01192 - Torque Converter Loc-up Clutch Error - SOLVED!
kb100
UAE
C?ID=170650
Hello everyone
I am a VW enthusiast based out of Dubai. I own a 2009 VW Tiguan 4Motion 6Speed Auto (CAWB engine). It has done about 131,000kms/81000 miles.
I have been fanatical about maintenance. I follow a religious 5,000 mile oil change. I have changed everything well in advance of the norm .. including tensioners, water pump, fluids etc. I took it for a routine drive train fluid change - Haldex + both differentials + transmission including filter, gasket etc - all VW originals purchased directly from the dealer.
I stay three kms away from the garage where I got this done. I ran a auto test just for the heck of it and it suddenly threw the following.
*Thursday,10,December,2015,20:22:21:00132VCDS -- Windows Based VAG/VAS
Emulator Running on Windows 7 x64(Parallels)VCDS Version 15.7.2.0 (x64)Data
version: 20151124www.Ross-Tech.com<http://www.ross-tech.com/>VIN:
WVGCE15N59W License Plate: Mileage: 131820km-81909mi Repair
Order: --------------------------------------------------------------------
Control Module Part Number: 09G 927 750 FF HW: 09G 927 750 FF
Component and/or Version: AQ 250 6F 1173Software
Coding: 0000328
Work Shop Code: WSC 16414 000 1048576
VCID: 7AFB347C35DFDDEE25-802F
01192 - Torque Converter Lock-Up Clutch
003 - Mechanical Failure
Fault Status: 00100011
Fault
Priority: 2
Reset counter: 0
Mileage: 131825 kmTime
Indication: 0Date: 2043.14.17
Time: 13:09:05*
Going by the Mileage counter this seems to have happened one kilometre into my drive after the fluid change. Strangely not very evident drivability issues till now - no shudder, over-revving engine etc. However I have been take it real easy - not wanting to put any more pressure on a suspect drivetrain.
The first thing I suspected was low/insufficient oil level.
I changed the Haldex and differential oils on the same day as well. In both cases I found the existing levels higher than stipulated. (at least 100-150 ml drained out from the fill hole - where as the level is supposed to be live with, or 3mm lower than the fill hole. Looked like it came overfilled from the factory or the dealership - the last fluid change was done at the authorised dealer.
Everything I read seemed to indicate the transmission will take anything between 3.5-4litres. In fact fact the dealer looked it up and gave me only 4 litres of ATF! I decided to play safe and measure how much came out. About 4250ml came out from the drain plug + pan. Upon removing the filter looked like another 100 odd ml flowed out. Hence I decide to play safe and fill all the four litres. In the end after wastage I must have put back about 3,900ml.
Today I took it to a specialist (a german garage that specialises in VW vehicles exclusively) just to get the level checked - and the level was okay. In fact the local specialist added around 500ml more stating that is what they normally do - which is what the dealership seems to have done too! I insisted they do a proper level check on a cold engine - and have left the vehicle there overnight. They will run the check first thing in the morning. The specialist clearly said they deal only with mechanical issues and they will not touch the gearbox.
Couldn't find a proper trouble shooting guide online . I measured block 6 (as advised by Peter on mail). MVB 006-3 The slip condition spec varies between 0/1/2. (0=Open / 1 = Closed/ 2= Slipped) and MVB 006-4 counter varies between -350 to +350. I don't know how to interpret this data to understand what is normal and what is abnormal.
I found a video online - http://www.ilexa.co.uk/vagmovies/auto_trans.htm. Unfortunately this is for a 1998 Seat 2.0 Toledo Petrol. Something like this may give some idea how to narrow down on what the issue is. Don't know if the same applies to my vehicle and GB (may be unlikely)... else something like that will definitely help.
I would like to know what to monitor to see/diagnose the component that has failed. (Torque converter or any of solenoids/pumps etc) Can someone point me in the right direction?
Much Obliged! :)
Gone But Not Forgotten
Please no snippets of scans and edited ........
Post a complete auto-scan in code tags ..........Thank you
http://wiki.ross-tech.com/wiki/index.php/01192
01192 - Torque Converter Lock-Up Clutch [h=3]01192 - Torque Converter Lock-Up Clutch: Mechanical Malfunction[/h][h=4]Possible Symptoms[/h]
  • Torque Converter Lock-Up Clutch slipping
[h=4]Possible Causes[/h]
  • Torque Converter Lock-Up Clutch faulty
  • Valve Body faulty
  • Internal Failure in Transmission
[h=4]Possible Solutions[/h]
  • Check Torque Converter Lock-Up Clutch Slip
[h=4][/h]
kb100
UAE
C?ID=170650
How will a scan of other modules help? (just for my understanding)
I was forced to run a scan from the "select control module" option because the auto scan kept failing at the engine module stage itself. It would list all the controllers, and start the individual interrogation .. and fail giving me an "unable to communicate - 99, use the options/test function" or something to that effect. The TEST function has no problem identifying the interface. I saved it and retried multiple times - all to no avail. I then tried accessing the same engine module individually from the "select control module" section - and strangely I didnt face any issue there! Hence I had to run this from the Auto Trans module - hence the truncated data.
Secondly, I saw that link earlier - but that is a vey wide swath. I am looking at help in narrowing down the fault. The transmission builders here charge the same bomb for touching the transmission regardless of the work involved... and give only 3 months warranty! Hence if its identified as a valve body fault, then I can order remanufactured upgraded valve bodies directly from companies like Sonnax - will be cheaper and comes with lifetime warranty!
Let me see ........NO
You are here for help, however, want to trivialize my request; by still not posting the data after you manually found you could, and didn't say anything about that before and wrote this babble?
Respectfully, was looking for conflicts/hardware issues based on control module configs.
Ones I might see from maybe things in my head .......you know this thing called life experience?
Oh I get it .......you want a magic answer......?
Bullshit! It's in the repair manual.......I just read it....... time to RTFB.
Do what is asked here if you want help or go fly the magic carpet to your local dealership.
Oh and I do see something even in your incomplete post........I'm not saying until I see your papers.
Magic ..........from this " 10010010101 " to this " 11010100100 "
kb100
UAE
C?ID=170650
Going by the level of hostility and sarcasm, I evidently must have done some cardinal wrong. Please accept my unconditional apology for any/all oversights.. But have you considered ...
1. Every now and then, you may come across someone who is distressed enough to have missed the fine print the first time around?
2. I am in the Ross-tech Forum. I understand (and completely agree) with your angst against people with pirated software/third party interfaces. However, here the moderators have VERIFIED me as a genuine cable user - else I would not have been able to post on this section/thread. I was directed to this forum by Peter from Ross-Tech support.
3. Please re-read that sentence of mine - with emphasis on the underlined part How will a scan of other modules help? (just for my understanding). I further went on to explain the struggles I've had with Auto Scan and how and why I posted what I did. What in that sentence - or the rest of my post - made you feel I was trivialising anything?
4. The only thing I "edited" was the last few digits of my VIN pertaining to my serial number from that scan report - more out of force of habit. We live in a world where we are encouraged not to put personally identifiable data on public forums.
5. Not everyone has access to repair manuals for a variety of reasons. I don't. I struggled to move my Bentley subscription when I moved laptops.. and finally gave up!
6. The only reason I am here is because I realise the "life-experience" is invaluable. I value and respect that - and no where did I mean or allude otherwise.
I run vagcom software on a Macbook Pro thru Windows7 on Parallels. I have largely used it for small things till date like SRI reset, TBA adaptations, Basic auto scan etc. I have not had a problem till date. When I pulled the cable out to run the test this time, it told me there is an upgrade from 15.7.1 to 15.7.2. I have not been able to run the auto-scan since I did the upgrade.
I have downloaded that version again, and reinstalled it. I will attempt to run the auto test now. If that does not work I will borrow a windows machine and run it.
Till then, request everyone to please cut me some slack. I mean no disrespect to anyone - I am a newbie, and not everyone gets it right the first time.
kb100
UAE
C?ID=170650
EDIT: Still getting the communication error on Macbook - Here are the screen shots
[/URL]
Here is the Full Auto Scan Report from my kids windows laptop . Please bear in mind I had deleted the fault codes from the auto-trans control module (ONLY - nothing else) last night. There were no fault codes anywhere else other than a tank flap error (works though) and an erratic reverse camera (works more often than not).
Monday,14,December,2015,13:39:19:00132
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WVGCE15N59W086615   License Plate: 14DEC15
Mileage: 131880km-81946mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4F 52 53 56 62
          6C 72
VIN: WVGCE15N59W086615   Mileage: 131880km-81946miles
Address 01: Engine (CAW)       Labels: 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 CG    HW: 06J 906 026 D
   Component: MED17.5             3978
   Revision: A7H06---    Serial number: VWX7Z0I03NS089
   Coding: 04230003190F0160
   Shop #: WSC 16414 000 1048576
   VCID: 71E9135068A99EB694-8024
Readiness: 0000 0001
   Part No SW: 09G 927 750 FF    HW: 09G 927 750 FF
   Component: AQ 250 6F           1173
   Revision: 00H76000    Serial number:
   Coding: 0000328
   VCID: 7AFB347C35DFDDEE25-802E
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000001713319
   Coding: 0010509
   Shop #: WSC 01324 020 00200
   VCID: 3979EB70705916F66C-806C
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 69D97B3040796676DC-803C
   Revision: 00H54000    Serial number: 00000009332532
   Coding: E58C8FA300041C0047190000140000000009FF475C400124420000000000
   VCID: 3365D9585235ECA6A6-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 280109  012 0203
   Coding: 00038805
   Shop #: WSC 01324
   Component: RLS     270109 046  0204
   Coding: 00208933
   Shop #: WSC 01324
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5N0 919 475 B    HW: 5N0 919 475
   Component: PARKHILFE 4K  H07 0023
   Revision: --------    Serial number: 11130902800288
   Coding: 300102
   VCID: 387FEE748B530FFE93-806C
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__201 VW10 HI   1916
   Revision: 20013000    Serial number: 003E1PRT9BE4
   Coding: 0012337
   VCID: 428B8C9C1D8F552E3D-8016
   Subsystem 1 - Serial number: 6332MTS629490219
   Subsystem 2 - Serial number: 6342MTS667070209
   Subsystem 3 - Serial number: 6351HTS61TPFV5KJ
   Subsystem 4 - Serial number: 6361HTS6RBO2V5KJ
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           855 0111
   Coding: 0001132
   Component: E0221           002 0030
   Part No SW: 5N0 920 870 C    HW: 5N0 920 870 C
   Component: KOMBIINSTRUMENT VDD 2422
   Revision: V0005000    Serial number: VWX7Z0I03NS089
   Coding: 0007604
   Shop #: WSC 76700 819 99972
   VCID: 306FD654A323D7BEDB-8064
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 170109F1001570
   Coding: FDA27F06004203006002
   VCID: 387FEE744B530FFE93-806C
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4B95A1B82AC59466CE-801E
   Component: IMMO            VDD 2422
   Part No SW: 5N0 959 701 B    HW: 5N0 959 701 B
   Component: Tuer-SG         008 2005
   Coding: 0000188
   VCID: 3467DA44573BEB9EBF-8060
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.098 0502
   Revision: 1AH02271    Serial number: 00083460032702
   Coding: 0000258
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component: A_ KSG PQ35 G2  020 0205
   Coding: 80800A0052831F7F3F058F0F70084F0BE0FC00
   Shop #: WSC 76700 819 105483
   VCID: 0305499842159C2676-8056
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 136
                    Mileage: 131881 km
                    Time: 17:01:46
Address 4F: Centr. Electr. II (J533)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 66C3700C9167490EF1-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 5N0 959 702 B    HW: 5N0 959 702 B
   Coding: 0000188
   Shop #: WSC 97675 767 92568
   VCID: 3561E7405C41F29688-8060
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000182559
   Coding: 0000057
   VCID: 2E53C82CB917C14EC9-807A
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 190     HW: 3C8 035 190
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4297236
   Coding: 0500040004
   VCID: 60CF66147343273E0B-8034
   Part No SW: 5N0 959 703 B    HW: 5N0 959 703 B
   Component: Tuer-SG         007 2001
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   VCID: 3663E04C4147F98E81-8062
   Part No SW: 5N0 907 441     HW: 5N0 907 441
   Component: J772__Rearview      0021
   Revision: 00H05000    Serial number:    PA8 J910742
   Coding: 0020010
   Shop #: WSC 01324 785 00200
   VCID: 6CD702244F8B735EA7-8038
02203 - Audio / Video Input 1
                    Reset counter: 136
                    Mileage: 131842 km
                        Reverse OFF
                    Count: 3
02283 - Video Connection to Output [End Unit]
                    Reset counter: 175
                    Mileage: 131842 km
                        Reverse OFF
                    Count: 3
   Part No SW: 5N0 959 704 B    HW: 5N0 959 704 B
   Coding: 0000144
   VCID: 377DED48464D00869A-8062
End-------------------------(Elapsed Time: 02:10)--------------------------
The scan contains other information that is above your understanding and helps others sort your config to try to help you........ not just detection of pirates.
For example in addition things like this.
Component: MED17.5 3978 <<<<<<<<<<<<<<<<<<<<<<<<<<<< I now can see that this has been through a couple updates.......
However!
Component: AQ 250 6F 1173 <<<<<<<<<<<<<<<<<<<<<<<<<< I can see that the trans is not up to date and belongs at SW 1700 or higher.
Since you have a trans issue, maybe it would be a good idea to get the update...........?
Now stop whining and go get it done.........In addition, take the VB off, & have it tanked + check the noids for load operation.
Consider an ATF that is slightly thicker, to deal with heat in your geographic region............this will help boost PSI of the ATF, and smooth out shift points.
kb100
UAE
C?ID=170650
Went to the Authorised Service Centre here and spoke to their Irish service manager. He mentioned how they faced a similar situation just last week where another Tiguan threw a TCC lock up error post ATF change. Apparently that went away when they did a transmission factory reset . He has asked me to bring the vehicle over on Thursday.
I have just joined a new job and mobility is critical. Hence decided not to wait till then and try this out myself from info gleaned from multiple threads/forums.
I first went into the engine module and did a TBA and Kick Down Adaptation. Then went into the Auto Trans module and did the kick down adaptation/retun to factory settings as detailed here http://wiki.ross-tech.com/wiki/index.php/6-Speed_Automatic_Transmission_(09G)
Kick-Down Adjustment
Prerequisites:
No fault codes in the Auto Trans.
Throttle Body Alignment (TBA) performed successfully when applicable
Ignition on, engine off.
Do not touch the accelerator pedal.
[Select]
[02 - Auto Trans]
[Basic Settings - 04]
Set Group to "001"
[Go!]
System in Grundeinstellung will be displayed
[Done, Go Back]
Wonder if there is anything more to be done? Is the OE approach/equipment more detailed/exhaustive?
I have not driven the car after that - will update effects if any.
Defaults and basic settings are typically a good idea with a transmission service ........however, an unrelated application in some mechs/DSG etc. it may be the end of the clutch's if you do.
kb100
UAE
C?ID=170650
Now this makes absolute sense. My mistake - apologies once again.
Would you be able to tell me if this is the latest? The last time this was updated was when my ECU blew and had to be replaced 25 months back. They must have flashed the then current version. They charged my the equivalent of US $ 2500 for this! (The dealerships these parts are absolute monopolies - so pretty much ask whatever they want!)
However!
Crap! Wish I'd known this an hour back!
Like most service centres, they need to be 'convinced' that there are updates that needs flashing. Given my problem guess that should be easy enough.
In the midst of all this I did fleetingly consider things like the the Lucas Transmission Fix that I read about online. Did not have the courage to go thru. Any advice on that (or any other product you may recommend?)
VB - unfortunately we have a predominantly replacement market here. Not much of diagnostic skills. I went to a transmission shop - apparently Sonnax distributors here - to enquire about the possibility of buying the upgraded valve body that Sonnax had on their website. (What was nice is the lifetime warranty.) They were more interested in pushing a transmission rebuild - without being specific as to what they will change/upgrade etc. Was not confidence inspiring. Dont know if they have machines to check flow etc. I don't want it to be a solenoid swap alone.
Worst case i don't mind importing a fully rebuilt unit from the US.
kb100
UAE
C?ID=170650
Well - SOLVED! :thumbs:
Guess the authorised service centre was right after all! An factory reset of the TCS seems to have solved the problem!
For the benefit of others who may face the same problem let me detail the steps here.
After multiple diagnosis's by everyone ranging from gearbox specialists thru to valve body specialists and VW specialist garages, what emerged was the error shrown was a Mechanical error - as such very limited options other than a rebuild (VB+GB). Unfortunately I was not getting anywhere with diagnosing the faulty part. Thats when I thought of going to the VW service centre in the hope that their diagnostic tools will be able to drill down and highlight the faulty part. Unfortunately they are a monopoly here in the UAE, and as such they are extremely busy and one needs to book a slot over a month in advance (no joke!). I decided to have a chat with the service manager, who said coincidentally they had faced the same issue with another Tiguan where this very same error came after a transmission oil change. Apparently it went away after a factory reset. He wanted me to bring the vehicle in a week from then - and in case some booking drops out then he'll look into it.
Unwilling to wait I decided to try the reset myself. I did multiple things ... but the combination that finally worked was this.. (Original VCDS mandatory)
1. Everything listed here is done with the KEY ON but ENGINE OFF.
2. First delete ALL codes - everything .. esp in the engine and Auto Trans. (delete everything to be on the safe side - you never know which module talks to which one)
3. Go tho the engine module , double check for codes, and then run the Throttle Body adaptation from the Basic Settings tab. (as per the process for your car)
4. Wait for 30 seconds before exiting the adaptation screen.
5. Switch off the key and remove key from ignition for five secs, then put it back in and turn it on (engine off)
6. Go to the kick down adaptation in Engine Module and run that from the Basic Settings tab (as per the process for your car)
7. Again wait 30 secs before exiting the module and cycle ignition.
8. Switch to Auto Trans Module and check for errors if any (delete if you find any)
9. Run the factory reset .. Please pull the applicable process for your car from the Ross tech wiki .. Please pick you make and car from http://wiki.ross-tech.com/wiki/index.php/Main_Page Mine was this http://wiki.ross-tech.com/wiki/index.php/6-Speed_Automatic_Transmission_(09G)
[Select]
[02 - Auto Trans]
Set Group to "001"
[Go!]
[Done, Go Back
However wait for 30 seconds to hit DONE and exit the module (as with the cases above)
PS: The 30 second wait before exiting adaptation, and the ignition cycling may seem excessive - but I have learnt from experience that this is the best way of doing it.
THE END.
I took the vehicle for a drive - and the fault promptly came back. I could see the TCC slipping (I was monitoring Measuring Block Group 006/7 in Auto Trans) . After about 40 odd kms, I sensed the transmission 'tightening' up and noticed the slipping had stopped. I then deleted the DTC - and drove for another 50 kms thru all the gears - progressively more aggressively - ended with giving it the stick in every gear! The fault has not come back till now. I will continue to monitor it and report.
(One trick of knowing if your TCC is locking properly is your "instant mileage reading" in your MFD will show "---" when you coast in higher gears (typically 4,5,6, - it can also happen in 2nd and 3rd gears depending on a bunch of factors ). If your TCC is slipping the MFD will never show ZERO - it will always have some number there - however improbable it may seem (upto even 70kmpl in my case)
I will anyway be taking my car into VW service this weekend to get the latest version of all software for my car. Will put up an autoscan once done.
Fanaticism starts with actually following procedure, and ultimately procuring + reading the repair manual.
Basic settings are clearly described in the publication.
If being serviced at a shop............this should have been done during the service, not 100 KM after with a DTC.
Further.......... a quality check road test would of shown this......... had it been preformed before releasing the vehicle back into your custody..........
kb100
UAE
C?ID=170650
The oil change was done in a local garage - they do not do European cars hence can't blame them. (This was pretty much a DIY effort - took their help only for labour and facilities)
One learns something new every day... :)
Hopefully you will have learned to get the repair manual........
At least you own your faults ......that is the sign of an honorable person. :p
kb100
UAE
C?ID=170650
Well - I already paid for the Bentley when I picked up the VCDS cable - lost it when my laptop fried itself. Picked up a Mac this time around. Never got around to installing it on that since that Bentley stuff runs only on XP (and they were clear they had no intentions of patching/upgrading it) - and I did not want a third virtual machine! (I already have Win7 running on parallels - need it for my work)
Found a site with free online manuals - wonder if that will do ? ..
Why don't these people permit us to buy an installable/online version I wonder - we bought the vehicle dint we! (Makes searching etc very easy). Its either a subscription model- followed by lockout. (useless - since it does not come in handy when you need it). Perhaps there are ways one can still print it out and then digitise the whole thing ... but what a waste of time and effort. There must be some reason why they have it so!
Old man .. Old school :)
kb100
UAE
C?ID=170650
However!
Have done about 300 kms since the factory reset - absolutely no problem till now. One default benefit is the mileage seems to have really improved - by as much as 15-25%! (comparing the mileage from BEFORE the issue started). My MID is showing a solid 12.0-13.0kmpl trip average (earlier used to get around 9.5 at best!). DTE on a full tank went up from 550 to 700- 750kms! (combined cycle!)
I have managed a slot with the dealer tomorrow for running the updates. I intend to get updates for all the modules on the car. Does the old adage "Don't fix what is not broken" apply here? I have read in a few places that some of these updates should be done only if you have a problem (unless there is a recall/TSB to that effect from the manufacturer). Should I update only the TCM or should I go ahead and update everything possible?
What will you advice?
kb100
UAE
C?ID=170650
Okay - Got the update. Apparently only the auto trans had an update (ver1700) - the rest, according to the dealership, had none. They were pressed for time - so I don't know.
Here is the auto scan
Tuesday,22,December,2015,16:31:21:00132
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVGCE15N59W086615   License Plate: AFTER AT FLASH
Mileage: 132140km-82107mi   Repair Order:
          6C 72
VIN: WVGCE15N59W086615   Mileage: 132140km-82107miles
   VCID: 71E9135068A99EB68E-8024
Readiness: 0100 0101
   Component: AQ 250 6F           1700
   Coding: 0000328
   Shop #: WSC 42049 001 1048576
   VCID: 7AFB347C35DFDDEE3F-802E
   Coding: 0010509
   VCID: 3979EB70705916F676-806C
   VCID: 69D97B3040796676C6-803C
   VCID: 3365D9585235ECA6BC-8066
   Coding: 00038805
   Shop #: WSC 01324
   Coding: 00208933
   Shop #: WSC 01324
   Coding: 300102
   VCID: 387FEE748B530FFE89-806C
   Coding: 0012337
   VCID: 428B8C9C1D8F552E27-8016
   Coding: 0001132
   Coding: 0007604
   VCID: 306FD654A323D7BEC1-8064
   VCID: 387FEE744B530FFE89-806C
   Coding: 0000005
   VCID: 4B95A1B82AC59466D4-801E
   Coding: 0000188
   VCID: 3467DA44573BEB9EA5-8060
   Coding: 0000258
   Coding: 80800A0052831F7F3F058F0F7008CF0BE0FCE0
   VCID: 0305499842159C266C-8056
                    Fault Frequency: 13
                    Reset counter: 146
                    Mileage: 132123 km
                    Time: 17:36:59
   Coding: 050B0500
   VCID: 66C3700C9167490EEB-8032
   Coding: 0000188
   VCID: 3561E7405C41F29692-8060
   Coding: 0000057
   VCID: 2E53C82CB917C14ED3-807A
   Coding: 0500040004
   VCID: 60CF66147343273E11-8034
   Coding: 0000144
   VCID: 3663E04C4147F98E9B-8062
   Coding: 0020010
   VCID: 6CD702244F8B735EBD-8038
   Coding: 0000144
   VCID: 377DED48464D008680-8062
First impressions -
1. Well... the code has not come back
2. After the dealers TCM adaptation run the instant mileage seems to have taken a hit - about 10-15% lesser than before.
3. Pick up seems to be slightly better in gears 1 and 2 - but the rest seem to be a tad slower. (Butt Dyno)
On the whole, early days yet.
