DSG7 calculator blocked (2019 Tiguan)
saidi
Ales, France
C?ID=526854
Hello, I have a problem with a DSG7 gearbox on a T
Friday,21,February,2025,16:45:04:56271
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVGZZZ5NZKW301947   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 29 39 42 44 4B 52 5F 6C 75
          A5 BB BC CA D6 D7
VIN: WVGZZZ5NZKW301947   Mileage: 122218km-75942miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 QQ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6579
   Revision: B4H25---    CVN: 89AA9EF737C5C2A218229D33
   Coding: 0125003203641D083000
   ASAM Dataset: EV_ECM20TDI01104L906026QQ 004006
   ROD: EV_ECM20TDI01104L906026QQ.rod
   VCID: 0944F2EC69B4FEB2085-805C
   VINID: 9E65EAAAA15EA9B9C30012441C219894F2
   Part No SW: 0GC 300 046 A    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V10    CVN: 6C8BCC85
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 28029768927EA7BA37B-807C
   No subsystems:
10743 - Valve 2 in Transmission Part 1
          P173F 00 [00101110] - Electrical malfunction
                    Mileage: 122218 km
                    Date: 2025.02.21
                    Time: 16:40:18
                    Engine RPM: 0.00 /min
                    Coolant temperature: 43 °C
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -100 Nm
                    Control Module temperature: 20 °C
                    Accelerator pedal position: 14.9 %
                    DTC memory status: 55
21197 - Transmission Control Unit
          P1701 00 [00101111] - Locked
                    Mileage: 122218 km
                    Date: 2025.02.21
                    Time: 16:40:09
                    Driving position: P
                    Control Module temperature: 21 °C
                    DTC memory status: 244
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 61978000001381
   Coding: 0AEE6A9A34200B6D4780060462CA4950562CD0E2604692713862F078C222420B002E64121A03102F35351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 77A084140F40F8426E1-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0487671383 Dataset Number: V03935272HX 0001
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D820C40B1864E2029-8016
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 212
                    Mileage: 122218 km
                    Date: 2025.02.21
                    Time: 15:41:21
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 7.471 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 M    HW: 5NA 907 044 M
   Component: AC Automat    H35 4301
   Revision: 20K09000    Serial number: 00000B01029793
   Coding: 00020124202110011105100000101022
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 49C432EC2934BEB2C85-801C
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
                    Reset counter: 212
                    Mileage: 122218 km
                    Date: 2025.02.21
                    Time: 15:32:54
                    Outside temperature: 10.5 °C
                    Voltage terminal 30: 11.5 V
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001820200567 Dataset Number: V03935287EX 0001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7DAC963C2D7CD21234D-8028
   Subsystem 1 - Part No SW: 5NB 955 119 A    HW: 5NB 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 LL 180627  033 0372
   Serial number: 00000001806210309074
   Component: RLHS  052 0107
   Serial number: SBY18M07D20H17M14S42
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0160
   Serial number: 0100230720180C300971
   Part No SW: 3Q0 919 298 E    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0046
   Serial number: 002506187498040 Dataset Number: V03935297KS 0001
   Coding: 0231163851
   Shop #: WSC 04876 004 1048576
   ASAM Dataset: EV_EPHBO2CVW3260000 010019
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   VCID: 3FD02C3467F00002661-806A
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935279GP 0001
   Coding: 3200674358FF8728749C8145804087
   ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
   VCID: 3E2E513060FA090A6D7-806A
1389 - Function Restricted due to Insufficient Voltage
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 212
                    Mileage: 122218 km
                    Date: 2025.02.21
                    Time: 15:41:22
                    Voltage terminal 15: 8.6 V
                    Control Module temperature: 44 °C
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4E64XP Dataset Number: V03935268MW 0001
   Coding: 98CCC0C00C0000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 5NB857705C0199S00082
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 5NB857706C0198S00381
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 707 18
   Serial number: 3570000000054C58233E
   Subsystem 4 - Part No SW: -----------    HW: 480 002 707 18
   Serial number: 358000000005E67DC23Z
   Subsystem 5 - Part No SW: -----------    HW: 480 402 707 18
   Component: SideSensor_Dr  003 6149
   Serial number: 35100019B29FD1555447
   Subsystem 6 - Part No SW: -----------    HW: 480 402 407 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011C2B70F33852.
   Subsystem 7 - Part No SW: -----------    HW: 480 402 607 18
   Serial number: 35500011E2B70F61651/
   Subsystem 8 - Part No SW: -----------    HW: 480 403 007 18
   Component: PedP_Sensor_D  003 6149
   Serial number: 2280001B329F2613352W
   Subsystem 9 - Part No SW: -----------    HW: 480 403 007 18
   Component: PedP_Sensor_P  003 6149
   Serial number: 2290001B329F2615F445
   Subsystem 10 - Part No SW: -----------    HW: 480 403 007 18
   Component: PedP_Sensor_C  003 6149
   Serial number: 2300001B329F261461BY
   Subsystem 11 - Part No SW: -----------    HW: 480 002 007 18
   Serial number: I0M000000008245CB231
   Subsystem 12 - Part No SW: -----------    HW: 480 002 007 18
   Serial number: I0N000000006245CB230
   Part No SW: 5NA 920 791 C    HW: 5NA 920 791 C
   Component: KOMBI         403 4191
   Coding: 07A401086F84000801886A031401000800000000
9634288 - Transmission Control Module
          B1301 F0 [00001001] - Not Authorized
                    Mileage: 122218 km
                    Date: 2024.12.22
                    Time: 00:05:09
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 01071810803443 Dataset Number: V03935286KX 0001
   Coding: 030100045F0873002110025E180F00010001070000000000000000000000
   GVL: 01463C0000000400408C80008002C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D2C563C6DFC121274D-8068
   Generator:
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 1911819031401862FH2B
   Coding: 2D0000
   Serial number: 6238818604
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45DC3EDC052C5AD22CD-8010
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RGO30362 Dataset Number: V03935278PU 0001
   Coding: 003F1320D000048000001000
   VCID: 44DA23D80E1663DA3B3-8010
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 855016 00  Dataset Number: V03935285PV 0001
   Coding: 0101001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
   VCID: 2B08686483888CA2DA9-807E
   Component: FCM MQB Low   002 0342
   Serial number: 02071810801007 Dataset Number: V03935275YQ 0001
   Coding: 00000005090008C200104F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353C4E1C55CCCA52BCD-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RGD09827 Dataset Number: V03935278PW 0001
   Coding: 003F1120DC00048000001000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     851 0867
   Serial number:                Dataset Number: V03935281HF 0001
   Coding: 02730601FF0000005111000100080A001F0500E4012000008E
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 31347A0CA1A4E672E05-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV1942823
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Dataset Number: V03935281GJ 0001
   Coding: 0123060122002017000040
   VCID: 3924422C79D42E32585-806C
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0824
   Revision: --------    Dataset Number: V03935278EW 0001
   Coding: 02230601EA42380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW32.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 27071812K12784 Dataset Number: V03935276EA 0001
   Coding: 000307060000040100221344C140A90094000E200040
   VCID: 3C2A5B3876E61B1A433-8068
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RGC0722D Dataset Number: V03935278PZ 0001
   Coding: 002A11200101048000001000
   VCID: 4ECE01F0D05A998A9D7-801A
   Component: TSG HBFS003 0187
   Serial number: YE007RGE21466 Dataset Number: V03935278PX 0001
   Component: SAD_STG_1     005 0002
   Dataset Number: V03935279TX 0001
   Coding: 608040732602
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75BC8E1C154C8A527CD-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 0052EFC85A8EBFFA5FB-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
iguan after changing the mega tronic. I have the following fault codes.
saidi
Ales, France
C?ID=526854
Tiguan
saidi
Ales, France
C?ID=526854
SORRY I have a problem with a DSG7 gearbox on Tiguan after changing mega tronic I have the following fault codes
saidi
Ales, France
C?ID=526854
yeah already come.
thanks for your info thank you very much for the help you give
saidi
Ales, France
C?ID=526854
it's good I know what I have left to do I will keep you informed once I have coded all that
