- Dec 7, 2024
- 8
- 2
- South Carolina, USA
- C?ID=601755
Hey all,
I am new to VCDS and had a few questions.
I have seen this question solved for another vehicle on this forum (2014 A6) however it is not working for mine (2008 Audi TT Quattro Roadster). Basically, I broke the (very brittle 17-year-old) plastic clip for the front left brake pad wear sensor while I was replacing rotors and pads. Now it is giving me a persistent message to "replace brake pads." If it is possible I would like to use VCDS to just disable this wear pad sensor.
As recommended by everyone I did a full auto scan when I first got the cable and saved it, I am pasting that below. (Also I know there are 44 fault codes, but I cleared these codes back in December and only a few have returned. The reason I bought the cable was to attempt to do the automatic roof adaptation after cleaning flap servos. I can do a new scan if necessary but I know my current issue is the brake pad sensor on the front left.
Any help would be appreciated.
Autoscan:
Autoscan:
Wednesday,04,December,2024,18:29:56:03878
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: TRURD38J481004168 License Plate:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 0F 14 15 16 17 19 22 25 26 42 44 46 47 52 55 56
65 77
VIN: TRURD38J481004168 Mileage: 292480km-181738miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine Labels: 022-906-032-BDB.LBL
Part No SW: 022 906 032 HF HW: 022 906 032 GP
Component: TT-3.2-HS-LEV2 G 0863
Revision: 1QH02--- Serial number: AUX7Z0G4FNN07W
Coding: 0000172
Shop #: WSC 14136 794 419462
VCID: 56F25E80C407AFDA557-8002
VINID: 92296250321A108040004046206BFFBE17
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected - Intermittent
Fault Status: 00100001
Mileage: 285379 km
Date: 2024.06.29
Time: 07:07:22
RPM: 1302 /min
Load: 16.9 %
Speed: 95.0 km/h
Temperature: 84.0∞C
Temperature: 33.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
001170 - Secondary Air Injection System: Bank 2
P0492 - 002 - Insufficient Flow - MIL ON
Fault Status: 11100010
Mileage: 289870 km
Date: 2024.08.30
Time: 08:36:16
RPM: 884 /min
Load: 25.1 %
Temperature: 30.0∞C
Temperature: 27.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.589 V
001169 - Secondary Air Injection System: Bank 1
P0491 - 002 - Insufficient Flow - MIL ON
Mileage: 289870 km
Date: 2024.08.30
Time: 08:36:16
RPM: 884 /min
Load: 25.1 %
Temperature: 30.0∞C
Temperature: 27.0∞C
Voltage: 13.589 V
U0155 - 008 - - Intermittent
RPM: 1323 /min
Load: 38.0 %
Temperature: 24.0∞C
Temperature: 26.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 10.287 V
000372 - Fuel Trim; Bank 2
P0174 - 004 - System Too Lean - MIL ON
Fault Status: 11100100
Mileage: 291324 km
Date: 2024.11.06
Time: 09:27:44
RPM: 622 /min
Load: 16.5 %
Temperature: 89.0∞C
Temperature: 20.0∞C
Voltage: 13.970 V
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8J0-614-517.CLB
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0026193
Shop #: WSC 01236 785 00200
VCID: 6A8A1A70607F1B3AE1F-803E
Reset counter: 80
Count: 64
Count: 12289
Count: 8208
Count: 41728
Reset counter: 80
Count: 192
Count: 12545
Count: 8211
Count: 43008
Reset counter: 82
Count: 192
Count: 13057
Count: 297
Count: 44032
Address 08: Auto HVAC Labels: 8J0-820-043.CLB
Part No SW: 8J0 820 043 AJ HW: 8J0 820 043 AJ
Component: J255 Klima 1 Zone 0080
Revision: 00H07003 Serial number: 00000001059430
Coding: 1572900
VCID: 6E8216605C97F71ABD7-803A
Reset counter: 80
Reset counter: 80
Reset counter: 80
Reset counter: 80
Mileage: 291176 km
Date: 2024.09.17
Time: 00:00:51
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.LBL
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007095926
Coding: F1061E83C0141C00471800001800000000284E075A250802000000000000
VCID: 45D089CC29A114422CD-8010
Subsystem 1 - Part No: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0060
Coding: 00064784
Shop #: WSC 01236
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00149804
Shop #: WSC 01236
9 Faults Found:
00985 - Right Tail Light (M2)
Fault Status: 00101100
Fault Frequency: 53
Reset counter: 103
Mileage: 284995 km
Date: 2024.06.25
Time: 17:31:00
Voltage: 12.80 V
02498 - Left Low Beam Reflector Motor (V294)
Fault Status: 01111100
Reset counter: 65
Mileage: 274664 km
Date: 2022.10.12
Time: 03:32:00
Voltage: 13.35 V
01800 - Light Switch (E1)
Reset counter: 81
Mileage: 291176 km
Date: 2024.09.17
Time: 00:02:00
Voltage: 13.45 V
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 168
Reset counter: 65
Mileage: 288006 km
Date: 2024.08.09
Time: 02:23:00
Voltage: 12.05 V
Fault Frequency: 117
Reset counter: 65
Mileage: 288006 km
Date: 2024.08.09
Time: 02:20:00
Voltage: 11.95 V
Fault Frequency: 19
Reset counter: 103
Mileage: 291258 km
Date: 2024.11.05
Time: 00:06:00
Voltage: 13.10 V
Fault Status: 01111010
Reset counter: 65
Mileage: 277174 km
Date: 2024.01.19
Time: 20:26:00
Voltage: 13.20 V
Reset counter: 65
Mileage: 275092 km
Date: 2023.12.14
Time: 12:16:00
Voltage: 14.25 V
Reset counter: 80
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.60 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.LBL
Part No SW: 8E0 035 593 K HW: 8E0 035 593 K
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0081967
Coding: 0000100
VCID: 3138CD1C8D29A8E2E05-8064
Reset counter: 59
Mileage: 292180 km
Date: 2024.11.22
Time: 00:40:53
01304 - Radio
Reset counter: 105
Mileage: 292484 km
Date: 2024.11.24
Time: 08:12:59
Address 14: Susp. Elect. Labels: 8P0-907-376.LBL
Part No SW: 8J0 910 376 HW: 8J0 907 376 A
Component: J250 Raddaempfung 0050
Revision: --H16--- Serial number: 190DPH 7053667
Coding: 0000014
VCID: 6C861C686A8B050A933-8038
Reset counter: 80
Voltage: 11.76 V
Voltage: 4.95 V
00774 - Level Control System Sensor; Rear Left (G76)
Reset counter: 2
Mileage: 276689 km
Date: 2024.01.11
Time: 16:07:14
Voltage: 13.92 V
Speed: 74.0 km/h
Voltage: 4.95 V
(no units): -4.0
(no units): -5.0
(no units): 0.0
(no units): 1.0
Fault Frequency: 44
Reset counter: 80
Voltage: 11.52 V
Voltage: 4.95 V
Address 15: Airbags Labels: 8J0-959-655.LBL
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -F Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K001DCU%
Coding: 0011590
VCID: 79A8353C15D9A0A2185-802C
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 00HYD
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ6332DRB404C0C5A7XˇÜ63
Subsystem 5 - Serial number: 0C5A7XˇÜ6342DRB405330F9BUˇÜ63
Subsystem 6 - Serial number: 30F9BUˇÜ63747RB402338888NˇÜ63
Subsystem 7 - Serial number: 38888NˇÜ63847RB40233888FVˇ
Subsystem 8 - Serial number: 3888FVˇ
Reset counter: 80
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
Fault Status: 00101001
Reset counter: 87
Address 16: Steering wheel Labels: 8P0-953-549-F.LBL
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0003041
VCID: 41D89DDC3D893862105-8014
Component: E0221 H06 0030
01304 - Radio
Address 17: Instruments Labels: 8J0-920-XXX-17-MY8.CLB
Part No SW: 8J0 920 990 E HW: 8J0 920 990 E
Component: KOMBIINSTR. VDO H22 0130
Revision: D0H22001 Serial number: 2244G001000117
Coding: 0117288
Shop #: WSC 04352 001 1048576
VCID: 3436C408723B9DCA8B3-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.CLB
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07419806A
Coding: E98B1F271007025100
VCID: 303EC8188623A1EAEFB-8064
Fault Status: 01111011
Reset counter: 190
Mileage: 285380 km
Date: 2024.07.07
Time: 11:20:37
01304 - Radio
Reset counter: 105
Mileage: 286108 km
Date: 2024.07.14
Time: 00:00:06
Fault Frequency: 82
Reset counter: 80
Time Indication: 15
Address 22: AWD Labels: 1K0-907-554.LBL
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3632FE0064478FDAB57-8062
Address 25: Immobilizer Labels: 1K0-920-XXX-25.CLB
Revision: D0H22001 Serial number: AUX7Z0G4FNN07W
Shop #: WSC 65072 004 1048576
Address 26: Auto Roof Labels: 8J7-959-255.LBL
Part No: 8J7 959 255 B
Component: 256 VSG TT H13 0110
VCID: 3E22E6204C77479A6D7-806A
02000 - Switch Position
Fault Status: 01101000
Reset counter: 3
Mileage: 291689 km
Date: 2024.11.13
Time: 01:58:01
01995 - Convertible Top Lock Switch (F295); Closed
Reset counter: 3
Mileage: 274675 km
Date: 2022.10.12
Time: 05:13:36
03246 - Sensor for Canopy Flap; Left (G596)
Reset counter: 3
Mileage: 282175 km
Date: 2024.05.22
Time: 20:29:44
03247 - Sensor for Canopy Flap; Right (G597)
Reset counter: 3
Mileage: 280963 km
Date: 2024.04.29
Time: 16:43:14
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.LBL
Part No: 8J7 959 801 C
Component: Tuer-SG H02 0060
Coding: 0001077
VCID: 3C26EC285A6B558A433-8068
Address 44: Steering Assist Labels:
VCID: 55F0598CDC01A4C25CD-FFFE
Address 46: Central Conv. Labels:. 8J0-959-433.LBL
Part No: 8J0 959 433 A
Component: KSG H07 0070
Coding: 9B90328241382D090F0FC88A0473
Subsystem 1 - Component: Sounder No Answer
Address 47: Sound System Labels: 8J0-035-223.LBL
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000007279
Coding: 0236126
Shop #: WSC 25105 444 84543
VCID: 2510294CC9E1F4420CD-8070
02246 - Loudspeaker; Center
Fault Status: 00111011
Reset counter: 105
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 91
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.LBL
Part No: 8J7 959 802 C
Coding: 0001077
VCID: 3D20E12C41715C8274D-8068
Address 55: Headlight Range Labels: 4F0-910-357.LBL
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000025
VCID: 2908257CA5F9D022285-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H04 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH04 0020
Address 56: Radio
Address 65: Tire Pressure Labels: 8J0-907-273.CLB
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502_RDK H02 0300
Revision: --H02-D0 Serial number: 12679671862465
Coding: 0860021
VCID: 2F3CCB649B1DBE12F61-807A
02214 - Tire Pressure Warning
Reset counter: 99
Mileage: 292136 km
Date: 2024.11.22
Time: 00:08:16
Speed: 35.8 km/h
Bin. Bits: 00001000 10000011
Voltage: 14.10 V
Text: 1 ∞C; 0,49bar;3422950432;00h;- 0∞C
Reset counter: 80
Bin. Bits: 00001000 00000001
Voltage: 12.20 V
Text: -50∞C;n.erkannt; n.erkannt
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P0 862 335 L HW: 8P0 862 335 L
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005030060
Coding: 0001207
VCID: 3FDC9B244B7D4E92661-806A
Reset counter: 80
End----------(Elapsed Time: 75:32, VBatt start/end: 13.6V/13.7V)-----------
