Security Access for USA 2016 MK7 Golf R - 17/Instruments
HDClown
C?ID=61732
I'm trying to do a tweak provided by DV52 to adjust the curves on the cluster light sensor, which requires Security Access to modify the necessary Adaption channels.
I've tried 20103, which DV52 has provide as working on other MK7 Golf platform cars, but it's not accepted on my car no matter what I try. I've tried it with ignition power only and with engine running, but it always says the code is not accepted.
Here's an AutoScan. Note that the malfunctions listed were caused by me when I disconnected the overhead console to install a homelink module.
Wednesday,09,December,2015,09:06:43:43055
VCDS Version: 15.7.3.0
Data version: 20151124
VIN: WVWLF7AU4GW136712   License Plate: 2016VWGOLFR
Mileage: 2182km-1355mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN: WVWLF7AU4GW136712   Mileage: 2182km-1355miles
Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 091D00122426000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H_VW37.rod
   VCID: 458BBB3CC409C91602-8010
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01508230699
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 53AF95643A5D67A69C-8006
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62575000000140
   Coding: 01FA6BA154230972057E030141C56980D62A90A0C08296B7004000D8C208
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 79F307CCF8717DF636-802C
   Revision: 00021000    Serial number: 0381191442
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A71D8C0BDF7B6EE7F-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004100100000005004012111402
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 6AD128808DD7C66ECF-803E
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061526100485
   Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 01036F2C90A125367E-8054
   Slave 1:
   Component: WWS    150707  043 0551
   Serial number:         150804121608
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y15M08D20H08M24S55
   Coding: 90A8DD
0263 - Supply Voltage for Interior Lights
          B1314 11 [008] - Short to Ground
                    Reset counter: 70
                    Mileage: 1849 km
                    Date: 2015.11.21
                    Time: 16:18:06
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 28091541350477
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3777C1F48EE5AB8680-8062
   Serial number: 003GCR03H5SP
   VCID: 4797B134FE05DB06F0-8012
   Seat occupant detection; front passenger side:
H11 0021
   Serial number: IBH0000000000034ZH8R
   Coding: 42462D4765776963687473732E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 609 15
   Serial number: 35700000000CDC45661V
   Subsystem 3 - Part No SW: -----------    HW: 480 001 609 15
   Serial number: 358000000009748C561P
   Component: -----------  001 6149
   Serial number: 3510002AD1D25F7112D8
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3520002AB1D1B5D160DB
   Subsystem 6 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3550002C11CF2DA4B28K
   Subsystem 7 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3560002C11CF2DA5A22F
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 18091508490846
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 07177134BE851B0630-8052
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
   Coding: 0BAD081A3B80CF0502087A001400000000000000
   VCID: 2E59E49071BF6A4ED3-807A
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003980871
   Coding: 0101000830085900FB00022A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 75EB0BFCD469199652-8020
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001812010035385
   Coding: 31FFFF
   Serial number: HA1-00010.08.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4A918800ED17266EEF-801E
   Revision: 00000000    Serial number: 15000214022006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 346DF6F89F93409EA5-8060
   Serial number: 060915BI505416
   Coding: 003E13208000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 438FA524CA3DF7262C-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000007354588
   Coding: 111000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   ROD: EV_SteerAssisMQB.rod
   VCID: 3973C7CCB8F1BDF676-806C
   Serial number: 100915BI915411
   Coding: 003E13208000040000800000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 4281A020D527FE2E27-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000007504944
   Coding: 091000
   Coding: 022202010B000400
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 4085AA28DB2BEC3E31-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0245
   Serial number: VWZAZ2R0415075
   Coding: 027300020000000051220002001808001F0207F401200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 71E33FECA00135B68E-8024
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC0087X
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
9455635 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 79
                    Mileage: 1849 km
                    Date: 2015.11.21
                    Time: 12:35:41
9458195 - Control Module for Cellular Telephone
          B1052 13 [008] - Open Circuit
                    Reset counter: 79
                    Mileage: 1849 km
                    Date: 2015.11.21
                    Time: 12:35:41
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 150908201144
   VCID: 2F67F99476B56346D8-807A
End-------------------------(Elapsed Time: 04:55)--------------------------
HDClown: If you still can't get access to the instrument control module to implement the tweak, perhaps this alternative option HERE might be worth looking-at. I've not tried the alternative tweak, but the author, MRG_AU is quite a gifted colleague, so I'm confident that it will work. Of course, a consequence of implementing the tweak is that the DRLs will be illuminated when the rotary light switch is in the "parker" position, but this is only a minor matter - and it's possibly an added advantage (IMO).
EDIT: I've been having a nice chat with two of your compatriots on another forum about this issue. Seems that like you, they are having similar issues in getting 20103 accepted by this control module. Interesting bit is that they also have a 2016 "R" type mk7 of the NAR version and the PN/SW of the module is 5G1 920 858 A -like yours and 5G1 920 758 A. What's so special about this control module of the *** *** *58 A ilk - the "spiffy" cluster lighting perhaps? But why does this normally impact a security code? not sure!
PPS: One of the Chat-ees tried the "alternative" tweak that I identified above. He reported that it lit-up everything inside the cabin EXCEPT the cluster lighting - bummer!
Yomny
C?ID=264555
Can you try 31347
Just to make sure that the lack of access to address 17 module wasn't somehow connected with RT's software (apology to RT for any unintended insinuation), I re-tried 20103 on my car after loading the new 15.7.3 - and it was accepted first time! Got to be something peculiar in the unit installed in the NAR 2016 "R" type mk7, or the newer version module.
Question for anyone who knows - Has it happened in the past that security codes become ineffectual with subsequent releases of control modules?
EDIT: OK- Given Zenerdiode's response below, this tweak might not be accessible with these newer modules until someone, somehow get's hold of the new SA - bummer!!
Zenerdiode
Newcastle, England
C?ID=24330
Yes, the 46-BCM2 module on the Audi A5 changed the SA code from BCM2 2.01 to BCM2 2.1 and subsequent versions. There's a recent thread where someone was wanting to unlock the ADP channels to code in their new rear LEDs that I was able to chip-in with a different SA code. :)
nathan16mk7R
C?ID=264933
Nooooooooooooooooooooooooooooooooooooooooooo! So how can we help get the new SA?
nathan16mk7R
C?ID=264933
Bump, any way we can get the SA for the Instruments on the '16s?
nathan16mk7R
C?ID=264933
So there is no way to get the new security code?
nsap
C?ID=270351
Has anybody made any progress on this? I'm also looking for the instruments security code.
Coding: 0BAD081A3B80CF0502086A001400000000000000
VCID: 2E7DF7DC71E69C4ED3-807A
Xpower
C?ID=163029
I'm trying to do the same on my Octavia III MY2016, 20103 is now rejected where as it worked on my 2014MY.
No luck so far........
nsap: Can you try 25327 as the security code for the instrument control module and tell me if it works - please? I've just been given this number by a colleague on the VWW forum (thanks Zloybob)
dmc
Toronto, Canada
C?ID=8335
Confirmed working on a NAR MY16 7R. Thank you!
NEtech
Denmark
C?ID=56995
What are your ASAM data for the Instrument, ...VDDMQB... 009046, or ...JCIMQB... 009005 ?
Confirmed accepted by this one too:
   Coding: 0BAD08123B80CF0502086A001400000000000000
   VCID: AE104EEFF1A3C24E5D-80FA
dmc
Toronto, Canada
C?ID=8335
So I just attempted to modify the dimming_characteristic_curve_adjustment_internal_phototransistor set with no success. The code is initially accepted, but then going into modify the above adaptation results in the controller requesting security access again. I haven't tried any other adaptation channels, but I will do a little more experimenting...
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 0BAD08127F88880902886A0B5400000000000000
   VCID: AD5B11C3FC748F566A-80F8
Gizmo
S.E.Kent UK
C?ID=49193
AIUI some controllers use multiple security access codes, so whilst the code is initially accepted when you try to change a certain adaptation (the one you mention for example... which I have also tried without success) you find you need a different security access code.
For example the ABS has at least 8 valid log in codes, but I have yet to find one to change the ‘Drivers door status’
Would it be possible to have a ‘sticky’ thread with security access codes (and what they let you change)??
nsap
C?ID=270351
Thanks for posting, I saw this on VWVortex as well. Repeating myself on this, but when I tried to change the black ice warning temps, it failed due to the security code.
Xpower
C?ID=163029
So close :-(
This was also accepted on my module but won't allow changes to the dimming characteristic curve.
Surely now we know 1 code can't we use VCP to force attempt every combination that has been mentioned before.....
If some one is close who could lend me it I would leave it to its work in the workshop all day with a battery stabilisation unit on it.
It's an option
Sorry all - finding the correct security code for the instrument cluster on MY16 mk7s is proving to be the delicious futility of an impossible task!
But if you think about it Zloybob's contribution is a victory of sorts. The older security code (20103) applied universally to all adaptation channels in the instrument cluster - I believe. But because the code 25327 was accepted by the control module, can we correctly assume that the security code regime for the newer instrument clusters is much like that of the ABS module - where separate security codes are used for individual adaption channels (or a bunch of adaption channels)?
Clearly though the search continues
