2009 Audi Intake Manifold Flap Stuck Closed
BackyardMTMechanic
59911, USA
C?ID=566677
Hi all. I bought an auction Audi S5 with the NA 4.2 v8 and 6 speed manual. I'm slowly working through all the issues trying to make it into a fun, low-cost, daily driver.
A little background first. It ran decently when I got it but when doing a harder pull I could feel it hesitating and missing above 4k rpm or so. As it didn't have any label on the coil packs I decided to swap out the plugs and coil packs for OEM brand new. While pulling the coil packs I discovered oil in the spark plug wells. I bought new valve cover gaskets and changed them and finished the spark plug and coil pack job.
I took it out for a road test and the miss was still there- even felt worse to my feeling. I scanned for codes and got 2 for the Intake Manifold Flap Stuck Closed on bank 1 and 2. I cleared the codes and they immediately come back. When I go into measured values and graph the commanded position vs the actual position the commanded is like 99.6% the actual is 0. Mine has the vacuum activated flaps and I was able to hook the end and actuate it. When I did that I saw the actual position go from 0 to 100 on the graph so the position sensor is reading correctly and the flaps aren't physically stuck.
I pulled off one of the little vacuum hoses on the actuator and there was no suction. I believe this is why the actuator is not in the correct position.
My question: does anyone have a hose diagram to show where those hoses go so I know where to check? They go down towards the manifold and I can't tell where they go from there. I'm assuming there is a solenoid somewhere upstream of the actuator that turns the vacuum on and off but I don't know where to find it.
Thanks in advance for any help!
Saturday,08,March,2025,17:59:41:62274
VIN: WAURV78T99A049038   License Plate:
Mileage: 296550km-184267mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
          42 46 47 52 53 55 56 65 67 6C 77
VIN: WAURV78T99A049038   Mileage: 296550km-184267miles
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 S    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0004
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 26142 001 1048576
   VCID: 4ACD72006CB03D7AC1F-801E
   VINID: 9D1962987224249440109003206D345103
Readiness: 0110 1101
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Coding: 112500
   Shop #: WSC 00816 001 1048576
   VCID: 7F5B13D467F248D2261-802A
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H80 0145
   Coding: 0F0000
   Shop #: WSC 06325 000 00000
   VCID: 75B7F1FC55CE02827CD-8020
   Component: ELVAUDIB8  H36 0041
   Serial number: 0209000007707016
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001243888
   Coding: 00017025002C00000000
   VCID: 42DD5A205480E53A09F-8016
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340CT097519970
   Coding: 0025003
   VCID: 43D35F24479AEC32029-8016
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000246978
   Subsystem 3 - Serial number: 0103.03.090000000100010100
   Subsystem 4 - Serial number: 010100
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01160320090312
   Coding: 48022000
   VCID: 72BDCAE024A015BA59F-8026
   Component: BCM1 1.0      H24 0253
   Revision: 05024001    Serial number: 00000000338554
   Coding: 26001091063CAF311E00080300003D3D0F9C93C800010161000000
   VCID: 303900E8EA2C67AAEFB-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160309  H13 0040
   Serial number: SWF09030160462
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10415103
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AC    HW: 8K0 941 531 AC
   Component: E1 - LDS  H07 0090
   Serial number: 00000000002502090411
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8764973
   VCID: 2A0D1280C0F01D7A21F-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7I0524203
   Coding: 0000100
   VCID: 313F05ECED266EA2E05-8064
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140907509364
   Coding: 200002
   VCID: 3C2124D8366493CA433-8068
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364 A    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0050
   Revision: 00000000    Serial number: 25020909600002
   Coding: 050181
   VCID: 313F05ECE1266EA2E05-8064
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 245
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:43:01
03262 - Comfort Restriction
                    Reset counter: 245
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:43:01
                    Error Code: 2
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14W2ZX   Dataset Number: 8T0909602J  0001
   Coding: 303333334330303030304A55304C38543053
   VCID: 40D950285A0CF72A1FB-8014
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R09000035HX
   Serial number: 6334MSME460318140
   Serial number: 6344MSME43016F227
   Serial number: 6352QSME231C0A027
   Serial number: 6362QSME2B1B020CH
   Serial number: 63732SME3C1A1514-
   Serial number: 63832SME6D1A3A167
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90315JIH000AL
   Coding: 000016
   Shop #: WSC 02132 444 103840
   VCID: 3E252ED0207881DA6D7-806A
   Part No SW: 8T0 920 981 E    HW: 8T0 920 981 E
   Component: KOMBIINSTR.   H32 0224
   Revision: 00200000    Serial number: 9D9724839
   Coding: 8B1501003B00D705020000
   Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0095
   Revision: FB600048    Serial number: 4800F093108036
   Coding: 000303
   VCID: 4FFB631497D21852961-801A
   Component: J367-BDM  H06 0160
   Serial number: 19068373100209
   Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
   Component: DYNAMIKLENK.  H06 0500
   Revision: 50001005    Serial number: --------------
   Coding: 840000
   Shop #: WSC 06324 000 00000
   VCID: 2F3B0394F7127852F61-807A
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B031784C30A0472DA9-807E
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001245265
   Coding: 00197B25002C00000000
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341CR097524926
   Shop #: WSC 00493 128 21355
   VCID: 382938C80E5CBFEAA7B-806C
Address 3C: Lane Change        Labels: 8K0-907-566.clb
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000004
   VCID: 363536F00448499AB57-8062
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F16.01.0900H010003CD10301
   Subsystem 4 - Serial number: D10301
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 245
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:43:01
16365 - Control Module - Electrical Error; CPU 2
            014 - Defective
                    Reset counter: 51
                    Mileage: 265862 km
                    Date: 2009.05.31
                    Time: 00:05:31
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008629638
   Coding: 011C13224E00120102
   VCID: 41DF552C5186FE22105-8014
                    Fault Status: 01101100
                    Reset counter: 245
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:43:01
   Revision: 00002001    Serial number: 0117353438
   Coding: 0106029A007A444500B000
   Shop #: WSC 06197 000 00000
   Component: GTO BF  H06 0040
   Serial number: 00000000000000125815
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814004522601
   Coding: 030101
   Shop #: WSC 12336 024 394758
   VCID: 3FDB53D4277288D2661-806A
02246 - Loudspeaker; Center
                    Voltage: 12.70 V
                    Temperature: 22.0 C
                    Temperature: 22.0 C
                    Bin. Bits: 01000000
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008615762
   VCID: 40D950285A8CF72A1FB-8014
                    Reset counter: 245
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:43:01
                    Reset counter: 30
                    Mileage: 296538 km
                    Date: 2025.03.08
                    Time: 14:49:22
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000197808
   VCID: 33330FE41B3A5CB2929-8066
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000018
   VCID: 303900E8E62C67AAEFB-8064
   Subsystem 1 - Part No: 7L6 941 329 C
   Component: AFS-Modul links H01 0004
   Subsystem 2 - Part No: 7L6 941 329 C
   Component: AFS-Modul rechtsH01 0004
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 357CV097526462
   Coding: 0000002
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13374790185754
   Coding: 0CD154
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 245
                    Mileage: 296554 km
                    Date: 2025.03.08
                    Time: 15:41:53
                    Bin. Bits: 00000000 00001001
                    Voltage: 12.70 V
                    Text:  11,5 C;n.erkannt;     n.erkannt
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000902180437
   VCID: 34310CF812345B8A8B3-8060
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J92906M
   Coding: 1001008
   VCID: 372B3BF40342B092AE1-8062
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005082828
   Coding: 0010900
   VCID: 2809E888DEFC2F6A37B-807C
End----------(Elapsed Time: 02:06, VBatt start/end: 12.2V/12.2V)-----------
                Address 01: Engine       Labels: 079-907-560-CAU.clb
Control Module Part Number: 8T0 907 560 S    HW: 8T0 907 560
  Component and/or Version: 4.2l V8/4V    H10 0004
           Software Coding: 01140009180F0120
            Work Shop Code: WSC 26142 001 1048576
008198 - Intake Manifold Flap; Bank 1
               P2006 - 008 - Stuck Closed
                    Fault Status: 01101000
                    Mileage: 296554 km
                    Date: 2025.03.08
                    Time: 17:59:43
                    RPM: 1054 /min
                    Load: 21.6 %
                    Temperature: 47.0 C
                    Temperature: 33.0 C
                    Absolute Pres.: 890.0 mbar
                    Voltage: 12.192 V
008199 - Intake Manifold Flap; Bank 2
               P2007 - 008 - Stuck Closed
                    Mileage: 296554 km
                    Date: 2025.03.08
                    Time: 17:59:43
                    RPM: 1054 /min
                    Load: 21.6 %
                    Temperature: 47.0 C
                    Temperature: 33.0 C
                    Voltage: 12.192 V
                    Mileage: 296554 km
                    Date: 2025.03.08
                    Time: 17:59:43
                    RPM: 1054 /min
                    Load: 21.6 %
                    Temperature: 47.0 C
                    Temperature: 33.0 C
                    Voltage: 12.192 V
                    Mileage: 296554 km
                    Date: 2025.03.08
                    Time: 17:59:43
                    RPM: 1054 /min
                    Load: 21.6 %
                    Temperature: 47.0 C
                    Temperature: 33.0 C
                    Voltage: 12.192 V
Address 0x01,8T0 907 560 S,Basic Settings,Group 002
Address 0x01,8T0 907 560 S,Basic Settings,Group 142
Address 0x01,8T0 907 560 S,Basic Settings,Group 144
                Address 01: Engine  (8T0 907 560 S)
18:04:24 Group 144: Fuel Supply System (Intake Runner Flap Adaptation: Bank 2)
  0.0 %  Runner Flap Position (act.)
  99.6 %  Runner Flap Position (spec.)
  4.100 V  Offset Value Position Sensor
  ERROR  Adaptation Status
Dr Sheldon
Windsor UK
C?ID=334979
Go to >>ERWIN<<
All your answers will be there
Dr Sheldon
Windsor UK
C?ID=334979
That could be a split hose or actuator stuck closed, possible wiring issue. Easy enough to solve once you know where the components are. Getting to those components could be another story on that car !!
BackyardMTMechanic
59911, USA
C?ID=566677
Update for anyone running into this issue later. I pulled the front end of the car off as I'm replacing the radiator and condenser anyways due to an impact by the previous owner. This gives me access to the vacuum lines and the solenoids that control both the flaps in the intake runners and the intake body.
I'll try to insert some pictures but the solenoid for the main body-the big vacuum actuator in the middle is mounted right behind the fans and a protective guard on front of the middle of the manifold. The solenoid that controls the intake runners is towards the drivers side under the main intake body.
I found one of the 2 lines to the actuators was broken at the T which explains why neither of them were working and were giving the "stuck closed" codes. The space is very very limited but I'm going to attempt a repair tonight with a new solenoid and new vacuum lines-hopefully without having to remove the intake to accomplish it. The vacuum lines are fed from the same line that runs across the front of the engine and also supplies the airbox solenoid. It is connected to a plastic chamber under the intake and the solenoid for the runner flaps connects to that.
I'm not sure how to add photos but I created a google photos link and inserted it below if it can help anyone.
https://photos.app.goo.gl/134c5GAbVa5QeUbV7
