Nathan. Hi. Not your fault, but withstanding the authorship of the post on your link - the original creator of this tweak was "dmc_" (who is a forum colleague on VW Vortex). The net is replete with examples of such copies which have no attribution and the original authors can either consider this to be outright plagiarism, or the most sincere form of flattery - the latter view is far less stressful IMO!
Anyhow, the tweak was originally intended (by dmc_) to disable the recent practice on your NAR mk7s, not to illuminate the cluster display when the rotary light switch was on the parking light position (hence the setting that is used : lds - which is what VW call their rotary light switch).
On older model clusters for the mk7, the Illumination_algorithm-Scale_switching_algorithm isn't available-so I can't test my hypothesis. But there are other settings in the earlier adaptation channel which has the simpler descriptor illumination_algorithm. If the channel in the more modern version of the instrument cluster also have other options - you could experiment with these settings (I suspect) which may deliver a more appropriate lighting effect - maybe.
Hi Don, yes, unfortunately it's not surprising that the original creator wasn't credited. I tried to do so by posting the link instead of copying/pasting the tweak, but of course I didn't know to go any deeper than that.
With the setting at lds, the cluster lights are on in any position except "off". This is the first tweak I have seen that enables ALL of the cluster lights to be on in "auto" mode. I believe you have shared a tweak before that turned on the steering wheel and button lights but not the instruments.
Unfortunately "lds" and "parking_light" were the only options on that channel.
