Sunday,09,March,2025,11:36:25:57302
VCDS Version: 25.3.0.3 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WA1DGAFE9FD030048 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE9FD030048 Mileage: 151690km-94255miles
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0A28
Shop #: WSC 31414 790 00001
VCID: 363524ACA44A80DA65C-8062
VINID: 9D10545D15952565000C00042028BD5A7B
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Fault Status: 00100001
Mileage: 151673 km
Date: 2025.03.07
Time: 15:36:43
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
004260 - Intake Air Regulating Flap
P10A4 - 000 - Mechanical Malfunction - Intermittent
Mileage: 151673 km
Date: 2025.03.07
Time: 15:36:44
RPM: 96 /min
Absolute Pres.: 984.2 mbar
(no units): 0.00
(no units): 24.60
Voltage: 1.760 V
(no units): 100.0
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: 354289C1
Coding: 001378
Shop #: WSC 63270 001 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 3A2D309C9CD264BA814-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627793
VCID: 34311EA4B23692CA5B8-8060
Reset counter: 13
Mileage: 149022 km
Date: 2024.12.12
Time: 14:23:37
Count: 64
Count: 8261
Count: 128
Count: 36864
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902212691
Coding: 0000135
Shop #: WSC 03824 003 1048576
VCID: 2517F3E009ECFB42DC6-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Component: FBSAUDIC6 KSG H03 0020
00956 - Key 2
Mileage: 148493 km
Date: 2024.11.24
Time: 16:58:26
Reset counter: 13
Mileage: 151507 km
Date: 2025.03.04
Time: 06:48:13
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Revision: 00---031 Serial number: 00000030389474
Coding: 000CC026
VCID: 2517F3E005ECFB42DC6-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0147795236
Coding: 070000
014 - Defective
Fault Status: 01101110
Reset counter: 230
Mileage: 133145 km
Date: 2023.09.15
Time: 21:41:47
Temperature: 28.0°C
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6E85CCCC9C9AF81A6DC-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931514704991
Coding: 290120
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311EA4BEB692CA5B8-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0011111
VCID: 270BF9E873E0E952EEA-8072
Fault Status: 00101101
Fault Frequency: 12
Reset counter: 12
Mileage: 149022 km
Date: 2024.12.12
Time: 14:23:36
Temperature: 17.0°C
Voltage: 10.24 V
Bin. Bits: 01000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH46 0230
Revision: 10H46000 Serial number: 0038QDA025P6
Coding: 0014131
VCID: 2B0305D86F08CD320A2-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME5453034A9
Subsystem 3 - Serial number: 6342QSME5A530366E
Subsystem 4 - Serial number: 6352QSME6A561260D
Subsystem 5 - Serial number: 6362QSME5453305EH
Subsystem 6 - Serial number: 63734SME715929641
Subsystem 7 - Serial number: 63834SME234B3342Y
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026151330286
Coding: 0012152
VCID: 2809FAD47EFEE62AE70-807C
Component: E0221 H03 0040
Reset counter: 13
Mileage: 151673 km
Date: 2025.03.07
Time: 15:35:21
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 985 F HW: 4L0 920 985 F
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2C00LT5G
Coding: 8BD763040D01CF05020205
VCID: 372B29A8AF4079D27EA-8062
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M155110B9A
Coding: 00C303
VCID: 3FDB418887704192B6A-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32140445094121971314
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---012 Serial number: 00000000478118
Coding: 0000006
VCID: 6889BAD4BE7E262A270-803C
Fault Status: 01101101
Reset counter: 120
Mileage: 133145 km
Date: 2023.09.15
Time: 21:41:52
Address 34: Level Control Labels: 4L0-910-553.clb
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 63964 001 1048576
VCID: 313F17B04D24A7E230E-8064
Reset counter: 13
Error Code: 13
03004 - Load Level Button (E539)
Fault Status: 00101100
Reset counter: 249
Error Code: 156
Reset counter: 249
Error Code: 157
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000149105295
Coding: 00581B00000011110000
VCID: 323D18BC44229CFA494-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 E HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0030
Revision: 00H03000 Serial number: 6PZ 009 014-16
Coding: 0010001
VCID: 303912B4462EAEEA3F0-8064
Subsystem 1 - Part No: 4L0 910 568 E
Component: J0770_SWA_Slave_H03 0030
Subsystem 2 - Serial number: 6PZ 009 014-36
Subsystem 3 - Serial number: 5F18.05.1500H03000AMS14006ÿ
Subsystem 4 - Serial number: S14006ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000152669571
Coding: 011F57205E40440004
VCID: 48C95A54D2BE062A070-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Fault Frequency: 27
Reset counter: 15
Mileage: 150518 km
Date: 2025.01.24
Time: 06:20:55
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010220430000
Coding: 3569949
VCID: 38292A94AE5E76AA770-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000088375
Coding: 030000
VCID: 290FFFD069F4DF22F8E-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191104139
Coding: 0694221
VCID: 2313EDF807D80572B22-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000239483
Coding: 0012001
VCID: 5EE59C0C6C3A689ADDC-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000152676107
VCID: 47CB5968DFA009520EA-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000032
Reset counter: 6
Mileage: 150750 km
Date: 2025.02.02
Time: 16:58:53
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F/0F8271670
Coding: 020007010000000000
VCID: 2411EEE40ED6024ACB8-8070
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513FY0F7525045
Coding: 180200060004F9EF710023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130FU0F3367064
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002253923
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000152697173
Coding: 010E57204040230004
VCID: 46D5546CD8AA105AF5C-8012
02131 - Child Safety Lock Motor
Fault Status: 01101000
Reset counter: 195
Mileage: 145786 km
Date: 2024.08.25
Time: 18:44:40
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000370513652
Coding: 0200000000000000
VCID: 313F17B04124A7E230E-8064
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0231842
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85CCCC901AF81A6DC-803A
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[Functional limitation by undervoltage]
Reset counter: 14
Voltage terminal 30: 6.9 V
Terminal 15 status: Terminal 15 on
9617993 - Proximity Camera
B145C 54 [00001001] - Missing Calibration / Basic Setting
Fault Frequency: 43
Reset counter: 229
Mileage: 129114 km
Date: 2023.05.06
Time: 11:50:25
Voltage terminal 30: 11.5 V
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H61 0500
Revision: --H61001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C6C4AA860A0A438-8038
Subsystem 2 - Serial number: ó
Subsystem 3 - Serial number: RD28.05.15--H61001002F0234ÿ
Subsystem 4 - Serial number: 2F0234ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0152929329----
Coding: 0003595
VCID: 2615F4EC74EAF05AD5C-8072
Component: J_245_EE16_SKB10H15 0220
Component: J_394_EE16_SKB10H15 0220
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000152697117
End----(Elapsed Time: 02:26, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
------------------------------19 Faults Found------------------------------
