Amarok 2.0 TSI , No Spark - No Fault Codes
Ashmeer
South Africa
C?ID=490848
Hi Guys,
Hope you are well.
Have a long story here that I need some advice on.
Short Story - Theres no spark.
Long Story:
My Dads Amarok, had damaged piston rings and once the motor was opened, we discovered the timing guides were damaged as well. so we replaced all of that(chain, guides, tensioners, camshaft sensor, gaskets, rings etc). once everything was put back together, we found that there wasnt any spark, so sent the ECU in for testing, the first company said that there was an issue but would cost alot to repair with no guarantee, so took it to someone else, who said that there wasnt any issues with the ECU. Finally took it to a third person and they said there definitely is an issue with the ECU(apparently a few diodes were an issue). After his repair and also bringing in another ECU(which was immo'd off apparently - also from the same model) we still dont have any spark(he said he will test again and check what the issue is).
We also have an audi with the same engine, swapped over the coils and crank sensor to the audi and it starts, so we dont think theres an issue with the coils or crank sensor
We tested and traced wires for continuity, we found that on the coil there is power, but no power on the signal wire (purple wire).
Today, I read thread that said the hpfp could cause such an issue, but I am not sure if that would cause an issue with spark, we notice that the fuel line coming from the lpfp in the tank gives very little fuel to the hpfp, like small pulses. So I am not sure if that might be an issue(perhaps the low pressure/no fuel is causing the ecu to cut the spark as a form of protection).
i have checked the pressure on the pumps with vcds and they seems to be in line with the specs according to what I have read.
I have posted an autoscan below as well some advanced values taken today.
Any Ideas would be appreciated
Thank you.
Tuesday,18,February,2025,18:50:46:45496
VIN: WV1ZZZ2HZB8081291   License Plate: AMAROK
Mileage: 250110km-155411mi   Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 25 69
VIN: WV1ZZZ2HZB8081291   Mileage: 250110km-155411miles
08-Auto HVAC -- Status: Cannot be reached 1100
Address 01: Engine (------CFPA)       Labels: None
   Part No SW: 2H0 907 115     HW: 2H0 907 115
   Component: 2.0l R4/4V TF H06 0002
   Revision: P8H06---    Serial number: 00000000000000 CVN: B09AD1E0
   Coding: 01190012430500010000
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_ECM20TFS0112H0907115 004001
   ROD: EV_ECM20TFS011_VN81.rod
   VCID: 619E595D71C2B182305-8034
   VINID: 9E606AAAA098A9220020108904DF2CA282
4527 - Coolant Fan Control Circuit 1
          P0480 00 [00100111] - Electrical Malfunction
                    Engine RPM: 0.00 /min
                    Coolant temperature: 21  C
                    Intake air temperature: 21  C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 12.274 V
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
                    Mileage: 250111 km
                    Date: 2025.02.18.
                    Time: 00:00:01
                    Voltage terminal 30: 12.227 V
4629 - ECM Power Relay Load Circuit
          P068A 00 [01100101] - Opens Too Early
                    Coolant temperature: 20  C
                    Voltage terminal 30: 12.510 V
Readiness: 1110 0100
Address 03: ABS Brakes        Labels: Redir Fail!
   Part No SW: 2H0 907 379 H    HW: 2H0 907 379 B
   Component: ASR MK25 E          0107
   Revision: 00H23001
   Coding: 0000070
   VCID: 3536DD0D994A6D22BCD-8060
Address 08: Auto HVAC
Address 09: Cent. Elect.
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00C H06 0013
   Revision: --------    Serial number: 003HN003MZS2 Dataset Number: 2H0003v____ 0157
   Coding: 000000000000000000000000000000003043
   Shop #: WSC 07446 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3332E3159BBE7312929-8066
   Serial number: 3555YRB405108IEIL8T1
   Serial number: 3565YRB405308IEIMPF8
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 250111 km
                    Date: 2025.02.18.
                    Time: 00:07:59
   Part No SW: 2H0 920 850 A    HW: 2H0 920 850 A
   Component: KOMBI         H05 0304
   Coding: 170000
   ROD: EV_Kombi_UDS_VDD_RM09_004_VN81.rod
   VCID: 231213552B5EE392629-8076
   Part No SW: 6N0 909 901     HW: 6R7 937 085 D
   Component: GW-K-CAN TP20 0022
   Revision: -5------
   Coding: 742100
   Shop #: WSC 07462 790 50316
   VCID: 70B82C19AAA8080AAFB-8024
   Component: IMMO          H05 0304
   VCID: 6A8C3E718CF4F2DAE1F-803E
   Revision: 3A001001    Serial number: 00000158747715
   Coding: 0100000100000000
   VCID: 3038EC196A28480AEFB-8064
End----------(Elapsed Time: 00:55, VBatt start/end: 12.4V/12.4V)-----------
Tuesday,18,February,2025,19:50:35:45496
VIN: WV1ZZZ2HZB8081291   License Plate: AMAROK2
                Address 01: Engine  (2H0 907 115 )
19:50:23
  IDE00019   Voltage terminal 30 12.274 V
  IDE00201   High fuel pressure: specified value 6.0000 MPa
  IDE00202   Low fuel pressure: specified value 500.0 kPa
  IDE00357   Fuel temperature -48.0 °C
  IDE00589   Fuel pressure 110 kPa rel
  IDE01378   Fuel high pressure: control deviation 5.7915 MPa
  IDE01773   Misfire totalizer 0
  IDE01774-ENG103277   Status misfire recognition-Channel 232 locked
  IDE01893   Fuel pump: specified value 10.001 %
  IDE01975   Numb.of misfir.: cylinder 1 3435
  IDE01976   Numb.of misfir.: cylinder 2 64469
  IDE03963   Low fuel pressure adaptation value for EFP 10.0 kPa
Ashmeer
South Africa
C?ID=490848
Hi Guys,
Any Ideas? Thought we might look at the cam rpm, which is quite low. perhaps the low speed causes ecu not to release spark output
Should be half of engine RPM at all times. If not, there's an issue with the sensor(s).
Log the crank sensor... does it register rpm while cranking?
Look at WDs... what's your trigger wire supposed to get signal from? Check the other end of said wire!
Ashmeer
South Africa
C?ID=490848
Checked every single wire for continuity, all perfectly fine...
Got an electrician out today, and he comes in with his own crank sensor...and now by some miracle we have spark.
Strangely enough we removed the old sensor placed in Audi and it started right up. So we definitely didnt think it was the Crank Sensor.
However, it still isn't starting as the compression is very low(around 2 Bar -29Psi), if im correct it should be around 125 to 175psi per cylinder.
Also picking up a P157000 code(but this is because apparently the ECU has been immo'd off, cant post autoscan because Im not with the vehicle today)
So now we have to check on the mechanical side, as to why the comporession is low and once that is done hopefully it starts up.
Thanks Alot Guys.
Seems as if everytime I come here I learn something new
