Setting the default distance for Adaptive Cruise Control
horrgakx
C?ID=610814
Hi all. I'm trying to set the default distance setting for the Adaptive Cruise Control, I found this method but I'm a bit stuck as under Module 13, Adaptation, I don't see anything to do with the default distance. Let alone "Channel 07" which it mentions:
Module 13 - Auto Distance Regulation
Adaptation - Channel 07 Set to 1
Reboot the MMI - Press MENU, central MMI knob and top right softkey
Outcome - In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the default adaptive cruise distance.
Here's a screenshot of the Adaptaiton list. Would it be any of these?
Car is a 2015 Audi A8L W12.
Thanks in advance.
Westbury, UK
The instructions that say channel 07 are out-of-date and don't apply to your car.
Please post an Auto-Scan
  • Agree
horrgakx
C?ID=610814
Ah I see. So I can't set the default distance?
Ok - full auto-scan follows;
Thursday,06,March,2025,16:43:30:31183
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: [REMOVED] License Plate:
Mileage: 120237km-74711mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 28 30 34 36
          3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 69 6C 6D 6F 72
          81 84 85 88 89 8A 8B 8D 8E 8F 90
VIN: [REMOVED]   Mileage: 120237km-74711miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CTNA)       Labels:. 07P-906-023-V1.clb
   Part No SW: 07P 906 027 A    HW: 07P 907 309
   Component: W12 6.3 EU6   H22 8556
   Revision: 41H22000    CVN: 077AE0AA
   Coding: 002A0012256601000800
   Shop #: WSC 23485 002 1048576
   ASAM Dataset: EV_ECM63FSI11107P906027A 001011
   ROD: EV_ECM63FSI07P906027A.rod
   VCID: 303ECF06AAA4CF7A3F1-8064
   VINID: 9D196AAAA1181567800890472095894A27
16672 - Please Check DTC Memory of ECU Number 2
          P1923 00 [00100111] - -
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 90  C
                    Intake air temperature: 51  C
                    Voltage terminal 30: 12.133 V
                    Unlearning counter according OBD: 0
                    Relative load value: 52.99 %
                    Engine torque: 0.0 Nm
                    Fuel level: 28.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft B1 active operating state: 0
19302 - Exhaust Pressure Control Valve
          P0478 00 [00100111] - Short to Plus
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:05
                    Voltage terminal 30: 12.180 V
                    Fuel level: 28.00 l
Readiness: 1110 1001
   Part No SW: 4H1 927 158 CG    HW: 0BK 927 156 AD
   Component: 0BK 63 FSIRdW H19 1004
   Revision: --H19---    CVN: 70C58982
   VCID: 77AC341A0F4AD842BEB-8022
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: A2E5EBA045A7D705E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71B80A02612E867270F-8024
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0560
   Coding: 05B76F4E000000000000
   VCID: 6E82117E7090998A6DD-803A
   Serial number: 3214000146951005
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000127663944
   Coding: C038B60085047201010001010101112131313333283333
   VCID: 3530FE125546EA526C7-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 4CE10BBEBC0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D00D672BD96A292147-8078
   Part No SW: 4H0 907 063 DB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0311
   Revision: 19020001    Serial number: 00000950283401
   Coding: 0105001440349FE2C9014084A0001800009DC30A2F080201800008946100170000400009090000
   VCID: 6B84186A43826CA24A3-803E
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140603  H36 0090
   Serial number:         140618061852
   Coding: 0045F7
   Serial number: 23544642
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 21 02 2014  00001174
   Component: EVLS-SG  H08 0300
   Serial number: WA109401000010289539
   Coding: 020300
   Serial number: 92288167000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2314304AEBD264E2B23-8076
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56261434300122
   Coding: B93B07
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000_AU64.rod
   VCID: 3530FE1255C6EA526C7-8060
Address 11: Engine II (J624)       Labels:. 07P-906-023-V1.clb
   ASAM Dataset: EV_ECM63FSI21107P906027A 001011
   ROD: EV_ECM63FSI07P906027.rod
24749 - Exhaust Pressure Control Valve 2
          P04A2 00 [00100111] - Short to Plus
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:38:05
                    Intake air temperature: 45  C
                    Voltage terminal 30: 12.203 V
                    Fuel level: 28.00 l
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Serial number: 00000000000000 Dataset Number: 4H0909863E  0037
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002_AU64.rod
   VCID: 2B04D86A8382ACA20A3-807E
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002BELY Dataset Number: 4H0909602J  0017
   Coding: 30333045313430303037554A305234483053
   VCID: 3B24E82A73E23C229A3-806E
   Serial number: 3575HRB40532OSCEAPD0
   Serial number: 3585HRB40552QMKACPB3
   Serial number: 3515JRB405932I4ODG2%
   Serial number: 3525JRB405932I4OH82$
   Serial number: 3554VRB405F34GNSF8D5
   Serial number: 3564VRB405F34GNSF0D+
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 01335NKT0019U
   Coding: 0004FC
   VCID: 382EF7264254173A771-806C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 15 10 2014  C0042916
   Part No SW: 4H0 920 850 R    HW: 4H0 920 850 R
   Component: TBenGB-ACCNV- H53 0707
   Revision: 37081202    Serial number: 658041214592070
   Coding: 338608001F552600010200
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 3632F91E48C0E14A65D-8062
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2141112000585
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001662604 Dataset Number: 4H0909515L  0087
   Coding: C0CD075C08
   GVL: FFFFE85CFFE7E7FDC0000000
   VCID: 75B03E121546AA52AC7-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 61323F46171911098926
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14342000404021200410
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 382EF72642D4173A771-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000071746
   Coding: 01010101000000000001000102
   VCID: 64967356AE5C23DA0B9-8030
   Dataset Number: 4H0909553H  0038
   Coding: 008003
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F3CCC7AB79AD08226B-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000127663111
   Coding: C038BF8085857201030001010101112131313333203333
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7702C3TB
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372CF41A4FCA18427EB-8062
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0351694540 Dataset Number: 4H0909535D  0017
   Coding: 040312
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 3334C00A5BB2F462423-8066
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0030
   Serial number: 0352225009
   Coding: 040312
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000127890478
   Coding: 011F1E015E0162C202083017
   VCID: 48CE87E632B467BA071-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H40 0011
   Revision: 00001000    Serial number: 0002650065 Dataset Number: 4H0909852J  0023
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0354490037
   Coding: 011B0E2280B93985FB30C7C40E0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H08 0006
   Serial number:     WOO33926478
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 907 133 A    HW: 4H0 907 133 A
   Component: J505-FSH  H06 0046
   Serial number: 00000000000000010606
   Subsystem 5 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000829295
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO10008DNJ
   Subsystem 7 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93351668
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000011986
   Coding: 030000
   VCID: 1C660BB6D6AC5B1A739-8048
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0158
   Revision: AA000000    Serial number: 00000122570039
   Coding: 003892800000700D0A00392038193A2039203B3B202020
   VCID: 71B80A0261AE867270F-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000126798159
   Coding: 011F1E015E0162C202083006
   VCID: 3C26EB36766C3B1A939-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001294340 Dataset Number: 4H0909522D  0017
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865C  0018
   Coding: 02F60220221B0200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   VCID: 3138CA02A1AEC67230F-8064
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109L50E7996311
   Coding: 010103010000000001
   VCID: 2D00D672BD16A292147-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301739701
   Coding: 03000000
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0158
   Revision: AA000000    Serial number: 00000122569710
   Coding: 003896800000700D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 654 E    HW: 4H0 035 670 T
   Component: H-BNT-EU      H48 1072
   Revision: --------    Serial number: 449L80E7500866
   Coding: 04010100000BF9EF7DB4C31600000003080001000000000000
   VCID: 280E276692F487BAE71-807C
   Subsystem 1 - Part No: 8R0 060 884 KL
   Component: EUR 2023  3600
   Subsystem 2 - Part No SW: 4F0 910 393 AH    HW: 4F0 862 393 E
   Component: BTHS  H25 0750
   Serial number: P14004026934
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000180608
   Component: CD-Database  5950
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:06
                    Text: KBD_FD4,TPE,M,0,0,6
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:07
                    Voltage: 11.50 V
03623 - Invalid Security/Release Code
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:04
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
03787 - Rotation Mechanism for Display Module Front
                    Reset counter: 55
                    Mileage: 120237 km
                    Date: 2025.03.06
                    Time: 16:32:03
                    Voltage: 11.50 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000128623205
   Coding: 010F1E01420062C202083006
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 N    HW: 4H0 907 383 L
   Component: Anhaenger     H20 0160
   Revision: 7A001003    Serial number: 0417008171
   Coding: 0100000202000000
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0192857
   Coding: 020D000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E02D17EB090D98A2DD-807A
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 344400055 Dataset Number: 4H0909541F  0008
   Coding: 021004C021
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBC0C7A771A908266B-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000171871 Dataset Number: 4F0000000__ U001
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6394704AABD224E2F23-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000128623206
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN141104  0165
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C06DB76868CAB9A039-8078
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201445
   Coding: 201100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X_AU64.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1606000255
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547F  0046
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00019307143601 Dataset Number: 4H0909880D  0019
   Coding: 776FF2
   ROD: EV_IVBDriveSideFrnt_AU64.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00019138111001 Dataset Number: 4H0909881D  0019
   Coding: 376FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00019139006901 Dataset Number: 4H0909882D  0014
   Coding: 212F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002_AU64.rod
   VCID: 29082262897EBEB2F8F-807C
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00019139060601 Dataset Number: 4H0909883D  0014
   Coding: 212F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000620112147 Dataset Number: 4H0909548K  0035
   Coding: 02C23B041111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323AC50EA4A8FD6A495-8066
End----(Elapsed Time: 03:38, VBatt start/end: 12.2V/11.9V. VIgn 11.9V)-----
------------------------------7 Faults Found-------------------------------
Westbury, UK
I didn't say that! Just that those instructions don't apply to your car, but there MIGHT be instructions that do - as I don't own an A8 I can't say but someone here most likely can.
Unclear. There isn't a really obvious channel for that, one or two that might be it.
I'd like to see an Adaptation Channel Map from your 13 - Auto Dist. Reg module.
horrgakx
C?ID=610814
I will be glad post whatever you like if it helps, from whatever module you like - do I just do a screenshot, or is it something deeper?
horrgakx
C?ID=610814
See how the phrase Channel Map is dark blue and bold? That means it's a link. ;)
I watched the video on creating controller maps. So this is where I would set the Debug Level to "2" and re-run the scan, then it will create .PLS & .PLB files for every module?
Or are you only interested in the module 13?
I would just like to see the Adaptations from module 13. Getting that should only take a few seconds. Running the whole car will take considerably long, potentially 20 minutes or more.
horrgakx
C?ID=610814
Ok give me a few days and I'll follow those instructions you linked.
I don't mind getting more if you need them.
You sure are correct about that Uwe, when I did my RS5 block maps and adaption channel maps for the entire car (ie all the modules) it was 40-45 min. for Each of those two! (with vehicle running).
And the Op has a A8 which I would guess has 12-14 more modules than my RS5.
Edit: Op has 51 addresses ; my RS5 has 34 addresses . I would estimate his would be 1 hour Each (block maps and adaption channel maps) , total 2 hours.
@horrgakx , if your curious what that looks like, you can check out my post in the reference and scans of non-broken cars section on the home page of this forum.
That seems high, but much depends on the modules in the car, how measuring values and Adaptation channels they have, and how fast they answer requests.
I based my "20 minutes or more" on my most recent Auto-Scan with Debug Level 2 on our 2018 Tiguan SEL Premium. It also has 34 addresses. The complete scan with both MVB and ADP maps in that car took 19:41.
horrgakx
C?ID=610814
Were the files of use?
Possibly. Address 5F already has ACC menus enabled via coding so we don't believe any additional menus can be enabled in that controller directly.
Address 13 has this Adaptation Channel: IDE01949-Distance basic setting option OFF
Our recommendation is to try tuning that adaptation channel on. If you receive an error related to Security Access Required try using the ones in the VCDS help balloon first. Those are: 89531 and 20103
With any luck a new menu that lets you save the distance setting appears in the MMI after the change.
horrgakx
C?ID=610814
Thanks. I changed that option to ON, it didn't ask for any codes.
In the MMI settings there was indeed another menu which is the default distance so it worked!
Why would they hide this from the driver?
But thankyou very much. If you need a full scan I can do that, if it'll help anyone.
I have no idea why they would hide this from the user but glad to hear that ADP channel sorted it.
Another scan won't show changes (since that's within the Adaptation function) however a photo of your MMI screen proudly showing the menu options may help someone in the future with a MLB based A6/7/8 in the future!
Time permitting you can share a link if your phone saves photos to a cloud service by default (i.e.Google photos or similar) or upload it to a host like imgur and share a pic that way.
horrgakx
C?ID=610814
I meant would you like me to send a scan of the full car - block/adaptation - would it help your guys at all?
And I'll get a shot of the MMI menu as soon as I can.
Sure, a full Whole Vehicle map set configured to Measuring values, Adaptation and (time permitting) Adv ID with the Auto-Saved scan would be great! All of the mapping files will end up in Logs. The automatically saved Auto-Scan during that process will be in the Scans folder by default. This page doesn't have the new Adv ID option updated yet but it expands on that process:
Note; That may take near 1 hour on this vehicle so make sure you have a battery charger connected to the 12V battery and that the laptop has a pretty high SOC before starting it.
horrgakx
C?ID=610814
Just a thought, where there are no labels: ie. "Labels: None", I'll send an email (instead of spamming here) to ask if you'd like them. Would it be pointless if you have Label files for them?
