VW Golf Mk7 Towbar electrics
RHG
C?ID=547843
Hi all,
I am fairly new to all this coding and I know there are lots of topics on towbar electrics, so I am sorry for yet another one but every case seems different and needs the individual code...hence why I'm here.
So I've installed an aftermarket wiring kit from ECS where I had the battery disconnected for well over a day, just in case that is a cause for some of the faults.
As for VCDS, I'm currently running version 23.11.0 (don't know if that will make any difference, but I've heard there are issues with the update) but I've entered [19-CAN Gateway], [Installation list], checked the [69-Trailer] box and clicked [write coding]. Now I am unsure what to change next and I have run an auto scan and cleared all DTC's which is the following:
Thursday,06,March,2025,12:03:36:47103
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
VIN: WVWZZZAUZHP542486   License Plate: J28 RHG
Mileage: 154658km-96100mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 A9
VIN: WVWZZZAUZHP542486   Mileage: 154658km-96100miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BR    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 7724
   Revision: B5H23---    CVN: 0ABAE3D2
   Coding: 01190012034505083000
   Shop #: WSC 25242 005 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026BR 004006
   ROD: EV_ECM20TDI01104L906026BR_004.rod
   VCID: 7BA3E5F1B36E1F227A1-802E
   VINID: 9E69EAAAA465A9880510210818BD8F9A8C
17156 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 154658 km
                    Date: 2025.03.06
                    Time: 11:59:52
                    Engine RPM: 816.50 /min
                    Normed load value: 37.3 %
                    Coolant temperature: 38 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.800 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 62556000003346
   Coding: 04FA8AA13424096E477B060841C92920512C90E26082947514605078C00903
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 74B1CECD9E30505A3BB-8020
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0417697625 Dataset Number: 5G2IJ1v____ 0006
   Coding: 032C0C
   Shop #: WSC 00028 028 00068
   VCID: 3B2325F1F3EEDF223A1-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 02120104202110011005000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 72BDC8D5E4245E6A297-8026
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 8658300916022L Dataset Number: 5G9063v____ 0001
   Coding: 03010A46C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03539D11CB9E67E2321-8056
   Component: WWS    160903  042 0551
   Serial number:         160913194618
   Component: RLHS  042 0105
   Serial number: S4Y16M10D04H06M02S10
   Coding: 00A8DD
   Serial number: 000000000ZY162352QTC
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000067073868
   Humidity sensor: interior:
   Revision: --------    Serial number: 39331626412659 Dataset Number: V03935236FM 0001
   Coding: 0071051001
   VCID: 43D35D118B1EA7E2721-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: V03935239PQ 0001
   Coding: 2D00408151FFC428949C8045000006
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
1229 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_CODING_AAG]
                    Reset counter: 209
                    Mileage: 154658 km
                    Date: 2025.03.06
                    Time: 11:59:50
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 14.6 V
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR24T1E. Dataset Number: 5G0003V____ 0112
   Shop #: WSC 00028 028 00062
   VCID: 7F5B11E1A7760302569-802A
   Left seat belt tensioner:
   Serial number: 34169677D22091650657
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676D22091641092
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 309 16
   Serial number: 35767000000BE35C9F1C
   Subsystem 4 - Part No SW: -----------    HW: 480 002 309 16
   Serial number: 3586700000043320BE1O
   Subsystem 5 - Part No SW: -----------    HW: 480 401 709 16
   Serial number: 3516502B321A3723020N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3526502A921A372321B+
   Subsystem 7 - Part No SW: -----------    HW: 480 402 708 16
   Serial number: 35565029B215E1D412DG
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160708500905
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04519E0DCE9060DA0BB-8050
   Part No SW: 5G1 920 957 B    HW: 5G1 920 957 B
   Component: KOMBI         304 8311
   Coding: 27AD11102F80260001886B011400000000000000
   VCID: 2F3B01A137963382869-807A
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 23091610520577 Dataset Number: V03935242HR 0001
   Coding: 030100041F086800FB00027E080F00010001050000000000000000000000
   GVL: 01543C1000000600C00C90000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1E6EDB660181A73B-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160001853650096381
   Coding: 2CFFFF
   Serial number: 0874621304
   Revision: 00000000    Serial number: 16000159215005
   Coding: 5500000000000000
   Shop #: WSC 00028 028 00244
   VCID: 34310ECDDEB0105AFBB-8060
   Component: TSG FS        010 0031
   Serial number: 0000219361370  Dataset Number: V03935248ZF 0001
   Coding: 003F1220D001028000001000
   Shop #: WSC 00028 028 00226
   VCID: 47CB4901BF268BC2AE9-8012
   Serial number: 00000000000004576208
   Coding: 0D0000
   Dataset Number: V03935249RP 0001
   Coding: 8107
   Shop #: WSC 00028 028 00208
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D20F5FCD4E62A217-806E
   Component: TSG BFS       010 0031
   Serial number: 0000218917707  Dataset Number: V03935249AJ 0001
   Coding: 003F1020DE01028000801000
   VCID: 46D54405B82C92CA55F-8012
   Serial number: 00000000000004623532
   Coding: 050000
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0021
   Coding: 069E01000B000200
   VCID: 40D9521D9A08BCFA6F3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    H30 0359
   Serial number: VWZAZ2S0527837 Dataset Number: V03935247LK 0001
   Coding: 02730201FF00000051110101008808001F0202C601200100CF
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 313F07D921A2257290D-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H50 4065
   Serial number: VWZ6Z9S2740301
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789123456 Dataset Number: v12400160G0 0016
   Coding: 0100000202000000
   Component: SAS-GEN 2     H06 0014
   Serial number: 160830202342
   VCID: 6B83D5B1C30E8FA2EA1-803E
End----------(Elapsed Time: 01:37, VBatt start/end: 14.7V/14.7V)-----------
Any help with proceeding with this would be greatly appreciated. Thanks
Address 13: Auto Dist. Reg -> Byte 3, Bit 3 "Control Module for Trailer Recognition installed"
Nothing else indicating that it's upset with your retrofit.
RHG
C?ID=547843
Thank you @Uwe, that has solved that problem.
However, I've just checked and some of the features that are meant to occur when towing such as disabling the rear sensors when reversing with a trailer, showing a trailer on the display and disabling the rear fog lights are not functioning...is there more coding to enable these features?
10-Park/Steer Assist -- Byte 3, Bits 0-1.
downtime
Finland
C?ID=280813
Also you may want to enable ABS adaptation "Trailer Stabilization", and code trailer to 01 engine.
RHG
C?ID=547843
Thank you again for your help @Uwe and @downtime.
The instructions I had with the electrics had instructions for ODIS so I've also looked at them to try and make sense of it. (instructions in quoted section)
After connecting to ODIS, the “69 trailer function” controller has to be set to encoded in the target installation list.
Activated in 19-CAN gateway installation list
The following may be necessary in the further course of work:EZE_09 (electronic central electric controller): Diagnosis (possible login code: 31347) Networking plan Controller self-diagnosis Encode Trailer connection device ›installed or: hitch_ecu ›installed. Alternative encoding EZE_09as follows (MY 2017 >>): Self diagnose control unit Access authorization ›31347 Adjustment Integration Trailer control unit > installed
Unable to find anything matching the description above - not sure what function this provides and if vital?
ZKS_46 (Central module convenience system) trailer monitoring ›put on active trailer control unit ›installed
SWA_3C (Lane Change Assist) ECU for draw bar ›with ECU for draw bar
SW2_CF (Lane Change Assist2) ECU for draw bar ›with ECU for draw bar
Don't believe I have any of these modules
SCH_17 (Dash panel insert) Trailer ›yes
In 17 - Instruments - Byte 15, Bit 0 Towing_capacity_display activated. I have also activated Byte 12, Bit 5 Trailer manoeuvring assistant (only because it mentions trailer and I thought I'd activate it to see what happens)
RFK_6C (reverse camera system) equipment_ahk ›installed
STF_74 (chassis control system) Trailer ›installed
EPH_76 (PDC controller) Trailer ›trailer device can be removed manually
DIS_13 (controller distance control (possible login code: 20103) Control module for towing sens ›installed. Alternative encoding DIS_13 as follows: Self diagnose control unit Access authorization ›20103 Encoding Binary encoding Byte 3 Binary ›xxxx1xxx or Hex ›+8
I believe this has been done from Uwe's comment earlier 13: Auto Dist. Reg - Byte 3, Bit 3 Control Module for Trailer Recognition installed
FFF_A5 (front sensor system controller) AAG ›coded
HDE_6D (boot lid electronics controller) Trailer ›installed
I don't believe I have either of these modules.
Other modules I have looked at after your previous comments include:
01 - Engine - Byte 5, Bit 4 Trailer Recognition installed - activated
10 - Park/Steer Assist - Byte 3, Bit 0-1 "01 Trailer,Trailer hitch (manually removable)" - activated
Finally the ABS, I can't access to review any of the byte's as the module states "Only limited coding information is available for this control module"
That's probably not what you want. I think there's more to getting that assistant than just checking the bit.
Nordicduck
C?ID=571205
On my 22 plate Crafter I just followed the procedure in the instructions provided with the module from ECS, I do remember it mentioning ODIS rather than Ross Tech but all the module numbers and adaptation channel names were the same.
It was so hassle free that I don't really remember doing it now, that said, looking at my scan history I see that I made changes to 10,13,19 and added 69 to the list.
I know in my case it disables the park assist and rear sensors (and probably other things) when I have a trailer connected, our vehicles are different so you may need to make changes to more or less modules than I did but you get the idea why just adding 69 to the list won't cut it. I don't wish to seem unhelpful but all the info I needed was provided in the instructions.
Tor.
Warren333
Hull, UK
C?ID=604450
Probably of no use to you, but below is what I had to do for my mk5 Caddy. I had no instructions for coding. Just read forums.
My big lesson was DONT tick everything that mentions trailer!
19-installation 69
69-Trailer changed byte 0 from 02 to 01 (country swap from US to rest of world). Also confirmed some pin settings for trailer power supply ( nothing needed to change)
01-Engine Byte5 ticked bit 4 Trailer recognition installed
03-ABS Did nothing. I know others have gone into adaptation and ticked something IDE04774 Vehicle trailer stabilisation. It wouldn't let me change it.
09-Central electrics I did nothing, but again I have read in other forums ENG122979-ENG141968 Networking Anhaenger Not installed to installed but security access denied me from doing that.
10-Park steet assist Byte 3 Bit 00 to 01 Trailer hitch manually removable
13-Auto dist reg Byte 1 bit 7.
This is where I lost days of my life; in 13 (the byte and bit numbers will be different for you I guess), I originally had byte 2 bit 2 ticked and not byte 1 bit 7. The former was TRAILER ASSISTANT. Later this would give me errors including the loss of ACC
U1014 00 [10101111] - -
[FAULT_CODING_AAG]
Fault Found:
0730 - Databus
U1121 00 [00101111] - Missing Message
[FAULT_TIMEOUT_ARA_STATUS_01]
@Uwe corrected me me and said add byte 1 bit 7. That got rid of the engine warning light, the above fault (which is an abbreviation of a German word), but I still didn’t have the functionality of ACC.
Additionally I still had the 0730 fault
@NEtech that pointed out to remove byte 2 but 2 as I didn't have AGA (another abbreviated German word for trailer assistant )
Problem solved. Don’t get carried away ticking like I did.
Apendiixator
Czech Republic
C?ID=569308
Hello RHG, From your unit scan, I understand it this way: After your installation of a non-original trailer installation that connects to the CAN BUS, the engine light is currently on in the cluster and the distance control is still malfunctioning. Plus text information about the unavailability of various assistants. I have been dealing with the installation of towbar devices for many years. Unfortunately, I have not yet encountered a case similar to yours that would make this installation work in the long term. If you want to put the trailer unit assembly into operation, contact the dealer from whom you bought it. This dealer should have his own device in which the SW for the function to be put into operation is continuously loaded. The aftermarket unit that you bought is illegal (although the dealer claims the opposite). Using the device for activation is the only way to your "success". Why the quotation marks? If you are lucky, the device will work correctly. It is possible that occasional assistant failures will continue. In any case, be prepared for the fact that when you visit a VW service (for example, to carry out some quality improvement measures), everything will return to the state you currently see on your car.
If someone wants a towing device and does not want to invest such a high amount for an original installation, there are other ways. But again with any compromise.
Apendiixator
Czech Republic
C?ID=569308
The vehicle manufacturer invests a lot of money in the development of such devices as a towbar unit and cars. The intention is understandable: Only VW decides on the retrofit. VCDS probably cannot go against this VW philosophy. So if you find out what needs to be changed in all units, VCDS will do it. But I'm sure you won't find out.
downtime
Finland
C?ID=280813
What the heck are you talking about? Retrofitting original VW towbar and electronics is 100% doable. Even with VCDS.
downtime
Finland
C?ID=280813
I agree with you completely. But the questioner is not installing the original electronics.
Aftermarket wiring kit
The module is original. And in this case I presume the aftermarket wiring kit means OEM comparable wiring.
Apendiixator
Czech Republic
C?ID=569308
Let's clarify the terms. Original towbar unit = such a spare part that comes exclusively from VW AG. Everything else is NOT original (aftermarket)
I think it's up to the questioner to give a relevant answer about the origin of what is now connected to the Gateway.
But if this unit is really from the original VW AG production, I recommend online adaptation via ODIS. This will result in the correct setting of all units, but above all, the PR equipment will be recorded on a remote server. And in this case, there will never be a problem with SVM in the future. I believe that this recording can never be achieved through VCDS
downtime
Finland
C?ID=280813
Yes I agree with you, online SVM IF possible would be the best thing to do as it will then also record the PR code to factory database, and this way it keeps the coding if the car goes in to official maintenance work.
Thing is though that the OP has received the instructions what needs to be enabled or disabled to fix the only coding issue with ACC. Now I think we are just overly complicating the thread with something that is not relevant in this case.
I would like to hear from OP that is there still a problem or not? And if yes, what problems?
