Tiguan cluster on Golf 6 2011 TDI — Manual/Electronic Handbrake light Problem
Zagor
Italy
C?ID=96696
Hello everyone. I am asking for help from the more experienced: on a golf 6 I mounted a cluster with MFA Plus Color 3D taken from Tiguan (5N0 920 883 G). No immo problems, everything works as it should, except the handbrake. Using VAG Dash Editor V7.3 I changed the setting from electronic handbrake (Tiguan) to mechanical handbrake (Golf 6), but the handbrake light still remains on. I know that on Tiguan the brake signal is positive, while on Golf 6 it is negative, but I don't know if it is a simple impulse or a voltage that is always present or always absent depending on whether the brake is engaged or not. Can anyone help me please? Thanks
Edit.. I'll answer myself: it is necessary to move a resistor and add another one
Fredrick Awuor
Kenya
C?ID=309834
you have to modify the cluster pcb, I cannot remember how i did mine in 2020, but my good friend @dnoermann can help you
Zagor
Italy
C?ID=96696
Thanks a lot bro, but I already solved the problem a few days ago. I was just about to post the solution. Here it is
