POLO new generation electric windows not open/close.
RyMar
South Africa
C?ID=133909
Good day
Cannot open/close windows from output test mode but in measure value blocks the switches open/close on all 4 doors.
From the manual switches, no windows open/close.
Tested all fuses and found to be OK.
Hooter also not working but on output test mode it will go off once.
Any suggestions?
Monday,14,December,2015,12:06:02:65476
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Dealer/Shop Name: RyMar Auto
VIN: AAVZZZ6RZBU086109   License Plate: CYK 793 L
Mileage: 91350km-56762mi   Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: AAVZZZ6RZBU086109   Mileage: 91350km-56762miles
Address 01: Engine (J623-CLSA)       Labels: None
   Part No SW: 03C 906 014 AF    HW: 03C 906 014
   Component: CLSA-MM7GV    H02 8573
   Revision: --H02---    Serial number:
   Coding: 00110014020400000000
   Shop #: WSC 31414 790 31414
   VCID: 61CF1D8A7BB66E3604-513C
17012 - Fuel Pump Relay Control Circuit
            P0628 - 000 - Short to Ground - MIL ON
                    Fault Status: 11100000
                    Reset counter: 208
                    Mileage: 91354 km
                    Date: 2015.12.10
                    Time: 20:32:01
                    Bin. Bits: 00000100
                    Lambda: 0.0 %
                    Temperature: 56.0°C
                    Absolute Pres.: 931.0 mbar
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 200200E3007500B8042600E200DA00000000
   VCID: 0009380E97FCC73E6B-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326DA2C66DD0A5AEAD-8066
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 169111993
   Coding: 3DB02BBF08F3240092380800342B0CD00040410F60040000200000000000
   VCID: 428DF206DD70152E3D-8016
   Subsystem 1 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 2 - Part No: 1K8 951 605 B
   Subsystem 3 - Part No: 1K8 951 171 A
03020 - Local databus 2
                    Fault Status: 01101100
                    Reset counter: 208
                    Mileage: 91354 km
                    Date: 2015.12.10
                    Time: 18:54:44
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag028 H09 0020
   Revision: --------    Serial number: 003GX00MLD0M
   Coding: 003238
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A9DDA26ED40CD6EF5-801E
   Serial number: 3575HRB405T0H922982X
   Serial number: 3585HRB405H0HM767OFS
   Serial number: 3515RRB404T0I4AGCG6Q
   Serial number: 3525RRB405T0I70GEH1J
   Part No SW: 6R0 920 860 F    HW: 6R0 920 860 F
   Component: KOMBI         H05 0304
   Coding: 140800
   Shop #: WSC 31414 790 50316
   VCID: 377B93D28EB240869A-8062
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70E968CEA35CD7BE9B-8024
   Component: IMMO          H05 0304
   VCID: 6ADD7AA68D802D6ED5-803E
   Part No: 6R0 423 156 B
   Coding: 10150
   Shop #: WSC 31414
   VCID: 2F6BABB2EAE28846C2-807A
   Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
   Component: Radio         510 0521
   Revision: R0510001    Serial number: VWZ5Z1L0506156
   Coding: 0500040002
   Shop #: WSC 00000 000 31414
   VCID: 295F45AA4006E6761C-807C
End-------------------------(Elapsed Time: 02:02)--------------------------
RyMar
South Africa
C?ID=133909
I checked again today. In measure value blocks all 4 windows register `NO` and the switches does not show open/close.
In long coding it does not show what the coding for electr windows should be. Any suggestions.
Hooter is sorted. Airbag slipring.
Dex
Serbia
C?ID=25360
I would start from connector between drivers door and body. Is illumination on drivers door window switch on? If power supply is OK, you have problem with LIN bus (violet-white wire), you have error in address 09.
