Resolved 2024 Audi Q3 F3 Rear View Camera Retrofit Help
Resolved
dulux72
C?ID=336242
I would just like to ask for advice on coding this camera as I seem to be missing something to successfully find all the correct coding.
Added 6C to the Can Gateway 19,
Coded 5F CAR-Function List-BAP-VPS-OXOB to active
CAR-Function List-BAP-VPS-OXOB-MSG-BUS to Infotertainment bus.
But something is still not right
Monday,03,March,2025,15:44:28:26910
VCDS Version: 25.3.0.2 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
VIN: WAUZZZF3XR1120458   License Plate:
Mileage: 2492km-1548mi   Repair Order:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 23 3C 42 44 4B 51 52 5F 6C 6D
          75 8C A5 BB BC C0 C6 CF D6 D7
VIN: WAUZZZF3XR1120458   Mileage: 2492km-1548miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGEA)       Labels: None
   Part No SW: 04E 906 024 CJ    HW: 04E 907 309 CG
   Component: 1.4 TFSI hy   H20 2868
   Revision: DCH20000    CVN: FBF50708
   Coding: 021D0012636405082008
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906024CJ 003002
   ROD: EV_ECM14TFS011_AU37.rod
   VCID: 6B833BCEC30361B24A3-803E
   VINID: 9D196AAAA583A2204108010520C389FE29
   Part No SW: 0DD 300 046 K    HW: 0DD 927 770 E
   Component: GSG DQ400E    H32 2303
   Revision: 00032120    Serial number: 5ZV02308080739 CVN: AF405F2F
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 3039ECA22AA5C26A3F1-8064
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 HB    HW: 5QM 614 517
   Component: ESC           H26 0157
   Revision: 00000000    Serial number: 63233000002429 Dataset Number: F30909504J  0003 CVN: 3665B7DB
   Coding: 3AFFB27F53223B6C8B7B0E056ACB685C4DCADCD1705616FD18A1557492BD4A0B00632E64121A83902F35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060.rod
   VCID: 78A914828255DA2AB71-802C
   Part No SW: 83A 820 043 AD    HW: 83A 820 043 AD
   Component: AC Automat    H04 0021
   Revision: 20026000    Serial number: 00000001614493 Dataset Number: 83B909862A
   Coding: 071000000000100108000000000011000100000000000000
   ASAM Dataset: EV_AirCondiFrontPHEVAU326 001002
   ROD: EV_AirCondiFrontPHEVAU326.rod
   VCID: 629D56EA34C920FAF95-8036
   Subsystem 1 - Part No SW: 5QF 963 231 C    HW: 5QF 963 231 C
   Component: J848 HV-PTC  H13 1000
   Serial number: LT240573014604000212
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: C15DA81500PAG0MUFU04
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 816 803 L    HW: 5QE 816 803 L
   Component: J842 eKK  H03 0010
1179914 - Control Module for HV-Heater
          B1581 16 [00101000] - Voltage Too Low
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 19:56:54
                    Unlearning counter according OBD-OBD Parameter: 35
                    Outside temperature: 9  C
                    HV heater status: global-Specified value: 0 %
                    HV heater status: global-Requirement: not active
1179924 - Control Module for HV-Heater
          B1581 F4 [00101000] - HV Voltage too Low
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 19:56:54
   Part No SW: 5Q1 937 084     HW: 5Q1 937 084
   Component: BCMMQBAB MxLO H44 0512
   Serial number: 02102404801151 Dataset Number: 83A909514H  0072
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 76B51ABA8841AC5AA5D-8022
   Subsystem 1 - Part No SW: 83C 955 119 B    HW: 83C 955 119
   Component: J400FRWISCH  063 0051
   Serial number: 890053F0402400402292
   Coding: 5DC72F
   Component: G397_RLFSS  H06 0004
   Serial number: 23054881X81A955555B0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K2 941 501 R    HW: 4K2 941 501 R
   Component: E1 - LTM  H07 0060
   Serial number: 20S09.02.2400302855
   Subsystem 4 - Part No SW: 5Q0 951 177 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  004 0403
   Serial number: 0000000000000JQA4AFJ
   Serial number: 00000000000052262847
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 NL    HW: 5Q1 953 549 D
   Serial number: 00000026022420240520
12810 - Bulb for Right Back-up Light
          B12CC 15 [00001000] - Open or Short to Plus
                    Reset counter: 91
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 19:55:34
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 14.2 V
                    Outside temperature: 9.0  C
13834 - Bulb for Right Tail Light 2
          B12C1 15 [00001000] - Open or Short to Plus
                    Reset counter: 91
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 19:55:24
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058624057 Dataset Number: 83A909526D  0033
   Coding: 9471055811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   VCID: 53F3832E7B73D972623-8006
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H12 0396
   Dataset Number: 83A909863P  0006
   Coding: 5205E7D21CFF8728747C64648150A700080000000000000044
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B323AE9B33B972823-8026
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Reset counter: 93
                    Mileage: 2397 km
                    Date: 2025.02.27
                    Time: 16:10:18
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 13  C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.59 m/s
                    Adaptive distance regulation: status: ACC_StandBy
   Part No SW: 5Q0 959 655 CC    HW: 5Q0 959 655 CC
   Component: AirbagVW21    011 0421
   Serial number: 003J5RB3RT61 Dataset Number: 83A909602L  0005
   Coding: 88CCF0C0002000009C5400DFC0C8005400C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 0353736ECB9389F2923-8056
   Left seat belt tensioner:
   Component: BeltPretRevFL  506 1062
   Serial number: 83A857705K0061Y01652
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  506 1062
   Serial number: 83A857706K0066Y01798
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 480 000 203 24
   Serial number: 35700000000403C8BE6U
   Subsystem 4 - Part No SW: -----------    HW: 480 000 203 24
   Serial number: 358000000009BA91CE62
   Subsystem 5 - Part No SW: -----------    HW: 480 400 103 24
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A8B050CA58485
   Subsystem 6 - Part No SW: -----------    HW: 480 400 103 24
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B2B0254B3C67%
   Subsystem 7 - Part No SW: -----------    HW: 480 401 502 24
   Component: FrontSensor_D  005 6149
   Serial number: 3550001BAB061DD8970H
   Subsystem 8 - Part No SW: -----------    HW: 480 401 502 24
   Component: FrontSensor_P  005 6149
   Serial number: 3560001A6AFF55B1C98-
   Part No SW: 83A 920 704 G    HW: 83A 920 704 G
   Component: KOMBI         H08 6190
   Dataset Number: 83A909525T  0036
   Coding: 2D0404086F8C06000180E0501000030000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_AU37.rod
   VCID: 290F01C6097FB3A2F8F-807C
   Part No SW: 3Q0 907 530 AS    HW: 3Q0 907 530 H
   Component: GW MQB EV     627 6504
   Serial number: 24022411603551 Dataset Number: 83A909515K  0046
   Coding: 020900172FE200005B10325E5A1000000001010100010000000300000000
   GVL: 01463C000800000850CC80009002C81800040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 00597C62DA8592EA8F1-8054
   Subsystem 1 - Part No SW: 83A 951 523 J    HW: 83A 951 523 J
   Component: J453 MFL  H07 0004
   Serial number: 20240117002400 30053
   Subsystem 2 - Part No SW: 5QA 915 181 G    HW: 5QA 915 181 G
   Component: J367-BDMHella  H11 9070
   Serial number: 7011953706
131689 - Rear View Camera System Control Module
          U104C 00 [00001001] - No communication
          [Timeout Knoten 0x69 / 6C - Steuerger t f r R ckfahrkamerasystem]
                    Fault Frequency: 27
                    Reset counter: 56
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 12:18:12
                    Terminal 30 power supply: 14.8 V
                    Terminal 15: On
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AK    HW: 3Q0 909 059 D
   Component: EBKV          H09 0272
   Serial number: BPA085300124013 Dataset Number: F30909524E  0001
   Coding: 4402C504400000DE7BEFBDF7000049902449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
108560 - No Communication with Transmission Control Module
          U0101 00 [00101000] - -
          [ComScl_CAN_Getriebe_11_Timeout]
                    Fault Frequency: 88
                    Reset counter: 36
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 16:53:13
108592 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_CAN_Getriebe_11_GE_Fahrstufe_Error]
   Part No SW: 3Q0 907 566 L    HW: 3Q0 907 566
   Component: MRR1Rear      H27 0550
   Revision: --------    Dataset Number: 83A909535B  0009
   Coding: 46C002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 41DFB966910F5BE2C0F-8014
1188157 - Databus
          [databus unreasonable message - Perso_Status]
                    Reset counter: 51
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 12:19:17
                    Control Module temperature: 31  C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 14.70 V
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007XBC1457D Dataset Number: 83A909872D  0030
   Coding: 001E8E005001008000011032
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9E4AAC3998BA115-801E
   Part No SW: 5TA 907 145 F    HW: 5TA 907 145
   Component: BASGEN1MQB37  502 1063
   Serial number: 02384643 Dataset Number: 83A909852AB 0004
   Coding: 01000001010001010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010.rod
1408 - Databus
          U1121 00 [00100000] - Missing Message
          [DTC_ESP_24_TIMEOUT]
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0367
   Serial number: 24022410800700 Dataset Number: 83A909583E  0011
   Coding: 000000050900196E00102B03020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD7BECFCB15527EB-8062
   Part No SW: 5NA 907 080     HW: 5NA 907 080
   Component: LE Gen 3.3H30 1403
   Revision: 00H30000    CVN: 65F1EF1E
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530115NA907080 001002
   ROD: EV_DMCM08530115NA907080.rod
   VCID: 7CA10892B66DF60AD39-8028
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007XAG10658 Dataset Number: 83A909873D  0030
   Coding: 001E8E005C01008000011030
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA146A93F93A218F-801C
   Part No SW: 82A 035 043 N    HW: 82A 035 043 A
   Component: MU-TH-ND-EU   044 3843
   Serial number: GRO-63307.02.24 Dataset Number: 83C909545Q  0033
   Coding: 13260028804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 280904C212758AAAE71-807C
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 83A 919 620 A    HW: 83A 919 620 A
   Component: CenterDisplay  H40 0132
   Serial number: AUZ8ZHR22062NP
   Subsystem 2 - Part No: V03 959 822 PR
   Component: MIB3_EU_       1290
   Compact disc data bank:
   Component: Gracenote2     1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008324000015325005
   Media socket:
7179 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 51
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 16:51:28
                    BAP: 02
                    Voltage terminal 30: 14.6 V
5529 - Secure Control Modules; Internal Communication
          U15CA 00 [00001000] - Not Available
                    Reset counter: 93
                    Mileage: 2380 km
                    Date: 2025.02.26
                    Time: 18:39:43
                    Voltage terminal 30: 13.4 V
Address 6C: Back-up Cam.
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 5QS 959 107 A    HW: 5QS 959 107 A
   Component: HDSG-Modul    H02 0811
   Revision: --------    Serial number: A2-C785-8730-3 Dataset Number: 83A909541H  0015
   Coding: 2900
   ASAM Dataset: EV_DeckLidCONTIAU536 001008
   ROD: EV_DeckLidCONTIAU536_001_AU49.rod
   VCID: 59EF7106199FE322A8F-800C
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H22 0143
   Serial number: 0000000311VIUQJ Dataset Number: 83A909612N  0023
   Coding: 013260101FE829009005460120012607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
9457171 - Audio signal output 1
          B14F1 13 [00001000] - Open Circuit
                    Mileage: 2492 km
                    Date: 2025.03.03
                    Time: 15:19:05
                    Voltage terminal 30: 12.5 V
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 5NA 915 183 B    HW: 5NA 915 183 A
   Component: J840 K8C  BMC 004 1043
   Serial number: 000000190224020 CVN: CE40F9634C4A4147C6E4041FC6E4041FC6E4041FC6E4041FC6E4041FC6E4041F
   ASAM Dataset: EV_BMCeVWBSMQB48 001010
   ROD: EV_BMCeVWBSMQB48_VW41.rod
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Component: CMC            H04 0501
   Serial number: 23A25591AH0405011422
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A25591AH0405011421
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A25591AH0405011419
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A25591AH0405011360
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A13591AH0405011432
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A12591AH0405011020
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A13591AH0405011434
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591 H    HW: 5KE 915 591 A
   Serial number: 23A12591AH0405011029
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H19 1421
   Serial number: EB7792611240600 Dataset Number: 83A909466J  0003
   Coding: 00040908216E4020A89E10001020002000410000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 3635DABAC8C1EC5A65D-8062
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007XBN18488 Dataset Number: 83A909897D  0030
   Coding: 000E8C004001008000001020
   VCID: 4CC19852A64D868A239-8018
   Component: TSG HBFS005 0350
   Serial number: YE007XBN1514E Dataset Number: 83A909896D  0030
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 R    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0309
   Serial number: E2313002120000 Dataset Number: 83A909470C  0004
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
   VCID: 50F98C224A65A26A5F1-8004
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H63 4031
   Revision: --------    Serial number: 060324RBL02480 Dataset Number: 83A909811A  0002
   Coding: 115069622000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001.rod
   VCID: 1D6725164D375F02847-8048
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BapErr_Timeout_Heartbeat]
                    Reset counter: 96
                    Mileage: 2492 km
                    Date: 2025.03.03
                    Time: 15:27:04
12583681 - Function Restricted due to Missing Message(s)
          [BapErr_RetryNotSuccessful]
                    Reset counter: 91
   Part No SW: 3Q0 907 590 L    HW: 3Q0 907 590
   Revision: --------
   Coding: 46C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 3E25C29AE0F1241ABDD-806A
   Part No SW: 4K0 941 572 CG    HW: 4K0 941 572 C
   Component: LMS_MQB       H20 0132
   Dataset Number: 83A909471F  0015
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 75B71DB69547A742AC7-8020
   Dataset Number: 83A909472F  0015
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
End----------(Elapsed Time: 01:56, VBatt start/end: 14.9V/14.9V)-----------
------------------------------15 Faults Found------------------------------
Monday,03,March,2025,15:55:00:26910
Readiness: 1110 0001
   A/C compressor sub:
   Coding: 5DC72F
   Coding: 00005D
   Coding: 9471055811
   Coding: 802006
   Coding: 802006
                    Reset counter: 56
                    Mileage: 2492 km
                    Date: 2025.03.03
                    Time: 15:47:30
                    Terminal 15: On
   Coding: 46C002
1188157 - Databus
                    Reset counter: 51
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 12:19:17
1408 - Databus
   Volume Control 1:
   Media socket:
                    Reset counter: 51
                    Mileage: 2342 km
                    Date: 2025.02.22
                    Time: 16:51:28
                    BAP: 02
                    Reset counter: 93
                    Mileage: 2380 km
                    Date: 2025.02.26
                    Time: 18:39:43
   Coding: 2900
                    Mileage: 2492 km
                    Date: 2025.03.03
                    Time: 15:19:05
   Coding: 04
   Revision: --------
   Coding: 46C002
End----------(Elapsed Time: 01:55, VBatt start/end: 14.9V/14.9V)-----------
------------------------------6 Faults Found-------------------------------
Any help greatly appreciated
siLc
Tallinn, Estonia
C?ID=330192
Well then, how did you connect the camera up to the CAN network and power/ground? Because it's not talking...
dulux72
C?ID=336242
OK 12v power is connected in fuse holder C Fuse 18
Ground is connected at the rear of the car
With the CAN bus high pin 1
and the CAN bus low pin 7 connected to the Grey 12 PIN connector in J794
Camera feed connected to T2kd 2 pin green connector in J794
vastechnics
C?ID=143747
Wrong canbus need to go on 6 and 12. Then camera will be shown.
MSGBUS need to be Terminal 15 instead INFO databus
dulux72
C?ID=336242
Thanks for the pointers
Can I just check that the connector is still the same one (T12g 12 Pin Grey) and that these pin positions would be correct for a 2024 vehicle as thats different from the wiring diagram I have.
dulux72
C?ID=336242
Thank you vastechnics
Was starting to go mad
All sorted
vastechnics
C?ID=143747
Ok good so all working now?
