IDE04555-Activation of pwr steering asst without engine running
racofuy
New Zealand
C?ID=197081
Curious about the above adaptation, I can enter security access and activate this (power steering works with engine off) but it defaults back to not active after a key cycle. No way to make this a permanent change?
(A 2019 GTI I had for a while had power steering with the engine off, hence the idea)
Reason being is that I use my stop start by turning the steering wheel a little,
My Auto Hold is always on so releasing the brake does not start the engine and pressing the accelerator gives an annoying jolt as you move off.
My previous car (16, MK7 wagon 1.4) you could turn the steering very small amount and the engine would start, this car 17, 7.5 Wagon 1.4 it takes 1/4 turn almost and without power steering that doesn't work very well.
Do we have an Auto-Scan from this car?
racofuy
New Zealand
C?ID=197081
Here's one from last month.
Monday,10,February,2025,08:56:52:54382
Dealer/Shop Name:
VIN: WVWZZZAUZJP525286   License Plate:
Mileage: 29901km-18579mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 29 2B 39 3C 42 44 47
          4B 52 57 5F A5 D6 D7
VIN: WVWZZZAUZJP525286   Mileage: 29901km-18579miles
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CG    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H13 9191
   Revision: WAH13---    CVN: DD863503
   Coding: 01250032236405083000
   Shop #: WSC 00028 028 00081
   ASAM Dataset: EV_ECM14TFS01104E906016CG 002007
   ROD: EV_ECM14TFS01104E906016CG.rod
   VCID: 698FB82439F4A4A2E85-803C
   VINID: 9E69EAAAA465A9A80508508818580ED3D3
17158 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:55
                    Engine RPM: 0.00 /min
                    Coolant temperature: 39 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.086 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 1
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
Readiness: 1110 0001
   Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1006
   Revision: 00005026    Serial number: CU501707195164 CVN: 1265A98F
   Shop #: WSC 00028 028 00066
   ROD: EV_TCMDQ200021.rod
   VCID: 343119502EB6294A8B3-8060
   Revision: 00000000    Serial number: 62157000000420
   Coding: 04FA8AA1242221714779060880C92920512484E260019473382250B9C2A2430000000012121212B835351919323200
   VCID: 77ABEE5C7F4002526E1-8022
8331 - Databus
          U1121 00 [10001001] - Missing Message
          [FCAN: Quersperre_03 message is not received]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:41
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0450665403 Dataset Number: V03935252RF 0001
   Coding: 032C0C
   VCID: 3C21317006E6E10A433-8068
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0212000410010001110500001010102A
   VCID: 6C81C1303606B18A933-8038
   Air quality sensor:
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865825071701T1 Dataset Number: V03935265FF 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B43A2AC13C816B23A9-805E
   Component: WWS    170713  042 0551
   Serial number:         170801074435
   Component: RLHS  042 0105
   Serial number: S4Y17M08D14H14M13S27
   Coding: 31E8DD
   Humidity sensor: interior:
65802 - Rear Left Ride-Height Sensor
          C1036 15 [00001001] - Open or Short to Plus
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:37
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.3 V
                    Outside temperature: 24.0 °C
65800 - Rear Left Ride-Height Sensor
          C1036 29 [00001001] - Signal Implausible
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.3 V
65806 - Rear Left Ride-Height Sensor
          C1036 04 [00001001] - Internal System Fault
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.3 V
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617126 Dataset Number: V03935256VM 0001
   Coding: 0371167051
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50F975C0BA6E756A8FB-8004
13637426 - Databus
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935259QS 0001
   Coding: 330007C159FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E253B7810FAF31A6D7-806A
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 12.1 V
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
0928 - Databus
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
   Serial number: 16021841350940 Dataset Number: V03935399NL 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292D6032DECD2AA7B-806C
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Component: AirbagVW21    005 0336
   Serial number: 003VXR360NKH Dataset Number: V03935259SL 0001
   Coding: 98FCC0C0000000005C5400CF008800000065
   Shop #: WSC 00028 028 00057
   VCID: 0A4DA7A81CB20FBA01F-805E
   Left seat belt tensioner:
   Serial number: 34169677E07081741575
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E08081751304
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 357000000002553C652C
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35800000000217945629
   Subsystem 5 - Part No SW: -----------    HW: 480 400 308 17
   Serial number: 3510001C7269FFA3083E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 308 17
   Serial number: 35200019D26441E3531X
   Subsystem 7 - Part No SW: -----------    HW: 480 400 408 17
   Serial number: 3550001A12711E34B41U
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170804200093
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3DA4C6B386E72529-8026
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 27A459187F88000E02886B0B5401000080000000
   VCID: 2A0D0728FC726FBA21F-807E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 28071710520751 Dataset Number: V03935266ZJ 0001
   Coding: 030100047F085700FB00025E9C0F00010001070000000000000000000000
   GVL: 01563C000000060040CC80000000CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 33331A4C2BB82E72929-8066
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170001573480107295
   Coding: 2DFFFF
   Serial number: 0585834704
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CB5E9C4F20B2D2DE1-8012
   Revision: 00000000    Serial number: 17000206322009
   Coding: 5D00000000000000
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0080
   Serial number: 0449804213 Dataset Number: V03935260LG 0001
   Coding: 02011203
   Shop #: WSC 02345 003 104857
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273C741DFCE80274D-8068
   Component: HRE_Slave  H12 0080
   Serial number: 0449744698
   Coding: 020112
   Serial number: 0000270320359  Dataset Number: V03935257PY 0001
   Coding: 003F1320D001028000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Serial number: 00000000000006656783
   Coding: 0D0000
   Dataset Number: V03935259RW 0001
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D37680CD2DF3A51F-806E
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1LMD07HY31 Dataset Number: V03935259RT 0001
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001004
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 2E050B38C09A039AFD7-807A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 31071710800456 Dataset Number: V03935259VB 0001
   Coding: 000000050100194E07204F01020000000000000000000000000000000000
   VCID: 72BDDF481422677A59F-8026
   Serial number: 0000266495183  Dataset Number: V03935267WU 0001
   Coding: 003F1120DE01028000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 46D55398482AABDA257-8012
   Serial number: 00000000000006734884
   Coding: 050000
Address 57: TV Tuner (R78)       Labels:| 8V0-919-DTV-V1.clb
   Part No SW: 8V0 919 129 F    HW: 8V0 919 129 D
   Component: JP-DTV        H12 2110
   Coding: 02041C0000000100000002
   ASAM Dataset: EV_TVMELC 001039
   ROD: EV_TVMELC_VW37.rod
   VCID: 43D34A8C7B189EF2029-8016
   Part No SW: 5NA 035 050 D    HW: 5NA 035 050
   Component: MU-H-N-EU053 1367
   Serial number: K5F AW7U80O4MI Dataset Number: V03935262VW 0001
   Coding: 027312080000000051110002001838001F0106F601200400FE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   VCID: 3537245425CC3042BCD-8060
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2060393
   Subsystem 2 - Part No SW: V03 959 821 CN    HW: -----------
   Component: ROW 2024/2025  --- 0373
   Compact disc data bank:
   Component: Gracenote2  --- 1017
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 27071712K11732 Dataset Number: V03935265PP 0001
   Coding: 000307020000050100022354C150A90084000E300040
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    Control Module temperature: 28 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 62.5 s
                    Voltage terminal 15: 12.2 V
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
          [APS_03_US_Fehler_VS]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 248
                    Mileage: 29901 km
                    Date: 2025.02.10
                    Time: 08:35:38
                    System run time: 61.7 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F286409D4D422585-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:08, VBatt start/end: 12.3V/12.2V)-----------
Quote ReplyReport
racofuy
New Zealand
C?ID=197081
Anyone have any thoughts on this?
Looking at the data for that steering rack, I don't see anything obvious.
I'm also a bit surprised that the contents of an Adaptation channel would revert after an ignition cycle.
In an case, it seems like you've found yet another reason why people generally despise start/stop. ;)
racofuy
New Zealand
C?ID=197081
Well this setting definitely didn't do what I expected, tried setting to active with the engine running which worked but while driving the steering felt super super light.
Very weird feeling, once stop start was activated it reverted back to not active and steering felt normal again.
The search for a solution continues.
