1k Golf Handbrake light flashing.
HCAE
New Zealand
C?ID=213797
Hi All
This cars handbrake light comes on with a beeeeep and then has a flashing handbrake light. I have checked the fluid level, handbrake switch (on VCDS MVB too) and are OK. Code in Engine for 006419 - Pressure Sensor for Brake Boost (G294) and in ABS for 01435 - Brake Pressure Sensor 1 (G201) come up (see auto scan for more details). After erasing the codes, let the engine sit and idle (for as long as you want), the codes will not come up. As soon as we get moving (about 20kmh) the handbrake light comes back. No ABS or engine check lights. All MVB for brake light switch, brake pressure and brake boost pressure are all normal. We performed a basic setting on the G201, still the same. G201 sits at about 3.8 at rest, and goes up to 100ish when pressed hard.
Any thoughts?
Friday,11,December,2015,16:06:32:55685
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WVWZZZ1KZ6U018808   License Plate: HZK262
Mileage: 60320km-37481mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ6U018808   Mileage: 60320km-37481miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 DN    HW: Hardware No
   Component: MED9.5.10        00 9970
   Revision: --H01---    Serial number: VWZ7Z0E2726982
   Coding: 0000075
   Shop #: WSC 52973 000 1048576
   VCID: 72EBC8B36D76A4AE6D-8026
               P1913 - 008 - Short to Ground - Intermittent
                    Mileage: 60319 km
                    Time: 06:46:52
                    RPM: 1800 /min
                    Load: 42.7 %
                    Speed: 17.0 km/h
                    Temperature: 84.0°C
Readiness: 1110 0001
   Part No: 09G 927 750 FA
   Component: AQ 250 6F           0707
   Coding: 0000072
   Shop #: WSC 00046 412 00000
   VCID: 75E1F3AF1C18B39648-8020
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 R    HW: 1K0 614 517 R
   Component: ESP FRONT MK60-AT   0103
   Revision: 00T12001
   Coding: 0021122
   VCID: 366334A3419EF88E81-8062
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   VCID: 6BD5D5D74A5C7566AE-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005155012
   Coding: 008D0F2700041800001400001400000000087B075C
   VCID: 2A5B10D38526AC6E15-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00049109
   Shop #: WSC 00046
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 15 AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD03GNGB
   Coding: 0012597
   VCID: 39793F9F708017F66C-806C
   Subsystem 1 - Serial number: 6332MSME0D021E4AF
   Subsystem 2 - Serial number: 6342MSME0C3727519
   Subsystem 3 - Serial number: 6352QSME05490F1FQ
   Subsystem 4 - Serial number: 6362QSME0613214B6
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenksäulenmodul 034 0070
   Coding: 0010002
   Part No: 1K0 920 852 A
   Coding: 0003503
   Shop #: WSC 90030 981 138284
   VCID: 275DE9E7963491060A-8072
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A01830A
   Coding: 3F3F0340070003
                    Reset counter: 90
                    Mileage: 35229 km
                    Time: 15:50:36
01304 - Radio
                    Reset counter: 90
                    Mileage: 35229 km
                    Time: 15:50:39
   Component: IMMO            VDD 1212
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2468
   Coding: 0000694
   VCID: 377D39A7469401869A-8062
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 33650DB752ECEDA6A6-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AM
   Coding: 00C802087F2D8405485F01E010CC
   VCID: 7BF5E5973A3CE5E63E-802E
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0000694
   VCID: 387F3A9B4B8A0EFE93-806C
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 34670EAB57E2EA9EBF-8060
End-------------------------(Elapsed Time: 01:37)--------------------------
Gone But Not Forgotten
Bad wire, PSI sensor or controller .........get WD and trace tracks + check the grounds and ability to carry current..
Jef
HQ
The "handbrake switch", or as we call it, the parking brake, is the F9. It is wired to the J285 instrument cluster, T36/6. As best I know, the F9 is not monitored via the data port, so there is no data to look at with VCDS.. just the warning light in the instrument cluster.
I'd start with taking a the switch on the parking brake lever.
