Jetta Sportwagon TDI (CJA) 2012 - Lots of communication problems
Mike Taylor
Florida, USA
C?ID=613049
Hi,
Well recently bought a new Wagon at a good price and maybe this is why. Picked it up and started driving home then the dash lite up and started giving me codes. Had no problems on the test drive. I think they are all related since most are communication problems.
I have checked all of the fuses inside and in the engine compartment and all of them have voltage on both sides of the fuse. (Tested with a meter on top of the fuse and touched both sides) I also ohmed them and they all checked out.
I have cleaned all of the grounds near the battery since it seemed like a common issue. Most looked fine but I cleaned them all anyways. I have started to dive a little deeper but figured some insight on the scan may give me some areas to check. New to the VCDS world and already love this thing.
Maybe start with the Can bus diagnostic module replacement to see if they are just communication? It seems like most are responsive and have good voltage but they aren't talking to each other. I ran a new scan today and picked up another 10 faults. I had a few speed sensors from my other wagon and I put them in and they still test the same. Seems like it has to be wiring or communication.
Despite all the codes it still starts and drives just fine. The dash just looks like a Christmas tree.
Any help is greatly appreciated.
Monday,10,March,2025,17:06:59:23791
VCDS Version: 25.3.0.3 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250301 DS365.0
VIN: 3VWPL7AJ9CM679612   License Plate:
Mileage:    Repair Order: Dusty Wagon v2
Chassis Type: AJ-VW36 (7N0)
          77
1C-Position Sensing -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 1010
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 50797 004 1048576
   VCID: 303262CB96269D7A3F0-8064
   VINID: 0E69E070745A2537461C91810841F52D07
7 Faults Found:
               U0155 - 003 -  - Intermittent
                    Fault Status: 00100011
                    Fault Frequency: 9
                    RPM: 920 /min
                    Temperature: 11.7 C
                    Voltage: 13.91 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Temperature: 16.2 C
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    RPM: 1725 /min
                    Voltage: 11.63 V
                    Pressure: 1004.3 mbar
                    Pressure: 955.9 mbar
                    Temperature: 10.8 C
                    Temperature: 10.8 C
049682 - Steering Column Control Module
               U0212 - 001 - No Communications - Intermittent
                    Fault Status: 00100001
                    RPM: 874 /min
                    Temperature: 10.8 C
                    Voltage: 11.55 V
                    Bin. Bits: 00000000
                    Torque: 390.0 Nm
                    Temperature: 10.8 C
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 001 -  - Intermittent
                    RPM: 138 /min
                    Temperature: 10.8 C
                    Voltage: 11.78 V
                    Bin. Bits: 00000000
                    Torque: 126.0 Nm
                    Temperature: 10.8 C
049478 - Diagnostic Gateway
               U0146 - 003 - No Communications - Intermittent
                    RPM: 138 /min
                    Temperature: 10.8 C
                    Voltage: 11.78 V
                    Bin. Bits: 00000000
                    Torque: 126.0 Nm
                    Temperature: 10.8 C
001575 - Fuel Pump Relay Control Circuit
               P0627 - 000 - Open Circuit - Intermittent
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:55:19
                    Voltage: 12.31 V
                    Pressure: 0.0 bar
                    Inj. Quantity: 0.0 mg/str
                    Lambda: 30.8 %
                    Lambda: 9.5 %
009778 - Relay for Fuel Pump 2 (J49)
               P2632 - 000 - Open Circuit - Intermittent
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:55:45
                    Voltage: 12.31 V
                    Pressure: 0.0 bar
                    Lambda: 30.8 %
                    Lambda: 9.5 %
Readiness: 0 2 0 0 0
   Component: GSG DSG AG6     512 9430
   Revision: 05551213    Serial number: 00001112191068
   Shop #: WSC 00066 000 00000
   VCID: 147ACE5B027E415A3B8-8040
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 93
                    Reset counter: 1
                    Mileage: 267742 km
                    Date: 2061.14.24
                    Time: 04:48:07
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Fault Frequency: 46
                    Reset counter: 37
                    Mileage: 267813 km
                    Date: 2061.14.24
                    Time: 16:25:59
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Fault Frequency: 38
                    Reset counter: 37
18097 - Powertrain Data Bus
            P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
                    Fault Frequency: 30
                    Reset counter: 34
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Fault Frequency: 28
                    Reset counter: 34
18288 - Powertrain Data Bus
            P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
                    Fault Frequency: 28
                    Reset counter: 34
   Revision: 00H31001
   Coding: 114B600C49290003881106E5921B0042B70000
   VCID: 7DAC8BFF1DF4A012E46-8028
10 Faults Found:
                    Reset counter: 114
                    Mileage: 263970 km
                    Date: 2061.14.05
                    Time: 16:03:41
                    Count: 7
                    Count: 4608
                    Count: 81
                    Count: 47872
                    Count: 62184
                    Count: 64257
                    Reset counter: 115
                    Mileage: 263952 km
                    Date: 2059.14.08
                    Time: 16:48:58
                    Count: 7
                    Count: 4608
                    Count: 83
                    Count: 50177
                    Count: 517
                    Count: 65286
                    Reset counter: 138
                    Mileage: 263955 km
                    Date: 2059.14.13
                    Time: 10:52:52
                    Count: 7
                    Count: 13
                    Count: 20480
                    Count: 128
                    Count: 34048
                    Count: 65281
                    Count: 765
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 117
                    Mileage: 592392 km
                    Date: 2000.04.01
                    Time: 00:24:08
                    Count: 1031
                    Count: 158
                    Count: 26368
                    Count: 87
                    Count: 320
                    Count: 1537
                    Count: 64
                    Count: 18433
                    Fault Status: 00101100
                    Reset counter: 144
                    Mileage: 263955 km
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 80
                    Count: 33792
                    Count: 1
                    Count: 766
16352 - Control Module - Electrical Error
                    Fault Status: 00101110
                    Fault Frequency: 15
                    Reset counter: 149
                    Mileage: 263955 km
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 96
                    Count: 33792
                    Count: 1
                    Count: 766
                    Reset counter: 106
                    Date: 2027.04.07
                    Time: 16:01:52
                    Count: 256
                    Count: 20624
                    Count: 1024
                    Count: 104
                    Count: 80
                    Count: 20850
                    Count: 256
01130 - ABS Operation
                    Fault Status: 01101000
                    Fault Frequency: 15
                    Reset counter: 109
                    Mileage: 263952 km
                    Date: 2059.14.08
                    Time: 16:45:44
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 100
                    Count: 44032
                    Count: 65281
                    Count: 1021
                    Reset counter: 103
                    Count: 7
                    Count: 12
                    Count: 4608
                    Count: 16390
                    Count: 42240
                    Count: 1
                    Count: 511
                    Fault Status: 01101100
                    Reset counter: 72
                    Mileage: 263955 km
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 64
                    Count: 33792
                    Count: 1
                    Count: 766
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   Shop #: WSC 00066 000 00118
   VCID: 0052F20B6A86CDFA8F0-8054
          U1111 00 [00001000] - -
          [Motorsteuerger t - kein Signal/Kommunikation]
                    Fault Frequency: 53
                    Reset counter: 143
13701392 - Function Restricted due to Missing Message(s)
          [Bremsensteuerger t - kein Signal/Kommunikation]
                    Fault Frequency: 53
                    Reset counter: 143
13701408 - Function Restricted due to Missing Message(s)
          [Diagnoseinterface f r Datenbus - kein Signal/Kommunikation]
                    Fault Frequency: 101
                    Reset counter: 143
13701456 - Function Restricted due to Missing Message(s)
          [Steuerger t im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Fault Frequency: 78
                    Reset counter: 146
9481748 - High Pressure Sensor
          B10AE 14 [00001000] - Open or Short to Ground
                    Reset counter: 139
                    Mileage: 267657 km
                    Date: 2125.14.24
                    Time: 00:00:29
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 3068
   Revision: BG021001
   Coding: 2F380E1F802F3EC4008800C17000004449000086535D0560648020200040
   Shop #: WSC 50715 002 1048576
   VCID: 39245FEF495C5C3288E-806C
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 07031  26  0512
   Coding: 009795
15 Faults Found:
                    Reset counter: 144
                        Term 15 Off
                    Voltage: 12.25 V
                    Fault Frequency: 111
                    Reset counter: 143
                    Voltage: 13.75 V
                    Fault Frequency: 21
                    Reset counter: 143
                    Voltage: 11.70 V
                    Fault Status: 00101001
                    Reset counter: 144
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:29:48
                        Term 15 Off
                    Voltage: 12.75 V
                    Fault Status: 00100101
                    Reset counter: 143
                        Term 15 Off
                    Voltage: 12.45 V
                    Fault Frequency: 152
                    Reset counter: 143
                        Term 15 Off
                    Voltage: 12.30 V
                    Fault Frequency: 19
                    Reset counter: 143
                    Voltage: 11.65 V
                    Fault Frequency: 21
                    Reset counter: 143
                    Voltage: 11.65 V
                    Reset counter: 143
                    Voltage: 11.80 V
                    Reset counter: 143
                    Voltage: 11.80 V
                    Fault Frequency: 49
                    Reset counter: 146
                    Voltage: 11.65 V
                    Fault Frequency: 21
                    Reset counter: 143
                    Voltage: 11.70 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 72
                    Mileage: 263952 km
                    Date: 2059.14.08
                    Time: 16:46:04
                    Voltage: 12.15 V
                    Reset counter: 144
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:29:48
                        Term 15 Off
                    Voltage: 12.75 V
                    Fault Status: 00101011
                    Reset counter: 144
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:29:48
                        Term 15 Off
                    Voltage: 12.75 V
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1AV33   Dataset Number: 1KM003v__B_ 0035
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FD031F757F87202B6A-806A
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--000038XX00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME5D412568ZZZ.
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME60412568ZZZQ
   Serial number: 3511HSME71003D2BZZZI
   Serial number: 3521HSME0C063E2BZZZU
   Serial number: 35527SME1C4B7129ZZZN
   Serial number: 35627SME4E447129ZZZM
          B1000 1B [10001000] - Resistance Too High
9445889 - Seat occupied recognition control module
          B1022 01 [00001000] - Electrical Failure
                    Reset counter: 139
                    Mileage: 267657 km
                    Date: 2125.14.24
                    Time: 00:00:32
12670208 - No Communication with Instrument Cluster
          U0155 00 [00001000] - -
                    Fault Frequency: 108
                    Reset counter: 146
12666368 - Diagnostic Gateway
          U0146 00 [00001000] - No Communications
          [Lost Communication With Gateway]
                    Reset counter: 143
12674816 - Immobilizer Control Module
          U0167 00 [00001000] - No Communications
          [Lost Comminication with Immobilizer]
                    Fault Frequency: 19
                    Reset counter: 146
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 9
                    Reset counter: 109
                    Mileage: 263952 km
                    Date: 2123.14.08
                    Time: 16:46:11
   Revision: --------    Serial number:  90440LAB0008Z Dataset Number: 5K0953507AH D005
   Coding: 188A140000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 76BE94D33842F34AA5C-8022
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0331379
   Coding: 820000
11 Faults Found:
0516 - Databus
                    Fault Frequency: 9
                    Reset counter: 143
227339 - Windshield Wiper Switch
          B1145 13 [00001000] - Open Circuit
          B1149 13 [00001000] - Open Circuit
227371 - Windshield Wiper Switch
229163 - Turn Signal Switch
          B1144 13 [00001000] - Open Circuit
229179 - Turn Signal Stalk; Switch for Cruise Control
          B1144 F3 [00001000] - Electrical Malfunction
332564 - Databus
                    Fault Frequency: 145
                    Reset counter: 143
                    Mileage: 263958 km
                    Date: 2123.14.22
                    Time: 08:10:08
332580 - Databus
                    Fault Frequency: 142
                    Reset counter: 143
                    Mileage: 263958 km
                    Date: 2123.14.22
                    Time: 08:10:08
332596 - Databus
                    Fault Frequency: 50
                    Reset counter: 103
                    Mileage: 263958 km
                    Date: 2123.14.22
                    Time: 08:10:08
365080 - Controls in Steering Wheel
          U108E 00 [00001000] - No Communications
                    Reset counter: 143
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [00001000] - Signal Implausible
                    Reset counter: 135
                    Mileage: 263960 km
                    Date: 2124.14.05
                    Time: 10:33:21
Address 17: Instruments
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 26021201290324
   Coding: 352002
   VCID: 3D2C4BFF5D746012A46-8068
10 Faults Found:
                    Fault Frequency: 24
                    Mileage: 263960 km
                    Date: 2060.14.05
                    Time: 10:40:45
                    Reset counter: 144
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 01:49:29
                    Mileage: 266138 km
                    Date: 2061.14.17
                    Time: 22:02:12
                    Fault Status: 00110100
                    Reset counter: 144
                    Mileage: 266553 km
                    Date: 2061.14.18
                    Time: 12:32:06
                    Reset counter: 139
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 02:31:46
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 132
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 01:52:19
                    Reset counter: 132
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 01:56:40
01304 - Radio
                    Reset counter: 138
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 01:43:08
03272 - Control Module for Audio Interface
                    Reset counter: 138
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 01:43:08
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RG5S206
   Coding: 0000002
   VCID: 7EAE8CF31CF2BB0AFDC-802A
                    Fault Frequency: 11
                    Reset counter: 146
                    Mileage: 263960 km
                    Date: 2060.14.12
                    Time: 10:50:49
                    Fault Frequency: 11
                    Reset counter: 143
                    Mileage: 266138 km
                    Date: 2061.14.17
                    Time: 22:01:49
                    Reset counter: 143
                    Reset counter: 132
                    Mileage: 266553 km
                    Date: 2061.14.18
                    Time: 12:33:23
   VCID: 6A86B0A37CFA27AA314-803E
   Revision: A1001003    Serial number: 7661527796
   VCID: 29048FAFB9FCECB2F8E-807C
                    Fault Frequency: 32
                    Reset counter: 143
                    Mileage: 263958 km
                    Date: 2059.14.22
                    Time: 08:10:25
                    Reset counter: 132
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0004131404
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE8E567A3A04E22BA2-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1509
   Serial number: 00000006421921
   Coding: 000490
68102 - Function Restricted due to Missing Message(s)
          [Front CAN Kombi]
                    Fault Frequency: 40
                    Reset counter: 146
68103 - Function Restricted due to Missing Message(s)
          [Front CAN gateway]
                    Fault Frequency: 78
                    Reset counter: 143
68107 - Function Restricted due to Missing Message(s)
          [Front CAN AirBag]
                    Fault Frequency: 28
                    Reset counter: 143
68108 - Function Restricted due to Missing Message(s)
          [Front CAN MSG]
                    Fault Frequency: 20
                    Reset counter: 135
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 353C53DF6944B8526C6-8060
                    Fault Status: 11101101
                    Reset counter: 71
                    Mileage: 263931 km
                    Date: 2059.14.04
                    Time: 16:18:52
                    Voltage: 12.00 V
                        DD
                    Temperature: 32.0 C
                    Fault Frequency: 29
                    Reset counter: 143
                    Voltage: 12.00 V
                        DD
                    Temperature: 11.0 C
                    Reset counter: 146
                    Mileage: 268663 km
                    Date: 2061.14.28
                    Time: 18:48:11
                    Voltage: 13.88 V
                        DU
                    Temperature: 18.0 C
                    RPM: 851 /min
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: 6FB0A1B74798C28266A-803A
   Component: J245EE20SKB13  H02 0220
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 116
                    Mileage: 264267 km
                    Date: 2061.14.07
                    Time: 06:42:23
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0004173898
   Coding: 0004B4
   VCID: 5CEAE67BA6AE491AB38-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1509
   Serial number: 00000006245950
   Coding: 000490
          [Front CAN Kombi]
                    Fault Frequency: 40
                    Reset counter: 146
          [Front CAN gateway]
                    Fault Frequency: 78
                    Reset counter: 143
          [Front CAN AirBag]
                    Fault Frequency: 28
                    Reset counter: 143
          [Front CAN MSG]
                    Fault Frequency: 20
                    Reset counter: 135
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 147
                    Mileage: 267647 km
                    Date: 2125.14.23
                    Time: 17:07:10
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M3262833
   Coding: 01000400040007
   VCID: 6398DD879B5076E2F22-8036
8 Faults Found:
                    Reset counter: 112
                    Mileage: 263931 km
                    Date: 2059.14.05
                    Time: 16:38:02
00849 - S-contact at Ignition/Starter Switch (D)
                    Fault Frequency: 32
                    Reset counter: 143
01704 - Terminal 58 (Dimming)
                    Reset counter: 113
                    Time: 10:33:04
                    Fault Frequency: 16
                    Reset counter: 146
                    Date: 2060.14.05
                    Time: 10:33:60
                    Reset counter: 132
                    Mileage: 266539 km
                    Date: 2061.14.18
                    Time: 02:14:25
00856 - Radio Antenna
                    Reset counter: 132
                    Mileage: 266554 km
                    Date: 2061.14.18
                    Time: 14:48:20
                    Reset counter: 132
                    Mileage: 266554 km
                    Date: 2061.14.18
                    Time: 14:48:20
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 104
                    Mileage: 268413 km
                    Date: 2061.14.28
                    Time: 00:12:22
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661788185 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 27008997AF68DAC2EEA-8072
8 Faults Found:
          B104F 13 [00011000] - Short to GND
                    Reset counter: 135
                    Mileage: 266554 km
                    Date: 2125.14.18
                    Time: 14:17:35
          B104E 13 [00011000] - Short to GND
                    Reset counter: 135
                    Mileage: 266554 km
                    Date: 2125.14.18
                    Time: 14:17:35
12608768 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [00001000] - Performance
                    Reset counter: 132
                    Mileage: 266553 km
                    Date: 2125.14.18
                    Time: 12:33:22
12664832 - Body Control Module (Central Electric)
          U0140 00 [00001000] - No Communications
                    Reset counter: 135
          [Kombiinstument: keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 145
                    Mileage: 263960 km
                    Date: 2124.14.05
                    Time: 10:33:59
12718592 - Steering Column Control Module
          U0212 00 [00001000] - No Communications
                    Reset counter: 135
13633792 - Diagnostic Gateway
          [Gateway: keine Kommunikation]
                    Reset counter: 135
                    Mileage: 266553 km
                    Date: 2125.14.18
                    Time: 12:33:22
0022 - Radio
          U1066 00 [00001000] - No Communication
          [Steuerger t Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 138
                    Mileage: 266553 km
                    Date: 2125.14.18
                    Time: 12:33:22
End----------(Elapsed Time: 01:42, VBatt start/end: 12.6V/12.5V)-----------
-----------------------------105 Faults Found------------------------------
DrPeter
16.4905° S, 151.7375° W
Thank you for posting your Auto-Scan and joining the forum. Welcome.
Hmm, there are a lot of fault codes in your Auto-Scan!
Since many of the faults are communication-related, I would clear ALL the fault code again and post a new Auto-Scan so we can see what returns too.
Try to communicate with the [17-Instrument] cluster and retrieve fault codes from it, as your Auto-Scan indicates the [17-Instruments] "Cannot be reached."
Also, the CAN Gateway controller could be at fault. Given the large number of communication fault codes, replacing the CAN Gateway with a known good unit would be a reasonable test, as used ones are typically inexpensive.
The two fault codes in the ABS controller are also concerning:
If these codes return after clearing, I recommend checking the ABS power supply, grounds, and wiring/connections for any issues and since you already replaced the speed sensors with known good ones and the faults remain, that suggests the issue is elsewhere—likely wiring, connections, etc (or maybe the ABS controller/pump is the issue?).
We recommend the Official Factory Repair Information when attempting to repair and diagnoses these vehicles.
Let us know what you find, hope this helps,
drpeter
Mike Taylor
Florida, USA
C?ID=613049
I will try to get a new Scan this weekend before I leave town again. I cleared them a few days before that scan so its probably pretty accurate.
Mike Taylor
Florida, USA
C?ID=613049
Well this morning it wouldn't start and gave a ton of codes. I messed with a bunch of wiring trying to check fuses and relays. I went in and cleared every code by module this time which seemed to help.
Maybe a few of the codes that are left are he ones that are causing it to melt down occasionally. I have cleared codes and it will be fine for a while then everything blows up on me. Looks like the instrument cluster has a memory problem as well as the ABS.
Saturday,15,March,2025,15:21:09:23791
Mileage: 270770km-168248mi   Repair Order: Dusty Wagon v4
          77
VIN: 3VWPL7AJ9CM679612   Mileage: 270770km-168248miles
   Coding: 0050078
Readiness: 0 0 0 1 1
   Revision: 00H31001
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:14:19
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 100
                    Count: 44032
                    Count: 64769
                    Count: 256
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:14:11
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 44032
                    Count: 64769
                    Count: 256
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:14:19
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 64
                    Count: 44032
                    Count: 64769
                    Count: 256
   Revision: 00001016
   Coding: 0000001002
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [Steuerger t f r Bordnetz - bitte Fehlerspeicher auslesen]
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2025.03.15.
                    Time: 01:14:31
   Revision: BG021001
   Coding: 009795
01800 - Light Switch (E1)
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:15:10
                    Voltage: 12.15 V
                    Fault Status: 01100010
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:15:12
                    Voltage: 12.15 V
   Coding: 00003133
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2025.03.15.
                    Time: 01:16:10
   Coding: 188A140000
   Coding: 820000
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Coding: 270F01
   VCID: 303262CB9AA69D7A3F0-8064
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [10001001] - Internal Electronic Failure
          [Steuerger t defekt (SiWaLa)]
   Coding: 352002
   Coding: 0000002
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:19:10
                    Voltage: 12.25 V
                        DD
                    Temperature: 65.0 C
   Coding: 050B0500
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
                    Reset counter: 115
                    Mileage: 270772 km
                    Date: 2019.08.06.
                    Time: 01:20:26
   ROD: UHVNA.rod
End----(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.1V. VIgn 11.9V)-----
------------------------------10 Faults Found------------------------------
You've got a failing ABS module:
01130 - ABS Operation 008 - Implausible Signal
And a dodgy Instrument Cluster:
10485833 - Internal Control Module Memory Check Sum Error B2000 49 [10001001] - Internal Electronic Failure [Steuerger t defekt (SiWaLa)]
Either one of them is capable of choking communications on the Powertrain Data Bus.
Mike Taylor
Florida, USA
C?ID=613049
Well thanks that is what I was working towards as well.
The ABS I can buy a new to me one and then code it with VCDS correct? I looked at a new one and the prices were stupid high. Any suggestions on a new but not dealer price ABS?
The instrument cluster if I remove it I need to find some one to code it or clone it for me?
