2013 Passat TDI DPF Diagnosis for frequent regeneration and ash volume
KIrwan10
Lake Village. IN, USA
C?ID=609540
Hello everyone, a little new here so this will be my first post. I am having a few concerns regarding my DPF on my 2013 Passat TDI.
Here is some background first.
Originally I had an engine light for a few months relating to the Adblue heater, It got to the point about a month ago that the vehicle locked me from starting it again due to the SCR lock. At that point I ordered this software, and a replacement heater assembly, dropped the tank, cleaned it, installed the new heater and filled with fresh fluid.
I reset the SCR lock, relearned the adblue level and drove it around and the fault went away.
About a week later I noticed frequent regenerations, about every 50 miles or less (I drive mainly highway to work every day, 50 miles one way)
The engine light came back on with a regeneration frequency code. I removed the differential sensor, cleaned it carefully with electronics cleaner, blew air through the hoses and reset the code, after a few more times of this error showing back up I ordered a new sensor and replaced it. A few days later is when I found out that you are supposed to adapt these sensors. While I adapted it correctly, I accidentally pressed "resetting of learned values of particulate filter."
Since then, the engine light remains, I have performed a few forced regens, and noticed my oil ash volume reads 0, I believe the car uses that value to help determine how frequently the DPF needs to regenerate but I am not sure.
My wife has the same vehicle but a 2014, and with 120,000 miles, her reading is about 0.12
Did I screw something up by relearning values of the particulate filter and is there a way for me to give it a value that would be in some way close to it's mileage? About 197,000 miles currently. I am aware that this filter is more than likely at the end of it's life but I was hoping to buy some time until I can afford to replace it or finish paying off the car.
I also notice after a regen, my values are the following,
-Difference pressure: 9hPa (if I raise the RPM it climbs to around 14-20 and then does not drop back to 9 when I return it to idle)
-Oil ash volume: 0.00
-Soot Mass Calculated: 1.2
-Soot Mass Measured: (usually in the range of negative values around 2)
Here is also my auto scan results, hopefully someone can shed some insight so I know which path to take. I am learning more about this every day but kind of worried I may have screwed myself over with resetting learned values.
Have a great weekend everyone,
Matt
Saturday,08,March,2025,12:20:31:13510
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250301 DS365.0
VIN: 1VWCN7A38DC020305   License Plate: SSDD
Mileage: 197930   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number:                CVN: D240C61FD45710C1
   Coding: 001D0012042400008000
   Shop #: WSC 03328 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B24E85C83E6ECB29A2-806E
   VINID: 0669D37874432144C00800C014053C498E
8863 - Particulate Filter
          P2459 00 [11101101] - Regeneration Frequency
                    Mileage: 317751 km
                    Date: 2119.14.30
                    Time: 13:32:07
                    Engine speed: 1624.00 /min
                    Normed load value: 34.1 %
                    Vehicle speed: 16 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.200 V
                    Exhaust gas jet volume in particle filter: 202.4 m³/h
                    Particle filter: difference pressure: 155 hPa
                    Particle filter: soot mass measured: 24.70 g
                    Particle filter: soot mass calculated: 24.70 g
                    Particle filter: differential pressure: dynamic offset: -11 hPa
                    Exhaust gas temperature sensor 3: 302.2 °C
                    Exhaust gas temperature sensor 4: 133.5 °C
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05551213    Serial number: 00001206280927
   Shop #: WSC 09003 957 00200
   VCID: 2416332012D8B34ACB8-8070
   Revision: 00H31001
   Coding: C54BC0F5492400FAA30E03E4921E0042A71000
   VCID: 7DA02644DDF22282E46-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0175740223 Dataset Number: 5K0116v____ 560E
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW41.rod
   VCID: 3436C360AEB823CA5B8-8060
   Part No SW: 561 907 044 M    HW: 561 907 044 M
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0010001012
   VCID: 21183A34014AA662A0E-8074
9473137 - Motor for Left Temperature Flap
          B108C 71 [00001000] - Actuator Stuck
                    Reset counter: 59
                    Mileage: 316202 km
                    Date: 2119.14.19
                    Time: 03:34:00
9473393 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 59
                    Mileage: 316202 km
                    Date: 2119.14.19
                    Time: 03:34:00
9472786 - Motor for Fresh Air / Recirculated Air Flap
          B108B 12 [00001000] - Short to Plus
                    Fault Frequency: 206
                    Reset counter: 89
                    Mileage: 232551 km
                    Date: 2097.14.23
                    Time: 15:16:35
9472785 - Motor for Fresh Air / Recirculated Air Flap
          B108B 11 [00001001] - Short to Ground
                    Fault Frequency: 234
                    Reset counter: 50
                    Mileage: 232551 km
                    Date: 2097.14.22
                    Time: 15:26:53
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
   VCID: 74B60360EEB863CA9B8-8020
   Component: RLS 230612 05  54  0403
   Coding: 22300A
                    Fault Status: 00101010
                    Reset counter: 90
                    Mileage: 232812 km
                    Date: 2033.14.27
                    Time: 03:45:51
                    Voltage: 14.50 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM03A751   Dataset Number: 560003v__A_ 0124
   Coding: 00004D48
   Shop #: WSC 33345 003 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBC0C0C871E401266A-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000HBKB0T
   Coding: 303047
   Serial number: 3572MSME334A4469ZZZ-
   Serial number: 3582MSME3B3A106DZZZ+
   Serial number: 3516KSME13761C1DZZZX
   Serial number: 3526KSME661E1D1DZZZ2
   Serial number: 3556LSME5D60451CZZZ/
   Serial number: 3566LSME33583E1CZZZ1
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120701300178
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA02644DD722282E46-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
Address 17: Instruments
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 13071203290518
   Coding: 461000
   VCID: 41D89AB4E18A8662C0E-8014
   Component: IMMO          H07 0705
   Coding: 000007
   VCID: 6A8A1D18BCFCA53A314-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000142955004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW41.rod
   VCID: 2F3CCC0C479E001226A-807A
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662885822
   Coding: 010100
   VCID: 2A0ADD187CFC653AF14-807E
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000030094038
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 609E7F304A40EF6AEF0-8034
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H02 3696
   Revision: AB001001    Serial number: VWZ6Z7M7189007
   Coding: 04090042010000A6000B
   VCID: 270C242C6FEE5852EEA-8072
                    Reset counter: 51
                    Mileage: 232544 km
                    Fault Status: 00100111
                    Reset counter: 91
                    Mileage: 251243 km
                    Date: 2038.14.12
                    Time: 13:09:12
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0005086058
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C660BC026288B8A738-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [00001001] - Electrical Failure
                    Fault Frequency: 18
                    Reset counter: 121
                    Mileage: 232551 km
                    Date: 2097.14.23
                    Time: 15:18:27
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 223
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 372CF46CB34EC8D27EA-8062
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0007730 Dataset Number: 560050v____ 5604
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   VCID: 65906E2455E28A421C6-8030
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 01030108
   VCID: 6FBC0C0C879E401266A-803A
   Serial number: 53388786011212002500
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0005132311
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D6006C43D328282846-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 223
                    Reset counter: 51
                    Mileage: 232544 km
                    Reset counter: 91
                    Mileage: 251243 km
                    Date: 2038.14.12
                    Time: 13:09:12
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662924762 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VW25.rod
   VCID: 3A2AED588CDCD5BA814-806E
End----------(Elapsed Time: 01:36, VBatt start/end: 14.1V/14.2V)-----------
------------------------------13 Faults Found------------------------------
                Address 01: Engine  (03L 997 009 J)
12:22:43
  IDE00427   Particle filter: difference pressure 9 hPa
  IDE00433   Particle filter: oil ash volume 0.00 l
  IDE00434   Particle filter: soot mass calculated 5.88 g
  IDE00435   Particle filter: soot mass measured 6.54 g
12:22:50
12:22:54
12:23:17
  IDE00434   Particle filter: soot mass calculated 5.89 g
Dr Sheldon
Windsor UK
C?ID=334979
Really !!
Do you expect that someone will read and absorb that text in one go ?? It is a block of text !! Garbage !!
KIrwan10
C?ID=609540
Main concern, did I mess something up with resetting learned values of DPF, if I did, is there a way to add some kind of value into the computer so it believes the ash volume is somewhat relating to the mileage?
Your ECU has an Adaptation channel:
IDE00275 -- Particle filter initialization (Tkm)
This is actually meant for cases where the ECU is replaced, so that the replacement ECU knows how many miles are on the DPF, but that's pretty much what you need here.
Note that the units (Tkm) are thousands of km. So for ~100,000 miles, you'd put in 160. For ~120,000 miles you'd put in 200. For ~200,000 miles you'd put in 320. If it were mine, I'd put in something a bit less than the actual mileage.
But no matter how you slice it, at almost 200,000 miles your DPF is pretty well done. Rather than replacing it, consider giving it a good cleaning..?
Meh. It's properly capitalized and punctuated, and even split into paragraphs. No harder to read than a book.
KIrwan10
C?ID=609540
Thank you very much for that information, I do have some cleaner that I ordered and will give that a try also.
Once again much appreciated,
Matt
KIrwan10
C?ID=609540
Matt
I was able to find this screen, however it is asking for a security access code, is that a common code or is that something I would have to find elsewhere? I have heard 27971 for particle filter initialization is a common code. Any advice would be appreciated.
Dr Sheldon
Windsor UK
C?ID=334979
Is it better to not describe the situation that led to my question then? I could just say "car no work" if thats better
Perhaps a line space between paragraphs would help - Some white on the screen to help the black text stand out.
Sorry but that hurt my eyes !!
KIrwan10
C?ID=609540
Wasn't my intention to post excessive information, for the last 11 years I have had to deal with people giving the most basic requests that have no substance, in which case I have to ask a million questions, so I figured I would try my best to avoid those questions having to be asked is all.
I am aware I can go a little overboard at times
Dr Sheldon
Windsor UK
C?ID=334979
The content is not the issue
Just some more white ! Blank lines between paragraphs would make it easier for me.
Dr Sheldon
Windsor UK
C?ID=334979
Have you tried a Chemical Clean of the DPF yet ?
And with what product ?
KIrwan10
C?ID=609540
A few months back I did, just did about an hour ago also. "power motor care" foaming cleaner smells alot like oven cleaner. We will see how it goes this week
Dr Sheldon
Windsor UK
C?ID=334979
Not that easy.
When doing a DPF Clean you really do need to be monitoring Pressures and Temperatures, first to confirm the sensors are working and accurate. Then to confirm the thing is getting clean.
Then the Pressure Sensor pipes need to be checked and blown through (before and after) and confirmed to be intact.
And also free of leaks.
KIrwan10
C?ID=609540
Not that easy.
Trust me I know it's not as simple as spraying a cleaner in there and calling it done.
I have blown compressed air into those two hoses for the differential pressure sensor, I have checked it for leaks, more than once.
I have cleaned every sensor I can think of that I can access without dislocating my joints lol.
I have also been monitoring this vehicle since 50K when I bought it with oil tests at every oil change so you could say I am a little obsessed with making sure it functions properly. Probably unhealthy on my part but a good thing for the vehicle.
My main worry is why my oil ash volume reads 0 when I know that is pretty much impossible with the mileage.
KIrwan10
C?ID=609540
I need you guys to trust me when I say I am not a dummy when it comes to figuring out how systems work, I just don't want to screw with any kind of settings or functions that I haven't learned about yet
Dr Sheldon
Windsor UK
C?ID=334979
That will / should change and become accurate in short time.
How sure are you that the Pressure sensor is good and accurate ?
Where from ?? I test them with a MityVAC.
Dont matter - Every one does that !!
It will re learn.
That there is your starting Point - That is just plain Wrong !!
Dr Sheldon
Windsor UK
C?ID=334979
How do you know ?
You dont yet know what you dont know !!
