What are the best ignition coils
   #21
Sure I will check, but we need your VIN.
Folks here on the forum with Partslink 24 may also chime in.
Yes, genuine plugs are also a good idea.
You can enter your VIN on the web-site of either of those and see what comes up; the ignition coils are a very good price!
I'll check and email my local dealer and see what they come up with.
   #24
DrPeter
16.4905° S, 151.7375° W
Hi there....
Option #1 = Yes (that is the newest part number, it looks like the old part numbers where superseded at least two times!)
Option #2 = No (only fits 2019 ~ 2023 A6, A7, A8, Q3, Q5, Q7, Q8, etc)
And Yes, genuine Audi spark plugs are recommended.
One thing to remember, these vehicles were designed and built to use these specific parts, so it only makes sense to use original Audi/Volkswagen parts.
One day access to www.PartsLink24.com is $12.00
We also recommend to use the Official Factory Repair Information
The erWin website subscription is also inexpensive at $35.00 for 24 hour access!
Hope this helps,
drpeter
   #25
Elliotte58
California, USA
C?ID=608416
Okay thank you, unfortunately I already pulled the trigger on the order for number two option, I entered my VIN number on their website so it's really irritating that it's ended up being the wrong one, I requested a change hopefully they can update that before it ships out.
   #26
DrPeter
Hi, you may want to call them and see what they say, as part numbers from www.PartsLink24.com are deemed reliable, but Not guaranteed.
Hope this helps and let us know what you find out!
drpeter
Elliotte58
California, USA
C?ID=608416
ok, new coils and plugs are installed. I hate to admit this but I feel I owe it to the channel. I inspected the coils that I replaced and to my surprise I had 3 different part numbers on the 4 ignition coils. I trusted way too much when buying from the local box stores. I feel like a fool and I am upset that I have wasted money. I am however very greatful for the advise that came from this forum. Thank you for those how chimed in. I am guessing that I will not be able to return the garbage ignition coils so I will call this the cost of my lesson.
   #29
Elliotte58
California, USA
C?ID=608416
I have restored all my parts to Audi factory.
Upstream o2 (old part)
Downstream 02 (old part)
Map Sensor (old part)
Ignition coils (new)
Spark plugs (new)
I got my first fault since going back to non shit parts.
Thursday,20,March,2025,14:59:36:06734
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WAUF8AFC8HN046746   License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 42 44 46 52 53 55 5F 62
          6C 72 8F 90 47
VIN: WAUF8AFC8HN046746   Mileage: 126312km-78486miles
Address 01: Engine (J623-CYNB)       Labels:. 06L-907-115-V1.clb
   Part No SW: 4G5 907 115 C    HW: 8T2 907 115
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: F7341EBC
   Coding: 0A2A00322426010E2002
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0204G5907115C 001001
   ROD: EV_ECM20TFS0204G5907115C.rod
   VCID: 2A0ADD3F1C7E8DBAF13-807E
   VINID: 9D19562115932187801061C418B86C3D8E
26363 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [11101101] - Implausible Signal
                    Mileage: 126311 km
                    Date: 2025.03.20
                    Time: 12:01:31
                    Engine speed: 0.00 /min
                    Coolant temperature: 72  C
                    Intake air temperature: 45  C
                    Voltage terminal 30: 12.167 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 15 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.846 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 9520.0 kPa
   Part No SW: 4G0 927 158 BG    HW: 0BK 927 156 AM
   Component: 0BK 20TFSIUSA H19 1010
   Revision: --H19---    CVN: B391D0B6
   VCID: 74B603478E3A8B4A9BF-8020
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 41A7964182E569821B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41D89A9381086EE2C09-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0825
   Coding: 0DA86F4E000000000000
   VCID: 005E5F97CA02A7EA8F7-8054
   Serial number: 3216000175637013
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BP    HW: 4G0 820 043 BP
   Component: KLIMA 2 ZONEN H14 0113
   Serial number: 06091600110542
   Coding: 64813018C90000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 6E82112FE016A19A6DB-803A
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 21020001    Serial number: 00001469269802
   Coding: 01850019013C9FE08101488380003800CF9CD208A608022100000414F110150200600034030000
   VCID: 79A83273A9D8F622C89-802C
   Component: WWS57X 160702  H38 0080
   Serial number:         160715071358
   Coding: 004DF7
   Serial number: 62240069
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 06 09 2016  00001343
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02713DE9
   Subsystem 5 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H01 0005
   Serial number: 3F29484800PAG0FSA002
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0003F7EF Dataset Number: 4G0909602N  0002
   Coding: 303331343134303334374A55304C34473053
   VCID: 3436C347CEBACB4A5BF-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y160001J5660B
   Serial number: 3575HRB405F45CG8COHP
   Serial number: 3585HRB405B45CG851BT
   Serial number: 3515JRB40065752IHA4K
   Serial number: 3525JRB400A5752I59KS
   Serial number: 3554VRB401257ACI8HHF
   Serial number: 3564VRB400457ACISGV7
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372PI4000L4
   Coding: 000434
   VCID: 382EF777D2522F2A777-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 20 05 2016  A0054880
   Part No SW: 4G8 920 987 T    HW: 4G8 920 987 T
   Component: TBenUsa       H14 0225
   Revision: 11001108    Serial number: 658030916596013
   Coding: 03EF09040B41D705020000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 4ACABDBFBC3EADBA113-801E
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002369598 Dataset Number: 4G0909515K  0022
   Coding: C0CD072910
   GVL: FD81C808DC20600D00040800
   VCID: 3D20E663FDF00A02A41-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 8896831104
   Voltage stabilizer:
   Serial number: 16062800000000000641
   Revision: AA000000    Serial number: 00000217982010
   VCID: 77AC344B9FCCE052BED-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720SY98$ Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3334C05BCBB4CC72425-8066
   Component: TSG FA        H03 0511
   Coding: 011F17014E00628002000002
   VCID: 47CC848BAFAC50D20ED-8012
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000242357 Dataset Number: 4G0909852L  0038
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2AED7FECDE3D3A813-806E
   Revision: 00002001    Serial number: 0416538796
   Coding: 0106063A00FA400583B0088402070E4F0000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000365400
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST0015VGZG00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00024446921
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 66033916
   Component: TSG BF        H03 0511
   VCID: 46D2898FA8A649DAF5B-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001959277 Dataset Number: 4G0909522F  0008
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3138CA5331A8FE62309-8064
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0018
   Coding: 04FA021122200400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 J    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   052 1426
   Serial number: A741I0G7514278 Dataset Number: 4G1909545H  0037
   Coding: 01750102FF0A000013220001041A00102F0006E5F17001047E
   VCID: 25102E037560A2C2DC1-8070
   Subsystem 1 - Part No SW: V03 959 803 AS    HW: -----------
   Component: NAR 2024/2025  --- 0376
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY8062EY
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PI6000DX
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 49C882B3B9B8A6A2189-801C
02123 - Door Warning Light / Entry Light
                    Fault Status: 01101100
                    Reset counter: 78
                    Mileage: 126247 km
                    Date: 2025.03.18
                    Time: 07:53:09
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Dataset Number: 4G0909460D  0013
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78AE37779252EF2AB77-802C
   Component: TSG HR        H03 0511
   Component: RGS-VL        H16 0080
   Dataset Number: 4G0909614C  0001
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H16 0080
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323AC55F34AEC57A493-8066
End----------(Elapsed Time: 02:11, VBatt start/end: 14.5V/14.5V)-----------
------------------------------2 Faults Found-------------------------------
   #30
Elliotte58
California, USA
C?ID=608416
          6C 72 8F 90 47
                    Mileage: 126311 km
                    Date: 2025.03.20
                    Time: 12:01:31
                    T_AST_SAE: 15 s
   Coding: 004DF7
   Coding: 02006D
   Coding: 000434
   Coding: C0CD072910
   Voltage stabilizer:
   ROD: EV_SARA2.rod
   Coding: 101F02
   Coding: E01E00
   Coding: E01E00
                    Reset counter: 78
                    Mileage: 126247 km
                    Date: 2025.03.18
                    Time: 07:53:09
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
   #31
DrPeter
The fault code P0236 will set when the Engine Control Module detects any of the following conditions:
- A difference between turbocharger boost pressure and manifold absolute pressure exceeding 75 mBar.​
- A difference between barometric pressure and turbocharger boost pressure exceeding 75 mBar.​
- A difference between barometric pressure and manifold absolute pressure exceeding 75 mBar.​
Inspect the G31 (Charge Air Pressure Sensor), V465 (Charge Air Pressure Actuator), boost pipe/hoses, clamps, intercooler, and all associated components for leaks, damage, or improper operation. Also verify there are no wiring or connection concerns too.
We recommend to use the Official Factory Repair Information when trying to diagnose and repair these vehicles.
Hope this helps,
drpeter
