2006 Jetta dash lights delete
gbarrera09
Pennsylvania, USA
V2-2H
Hello all. I have a 2006 Jetta TDI that I did some mods to and would like some help in permanently deleting some dash lights. recently upgraded both my high and low beams with LEDs and got the burned light indicator. I also replaced a steering wheel airbag sensor, but the light remains on. and a low washer fluid light even though the sensor has been replaced and the electrical connects were treaded. here is my auto-scan showing what I'm working with.
Sunday,01,December,2024,15:45:55:14621
VIN: 3VWST81K66M747880   License Plate:
Mileage: 387900km-241029mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST81K66M747880   Mileage: 387900km-241029miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AC    HW: 028 101 223 9
   Component: R4 1,9L EDC G000DG  7551
   Revision: --H01---    Serial number: VWZ7Z0E3104042
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 6491BBEE32582EFADB3-8030
   VINID: 0E69E390805B18674710720800BF0FAFC7
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1126
   Revision: 04507000    Serial number: 00000610230813
   Shop #: WSC 44551 111 44551
   VCID: 51FF623A5DEAAB52805-8004
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71BFC2BAFDAA8B52A05-8024
   Part No: 1K0 820 047 DL
   Component: Climatic PQ35   090 0505
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000224861
   Coding: 14018E234004100000140000001400000008730B58
   Shop #: WSC 00137 211 07671
   VCID: 2A0D15D610FCB88A21F-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00137
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 116
                    Mileage: 387902 km
                    Voltage: 13.25 V
                    Reset counter: 116
                    Mileage: 387902 km
                    Voltage: 13.25 V
                    Reset counter: 116
                    Mileage: 387902 km
                    Voltage: 13.00 V
                    Reset counter: 116
                    Mileage: 387902 km
                    Voltage: 13.00 V
Address 0F: Digital Radio        Labels: None
   Part No SW: 1K5 035 553 K    HW: 1K5 035 553 K
   Component: SDAR XM         H04 0160
   Revision: 00000000    Serial number: VWZ4Z7G0062988
   VCID: 313F02BA3D2ACB52E05-8064
                    Reset counter: 104
                    Mileage: 379409 km
                    Time: 01:53:29
01304 - Radio
                    Reset counter: 116
                    Mileage: 387902 km
                    Time: 04:42:24
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 38 AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD03ATA5
   Coding: 0013112
   VCID: 392F3A9AE55A0312585-806C
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0C7E0513D
   Subsystem 3 - Serial number: 6342MSME0C367876L
   Subsystem 4 - Serial number: 6351HSME087C18014
   Subsystem 5 - Serial number: 6361HSME08654016+
   Subsystem 6 - Serial number: 63727SME08094112S
   Subsystem 7 - Serial number: 63827SME0844026D+
01588 - Igniter for Head-Airbag; Drivers Side (N251)
            002 - Lower Limit Exceeded - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
01281 - Airbag; Drivers Side; Disabled
01284 - Side Airbag; Drivers Side; Disabled
01646 - Head-Airbag; Drivers Side; Disabled
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenks ulenmodul 036 0070
   Coding: 0010021
   VCID: 0059977EC60092DA5FB-8054
   Part No: 1K0 920 952 L
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023203
   Shop #: WSC 02607 444 54002
   VCID: 333308B2C736F942929-8066
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105B048B1D
   Coding: 3F3F0B60071002
01304 - Radio
                    Reset counter: 116
                    Mileage: 381343 km
                    Time: 03:01:11
   Component: IMMO            3HL 4312
   Shop #: WSC 47637 005 1048576
01176 - Key
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 363531A6D444EC6AB57-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D0DB6382CF04A99F-8066
   Part No: 1K0 959 433 AF
   Coding: 037803281B09058F880F048051A0
   Shop #: WSC 00137 211 56823
   VCID: 74B1CBAE82B8BE7A4B3-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B3CA2D34E1562AE1-8062
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
00934 - Electric Window Motor; Rear Left (V26)
   Part No: 1K0 959 704 D
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D071ECA2112AFB2C4D-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End----------(Elapsed Time: 01:13, VBatt start/end: 14.3V/14.3V)-----------
thank you all in advance
I don't think there's any way to directly accommodate LED bulbs in this CECM.
You can try turning off:
Cold Diagnosis High Beam (Byte 18, Bit 4)
Cold Diagnosis Low Beam (Byte 19, Bit 0)
That may kill the warnings until you actually turn those lights on, but I expect once you do, you'll still get the warning because those LEDs draw less current than the module expects.
I'm not sure what you mean by "steering wheel airbag sensor".
You should be able disable the washer fluid warning by changing the instrument cluster's coding from 0023203 to 0019203
gbarrera09
Pennsylvania, USA
V2-2H
-Uwe
My apologies for no being more clear. But this is the section I was referring to. I replace the Air Bag Clockspring and the light still illuminates.
Dr Sheldon
Windsor UK
C?ID=334979
You really dont have a clue !! Absolutely no research on your part -Just looking to lash it up !! Poor car.
Either throw the LED lamps away - You dont need them - or fit resistors, get them on ebay.
Get a Wiring Diagram from >ERWIN< - Fix it properly !!
Surprise 7uckin surprise !!!
Do you read ??
Only 6 Major faults !! In a SAFETY CRITCAL system !!!
And you wonder why the light is on :banghead: :banghead: :banghead:
I think he knows why the light is on, but I'm not touching that with a 3 meter pole since he's already gone and disabled things in the Airbag module.
Since when did you go Metric ? :confused:
I was born metric. Got dragged into arcane Imperial/American units at age 7-1/2. Can for (for the most part) handle either one. Just don't ask me how many feet in a furlong -- I'd have to look that up.
Dr Sheldon
Windsor UK
C?ID=334979
The "old school" terminology, and the only one in use on the streets here is "6 (foot barge) pole"
Dr Sheldon
Windsor UK
C?ID=334979
I was born metric.
Ah - Germany ?
Same with me - Born Imperial but UK went into Europe 1971 ish ??
Still have sets of AF tools.
Here in America (fuck yeah!), we normally say "I wouldn't touch that with a 10 foot pole!" and I never knew where the expression came from until a lightning hit took out the (ground/pad mounted) transformer that supplies electricity to our cabin. Power company guy came out. First thing he tried was replacing the fuse on the primary side. The primary/distribution voltage there is 7.2 kV. He used a 10' long fiberglass pole to do the deed. Now I know! :D
gbarrera09
Pennsylvania, USA
V2-2H
Hello Uwe and Dr. Sheldon. Wanted to follow up with some updates for my previously requested help. I did install some resistors to the high and low beams, and now thankfully the exterior light fault on the dash is now intermittent with illuminating. Dr. Sheldon was correct, I tracked down where there was in fact a tear in the windshield wiper low level sensor harness and corrected that matter. As for the airbag faults, I replaced the steering wheel airbag clock spring. That did eliminate one of the two faults. I'm currently researching a permanent fix, and not a rig, for the fault to the airbag under the driver seat. And also tracking down fixes for the others listed below. Here is my auto-scan for yesterday. Any pointers you have for the remaining listed faults would be greatly appreciated.
Thursday,20,March,2025,18:04:57:14621
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
Mileage: 391020km-242968mi   Repair Order:
VIN: 3VWST81K66M747880   Mileage: 391020km-242968miles
   Coding: 0050078
   VCID: 6491BBEE32582EFA0BF-8030
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 9
                    Mileage: 388321 km
                    Time: 19:05:04
                    RPM: 1701 /min
                    Speed: 81.0 km/h
   VCID: 51FF623A5DEAAB52509-8004
   Revision: 00H13001
   Coding: 0021122
   VCID: 71BFC2BAFDAA8B52709-8024
   VCID: 2A0D15D610FCB88AF13-807E
   Coding: 00063445
   Shop #: WSC 00137
                    Reset counter: 181
                    Mileage: 391029 km
                    Voltage: 14.15 V
                    Fault Status: 00101010
                    Reset counter: 221
                    Mileage: 391029 km
                    Voltage: 14.15 V
   VCID: 313F02BA3D2ACB52309-8064
                    Reset counter: 116
                    Mileage: 387902 km
                    Time: 04:51:31
01304 - Radio
                    Reset counter: 181
                    Mileage: 391029 km
                    Time: 00:00:48
   Coding: 0013112
   VCID: 392F3A9AE55A0312889-806C
01587 - Igniter 2 for Airbag; Drivers Side (N250)
   Component: Lenksäulenmodul 036 0070
   Coding: 0010021
   VCID: 0059977EC60092DA8F7-8054
   Coding: 0019203
   VCID: 333308B2C736F942425-8066
01304 - Radio
                    Reset counter: 181
                    Mileage: 387903 km
                    Time: 02:17:03
   Coding: 0001269
   VCID: 363531A6D444EC6A65B-8062
   VCID: 323D0DB6382CF04A493-8066
   VCID: 74B1CBAE82B8BE7A9BF-8020
   Coding: 0001269
   VCID: 372B3CA2D34E15627ED-8062
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
   VCID: 2D071ECA2112AFB2141-8078
            014 - Defective
End----------(Elapsed Time: 01:12, VBatt start/end: 14.2V/14.2V)-----------
------------------------------10 Faults Found------------------------------
