coding a second hand ecu on mk5 gti
Shafo
South Africa
C?ID=163752
Hi guys
Ive got a golf 5 gti with a faulty ecu..i have a second hand ecu i want to use but im having difficulty coding it...
I was able to retrieve the cars original pin aswell as the new (second hand) ecu pin! So i plug the new ecu in and go to engine...security access...security login....enter the new second hand ecu pin and it accepts login...next i go to adaptions and channel 50...i enter the original car pin and it accepts. ..so im under the impression it should then take that pin and change the new ecus vin to that of the car...but it doesnt...when i try to login again it says error 37 security wait time....what am i doing wrong?how do i read what the actual security wait time is? (No value indicating it in the ecu measuring blocks)..when i go to immobiliser and read security wait time there it says 0 for both cluster and ecu....could someone please give me a detailed explanation on how i do this..
Many thanx
Ps med9.1
Shafo
Please post an Auto-Scan from this car so people can see what it's made of.
Shafo
South Africa
C?ID=163752
Damn il only be back at work on monday so il do it then...is the coding procedure not standard for this vehicle type tho? Immo4?
golfi_vend
Tartu, Estonia
C?ID=195131
Immo 4A or Immo4C - which one? :)
Shafo
South Africa
C?ID=163752
Will post autoscan asap
Shafo
South Africa
C?ID=163752
VCDS Version: Release 15.7.2 (x64) Running on Windows 7 x64
Data version: 20151124
Monday,14,December,2015,09:11:04:48700
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: AAVZZZ1KZ8U027768   Mileage: 106330km-66070miles
01-Engine -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H23ND8T8
   Coding: 0403001018070160
   Shop #: WSC 00046 412 00000
   VCID: 356799535CFF4A9688-8060
005476 - Throttle Actuator (J338)
               P1564 - 002 - Under-Voltage during Basic Setting
                    Fault Status: 01100010
                    Mileage: 106335 km
                    Time: 00:13:07
                    Temperature: 20.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 870.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E3674B120B14A666-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78F950670B6D77FE53-802C
   Revision: 00H54000    Serial number: 00000008173634
   Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
   VCID: 71EF6D43681726B694-8024
   Component: Wischer 230408 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: RLS     290308 046  0204
   Coding: 00208933
   Shop #: WSC 00046
8 Faults Found:
                    Fault Status: 01111100
                    Reset counter: 54
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 54
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.60 V
                    Reset counter: 54
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.60 V
                    Reset counter: 54
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.60 V
                    Reset counter: 54
                    Mileage: 106335 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.20 V
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                    Reset counter: 94
                    Mileage: 106335 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 94
                    Mileage: 106335 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.00 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 94
                    Mileage: 106335 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.00 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1RYJNO
   Coding: 0013121
   VCID: 3D77817364CF92D640-8068
   Subsystem 1 - Serial number: 6332MSME2E45101CA
   Subsystem 2 - Serial number: 6342MSME33710B142
   Subsystem 3 - Serial number: 6352QSME53680B0DN
   Subsystem 4 - Serial number: 6362QSME4C683273N
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01589 - Igniter for Head-Airbag; Passenger Side (N252)
            007 - Short to Ground - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0100
   Coding: 0002022
   VCID: 010F3D8358B7363664-8054
   Part No SW: 1K6 920 874     HW: 1K6 920 874
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H23ND8T8
   Coding: 0004103
   VCID: 70E96847631D2FBE9B-8024
                    Fault Frequency: 55
                    Reset counter: 54
                    Mileage: 106335 km
                    Time: 00:46:41
                    Reset counter: 94
                    Mileage: 106335 km
                    Time: 00:00:21
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K082158149
   Coding: E9817F060002020003
   VCID: 3069A847A39D6FBEDB-8064
                    Reset counter: 54
                    Mileage: 106335 km
                    Time: 00:13:32
                    Reset counter: 54
                    Mileage: 106335 km
                    Time: 00:13:33
01304 - Radio
                    Reset counter: 54
                    Mileage: 106335 km
                    Time: 00:13:37
   Component: IMMO            VDD 2216
   Component: Tuer-SG         006 1210
   Coding: 0000692
   VCID: 387990674BEDB7FE93-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 36659E5F41F9418E81-8062
                    Mileage: 106320 km
                    Temperature: 37.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
            000 -  -
                    Mileage: 106320 km
                    Temperature: 36.0°C
                    Voltage: 9.30 V
                    Voltage: 9.10 V
                    Mileage: 106320 km
                    Temperature: 25.0°C
                    Voltage: 9.40 V
                    Voltage: 9.20 V
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 199002005103087F2D040F0F70085FC690FC00
   VCID: 0303378B42AB242676-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Coding: 0000692
   VCID: 397F956370E7AEF66C-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E164571705139E7F-8020
00070 - Starting Battery Voltage
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
00099 - Rear Right Central Locking (Safe) Motor (V164)
End-------------------------(Elapsed Time: 01:38)--------------------------
Shafo
South Africa
C?ID=163752
this is the autoscan of my original ecu...will really appreciate help guys
ECU and Cluster serials start with VWX, so it's Immo 4c, which is what I'd expect for a 2008 model year (from the VIN).
Maybe Jack or Jetta97 have some ideas how to proceed.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
On this car with system you have , It is not possible to do this with VCDS.
I'm sure a new key is not possible, I have a fuzzy recollection that Jack had found a way to match an ECU...
Shafo
South Africa
C?ID=163752
Calling Jack!
