Resolved Golf MK7 2013 tow bar retrofit -> ACC ERROR & Trailer always detected
Resolved
GOLF 7 FR
Aveyron, France
C?ID=549429
Hello everyone,
This is my first thread on this forum and i hope you will be able to help me
So i retrofited an used oem retractable tow hitch with the used calculator rev F
I wired everything with the kufatec harness for this rev of calculator and everything is being powered as it should, the led in the trunk is working (green when the tow is hidden or deployed and red when it's dangling)
My golf is from 2013 so the oem calculator installed from factory was a rev A because rev B appeared in mid 2014 when they changed the ground system so i hope the more recent calculator is compatible.
I coded every calculator related to the trailer (trailer detection activated or things like that)
So when i plugged on my battery back and turned on the car, it was a christmas tree, i turned the steering wheel side to side and made a kick drive, everything turned off except the ACC and the trailer error which say "check the towing system" and after a message for every trailer light malfunctionning even if i dont have a trailer plugged in.
So my first problem is that the calculator always think i have a trailer hooked because it hide me the back sensor when i'm in reverse and show me a trailer even if the trailer hitch is retracted...
And secondly my ACC isn't working at all and i cant even use the cruise control
So here is an auto scan :
Monday,03,March,2025,20:38:22:23320
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
VIN: WVWZZZAUZDW137612   License Plate: XX-XXX-XX
Mileage: 173151km-107591mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 A5
VIN: WVWZZZAUZDW137612   Mileage: 173151km-107591miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---    CVN: 4B545CBB
   Coding: 011D0032037405083000
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AADE0A35C5AE85AC15-802E
   VINID: 9E69EAAAA465A949C10C718108C81C6505
17159 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:56
                    Engine speed: 0.00 /min
                    Coolant temperature: 22  C
                    Intake air temperature: 24  C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 12.320 V
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01303181152 CVN: 00005934
   ROD: EV_TCMDQ250021.rod
   VCID: 1577D31F550427224C7-8040
          P1734 00 [00000010] - -
   Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
   Component: ESC           H75 0537
   Revision: 00000000    Serial number:
   Coding: 01FA62A120230A73037D060101C52980460450C0608094F3F86A502AC1
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7EA5ECB34072C47AFDD-802A
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0210729423 Dataset Number: 5G0IJ1v____ 0001
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 79AFFFAF595CE342C8F-802C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020114102100011105004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 3635349328C2CC3A65D-8062
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011309401568 Dataset Number: 5G0063v____ 0001
   Coding: 00131B46C24122FB4FE44000110C0728180A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46D5445358225CBAF5D-8012
   Component: WWS    130322  042 0551
   Serial number:         130328054922
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M04D05H07M48S19S2
   Coding: 00A8DD
   Serial number: 00000000000041013861
   Sunroof control module:
   Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO1987483E
   Coding: 181901
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 99
                    Mileage: 173151 km
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 0
                    Voltage: 12.5 V
                    Outside temperature: 13.0  C
463104 - Seat Heating; Front Left
          B1398 F0 [00001000] - Safety Shut-Off Active
                    Reset counter: 139
                    Mileage: 172969 km
                    Date: 2025.03.03
                    Time: 18:06:30
                    Terminal 15 status: On
                    OFF: Not operated
                    Voltage: 14.4 V
                    Outside temperature: 12.5  C
   Part No SW: 5Q0 919 298 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0033
   Revision: --------    Serial number: 61131307900094 Dataset Number: 5G0039v__B_ 0008
   Coding: 0031161151
   ASAM Dataset: EV_EPHVA2CAU3700000 003015
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 3E252CB300F2047ABDD-806A
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 25031303070424 Dataset Number: 5g0114v____ 0014
   Coding: 001E1F00FE0309
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FDB51B707F80D72B6B-806A
1043 - Automatic Distance Control
          B10E7 F0 [00101111] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
                    Control Module temperature: 12  C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
1098 - Databus
          [FAULT_CIS_STPL_AAG_FAIL]
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R029WLV Dataset Number: 5G0003v____ 0079
   VCID: 4ACD70634C3AB8DA115-801E
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667A02041370361
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668A03041350103
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 203 13
   Serial number: 35767000000524013C0C
   Subsystem 4 - Part No SW: -----------    HW: 480 001 503 13
   Serial number: 358670000000C86D8C02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 603 13
   Serial number: 3516502C50FAE891C15S
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 13
   Serial number: 3526502C50FAE893403K
   Subsystem 7 - Part No SW: -----------    HW: 480 402 003 13
   Serial number: 3556502A10FBDE45724Q
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 21031304220332 Dataset Number: ----------
   Coding: 0C00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 025D9843348AA09A995-8056
   Part No SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Component: KOMBI         336 0580
   Coding: 07A501186F94000803887A03040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 270BE9D7FF68A5B2EEB-8072
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000446794 Dataset Number: 5G0067v____ 1020
   Coding: 030100040B087300FF00065C1C0F00010001000000000000000000000000
   GVL: 01543C0000000600C08C90000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 34310E9B3EBEDE2A5B9-8060
   Generator:
   Component: E221__MFL-DC1  H13 0035
   Serial number: 23130000274690110291
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 9248810203
          U1101 00 [00001001] - Active
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000027007005
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B3CD877B309912823-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 16031301100781 Dataset Number: 5G0222v____ 0036
   Coding: 003B1320D000048000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001020580
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: 5G0074v____ 0124
   Coding: 93
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D272BBF0DF41F62A47-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 17031304080126 Dataset Number: 5G0157v____ 0037
   Coding: 003B1120DE00048000801000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001077799
   Coding: 090000
   Component: LWR-ECU       005 0070
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0012
   Coding: 029A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
   VCID: 75B7F39F75448722AC7-8020
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02311001FF00000051110001000908001F0500D401200100CF
   Shop #: WSC 12345 123 61029
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3039028BCAA6E20A3F1-8064
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H60 8214
   Serial number: VWZ6ZJW1853587
   Subsystem 2 - Part No SW: 5NA 919 866 EF    HW: -----------
   Component: ECE1 2024/25  --- 2210
15360768 - Component Protection
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
                    Voltage terminal 30: 12.2 V
0517 - Front Right Bass Speaker
          B1062 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:57
0518 - Front Right Treble Speaker
          B1064 13 [00001001] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:57
                    Voltage terminal 30: 12.0 V
0522 - Front Left Bass Speaker
          B105F 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:57
0523 - Front Left Treble Speaker
          B1061 13 [00001001] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                    Reset counter: 97
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:57
   Part No SW: 5Q0 907 383 F    HW: 5Q0 907 383 C
   Component: Anhaenger     H14 0137
   Revision: 8B001002    Serial number: 0366648949 Dataset Number: 0G0124v____ 0014
   Coding: 0100000202000000
   VCID: 3A2D20A31CDA285A815-806E
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 14
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
656138 - Bulb for Right Tail Light on Trailer
          C10F4 15 [00001001] - Open or Short to Plus
                    Reset counter: 97
                    Mileage: 172881 km
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 13
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [00001001] - Open or Short to Plus
                    Reset counter: 98
                    Mileage: 172887 km
                    Date: 2025.03.03
                    Time: 13:04:59
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 14
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:54
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000041700    Dataset Number: 5G0HL1v____ 0040
   Coding: 0101010001020304000300000100000101
   ROD: EV_MFKBoschAU370.rod
2555904 - Databus
          [PSD_01_TO_FAILURE]
                    Fault Frequency: 18
                    Reset counter: 99
                    Mileage: 172881 km
                    Date: 2025.03.03
                    Time: 11:52:55
                    Control Module temperature: 21  C
                    Outside temperature: 11.0  C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.1 V
                    Terminal 15 on: 155.7 s
End----------(Elapsed Time: 01:32, VBatt start/end: 12.2V/12.3V)-----------
------------------------------18 Faults Found------------------------------
Tell me if you need more informations or not and if i have to change anything
PS : i'm not a native english so sorry for my mistakes
Thanks in advance !
downtime
Finland
C?ID=280813
check your wiring and do not code trailer assist, your car does not support it as it needs rear view camera you don’t have
GOLF 7 FR
Aveyron, France
C?ID=549429
Well, I have an RVC it's a lowline and dont have a calculator for it I think but I have one.
For the wiring, I re checked the 4 wires I connected to the BCM and following the Kufatec sheets it's ok, do I need to check if their informations is correct ?
Westbury, UK
On many forums I've visted over the years problems with incorrect wiring information from Kufactec has been a factor, so yes check the wiring yourself against a wiring diagram (that's a link).
GOLF 7 FR
Aveyron, France
C?ID=549429
Well from what i've found, i've already connected the 4 wires which are underlined in the picture below
But this wiring diagram is for the rev A calculator so is this different for rev from B to N ? I'm not really good at reading diagrams...
Here is a diagram for trailers past 2014 if you want to compare
downtime
Finland
C?ID=280813
Low RVC does not support trailer assist so you can’t code it in. You will have errors
  • Informative
GOLF 7 FR
Aveyron, France
C?ID=549429
Ok i got it, so what am I supposed to do now ? Change back every coding I have done in each calculators or only in a specific one ?
Thank you for your help :thumbs:
downtime
Finland
C?ID=280813
Sorry, I don’t know what exactly you have changed. If you can tell what you changed I think I can tell what is not correct
GOLF 7 FR
Aveyron, France
C?ID=549429
Here is all the coding or adaptations change that i've made :
19 - CAN GATEWAY Installation list checked 69 - Trailer
01 - Engine Byte 5 ticked bit 4 "Trailer recognition installed [PR …...]
09 - Central Elec Byte 1 ticked bit 1 "Trailer Hitch Control module installed"
03 - ABS Brakes Adaptation IDE04774-Vehicle and trailer stabilization -> activated
10 - Park/Steering assist Byte 3 bit 0-1 "Trailer Hitch installed (manually removable)
13 - Auto dist reg Byte 2 bit 3 "Trailer recognition control module installed"
A5 - Frt Sens Drv Assist Byte 16 bit 0-7 Trailer recognition control module installed
69 - Trailer Byte 3 bit 0-3 "02 Terminal 30 Output (Pin 9) active while trailer connected
69 - Trailer Byte 4 bit 0-7 "02 Terminal 30 Output switched (Pin 10) active while Trailer connected
Hope you will find the problem
Warren333
Hull, UK
C?ID=604450
You’ve probably already seen this thread, but I’m in a world of hurt with my own trailer coding and I thought it may be of use to you.
GOLF 7 FR
Aveyron, France
C?ID=549429
Sadly no, i tried again and nothing changed, i don't have any idea of what can be missing or wrong
downtime
Finland
C?ID=280813
I don’t see anything wrong in the coding changes either.
Are you sure the wiring is correct on the trailer module?
GOLF 7 FR
Aveyron, France
C?ID=549429
Oh god i have it i think...
I was to sleepy to notice but Kufatec say you have to connect the stop light control to pin 58 in plug C, correct
Clip 15 contact ??? to pin 14 in plug A, correct
Can high pin 16 plug A -> WRONG ! It's in plug C following the wiring diragram i sent before
And CAN low pin 17 plug >A -> Wrong too, it's in plug C also
And correct me if i'm wrong but the plug C is the closest one and the plug A is the farrest one
I really hope this is my problem but i'm really disappointed of this seller, 114€ for a wire set and a false notice... The fuses are also wrong for the calculators with revision B and later, well what a mess...
I keep you informed, but i think i'll have to buy connector to fit in the plug C for the true CAN positions because there is no cable in pin 17 plug C but in pin 16 there is a purple wire. I don't know what it can be
GOLF 7 FR
Aveyron, France
C?ID=549429
Well i don't understand, the wirings diagrams i found are pretty contradictory as you can see, for the BCM (J519) the CAN high and low connections are in the plug A pin 16 and 17 as Kufatec say
But in the wiring diagram for the trailer (J345) they are say we have to connect them to the plug C, and as i can see it is not meen for that
downtime
Finland
C?ID=280813
I don’t think there’s an issue with the CAN because the module is detected.
For some reason module thinks there’s a trailer connected because it’s complaining about the trailer lights.
So check grounding that it’s correct. Something is shorting somewhere
GOLF 7 FR
Aveyron, France
C?ID=549429
Ok so i have somes news,
To begin, the 3 grounds of the trailer plug are correct (0.3 Ω each) and the ground for the calculator is 0.3 Ω too.
After that, we checked the the A T24 plug of the trailer wiring to see if everything was correctly placed, and it was.
After that we tested the continuity but we found out that somes wires have a high resistance between them as you can see in the picture below
For exemple the pin 1 and 2 in the trailer plug have a resistance of 20 MΩ between them
So what do you think about this ? Every wire should be independant no ? Like the the pin 9 which dont have any resistance between any others pins (we have disconnected the grounds so that's normal if there is 0 for the 3 grounds)
And we tried every light with a test light and noticed right indicators and some others didn't work, so we thought about the calculator and i opened it to check if i can see something, and what was my surprise when i figured out that it has been flooded...
So i think the calculator is dead and i'll buy a new one hoping it will solve my problems, do i need to have a certain revision ? Mine was an "F", or can i look for a newer one so maybe it will have less "bugs" or somes new features
For the Golf MK7, i can have a revision B, C ,D ,F ,G ,H ,K ,M I think
And about the plug wiring what are your thought ? Do i need to re do it ? Is there maybe some water in the plug which make interferences ? Is there a risk to burn the new calculator if there is somes interferences in the plug ?
downtime
Finland
C?ID=280813
Buy the same one. Higher index does not necessarily mean it's better. In many cases it's a different part and not suitable for your car.
And yes, looks like the unit is flooded :(
RGH0
Australia
C?ID=433612
The module was clearly removed due to it being faulty due to the corrosion present and then sold on to you as an unsuspecting buyer. I would try to get my money back if possible
GOLF 7 FR
Aveyron, France
C?ID=549429
The cheapest calculator i've found is a H index and from what i've found on ETKA and on Kufatec, it should be compatible.
On ETKA it only show the index N which is the latest and it is also sold buy Kufatec
What do you guys think ?
And yes, i will try to contact the seller but I dont have any hope in being refunded.
Finally for the trailer wiring, as I asked before, is there a problem with it too ?
downtime
Finland
C?ID=280813
I don't see at the moment any problems with the trailer module wiring towards the car as no other module is complaining about it. The module from socket wiring it complains but that we already now know is due to fubar module.
For the modules, I would not trust what Kufatect says here as it's wiring they state compatibility against modules. A module is till 2014 and N is from 2014 onwards. If you click at A does it say it's superceded by module x? If yes, then you know it's outdated and you can get basically any higher index module. (up till N)
