- Feb 25, 2025
- 13
- 1
- Toronto, ON, Canada
- C?ID=610702
I swapped the engine and the ECM, when I started the car it run rough. I I performed an Auto Scan and had many DTC codes. I decided to clear all codes and start a new scan. When I click to start a new scan, VCDS just runs fast over all modules but fails to scan anything. Now thw car does not start as well. I have a saved copy of the 2 scans; before and after the clear all DTC. here bellow.
Tuesday,25,February,2025,12:18:21:61611
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
Data version: 20250210 DS356.4
VIN: WUARL48H85K900806 License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WUARL48H85K900806 Mileage: 211990km-131724miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8H0 910 560 G HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Revision: 00000000 Serial number: AUZ6Z0D0254749
Coding: 0007774
Shop #: WSC 00000 000 08192
VCID: 2C0A7688CA143DDAD33-513C
VINID: 9E54627042182056C9000200182898D15F
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low
17953 - Throttle Valve Controller
P1545 - 008 - Malfunction
Readiness: 0110 1101
Part No SW: 8E0 910 156 R HW: 09L 927 156
Component: AG6 09L 4.2L5V USA 0060
Revision: --H01--- Serial number: 0037460
Coding: 0001002
Shop #: WSC 00672 785 00200
VCID: 353C53EC195E7C12BCD-5160
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Fault Status: 01110000
Mileage: 211992 km
(no units): 30.0
(no units): 81.0
Temperature: 2.0°C
T.B. Angle: 0.0°
18289 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Fault Status: 00110000
Mileage: 211992 km
Address 03: ABS Brakes Labels: None
VCID: 55FCF36CBC1E5C125CD-51A8
No Faults Found
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1424
Coding: 00100
Shop #: WSC 00672
VCID: 6398DDB4E24AB2A2229-513C
00796 - Fan for Interior Temp Sensor (V42)
42-10 - Speed Deviation too High - Intermittent
01273 - Fresh Air Blower (V2)
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul KAN 0517
Coding: 01014
Shop #: WSC 12112
VCID: 353C53EC1C5E7C12BCD-4AE0
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 A
Component: SDAR XM 0010
VCID: 270089A4D6C21E823E1-5066
02617 - Satellite Antenna (R170)
29-00 - Short to Ground
02633 - Antenna for Satellite Tuner
31-10 - Open or Short to Ground - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 00672
VCID: 3E2E4CC02968BF4A6D7-4AE0
52-10 - Supply Voltage Too High - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.clb
Part No: 8H0 920 980 M
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 03301
Shop #: WSC 12345
VCID: 39245FDC30469872585-513C
WUARL48H85K900806 AUZ6Z0D0254749
Address 26: Auto Roof Labels: 8H0-959-255.clb
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6386
VCID: 73B8ADF457AA2222529-513C
02000 - Switch Position
Part No: 8H0 959 760
Component: Sitzmemory EE H06 0010
Coding: 00002
Shop #: WSC 00065
VCID: 74BAAEE85794251A4B3-4B1E
02010 - Left Entry Assistance Control Module (J572)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 E
Component: Komfortgerát T7B 3320
Coding: 11788
Shop #: WSC 00672
VCID: 363E54E00158770AB57-4AE0
Subsystem 1 - Part No: 8H1959801B
Component: Tõrsteuer.FS BRM 3020
Subsystem 2 - Part No: 8H1959802B
Component: Tõrsteuer.BF BRM 3020
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
17 Faults Found:
37-10 - Faulty - Intermittent
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 045AFE280734159A7B3-4B1E
30-00 - Open or Short to Plus
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 00205
Shop #: WSC 67584
VCID: 2C0A7688CF243DDAD33-5066
06-10 - Signal too High - Intermittent
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F M H13 0010
Coding: 00006
Shop #: WSC 00065
VCID: 353C53EC1C6E7C12BCD-4B1E
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
02014 - Switch for Seatback Latch; Passenger Seat (F212)
End----(Elapsed Time: 05:22, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
