Hi all, I'm new to this forum and hope I make myself clear. We have a VW 1.6 BCB Golf that didn't start one morning. 1st Auto-Scan was
So cleared DTCs, cleaned the throttle body, replaced the EGR valve with a new valve, adapted both and those dtc's passed by. Car behaves normally now but lights up MIL and "emission workshop." 2nd Auto-Scan was
We have read that replacing an EGR valve may require an ECU reset. Previously learned egr values has to be erased they say. So took the car to dealer's workshop and ordered an ECU reset. It didn't help. MIL lights up at the first engine braking.
Can You help reading this 3rd Auto-Scan? Is there any kind of ecu reset done at the workshop? What does mean differences in VCIDs and readiness in the Engine module? Thanks for help in advance!!
Saturday,07,November,2015,13:34:15:35874
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZ1JZ6W021995 License Plate:
76
VIN: WVWZZZ1JZ6W021995 Mileage: 120750km-75030miles
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 034 DR
Component: MARELLI 4MV G 5957
Coding: 00031
Shop #: WSC 01266
VCID: 65F83722FFEDE416CE-FFFE
WVWZZZ1JZ6W021995 VWZ7Z0E3010344
17961 - Barometric / Manifold Pressure Signals
P1553 - 35-10 - Implausible Correlation - Intermittent
17912 - Intake Air System
P1504 - 35-10 - Leak Detected - Intermittent
Readiness: 0010 0101
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 01266 785 00200
VCID: 335C997A51B94AA690-FFFE
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01266
VCID: 21706332AB45C83672-FFFE
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 0008
Coding: 12855
Shop #: WSC 01266
VCID: 22726C3EAE43D32E6B-FFFE
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 826 A
Component: KOMBI+WEGFAHRSP VDO V23
Coding: 05113
VCID: 2C6E8206DC87155ED1-FFFE
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70D65676302F31BEAD-FFFE
Part No: 1C0 959 799 B
Component: 1A Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 01266
VCID: 365AA06E12CB5F8EB7-FFFE
Component: 1A Tõrsteuer.FS KLO 0202
Component: 1A Tõrsteuer.BF KLO 0202
Component: 1A Tõrsteuer.HL KLO 0202
Component: 1A Tõrsteuer.HR KLO 0202
Part No SW: 6Q0 035 152 A HW: 6Q0 035 152 A
Component: Radio BVX 005 0004
Revision: 00005000 Serial number: VWZ1Z5E2997505
Coding: 0040400
VCID: 28667E16987F397E35-FFFE
End-------------------------(Elapsed Time: 07:32)--------------------------
Log-ASG-295-WVWZZZ1JZ6W021995-121560km-75533mi.txt
Wednesday,02,December,2015,15:43:19:35874
VIN: WVWZZZ1JZ6W021995 License Plate: *****Mileage: 121560km-75533mi Repair Order:
76
VIN: WVWZZZ1JZ6W021995 Mileage: 121560km-75533miles
Coding: 00031
Shop #: WSC 01266
16786 - EGR System
P0402 - 35-00 - Excessive Flow
Readiness: 1010 0101
Coding: 0001025
Coding: 11000
Shop #: WSC 01266
Coding: 12855
Shop #: WSC 01266
Coding: 05113
Coding: 00006
Shop #: WSC 01266
Coding: 00259
Shop #: WSC 01266
Coding: 0040400
End-------------------------(Elapsed Time: 07:30)------------------
Sunday,13,December,2015,14:38:31:35874
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Mileage: 122030km-75825mi Repair Order: version2
76
VIN: WVWZZZ1JZ6W021995 Mileage: 122030km-75825miles
Coding: 00031
Shop #: WSC 01266
VCID: 65F83722FFEDE416F8-FFFE
16786 - EGR System
Readiness: 1000 0100
Coding: 0001025
VCID: 335C997A51B94AA6A6-FFFE
Coding: 11000
Shop #: WSC 01266
VCID: 21706332AB45C83644-FFFE
Coding: 12855
Shop #: WSC 01266
VCID: 22726C3EAE43D32E5D-FFFE
Coding: 05113
VCID: 2C6E8206DC87155EE7-FFFE
80-10 - Single-Wire Operation - Intermittent
Coding: 00006
Shop #: WSC 01266
VCID: 70D65676302F31BE9B-FFFE
Coding: 00259
Shop #: WSC 01266
VCID: 365AA06E12CB5F8E81-FFFE
Coding: 0040400
VCID: 28667E16987F397E03-FFFE
End-------------------------(Elapsed Time: 07:45)----------
