236 km
                    Time: 18:26:50
                    RPM: 1620 /min
                    Load: 58.0 %
                    Speed: 32.0 km/h
                    Temperature: 94.0°C
                    Temperature: 22.0°C
                    Voltage: 13.208 V
               P0221 - 000 - Implausible Signal - Intermittent
                    Mileage: 214298 km
                    Time: 07:09:01
                    RPM: 1554 /min
                    Load: 16.9 %
                    Temperature: 14.0°C
                    Temperature: 14.0°C
                    Voltage: 10.795 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 214302 km
                    Time: 19:14:45
                    RPM: 1129 /min
                    Load: 48.6 %
                    Speed: 2.0 km/h
                    Temperature: 25.0°C
                    Temperature: 15.0°C
                    Voltage: 13.335 V
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - Intermittent
                    Mileage: 214806 km
                    Time: 18:09:41
                    RPM: 1477 /min
                    Load: 39.2 %
                    Speed: 50.0 km/h
                    Temperature: 93.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.335 V
008817 - Oxygen (Lambda) Sensor Signal B1 S2
               P2271 - 000 - too Rich - Intermittent
                    Mileage: 214816 km
                    Time: 18:17:43
                    RPM: 1515 /min
                    Load: 14.5 %
                    Speed: 61.0 km/h
                    Temperature: 93.0°C
                    Temperature: 24.0°C
                    Voltage: 13.335 V
008821 - Oxygen (Lambda) Sensor Signal B1 S3
               P2275 - 000 - too Rich - Intermittent
                    Mileage: 214816 km
                    Time: 18:17:47
                    RPM: 1512 /min
                    Load: 14.1 %
                    Speed: 51.0 km/h
                    Temperature: 93.0°C
                    Temperature: 24.0°C
                    Voltage: 13.335 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - Intermittent
                    Mileage: 214816 km
                    Time: 18:17:53
                    RPM: 891 /min
                    Load: 31.4 %
                    Speed: 11.0 km/h
                    Temperature: 93.0°C
                    Temperature: 25.0°C
                    Voltage: 13.081 V
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1916
   Revision: 05144002    Serial number: 00001007210002
   Shop #: WSC 04940 001 00001
   VCID: 224BA253FD71242E5D-8076
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B600D49240001881106E692200041B100
   VCID: 000FC8DB93BDD63E6B-8054
                    Fault Status: 00101101
                    Reset counter: 13
                    Mileage: 214806 km
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 48178
                    Count: 523
Jef
HQ
Thank you for posting the full Auto-Scans! :thumbs:
Is the engine timing correct?
Have you done a close visual inspection of the O2 sensors?
d1anony
C?ID=239079
have u checked wiring on those sensors cleaned or checked ur throttle
ddyson3
C?ID=31436
yes the timing is correct and i have checked and cleaned the conectors. the first scan was 12-8-15 and the second was 12-14-15. the only difference from the first scan to the second scan was changing out the cam position sensor.
Gone But Not Forgotten
Car is modified and running deleted diagnostic stack......?
ddyson3
C?ID=31436
no this car is Bone stock
Did you clear DTC's after first scan, and if not why, because when resetting you would default trims typically?
Have you reset defaults and all basic settings such as TV ADP ............ if not you should?
ddyson3
C?ID=31436
of course i did! i am not a beginner to this.... i am trying to save some money so i dont have to take this to the dealer for trouble shooting.
Dex
Serbia
C?ID=25360
99% its timing. Are you sure timing is correct?
Apparently you are still a wookie.......:p
Look at your time/mile stamps.
You did not reset DTC's based on your own scans and documentation.
Saving money starts with being truthful and to follow the orders......... when asking for help here.
Now reset the codes, preform the ADP.......... and repost the scan please.
"The orders have been given.......... It is our destiny to follow the orders"
