Golf 7 Changing Rear Pads
We have done more MQB rear pads with VCDS than I can remember, one of my techs went to do a set today and came to me saying he could not get it to work, some odd three digit code message. I thought he was just being a dingleberry so went and had a look and yes, he was right. I tried a different PC and the same result. I tried guessing a code and it did not like it so I put ODIS on and it works fine therefore I am stumped. I had to take a picture of the message as I can't get paint to work on this PC. I put ODIS on and it worked perfectly as normal, any suggestions?
Full car scan
Friday,07,March,2025,11:38:13:32095
VCDS Version: 25.2.0.0 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250210 DS364.0
Dealer/Shop Name: C&R Enterprises
Workshop Code: 210 01523 000004
VIN: WVWZZZAUZGW086315
License Plate:
Mileage: 115980km-72066mi
Repair Order: ORD22828
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1541
   Revision: B5H21---    CVN: B4EC2C4A
   Coding: 011D0012036505083000
   ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
   ROD: EV_ECM20TDI01104L906026BS_002.rod
   VCID: 7CAA9F60F66CB21AD7B-8028
   VINID: 9E69EAAAA465A979C02060C1149F1F3A98
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01507171142 CVN: 00004833
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1088EC073A0902929-804A
   Revision: 00000000    Serial number: 62015000002047
   Coding: 01FA8AA134280972077A060141C82980512C90E0608294F518625078C209
   VCID: 7AA69978FC588C2AC57-802E
   Revision: 00021000    Serial number: 0375588776 Dataset Number: V03935197YW 0001
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A265978BCD84C2A857-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120104202400011005000200101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A86A9388CF83CAA357-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061521500749 Dataset Number: V03935222AW 0001
   Coding: 03011A66C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0944F6B4A9BE97B2DCD-805C
   Component: WWS    150718  042 0551
   Serial number:         150722034052
   Component: RLHS  037 0059
   Serial number: S2Y15M08D06H08M56S53
   Coding: 90A8EE
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151883D7P
   Serial number: 00000000000063250237
   Revision: --------    Serial number: 39331521102402 Dataset Number: 5G0039v__A_ 0023
   Coding: 0071151011
   VCID: 43D8249CCB120DE2D61-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 09071503270237 Dataset Number: 5g0114v____ 1027
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR0ZHHX3 Dataset Number: 5G0003v____ 0094
   VCID: 7F50686CE77AA902F29-802A
   Left seat belt tensioner:
   Serial number: 34169677B04081540742
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B04081570570
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 607 15
   Serial number: 3576700000016D95B51-
   Subsystem 4 - Part No SW: -----------    HW: 480 002 607 15
   Serial number: 35867000000DC82DB518
   Subsystem 5 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 3516502C91C2F0349238
   Subsystem 6 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 3526502B51C2F03471DB
   Subsystem 7 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 3556502C51B7E8E3C15X
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 04081504400266
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_017.rod
   Part No SW: 5G1 920 957 A    HW: 5G1 920 957 A
   Component: KOMBI         302 6420
   Coding: 27AD09182F80260001886A011400000000000000
   VCID: 2E0E65287090908A29F-807A
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003811477 Dataset Number: 5G0067V____ 2215
   Coding: 030100041F087300FB00027E1C0F00010001050000000000000000000000
   GVL: 01543C1000000600400C90000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 75BC8A44D546E352A85-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001533920065312
   Coding: 2DFFFF
   Serial number: 6287297303
   Revision: 00000000    Serial number: 15000176694001
   Coding: 5D00000000000000
   VCID: 343A77409EBCBA5A5FB-8060
   Serial number: 210715BGL07354 Dataset Number: 5G0222v____ 0064
   Coding: 003F1220D001048000001000
   Serial number: 00000000000007018964
   Coding: 0D0000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 5G0074v____ 0980
   Coding: 8103
   VCID: 3720404C8FCA51427A9-8062
   Serial number: 220715BGL14651 Dataset Number: 5G0157v____ 0060
   Coding: 003F1020DE01048000801000
   VCID: 42D62198D40804EADD7-8016
   Serial number: 00000000000006765501
   Coding: 150000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0001
   Coding: 029E01000B010200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D22B90DA0416FACB3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3G0 035 020 B    HW: 3G0 035 020
   Component: MU-H-ND-EU    H42 0317
   Serial number: A598G0F7512255 Dataset Number: V03935223SB 0001
   Coding: 02730001FF00000051111101008808031F0202D601200100DF
   VCID: 167EADC8E800484A41F-8042
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU302TFE
   Subsystem 2 - Part No SW: V03 959 800 QM    HW: -----------
   Component: ECE 2015/2016  --- 0123
   Compact disc data bank:
   Component: Gracenote2  --- 1011
   Component: SAS-GEN 2     H06 0014
   Serial number: 150619203050
   VCID: 6B88AC3C830225A24E1-803E
End----(Elapsed Time: 01:47, VBatt start/end: 11.7V/11.8V. VIgn 11.9V)-----
---------------------------No fault code found.----------------------------
Known problem. Several threads about it already.
E.g:
Please update to the latest 25.3 Data Version 20250301 / DS365.
Thankyou. Do you have any idea why the update bar in settings won't work? I depend on the auto update notifications
My bad. I bet you have it set to Beta, and I hadn't updated the Beta entries on the server.
Note that it can take up to 24h for VCDS to see an update is available, so I suggest updating manually if you haven't already.
NEtech
Denmark
C?ID=56995
Did you try to enter 00 or 01 ?
Yes, rejected.
