Hello everyone. Haven't been around here for a while. Long story.
Of course it is not question of if I'll be back, but when... Well the moment came to ask again the collective (and single) wisdom to solve a pickle.
Thing is I sold my old warrior 1992 Passat and jumped on 2009 golf V avant (mexican made) 1.6 102PS BSE with 5 speed gearbox. The car is in amazing condition! I couldn't believe mu luck with it. Initially I thought the odometer was rolled back significantly, since it was showing only 127some t.km. but the moment I started pulling off it original parts I was a believer! (When I saw her face...
) Fuel filter with manufacturing date 08.2008. water pump 44th week 2008... very ground down front rotors with VW/Audi logo, Mexico and min.th. in inches... I mean-come on!
And since this is my usual self (nail in a bag) I decided, after only 2k kilometers on it that this gearbox is annoyingly short and this car definitely can use 6th gear.
Then it started to get complicated...
It was almost two months now in research what will do as a swap... I'm starting to miss the good old days when you could slap any ol'gearbox to anything and it was fine... apparently not anymore..
So all of the digging done led me to a very similar gearbox to mine, practically identical up to 5th.
Good people told me of possible issues with the engine brain if the ratios of the original and the swap differ significantly, so this stuck to the back of my head. After almost giving up the whole idea I finally noticed ( duh!) that engine brain can be coded to 6 speed manual! Oh joy! But short lived...
For some reason the ECU tells me the request is out of range...
And here is the reason for this excessively long post...
WHY!!?
So sorry if I bored you to death but I would really like to know is this swap going to be such big of a deal as certain sources tried (and succeeded) to scare me, and if so how can I tell the ECU it runs with 6th gear from now on... Mind you, again, my original gearbox is JHT and as a replacement I have found HBM. Both are 02T trannys, Both are practically the same.
Here is an autoscan if it will help somehow...
WHY!!?
Wednesday,19,February,2025,17:16:41:50573
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ1KZ9M314949 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9M314949 Mileage: 129410km-80411miles
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 GG
Component: SIMOS71 1.6l 2VG 1025
Revision: --H04--- Serial number: VWXBZ0J0034782
Coding: 0004071
Shop #: WSC 00066 000 00000
VCID: 6A8DC58CF073B18AE1F-803E
VINID: 9E69EAAAA05BA8974304424424E8DD9D17
Readiness: 0110 1101
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B200D092300FE881404E8902200403000
Shop #: WSC 04532 002 1048576
VCID: 76B5E1FCB8CB656A757-8022
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D7E4D6AF4B5AAFB-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000001146248
Coding: 118C83170004100F000F00001C00000000196F0E1900010C000000000000
Shop #: WSC 00066 123 12345
VCID: 333318E8E7393042929-8066
Component: Wischer 140109 021 0501
Coding: 00038805
Shop #: WSC 00066
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 205
Mileage: 129415 km
Voltage: 12.40 V
Component: 5P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD29319U
Coding: 0013648
VCID: 3D273ED0D17DF63274D-8068
Subsystem 1 - Serial number: 6332MSME4244383BA
Subsystem 2 - Serial number: 6342MSME434616220
Subsystem 3 - Serial number: 6351HSME1A4965248
Subsystem 4 - Serial number: 6361HSME1B2C2C019
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0003042
VCID: 015F8220ED0552D2505-8054
Component: E0221 002 0010
Part No SW: 1K0 920 864 A HW: 1K0 920 864 A
Component: KOMBIINSTRUMENT YJU 4005
Revision: V0010000 Serial number: VWXBZ0J0034782
Coding: 0003103
Shop #: WSC 01360 264 95858
VCID: 2A0D058C30F3718A21F-807E
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 051108F2000924
Coding: E9807F06400202002002
VCID: 372B2CF8F341DC62AE1-8062
Component: IMMO YJU 4005
Address 37: Navigation
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000779189121
Coding: 0000180
VCID: 6FBBD498CB9154A2B61-803A
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 68 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C0103943A076FBAD33-8078
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 8090020052834E7E0004840560044F0240FC20
VCID: 03538828F71940C2429-8056
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08102111341002
Coding: 0000180
Address 56: Radio
Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003737598
Coding: 0000144
VCID: 75B7E6F0A9CD6E727CD-8020
Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003752328
Coding: 0000144
VCID: 76B5E1FCB4CB656A757-8022
End----------(Elapsed Time: 01:10, VBatt start/end: 12.4V/12.4V)-----------
