Octavia Mk 3 VRS Fault Code Advice (P0671)
foofoo7777
Cork, Ireland
C?ID=593326
Hi folks,
Bit new to the VCDS world but have attached my recent log for 2013 Octavia VRS 2.0 diesel.
Few faults coming up causing check engine warning light that i need to remove to pass cars annual test.
Couple look ok, glow plug (P0671) will be replaced and that should be that.
The oxygen sensor (P2237) i need to order, which i hope may resolve that fault. i believe its the one pre cat near the bulkhead inside the engine bay? i have seen a few videos where they use VCDS to code the new one at install? i presume that is needed and should be followed.
i will worry about the fuel pressure regulation fault (P1065) afterwards.
Not sure what all the bulb faults are? Replaced both D3S bulbs fine the other week, not sure how it could be related, maybe coincidental and bad earth? Faults also for headlamp low beam that haven't cleared?
Last but not least, Rain and light sensor faults, cant code them out i understand, how to resole that??
Need to keep bright green VRS going, love her to bits.
Thanks for any words of wisdom or advice, cheers.
Tuesday,04,March,2025,19:40:14:65409
VIN: TMBBK7NE1E0103256   License Plate: 132OY690
Mileage: 298328km-185372mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
VIN: TMBBK7NE1E0103256   Mileage: 298328km-185372miles
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 6285
   Revision: 83X22---    CVN: B1165089
   Coding: 11190012032501081000
   Shop #: WSC 73430 031 00140
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002005
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73B406182B3AD082529-8026
   VINID: 91D4926C77950550010030851875CCB234
18111 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [01101000] - Pump Current Open Circuit
                    Fault Frequency: 27
                    Mileage: 295456 km
                    Date: 2024.12.06
                    Time: 08:05:03
                    Engine RPM: 2021.00 /min
                    Vehicle speed: 52 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 69 °C
                    Voltage terminal 30: 14.220 V
                    Unlearning counter according OBD: 32
                    Oxygen sensor bank 1 before oxi cat: signal qual. pump flow controller: 14
                    Oxygen sensor bank 1 before oxi cat: signal qual. temperature regulator: 6
                    Oxygen sensor bank 1 before oxi cat: electric. corrected Pump current: 0.0000000 A
                    Oxygen sensor bank 1 before oxi cat: heater activation: 83.893 %
                    Oxygen sensor bank 1 before oxi cat: electric. corrected Urie sensor value: 0.4870 V
                    Oxygen sensor bank 1 before oxi cat: adjustable resistor: 85.7 Ohm
                    Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0000
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [10101111] - Electrical Fault
                    Mileage: 295399 km
                    Date: 2024.12.04
                    Time: 08:28:45
                    Engine RPM: 297.00 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 12 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 9.980 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 2000 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 17
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 4
                    Outside temperature sensor 1: B1: raw value: 10.0 °C
5174 - Fuel Pressure Regulation
          P1065 00 [01101000] - Regulation Discrepancy
                    Fault Frequency: 36
                    Mileage: 295513 km
                    Date: 2024.12.09
                    Time: 08:32:46
                    Engine RPM: 1188.50 /min
                    Normed load value: 52.5 %
                    Vehicle speed: 5 km/h
                    Coolant temperature: 22 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.800 V
                    Engine status: COENG_RUNNING
Readiness: 1 2 0 0 0
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 62993000000548
   Coding: 1A0793915420096F0079060541C92958C92A9000608294F400630070C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_SK37.rod
   VCID: 4BC4BEF8134AE842FA9-801E
   Revision: 00021000    Serial number: 0194652698 Dataset Number: 5E0IJ1t____ 0001
   Coding: 030C0C
   Shop #: WSC 73430 790 00140
   VCID: 3A2AEB3C4CD061CA51F-806E
   Part No SW: 5E0 907 044 E    HW: 5E0 907 044 E
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 01110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 270C2248AF62EC223E1-8072
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011329800312 Dataset Number: 5E0063t____ 0046
   Coding: 0F010A42C24722FB03A04082B10C03280800000000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BA42E38036A98C20A9-802E
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131004  041 0570
   Serial number:         131007084939
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M10D29H17M24S41S6
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY13204193J
   Serial number: 00000000000028173148
5898 - Bulb for Left Side Turn Signal
          B12D0 15 [00001000] - Open or Short to Plus
                    Reset counter: 14
                    Mileage: 297898 km
                    Date: 2025.02.15
                    Time: 15:56:43
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 9.5 °C
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001000] - Open or Short to Plus
                    Reset counter: 31
                    Mileage: 297898 km
                    Date: 2025.02.15
                    Time: 16:10:24
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.7 V
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001000] - Open or Short to Plus
                    Reset counter: 14
                    Mileage: 297854 km
                    Date: 2025.02.14
                    Time: 07:59:20
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Low beam: operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 14.5 V
                    Outside temperature: 7.5 °C
          B1263 01 [00001001] - Electrical Failure
                    Reset counter: 102
                    Mileage: 295380 km
                    Date: 2024.12.03
                    Time: 19:18:30
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.0 V
                    Outside temperature: 10.5 °C
934149 - Rain/Light Recognition Sensor
          B1366 76 [00001000] - Incorrect Mounting Position
                    Fault Frequency: 23
                    Reset counter: 6
                    Mileage: 295408 km
                    Date: 2024.12.04
                    Time: 16:56:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 14.5 V
                    Outside temperature: 12.5 °C
934660 - Rain/Light Recognition Sensor
          B1366 04 [00001001] - Internal System Fault
                    Fault Frequency: 236
                    Reset counter: 0
                    Mileage: 295380 km
                    Date: 2024.12.03
                    Time: 18:58:09
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.8 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831329900137 Dataset Number: 5E0039t____ 0001
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 382EF13472DC73DAA7B-806C
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0189
   Revision: --------    Serial number: 003P4PMY9384 Dataset Number: 5E0003t____ 0048
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5CDA28177284E2261-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 110 13
   Serial number: 3576U00000043C612E07
   Subsystem 2 - Part No SW: -----------    HW: 454 001 310 13
   Serial number: 3586U000000096443E06
   Subsystem 3 - Part No SW: -----------    HW: 454 801 610 13
   Serial number: 3516R68A30D02000000+
   Subsystem 4 - Part No SW: -----------    HW: 454 801 710 13
   Serial number: 3526RF1D61A020000005
   Subsystem 5 - Part No SW: -----------    HW: 454 802 109 13
   Serial number: 3556V5C0E05020000002
   Part No SW: 5Q0 953 507 EE    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 31101304221081
   Coding: 1400
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7DA020201D7E96F234D-8028
   Part No SW: 5E0 920 961 F    HW: 5E0 920 961 F
   Component: KOMBI         233 2210
   Coding: 27A501106980A60001082A02000000
   VCID: 2B04DE78B38AC842DA9-807E
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001191540 Dataset Number: 5E0067t____ 0015
   Coding: 030100040F087300EF00026A080F00010001050000000000000000000000
   GVL: 01543C1000000600408C10000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FDC9A2857F244E2661-806A
   Generator:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000B0504021013
   Serial number: 0765021503
   Revision: 00000000    Serial number: 13000240669005
   Coding: 5500000000000000
   VCID: 3436C5046EB497BA8B3-8060
          U1400 00 [00001000] - -
          [Under voltage (temporary)]
                    Reset counter: 38
                    Mileage: 298308 km
                    Date: 2025.03.02
                    Time: 15:50:32
                    ELV State: 24
                    Information Clamps: 77 64
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 49
                    AD-Value H-bridge: 24
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000080448380  Dataset Number: 5E0222t____ 0012
   Coding: 001C00208001040000001100
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 42DA93DC2400290A09F-8016
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000981865
   Coding: 1D0200
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Dataset Number: 5E0074t____ 0205
   Coding: 9103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3530F80065CE8EB2BCD-8060
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000080972575  Dataset Number: 5E0157t____ 0012
   Shop #: WSC 73430 790 00000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 41D89CD021063212105-8014
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000961343
   Coding: 050200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: 5E0036t____ 0007
   Coding: 03DE02003E000000
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 3D20E0205DFE56F274D-8068
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
9574144 - Bulb for Low Beam Headlamp Left
          B1217 00 [00001000] - -
                    Fault Frequency: 13
                    Reset counter: 31
                    Mileage: 297898 km
                    Date: 2025.02.15
                    Time: 16:10:27
9574400 - Bulb for Low Beam Headlamp Right
          B1218 00 [00001000] - -
                    Reset counter: 14
                    Mileage: 297854 km
                    Date: 2025.02.14
                    Time: 07:59:23
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0421
   Serial number: S7E00411130733 Dataset Number: 5E0CV1t____ 0037
   Coding: 03735100FF0000002111120100A800002F0001060100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 21183C50C1461212705-8074
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9NK600K0P
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000140185    Dataset Number: 5E0HL1t____ 0013
   Coding: 0100000001030300000400000000010100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 131008200458
   VCID: 6988647079F61A52E85-803C
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)-----------
foofoo7777
Cork, Ireland
C?ID=593326
Well bizarrely, got multimeter on all glow plugs whilst still installed expecting glow plug 1 to have failed with no continuity but readings all the same?? What else could the code be for? Should i exchange glow plug 1 with a new Bosch one regardless? Thanks for any advice.
Dr Sheldon
Windsor UK
C?ID=334979
Not that bizarre !!
Read the fault Code !!
4984 - Cylinder 1 Glow Plug Circuit (Q10) P0671 00 [10101111] - Electrical Fault
I dont see where it says it is the Glow Plug ! Or to replace it ! Also Ohms readings wont always work as heat changes resistance.
If i was you I would now measure voltage to Each Glow Plug whilst activating them - Be aware that they may be PWM controlled !
I use a power probe - Engine not running - and power each plug and note the Volt Drop to test them.
No but Swapping Plug 1 with 2 will give better Diagnostic Value.
B1S1 is the one nearest the Engine
A new one will likely solve that !!
934660 - Rain/Light Recognition Sensor B1366 04 [00001001] - Internal System Fault
Try a used one from ebay
foofoo7777
Cork, Ireland
C?ID=593326
Not that bizarre !!
Thanks for the reply. I understood it said circuit but thought that if the glow plug had failed and there was no continuity then the circuit would in fact be broken, hence why i was surprised to see that it appeared fine and intact.
How do you test voltage to each glow plug? Just com to earth and red to cap and switch on ignition? What is PWM?
Replace the rain/light sensor? Is that the thing under the rear view mirror?
Many thanks.
foofoo7777
Cork, Ireland
C?ID=593326
Can i also ask the experts here, what triggers engine check dashboard light? Is it the 'Fault Priority' (whats the range and which is the worst?) or 'Fault Frequency' or a combination of both? Thanks.
Mileage: 295399 km
Date: 2024.12.04
Time: 08:28:45
Dr Sheldon
Windsor UK
C?ID=334979
Yes
PWM - Pulse Width Modulation
foofoo7777
Cork, Ireland
C?ID=593326
Glow plug mystery solved. Took out glow plug 1 and 2 and put multi meter on them both, cylinder 2 fine but cylinder 1 with circuit error was near dead, still some continuity but not much. Hence the DTC code and circuit error, too much resistance in glow plug flagged P0671 circuit error. Put no. 2 in cylinder 1 and new Bosch in cylinder 2. Cleared codes and wee spin and now no code. Good stuff. Can't explain why i couldn't capture this with a multimeter when it was in the head but dead obvious when out.
Dr Sheldon
Windsor UK
C?ID=334979
Did you unplug them before testing resistance ?
Did the temperature change - up or down a teeny weeny bit ?
Maybe the mild trauma of removing it killed it !!
Other than that it has to be a measurement error ?
Moving on, hate to pee on your fire but
That is a strange time to throw a Glow Plug DTC ?? Whilst cranking ??!!
I am wondering if there is an underlying concern that is still there ? I have come across a thing like this before, on a Passat and a Nissan Pathfinder ( Yes cars are all the same)
It could be that there was nothing wrong with your Glow Plug and your testing was correct however removing that plug killed it - It does happen, has happened to me before - Injectors and Glow plugs are a bastard for it.
Anyway - Good luck with the fix - if it does pop up again let us know !
foofoo7777
Cork, Ireland
C?ID=593326
Thanks for the input. Only thing i can think of is that when taking resistance reading whilst all glow plugs fitted (rubber caps off) i must have made contact with probes on the faulty glow plug, or indeed all of them. When removed had to lightly sand contact points to get readings off either so i wouldn't trust any of my in situ readings on that basis. I would say cyl 1 glow plug was always gone and new one resolved issue.....but if code comes back to cyl 1 more likely a wiring issue, unless that plug dies. Moral of story for me is remove glow plugs to test first before drawing any conclusions, just too tight in there for my sausage fingers and probes plus surface corrosion. No harm removing glow plugs anyway to clean thread etc and ensure don't get stuck in there....
Fingers crossed....
Dr Sheldon
Windsor UK
C?ID=334979
Have to disagree - The rule book says that your testing should be as Non Invasive as possible !!
Glow plugs can be tested in Situ !
Again no !! If you are removing an Injector or a Glow Plug (other sensitive components too) be prepared and be certain you have the money to replace them !! Risk of damage is there !! Just like Gaskets !
We do not know that - Diagnosis is an arena where being pedantic reaps rewards.
Eventually the rest will all die !! They have all done the same amount of work !
Again good luck - Hope it keeps going for you !
