2011 A8L D4 CDRA - Engine harness vs Squirrel
TheProj
C?ID=307152
So a squirrel(s) chewed through the engine wiring harness, had it towed to the mechanic and he replaced the engine wiring harness.
Prior the harness replacement had errors on the cluster like Auto Dist. Reg (pre-squirrel), Rear View Camera (pre-squirrel), Image Processing (pre-squirrel), Lane change (pre-squirrel), and EPC, that is gone however now I have a few new issues:
  1. Several component protections which the vehicle did not have any before
  2. Cent. Elect. (J519)
    1. AC Compressor Regulator Valve (N280). Which connects to J519 - Connector T17b - Pins 8 & 10.
    2. Solenoid Valve for Servotronic (N119) 02838 - 012 - Electrical Fault in Circuit
    3. Control Circuit for LED Module for DRL and Parking Light; Right (This one went away on a second scan)
  3. CAN Gateway (J533) 0267 - Optical data bus - U1049 00 [00001001] - Open circuit
  4. Instruments (J285)
    1. 15360768 - Component Protection
      U1101 00 [00001000] - Active
  5. Auto HVAC (J255)
    1. Control Circuit for A/C Compressor
      B10A9 29 [00001001] - Signal Implausible
    2. Component Protection
    3. Function Restriction due to Faults in Other Modules
    4. Supply Voltage Terminal 30 for Coolant Pump (This one went away on a second scan)
      B11D5 01 [00001001] - Electrical Failure
  6. Seat Mem. Pass (J521)
    1. Component Protection Active
I know I cant exactly do anything about the component protection without dealer/remote service but considering the errors for the CAN and instruments.
Here is my scan:
Control Module Part Number: 4H0 920 880 C
  Component and/or Version: TBenUSAACCNV- H30 0309
Optical Bus Diagnostic : Standard
Controller              Electrical              Optical
CAN Gateway             OK                      OK
Instruments             OK                      ERROR
Address 0x19,4H0 907 468 E,UDS Selective Output Tests,
Saturday,01,March,2025,09:55:42:15457
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
VIN: WAURVAFD9BN016726   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 46
          52 53 62 6C 6D 6F 72 81 84 85 88 89 8B 8E 8F 90
VIN: WAURVAFD9BN016726   Mileage: 175199km-108863miles
84-Night Vision -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---    CVN: 831BB1C6
   Coding: 0106000A290F0268
   Shop #: WSC 05146 444 100000
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A0E0B6A8C7CEF4AF15-807E
   VINID: 9D19629915942527800461C218ECB3E4C9
Readiness: 0000 0001
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---    CVN: B88C26AF
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   VCID: 72BED30A642CE78A895-8026
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H10 0273
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 323E130AA4ACA78A495-8066
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H23 0510
   Coding: 0D872000000000000000
   Shop #: WSC 21038 003 1048576
   VCID: 6E86C77A7094C36A6DD-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2310000087995014
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:04
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00001002290650
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 353428165542B0B26C7-8060
03766 - Motor for Seat Belt Height Adjustment
                    Fault Status: 01100101
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:06
                    Fault Status: 01101000
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 4 Zonen H14 0061
   Coding: 4801227E8C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 221EE34AF44C370AB95-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [00001001] - Signal Amplitude Too High
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:07
0269 - Control Circuit for A/C Compressor
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:07
          U1101 00 [00001001] - Active
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
0379 - Supply Voltage Terminal 30 for Coolant Pump
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 21:54:10
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:10
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000000771128
   Coding: 0907A091073C9FE18B000804A0003800009CD308820001218001085C3B00
   Shop #: WSC 12345 123 61029
   VCID: 2C020D728608F17A039-8078
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110115  H32 0040
   Serial number:         110117042402
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10054637
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 12 01 2011  00000106
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R096H06
   Subsystem 5 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A31 LED Mod1L  H01 0006
   Serial number: 00000018011100010636
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A27 LED Mod1R  H01 0006
   Serial number: 00000024011100010964
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102032000000167794
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 06384B85000000000001
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:00
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:00
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Fault Status: 00101100
                    Reset counter: 168
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:00
01232 - A/C Compressor Regulator Valve (N280)
                    Fault Status: 01101100
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:00
02838 - Solenoid Valve for Servotronic (N119)
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:00
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901101901362
   Coding: 300902
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001_AU64.rod
   VCID: 3728221E4FCE42A27EB-8062
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Serial number: 00000000000000 Dataset Number: 4H0909863B  0018
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 290CF466897AE452F8F-807C
          [FAULT_ATP_IKA_FAST_FAILED]
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
                    Control Module temperature: 29  C
                    Voltage terminal 15: 14.506 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
145152 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_SWA_FAIL]
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:08
                    Control Module temperature: 40  C
                    Voltage terminal 15: 14.071 V
93440 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:08
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0011MK8 Dataset Number: 4H0909602D  0003
   Coding: 303143303230303030314A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R11111019SR
   Serial number: 3575HRB405L0BI7UA0JS
   Serial number: 3585HRB405L0BI7U50UZ
   Serial number: 3515JRB405V06OG299KP
   Serial number: 3525JRB405V06OG2BGIX
   Serial number: 3554VRB406704QRO91DZ
   Serial number: 3564VRB406304QRO1OQH
9439761 - Front Passenger's Side Airbag Igniter
          B100A 11 [10001001] - Short to Ground
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:15
          U1101 00 [10001001] - Active
          [ATP Inconsistency]
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KAK00023
   Coding: 0000BC
   VCID: 313C1C06A12A9C9230F-8064
   Subsystem 1 - Part No SW: 4H0 951 528     HW: 4H0 951 528
   Component: E221 - MFL  H04 0009
   Serial number: 10 12 2010  33032895
   Part No SW: 4H0 920 880 C    HW: 4H0 920 880
   Component: TBenUSAACCNV- H30 0309
   Revision: 26110011    Serial number: 658220111593019
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU64.rod
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110112000566
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000087164
   Coding: 00C1034A00
   GVL: FFAFC84CD8A3E4CCC0
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3330160E5BB6AE82423-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650477759
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:22:04
                    Voltage terminal 30: 12.8 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 36  C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:06
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 24  C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:03
                    Voltage terminal 15: 14.4 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
15361024 - Component Protection
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:03
                    Voltage terminal 30: 14.4 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [00001001] - Too High
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 10:43:49
                    Voltage terminal 30: 12.6 V
                    Control Module temperature: 20  C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 C    HW: 4H0 919 158 C
   Component: Klima Fond    H14 0062
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 303A1902AAA0959A3F1-8064
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Dataset Number: 4H0909553D  0030
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2C020D728688F17A039-8078
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00001002289781
   Coding: C0183B0085053201010001010101112131313333203333
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100B4V10
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C82CD724608317A439-8038
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0100
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   Coding: 0000002
   VCID: 6D84C07671923872547-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0100
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F16.01.1100H010003CH10534
   Subsystem 4 - Serial number: H10534
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:16
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000112146178
   Coding: 011F1F205E0062C202000007
   Shop #: WSC 02312 785 00200
   VCID: 3B203E2E736666C29A3-806E
01482 - Motors for Central Locking
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:53
   Revision: 00002001    Serial number: 0139520695
   Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000016839
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  000C  H05 0004
   Serial number: 102700029125
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: DACHELEKTRONI  H11 0080
   Serial number: H2011000000000004876
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0060  H05 0004
   Serial number: 102700029318
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  007A  H05 0004
   Serial number: 102700029145
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00F0  H05 0004
   Serial number: 102700029315
   Coding: 020200
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:53
03219 - Access and Start Authorization
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:04
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:31:41
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0162
   Revision: --------    Serial number: 0000112218360
   VCID: 3A2E3B2A7C5C5FCA815-806E
   Part No SW: 4H0 907 801 D    HW: 4H0 907 801 A
   Component: EPB-4         H03 0010
   Revision: --------    Serial number: 00000000036034
   ASAM Dataset: EV_ParkiBrake 001021
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000112127520
   Coding: 010F1F20400062C202000007
   VCID: 392C2426795A54D288F-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J0YD1T4
   Coding: 1020002
   VCID: 6594B856A96200321C7-8030
03006 - Back-up Camera System not calibrated
                    Reset counter: 128
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 020100430 Dataset Number: 4H0909541C  0016
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B203E2E73E666C29A3-806E
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000020939 Dataset Number: 4F0000000__ U001
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6390A64EABD67E02F23-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000112127517
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H05 0081
   Revision: 0L0D5012    Serial number: SN101215  0254
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B000E6E8386F6420A3-807E
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0026
   Serial number: 0K84AE40023037
   Coding: 1200
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 313C1C06A1AA9C9230F-8064
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H07 0006
   Serial number: 00000000001100610158
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547C  0028
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6594B856A5E200321C7-8030
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00456842222701 Dataset Number: 4H0909880D  0017
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt_AU64.rod
   VCID: 2F381A7EB79E8A6226B-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00456842120501 Dataset Number: 4H0909881D  0017
   Coding: 364FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: 2708F25E9F6ED222EEB-8072
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
                    Control Module temperature: 27  C
                    Voltage terminal 15: 14.427 V
                    Velocity_vehicle_reference: -0.00 m/s
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 08:21:18
                    Control Module temperature: 35  C
                    Voltage terminal 15: 14.036 V
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H28 0034
   Serial number: 000040181801117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2514F856E562C032DC7-8070
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 21:52:33
                    Outside temperature: 21.0  C
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 15.0  C
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Dataset Number: 4H0909614A  0014
   Coding: 0066F609031F007E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FB8DA7E771ECA6266B-803A
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   Dataset Number: 4H0909615A  0013
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70BAD9026A20D59A7F1-8024
                    Reset counter: 128
                    Mileage: 175199 km
                    Date: 2025.01.25
                    Time: 22:04:05
End----------(Elapsed Time: 03:05, VBatt start/end: 14.6V/14.6V)-----------
------------------------------39 Faults Found------------------------------
TheProj
C?ID=307152
Fresh scan after disconnecting and reconnecting the battery.
Component protections are gone some how.
Friday,07,March,2025,17:29:54:15457
Mileage: 175198km-108862mi   Repair Order:
Control Module Part Number: 4H0 907 468 E
  Component and/or Version: J533--Gateway H08 0204
CAN Gateway             OK                      OK
Friday,07,March,2025,17:48:02:15457
VIN: WAURVAFD9BN016726   Mileage: 175198km-108862miles
Readiness: 1010 0101
   Coding: 000002
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:09
   Coding: 4801227E8C
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:06
          B10A9 29 [00001000] - Signal Implausible
                    Reset counter: 171
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:06
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.31
                    Time: 00:04:17
   Coding: 0045F7
   Coding: 025523
   Coding: 100000
   Coding: 100000
   Coding: 020300
                    Reset counter: 171
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:00
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:00
   Coding: 300902
   Coding: 3601020201
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:07
                    Control Module temperature: 41 �C
                    Voltage terminal 15: 14.219 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s�
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:07
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:11
   Coding: 0000BC
   Analog_clock:
   Coding: 00C1034A00
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:33:02
                    Control Module temperature: 37 �C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Coding: 0000000000
   Coding: 008002
   Coding: 0000002
   Subsystem 3 - Serial number: 5F16.01.1100H010003CH10534�
   Subsystem 4 - Serial number: H10534�
            014 - Defective
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:07
   Coding: 020200
   Coding: 070000
   Coding: 020200
   Coding: 020200
   Coding: 020200
   Coding: 1020002
                    Reset counter: 131
   Coding: 0210044100
   ROD: EV_Ambie.rod
   Coding: 1200
   Coding: E9060000
   Coding: 764FF2
   Coding: 364FF2
   Coding: 3601020201
                    Reset counter: 132
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:08
                    Control Module temperature: 34 �C
                    Voltage terminal 15: 14.287 V
   ROD: EV_BC7.rod
                    Reset counter: 131
                    Mileage: 175198 km
                    Date: 2025.01.30
                    Time: 08:30:02
                    Outside temperature: 15.5 �C
                    Control Module temperature: 30.0 �C
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:00, VBatt start/end: 14.4V/14.4V)-----------
------------------------------14 Faults Found------------------------------
Does it start, run, and drive? What functional problems are there with it?
TheProj
C?ID=307152
Turned on and drove it once since harness replacement. Prior, I knew there was a issue when i saw the headlights flickering on and off on a rainy night . Grabbed the key, got in, got yelled at multiple times in different tones, tried the light switch to on/off. Turned the car on/off. DVD changer made a bunch of noises like it was checking all the slots. Turned it off, disconnected battery..
Steering is stiff like no power steering. Steering wheel position works. Power steering tank was empty (it was towed?), filled with 202 (still full), but have been a lil weary to do anything but turn it on hence why driven once. Not sure if it would cause damage? Related: Solenoid Valve for Servotronic (N119) ?
AC wasn't cold but after disconnecting battery seemed cold but it's cool outside. Refrigerant Temp and Pressure sensor .75 bar. N280 AC regulation activation on, current 412 ma, pwm 35% Will check tomorrow. Related: A/C Compressor Regulator Valve (N280) Electrical Fault in Circuit - Intermittent, Address 08: Auto HVAC (J255) errors
Headlights work
I've felt, seen, and heard the air suspension working.
MMI turns, gets to the drive select and shows (for a couple seconds) the modes disabled and one time saw the nav screen and gps location on map was correct. Turns black and closes. 3 finger solute does not fix it. If I press to pop up it opens for a second with black screen and closes.
Checked almost every fuse on the driver side door fuse box with a multimeter.
Saw water intrusion and under rubber mat was damp. Started trying to take apart the PITA driver side foot well to see how accessible J519 and dried out.
Also visually inspected the fuse/relay E?-box under the hood and the positive connection wire and nut that comes from the trunk.
When I disconnected the batterey I also visually inspected the positive cable box
I'll check the night vision camera.
Just in case bought a body wedge kit, radio key tool, and fiber optic loop just incase.
Trunk and wall appear looked fine haven't identified and checked which ever fuses/relay
TheProj
C?ID=307152
Any referral/recommendation of online coding, component protection removal, and/or geko online account? I have a 5054a clone.
My hunch was right replaced J519 and the J519 was partially fried (water) and still haven't identified which is the eeprom for me to clone. Anyone see it?
AC nice and cold and steering while no longer stiff. Dashboard is black and mmi still closes after a couple seconds which i assume is due to the component protection.
TTT
C?ID=547002
Eeprom is that big fat processor.
Dr Sheldon
Windsor UK
C?ID=334979
You are not going the get Clone Software and Dongle past VAG !!
You can get yourself registered (Jump through some hoops - Some hoops you may not be able to do) !
You could move the processor / eeprom over but some times they have the data in 2 places - It is a learning curve - Interesting Challenging and worthwhile if you succeed !
Find a good Audi VW specialist with ODIS or look for those that are good at transferring data across for you.
Try
@Jetta 97
or
@EuroX
EuroX
Northern NJ USA
C?ID=208579
More of a mcu. Without specialized tools good luck as most are locked before they can even be read or rewritten.
TTT
C?ID=547002
Let me speak his language.
TheProj
C?ID=307152
Try
@Jetta 97
or
@EuroX
Thanks for all the info senor! Any resources for learning on what needs to be moved on this module and any other. I've got soldering station, hot air rework, eeprom reader/writers, soic, clips etc. I've used arduino, esp, and stuff to make stuff from temp and humidity sensors, saltwater tank dosing, and I mah have soldered back in the good ole dtv dish days :)
Dr Sheldon
Windsor UK
C?ID=334979
Do the research - I dont know and those that do are unlikely to give it away - it is a lucrative skill.
TheProj
C?ID=307152
My bad, though from your response you may have had some knowledge. Most of what I've found are Russian sites, mh auto, audi enthusiasts, etc. Appreciate the response though
Dr Sheldon
Windsor UK
C?ID=334979
I have half a clue - I am able to remove refit things like that MC9s12 and Soic EEproms etc. The rest comes from digging and experimenting.
Then this
It is a minefield however with the right knowledge and tooling it can all be done. I also have access to ODIS so I have little use for this malarkey now !
