Saturday,15,March,2025,14:37:42:50034
VCDS Version: 25.3.0.3 (x64) HEX-V2 CB: 0.4660.5
Data version: 20250301 DS365.0
VIN: 3VWPL7AJ3BM618416 License Plate:
Mileage: 247600km-153851mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWPL7AJ3BM618416 Mileage: 247600km-153851miles
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H08--- Serial number:
Coding: 0050078
Shop #: WSC 04024 003 1048576
VCID: 2D00D610911D0942146-8078
VINID: 0E69E070745A0D274604810118EDF758C8
9 Faults Found:
011174 - NOx Emissions Exceeded
P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON
Fault Status: 11100000
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:21:56
Pressure: 968.0 mbar
Temperature: 7.2°C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 18.0°C
005079 - Cylinder 4 Internal Pressure Sensor
P13D7 - 000 - Short to Plus - MIL ON
Fault Frequency: 76
Mileage: 245840 km
Date: 2019.08.06.
Time: 00:16:20
RPM: 2116 /min
Speed: 88.0 km/h
Bin. Bits: 00001100
Absolute Pres.: 0.0 bar
(no units): -12.80
Ign. Timing: 0.9 °BTDC
(no units): 11.60
005081 - Cylinder 4 Internal Pressure Sensor
P13D9 - 000 - Implausible Signal - MIL ON
Fault Frequency: 55
Mileage: 245860 km
Date: 2019.08.06.
Time: 23:09:39
RPM: 1633 /min
Speed: 50.0 km/h
Bin. Bits: 00001100
(no units): -12.80
Ign. Timing: 5.4 °BTDC
(no units): 11.60
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required
Fault Frequency: 218
Mileage: 245862 km
Pressure: 980.1 mbar
Temperature: -1.8°C
Temperature: 7.2°C
P13D9 - 003 - Implausible Signal - Intermittent
Fault Status: 00100011
Mileage: 247423 km
Date: 2019.08.06.
Time: 04:04:15
RPM: 2139 /min
Speed: 108.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 87.0 bar
(no units): 12.70
(no units): 11.60
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0°C
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Mileage: 246657 km
Date: 2019.08.06.
Time: 00:59:53
RPM: 966 /min
Speed: 12.0 km/h
Voltage: 13.83 V
Temperature: 61.2°C
Idle Stabilization: -1.8°KW
RPM: 479 /min
(no units): 48.0
001162 - Exhaust Pressure Control Valve 1
P048A - 000 - Stuck Closed - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 38
Mileage: 246269 km
Date: 2019.08.06.
Time: 01:11:03
RPM: 1288 /min
Speed: 17.0 km/h
Load: 23.9 %
Load: 9.8 %
Lambda: 55.2 %
Temperature: 36.0°C
Temperature: 22.5°C
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Mileage: 247377 km
Date: 2019.08.06.
Time: 07:32:06
RPM: 1679 /min
Speed: 22.0 km/h
Voltage: 13.91 V
Temperature: 71.1°C
Idle Stabilization: -2.3°KW
RPM: 821 /min
(no units): 48.0
Readiness: 1 4 0 0 1
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05151112 Serial number: 00001007021439
Shop #: WSC 00066 000 00000
VCID: 186E17C40E9F9CEA570-804C
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B600C49230002880F06E5921F0042B70000
VCID: 74B603743EB7188A9B8-8020
02214 - Tire Pressure Warning
Reset counter: 243
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:03:32
Count: 12
Count: 12800
Count: 16401
Count: 48640
Count: 256
Count: 255
Reset counter: 0
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:00:52
Count: 2
Count: 12
Count: 4096
Count: 16390
Count: 43008
Count: 255
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00147
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B03E70354D0182AC6-8020
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Reset counter: 28
Mileage: 245839 km
Date: 2025.03.15.
Time: 00:00:31
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 0035
Revision: BG011001
Coding: 2D380E1F902F3EC400080081600000C401000086535D8560648020000040
Shop #: WSC 00066 123 12345
VCID: 3436C3747E37588A5B8-8060
Fault Status: 01100010
Reset counter: 243
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:00:01
Term 15 Off
Voltage: 12.80 V
Reset counter: 0
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:00:60
Voltage: 12.80 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00LTBL Dataset Number: 1KM003v__B_ 0027
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3928F24059D5A5E288E-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005BLFV00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME5A542253ZZZT
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME21062654ZZZK
Serial number: 3511HSME77076322ZZZF
Serial number: 3521HSME23146422ZZZ6
Serial number: 35527SME60100523ZZZ-
Serial number: 35627SME2E050523ZZZ8
B10B4 00 [00001000] - Function Restriction due to Undervoltage
Reset counter: 29
Mileage: 246181 km
Date: 2025.03.15.
Time: 01:48:59
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JG9001EA Dataset Number: 5K0953507AH D005
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 76B2397C284B0A9AA5C-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0013267
Coding: 820000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 30
147464 - Terminal 15
B1148 29 [00001001] - Signal Implausible
Reset counter: 0
Mileage: 247605 km
Date: 2025.03.15.
Time: 00:06:07
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Coding: 270F01
VCID: 2F3CCC1897917B5226A-807A
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [00001000] - -
Fault Frequency: 40
Reset counter: 30
Mileage: 246190 km
Date: 2025.03.15.
Time: 17:46:24
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Supply voltage too low]
Reset counter: 29
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 09081001200732
Coding: ED807F0600160300002002
VCID: 2E02D11C9C1B725A2DC-807A
00469 - Infotainment Databus in Single Wire Operation
Fault Status: 00101011
Reset counter: 28
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:00:02
Reset counter: 243
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:03:37
Address 1C: Position Sensing
Component: IMMO H03 0406
VCID: 6A8A1D0C6CF3DE7A314-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001285782
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 270C2438BF612312EEA-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005122749
Coding: 000490
B11EC 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 0
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3138CA608D256DA230E-8064
000 - - - MIL ON
Battery Volts: 12.5 V
PD
Temperature: 23.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FBC0C1857913B5266A-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Reset counter: 36
Mileage: 246013 km
Date: 2019.08.06.
Time: 19:07:31
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 243
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:03:33
02907 - Control Module for Roof Shade (J394)
Reset counter: 243
Mileage: 245839 km
Date: 2019.08.06.
Time: 00:00:41
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001266646
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 280E2704B27F2C6AE70-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005140976
Coding: 000490
Reset counter: 0
Address 56: Radio
Address 77: Telephone
End----------(Elapsed Time: 01:17, VBatt start/end: 12.3V/12.3V)-----------
------------------------------27 Faults Found------------------------------
