Can onyone help to code the ABS (2015 A6)
firari
C?ID=145475
hi,
I am retrofitting my A6 2015 with original air suspension. I dont really know the code for the ABS unit. Can anyone support?
VIN: WAUZZZ4GXFN051376   License Plate: 11
Mileage: 188411km-117073mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 36 3B 3C 42
          44 46 52 53 5F 62 69 6C 6D 72 82 84 85 8B 8E 8F 90 A9 AC C0
          47
VIN: WAUZZZ4GXFN051376   Mileage: 188411km-117073miles
17-Instruments -- Status: Malfunction 0110
28-HVAC, Rear -- Status: Cannot be reached 0100
84-Night Vision -- Status: Malfunction 0010
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---    CVN: 070C81B22AA43454B866C2AD92F1EF3C63A632B8
   Coding: 122A403A257603030000
   Shop #: WSC 07443 002 104857
   ASAM Dataset: EV_ECM30BTD0114G0907589F 001008
   ROD: EV_ECM30BTD0114G0907589F_001.rod
   VCID: 377658828EA5ED2E3A-8062
   VINID: 9D196AAAA117A167801410C718EC279DB2
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRDW H19 1015
   Revision: --H19---    CVN: 43BF1921
   VCID: 77F69882CE252D2EFA-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49A79F4992E5F992BB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3F8630A2A695D56EF2-806A
200448 - Function Restriction due to Faults in Other Modules
          U1113 00 [00101111] - -
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    Uz: 99
200192 - Function Restriction due to Implausible Message(s)
          U1112 00 [00100011] - -
202240 - Control Module Incorrectly Coded
          U1014 00 [01111101] - -
          Confirmed - Not Tested Since Memory Clear
                    Mileage: 188161 km
                    Date: 2025.02.11
                    Time: 17:49:58
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 8A
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0560
   Coding: 05A96F0E000000000000
   VCID: 7CFC87AEFF030E7697-8028
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 15121400040707
   Coding: 369211B8350000
   VCID: 63CEDCD26ABDD18EB6-8036
0317 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
                    Voltage terminal 30: 11.91 V
                    Outside temperature: 10.5 °C
                    Engine RPM: 0 /min
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0311
   Revision: 14020001    Serial number: 00000969115002
   Coding: 2600001400749FE2818140C3A0001D0CCF9CE7082E090201000008206121150200400009090000
   VCID: 70E4A39EA34B7A163B-8024
   Component: WWS57X 141120  H37 0080
   Serial number:         141126191610
   Coding: 0045F7
   Serial number: 23559159
   Coding: 0200FD
   Subsystem 3 - Part No SW: 4G0 941 531 BH    HW: 4G0 941 531 BH
   Component: E1 - LDS  H07 0044
   Serial number: 25 11 2014  00000091
   Serial number: E2680267000000000001
00497 - Sensor for Vehicle Leveling; Rear
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56231434901356
   Coding: BA2B16
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 356A528A94A91F3E28-8060
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Serial number: 00000000000000 Dataset Number: 4G0909863D  0040
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 29528EFA48114BDEBC-807C
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1002KSD6 Dataset Number: 4G0909602J  0006
   Coding: 30333130313930313830554A304C34473053
   VCID: 3B7E44B2B28DC94EDE-806E
   Serial number: 3575HRB40552QMKA2OVB
   Serial number: 3585HRB405F2PMQ08PLE
   Serial number: 3515JRB405T32I4O9PP4
   Serial number: 3525JRB404R32Q98B0F9
   Serial number: 3554VRB405H33H8OE8N/
   Serial number: 3564VRB4053341DO9HGE
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NL8000BF
   Coding: 0004FD
   VCID: 38745BBE8BBBE25633-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 18 11 2014  E0059134
   Part No SW: 4G8 920 933 G    HW: 4G8 920 933 G
   Component: TDieRdwAccNv  H07 0043
   Revision: 03001036    Serial number: 658221114592012
   Coding: 138F12000F550008000000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 346C6F8E9FD306361F-8060
          U1014 00 [00001001] - -
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140722211905
   Coding: 5D3F01
   VCID: 264885C6510F64A691-8072
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001665126 Dataset Number: 4G0909515G  0018
   Coding: C0CD078118
   GVL: FDAFF94CD8A76C0F70040000
   VCID: 75EA928AD4295F3EE8-8020
   Serial number: 3349795203
   Voltage stabilizer:
   Serial number: 1409190000000000044A
5088 - Rear A/C control module
          U1072 00 [00001001] - No communication
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 24 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 020182646E6E645A5A253D3E00
Address 28: HVAC, Rear
   Dataset Number: 4G0909553H  0037
   Coding: 008003
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F6660E276F525EE62-807A
12 Faults Found:
198154 - Rear Left Ride-Height Sensor
          C1036 15 [00001001] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
198410 - Rear Right Ride-Height Sensor
          C1037 15 [00001001] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
198666 - Front Left Ride-Height Sensor
          C1034 15 [00001001] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:07
452874 - Front Right Ride-Height Sensor
          C1035 15 [00001001] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
453639 - Pressure Sensor for Ride-Height
          C1031 11 [00001001] - Short to Ground
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
206091 - Valve for Air-Spring Front Left
          C103C 13 [00001001] - Open Circuit
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:04
206347 - Valve for Air-Spring Front Right
          C103D 13 [00001001] - Open Circuit
                    Reset counter: 136
206603 - Valve for Air-Spring Rear Left
          C103E 13 [00001001] - Open Circuit
                    Reset counter: 136
206859 - Valve for Air-Spring Rear Right
          C103F 13 [00001001] - Open Circuit
                    Reset counter: 136
357643 - Bleed Valve for Ride-Height
          C103B 13 [00001001] - Open Circuit
                    Reset counter: 136
367877 - Ride Height Not Learned
          C1044 00 [00001001] - -
                    Reset counter: 136
266752 - Control module not coded
          U1013 00 [00001001] - -
                    Reset counter: 136
   Revision: AA000000    Serial number: 00000127720338
   VCID: 77F69882C6252D2EFA-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8208PD8F Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3668558689AF142621-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0580252237 Dataset Number: 4G0909535C  0008
   Coding: 040321
   Shop #: WSC 09260 004 104857
   VCID: 39725EBAB8B1FB5ECC-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0354833182
   Coding: 040321
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F1E015E00628002080013
   VCID: 458A224ACC498FBEB8-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0030267736 Dataset Number: 4G0909852M  0031
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 336E6C929ADD010E06-8066
   Revision: 00002001    Serial number: 0355565228
   Coding: 013A0E20A0B930818320098C2C030F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00010561730
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93406446
03615 - Rear Right Reading Light
                    Fault Status: 01101100
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:05
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F1E015E00628002080002
   VCID: 448C3F4EC773B6B6AF-8010
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001302660 Dataset Number: 4G0909522E  0008
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5A7AEA7CF957FE50-8078
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 043 M    HW: 4G1 035 043
   Component: MU-H-N-EU     041 1425
   Serial number: A591L0E7504120 Dataset Number: 4G1909545D  0029
   Coding: 017502010000000013110002000A00032F0006E5F17001009F
   VCID: 28548BFE531B72D6A3-807C
   Subsystem 1 - Part No SW: V03 959 802 TT    HW: -----------
   Component: ECE 2024/2025  --- 0370
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9EY8001FW
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349NLA000UC
   Compact disc data bank:
   Component: Gracenote2  --- 1017
          B201A 00 [00001001] - -
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:10
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: MDVDC2_A/DVDC_ME
1637 - Interface for External Media
          U11B8 00 [00001001] - No Communications
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:05
                    Interface for external media: status-Status: Open circuit
3077 - Telephone baseplate
          B1051 13 [00001001] - Open Circuit
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:02
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Component: TSG HL        H03 0507
   Coding: 010F1C004000628002080002
   VCID: 47962842F6459DAE4A-8012
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001002    Serial number: 0372092752 Dataset Number: 4G0909527B  0009
   Coding: 0100000202000000
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0193865
   Coding: 0213000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   VCID: 2E587DE671FF2CE669-807A
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 341400413 Dataset Number: 4G0909541E  0004
   Coding: 093205C031
   ROD: EV_HDSGAu571_AU57.rod
   Component: TSG HR        H03 0507
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H07 0304
   Coding: D70000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7_AU57.rod
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Serial number: 622352400201447
   Coding: 302100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C5C77EE47E35EF647-8078
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1429000282
9986 - Databus
                    Reset counter: 136
                    Mileage: 188411 km
                    Date: 2025.02.17
                    Time: 17:19:03
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547D  0007
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 275688C25E057DAEAA-8072
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
                    Reset counter: 166
                    Mileage: 187067 km
                    Date: 2025.01.18
                    Time: 16:55:30
                    Control Module temperature: 9 °C
                    Voltage terminal 15: 14.656 V
                    Velocity_vehicle_reference: -0.00 m/s
106240 - Function Restriction due to Faults in Other Modules
                    Reset counter: 161
                    Mileage: 187067 km
                    Date: 2025.01.18
                    Time: 16:55:30
131328 - Function Restriction due to Faults in Other Modules
                    Reset counter: 166
                    Mileage: 188067 km
                    Date: 2025.01.31
                    Time: 16:04:22
                    Control Module temperature: 4 °C
                    Voltage terminal 15: 11.030 V
140288 - Function Restriction due to Faults in Other Modules
                    Reset counter: 167
                    Mileage: 187067 km
                    Date: 2025.01.18
                    Time: 16:55:31
                    Voltage terminal 15: 14.491 V
144640 - Function Restriction due to Faults in Other Modules
                    Reset counter: 169
                    Mileage: 187108 km
                    Date: 2025.01.18
                    Time: 21:11:49
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 14.584 V
                    Velocity_vehicle_reference: 1.50 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.62 m/s²
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000620212147 Dataset Number: 4G0909548G  0008
   Coding: 04C0B91C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Dataset Number: 4G0909614C  0001
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3162669A60C1331E74-8064
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3260699665C708060D-8066
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 141121201102
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 143430466 Dataset Number: 4G0909571H  0017
   ROD: EV_RDCMA00100.rod
   VCID: 2B5E74F242ED59CE4E-807E
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 141003200049
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   Part No SW: 4G5 035 223 C    HW: 4G5 035 223
   Component: MIB2_amp_P    H02 0420
   Serial number: 00000000006627 Dataset Number: 4G1909510L  0011
   Coding: 01750208018AF02A5A0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 224099D635279886FD-8076
End-------------------------(Elapsed Time: 07:38)--------------------------
firari
C?ID=145475
updated
Here is the English version of VCDS ; scroll half way down the link page and click on "Download" . This English version of VCDS will work just fine along with your German version. So, no need to make any changes or deletes.
Edit: I see you found it already! :thumbs:
firari
C?ID=145475
thank you.
the update is in the first post
Morski
Cheshire, UK
C?ID=90186
This is from an RS7 with matrix headlights and air suspension
61B7DA4B86ED5BD29F00
firari
C?ID=145475
many thanks for that, my you have the codes from the controller:
13, 19, 5F, 85, 8E, 55
Morski
Cheshire, UK
C?ID=90186
This the scan from the car. Might be more useful to have the full scan
VIN: WUAZZZ4G4FN901508   License Plate: RH
Mileage: 37077km-23038mi   Repair Order: android install
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 30 34 36 3B 3C 42
          44 46 52 53 55 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90 BA 47
VIN: WUAZZZ4G4FN901508   Mileage: 37077km-23038miles
Address 01: Engine (------CWUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560 C    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0002
   Revision: NCH62---    CVN: FEB8D104
   Coding: 1A2A00326546010B3800
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_ECM40TFS0114G0906560C 001003
   ROD: EV_ECM40TFS0114G0906560C.rod
   VCID: 2809FAE4D2733E4A473-807C
   VINID: 9E546AAAA11711678900114020A24113C1
17881 - Exhaust Pressure Control Valve
          P0477 00 [00100111] - Signal too Low
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:35
                    Engine RPM: 0.00 /min
                    Coolant temperature: 15  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 11.756 V
                    Engine status: COENG_READY
17882 - Exhaust Pressure Control Valve 2
          P04A1 00 [00100111] - Short to GND
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:35
Readiness: 1110 1001
   Part No SW: 4G0 927 158 AN    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H19 1001
   Revision: --H19---    CVN: EA7328DA
   VCID: 7AADF0AC7C5F7CDA617-802E
   Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
   Component: ESP9 Premium  H01 0100
   Coding: 61B7DA4B86ED5BD29F00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 42DD484C540FF41A797-8016
   Coding: 05BA6F4E000000000000
   VCID: 7CA1F6B476EB42EA73B-8028
   Serial number: 3214000174161015
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Fault Frequency: 22
                    Reset counter: 157
                    Mileage: 37077 km
                    Date: 2024.04.11
                    Time: 20:14:32
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 23011500040006
   Coding: 682310B81D0000
   VCID: 6A8DC0EC0CFFCC5A917-803E
   Revision: 14020001    Serial number: 00000982272502
   Coding: 0105C01440349FE2E90140C7A0001800CF9DC30AAF080221800008946100170200400009090000
   VCID: 70B9D2842AA3368ADF3-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 141212  H37 0080
   Serial number:         141215114828
   Coding: 0045F7
   Serial number: 23670608
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Serial number: 14 01 2015  00001909
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R14JQ02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA109402000010552372
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: DC880B87000000000001
   Revision: --------    Serial number: 56261502400260
   Coding: B83B24
   VCID: 3537239015C153A2CC5-8060
   Serial number: 00000000000000 Dataset Number: 4G8909863D  0036
   Coding: 7E04010101
   VCID: 290FFFE0C979074258D-807C
   Revision: --------    Serial number: 003P1002Y2S9 Dataset Number: 4G8909602J  0001
   Coding: 30333046313130313137554A305234473853
   VCID: 3B2335A833E585D23A1-806E
   Serial number: 3575HRB406333HNI4OKS
   Serial number: 3585HRB405R33HNIGH3/
   Serial number: 3515JRB404V3468641IV
   Serial number: 3525JRB404R34686AH9+
   Serial number: 3554VRB406734BHEJ1PP
   Serial number: 3564VRB406734BHEI8SZ
   Revision: --------    Serial number: 90372OAN000DB
   Coding: 0000FC
   VCID: 372B29980F4DA1B2DE9-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 12 12 2014  F0044575
   Part No SW: 4G8 920 986 H    HW: 4G8 920 986 H
   Component: TBenGb AccNv  H07 0043
   Revision: 03001036    Serial number: 658260115592022
   Coding: 338F010B9F572600010500
   Shop #: WSC 01211 210 01254
   VCID: 3D273BB02DF18BE2045-8068
   Revision: --------    Serial number: 00000001703478 Dataset Number: 4G8909515H  0017
   Coding: C0ED07481C
   GVL: FDAFC8DCDCAB680D41040000
   VCID: 75B7E390554113A20C5-8020
   Serial number: 4559705503
   Voltage stabilizer:
   Serial number: 14111500000000000453
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 001401150001000 Dataset Number: 4G8909104B  0020
   ROD: EV_AllWheelDiffeQSPFR_AU57.rod
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 23011500040995
   Coding: 22
   VCID: 3E253CBC20F790FA1DF-806A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000073606
   Coding: 01010101000000000001000102
   VCID: 6491AED4EE5B9A2AABB-8030
   Dataset Number: 4G8909553G  0030
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B11F8F79D6972869-807A
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01C9A4 Dataset Number: 4G8909573A  0001
   ROD: EV_SARA2.rod
   VCID: 372B29980FCDA1B2DE9-8062
   Component: SWA Master    H06 0060
   Serial number: 0349654208 Dataset Number: 4G8909535C  0013
   Coding: 040312
   VCID: 392F2FA039D9B7C228D-806C
   Serial number: 0348200815
   Coding: 040312
   Revision: 00001000    Serial number: 0011311643 Dataset Number: 4G8909852N  0031
   VCID: 33331D881BB54D92E21-8066
   Revision: 00002001    Serial number: 0359087781
   Coding: 013F0E22A0B9F885C3300A840E0314470000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000017652
   Subsystem 2 - Part No: 4G0 951 177
   Subsystem 4 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST0003PZJA00000
   Coding: 901F02
   Subsystem 5 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
   Serial number: 0000000AP00011106739
   Subsystem 6 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120005000011217425
   Subsystem 7 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93397181
   Coding: 011F1E035E21628002080402
   VCID: 44D14E544E9BFA2A4BB-8010
   Revision: --------    Serial number: 00000001340377 Dataset Number: 4G8909522D  0007
   VCID: 2D070BF0FD911B62B45-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Revision: --------    Serial number: -------------- Dataset Number: 4G8909865C  0016
   Coding: 05FE02202A170200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E02100
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0030
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
   Part No SW: 4G1 035 021 P    HW: 4G1 035 021
   Component: MU-H-LND-EU   041 1425
   Serial number: A588A0F7504031 Dataset Number: 4G9909545D  0028
   Coding: 017563010000000013111102000A00132F000EE7F1700100DF
   VCID: 270BF9D8DF6D31324E9-8072
   Subsystem 1 - Part No SW: V03 959 802 TR    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Subsystem 2 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OAN000YD
   Subsystem 3 - Part No SW: V03 959 800 GG    HW: -----------
   Component: Gracenote2  --- 1021
                    Reset counter: 157
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:39
                    Voltage terminal 30: 11.9 V
                    Status_Software_Version_Management-module_name: MBose6416A_P/VDB
5717 - Mechanism for Mulimedia Display Unit 1
          B1401 07 [00001001] - Mechanical Failure
                    Reset counter: 157
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:34
6660 - No Communications with Display Unit 1 for Multimedia
          U10E2 00 [00001001] - -
          [Display 1: no signal/communication]
                    Reset counter: 157
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:34
   Coding: 010F1C024021628002080002
   VCID: 47CB59587FADD132AE9-8012
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000013020 Dataset Number: 4G8909850B  0004
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A0D00ECCC7F0C5A517-807E
   Revision: 11001001    Serial number: 82330JF0197779
   Coding: 0217000001000100000102000000
   VCID: 2E050CFCF097607A8DF-807A
9616666 - Supply Voltage for Rear Surroundings Camera
          B1285 14 [00001001] - Open or Short to Ground
                    Reset counter: 157
                    Mileage: 37077 km
                    Date: 2024.04.13
                    Time: 19:30:31
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 008501753 Dataset Number: 4G8909541G  0001
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 45D753504521C3225C5-8010
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Coding: C70000
   ROD: EV_HUDContiC7.rod
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G8909547E  0006
   Coding: EA160000
   VCID: 2C0106F4C68B126AA3B-8078
   Coding: 7E04010101
   Serial number: 005000621301157 Dataset Number: 4G0909548G  0008
   Coding: 03C21B1A1111
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308004240C2010000
   ROD: EV_RGS_L.rod
   VCID: 313F1780E1A97F8290D-8064
   ROD: EV_RGS_R.rod
   VCID: 323D188CE4AF449AE97-8066
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H09 0008
   Revision: 00001001    Serial number: 97811004623502 Dataset Number: 4G8909578B  0013
   ROD: EV_AEMLearAU64X.rod
   Serial number: 00000000009914 Dataset Number: 4G9909510K  0011
   Coding: 0175630A018AF02A5A0000010000
   VCID: 221DE8CCB44FD41A197-8076
End----(Elapsed Time: 02:50, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
firari
C?ID=145475
i dont see the 34 for level control
  • Agree
Morski
Cheshire, UK
C?ID=90186
Posted the scan from the wrong car. Corrected
