Audi E-tron Coolant bleeding
superfries
C?ID=321926
Hi all,
bought an E-tron (the SUV one) with minor crash damage. Replaced all parts and trying to fill the coolant system now, but struggling to figure out how to activate the bleeding program as the menu's for the EV are different from petrol cars (also have an A4B8 which I maintained with VCDS for the last 7 years)
I'm in exactly the same spot is this thread https://forums.ross-tech.com/index.php?threads/28593/ but no resolution was posted there. This thread also includes a pic of the menu I am stuck at myself.
Any suggestions would be welcome!
Many thanks,
Harmen
superfries
C?ID=321926
Sorry should've done so straight away :).
Here you go:
Monday,17,February,2025,19:54:21:53022
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUZZZGE4LB016291   License Plate:
Chassis Type: GE-AU58 (4KL)
Scan: 01 03 09 15 16 17 19 2B 36 42 44 46 51 52 5F 69 6D 74 75 81
          8C A5 BB BC C5 C6 CE D6 D7 8104
VIN: WAUZZZGE4LB016291   Mileage: 115395km-71703miles
51-Electric Drive -- Status: Malfunction 0010
74-Chassis Control -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: Redir Fail!
   Part No SW: 4KE 907 558 C    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   CVN: 7D75D4C5
   Coding: 2A0A0012002E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558C 001003
   ROD: EV_VCU00XXX0204KE907558C.rod
   VCID: 49DAB5DDE8761CDE5C-801C
   VINID: 9D196AAAA5D511C480046089043C0EF240
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2019.10.09.000000304
23075 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [00101111] - -
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:24
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 13.437 V
                    LF_MVB_PDU_INTC_DIAG_8: 16384
                    LF_MVB_PDU_INTC_DIAG_9: 195
                    LF_MVB_PDU_INTC_DIAG_10: 64512
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 4096
                    LF_MVB_BUS_INTC_DIAG: 12544
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4KE 909 059 AF    HW: 4KE 909 059 G
   Component: ESC           H09 0242
   Revision: 00000000    Serial number: 63139000005382 Dataset Number: 4KE909504AH 0003 CVN: D4D7BE22
   Coding: 008800BA3D950A9F9352087A1878D2D025BEA00000BC50C910184B0BA47D05
   Shop #: WSC 13524 004 1048576
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_011.rod
   VCID: 0B564FD5A28A4ECEAE-805E
8366 - Control Module for Instrument Cluster
          U1018 00 [00101111] - Missing Signal for Ambient Temperature
          [CCan_kbi_qbit_aussen_temp_gef_qualifier]
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:27
                    Unlearning counter according OBD-OBD unlearning counter: 40
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 23: 00
                    History Data-History data 24: 00
                    History Data-History data 25: 00
                    History Data-History data 26: 00
                    History Data-History data 27: 00
                    History Data-History data 28: 00
                    History Data-History data 29: 00
                    History Data-History data 30: 00
                    History Data-History data 31: 00
                    History Data-History data 0: 80
8367 - Control Module for Instrument Cluster
          [CCan_kbi_aussen_temp_gef_failure]
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Dataset Number: 4KE909514C  0021
   Coding: 07000143C1F900DD0740870898BF8C68130B33100806009701010800792216810A4509B362B6220B000001000009101A0000800000010000000000000000000000
   Shop #: WSC 24534 004 1048576
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DB2110DEC3E707EA0-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001910040400696
   Coding: 7DC727
   Serial number: 23882783X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 17S19.11.1900300726
   Serial number: GX1CE109081923811641
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0416
   Serial number: B01482557
   Coding: 0D0104
14 Faults Found:
65801 - Outside temperature sensor
          B103F 15 [00001001] - Open or Short to Plus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:20:31
                    average_Voltage_terminals: 11.80 V
                    Outside air temperature sensor-Resistance: 120.32 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: Malfunction
                    interior_temperature: Temperature not available
                    Vehicle speed: Initialization
                    Terminal activation-Terminal 75 status: Not available
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: Not available
67686 - Databus
          [MxB left high beam: faulty]
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:35
                    average_Voltage_terminals: 14.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 7.00 °C
                    interior_temperature: 8.00 °C
                    Vehicle speed: 0.00 km/h
67687 - Databus
          [MxB right high beam: faulty]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:36
                    average_Voltage_terminals: 11.90 V
                    interior_temperature: 15.50 °C
196720 - Front Parking Aid Sensor(s)
          B10FC 13 [00001000] - Open Circuit
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:26:12
                    average_Voltage_terminals: 14.60 V
                    interior_temperature: 12.50 °C
196904 - Parking Assist Not Available
          B1928 F0 [00001000] - Steering Assist Incorrectly Coded
                    Reset counter: 137
                    Mileage: 114857 km
                    Date: 2025.01.04
                    Time: 12:05:03
                    average_Voltage_terminals: 11.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 6.00 °C
                    interior_temperature: 13.00 °C
196913 - Databus
          [Instrument cluster control module: received error value in signal IC_outside_temp_filt]
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
                    average_Voltage_terminals: 11.30 V
                    interior_temperature: 12.00 °C
65609 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001000] - Open or Short to Plus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:37:32
                    average_Voltage_terminals: 13.00 V
65619 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001001] - Open or Short to Plus
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:31
                    average_Voltage_terminals: 12.80 V
65632 - Bulb for Right Fog Lamp
          B1220 15 [00001000] - Open or Short to Plus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:37:33
65634 - Bulb for Left Fog Lamp
          B121F 15 [00001001] - Open or Short to Plus
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:32
                    average_Voltage_terminals: 14.40 V
66672 - Control Module for Light Activation/Adjustment; Left
          U116E 00 [00001001] - No Communications
          [Left LCM: no signal/communication]
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:21:40
                    average_Voltage_terminals: 12.00 V
                    interior_temperature: 7.50 °C
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
66673 - Control Module for Light Activation/Adjustment; Right
          U116F 00 [00001000] - No Communications
          [Right LCM: no signal/communication]
                    Fault Frequency: 80
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:33:36
                    average_Voltage_terminals: 12.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: Initialization
                    interior_temperature: 13.50 °C
131353 - Power Output Module for LED Headlamps; Left
          U1170 00 [00001001] - No Communications
          [Left LED headlamp power output module: no communication]
                    Fault Frequency: 31
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:35
                    System run time-Engine running time: 65535 s
                    System run time-Terminal 15 on: 0 s
131361 - Power Output Module for LED Headlamps; Right
          U1171 00 [00001000] - No Communications
          [Right LED headlamp power output module: no communication]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:36
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H42 3122
   Serial number: 003XPM01D5HX Dataset Number: 4KE909602K  0003
   Coding: AACCF0C0002000009A5400FFF80D40A800C5
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   Left seat belt tensioner:
   Serial number: 00AI2019310410200000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2019287017700000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: 35700000000A1B44D04J
   Subsystem 4 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: 3580000000098244D04H
   Subsystem 5 - Part No SW: -----------    HW: 480 031 311 19
   Serial number: 351002C0054A78A099DC
   Subsystem 6 - Part No SW: -----------    HW: 480 031 311 19
   Serial number: 352002C0054A317098B$
   Subsystem 7 - Part No SW: -----------    HW: 480 020 811 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500012C62ED2C10451
   Subsystem 8 - Part No SW: -----------    HW: 480 020 811 19
   Component: FrontSensor_P  000 0149
   Serial number: 35600012A62ED2C70434
   Crash sensor high-voltage system 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 020 811 19
   Component: HVSensor_gSat  000 0149
   Serial number: 35100012A62ED2C0F4AE
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 020 811 19
   Component: SideSens_B_Df  000 0149
   Serial number: 35200012A62ED2C3322$
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 020 811 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500012A62ED2C196CH
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 91
                    Reset counter: 150
                    Mileage: 111204 km
                    Date: 2024.11.16
                    Time: 22:45:46
1061381 - Databus
          [NWD: 0x5E1 Klima_Sensor_02 error value BCM1_Aussen_Temp_ungef]
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:23
   Part No SW: 4N0 907 129 AH    HW: 4N0 907 129 AH
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 77BE0325CE025A2EFA-8022
Address 17: Instruments (J285)       Labels:| 4KE-920-KOM-V1.clb-SRI2
   Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
   Component: FHybRDWACC--- H13 0105
   Coding: 852400C8788000080D26E170B284280008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 45C2B9EDC46EF8BEB8-8010
13639936 - Databus
          [ECU for body control modul error error value recieved]
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
   Part No SW: 4KL 907 468     HW: 4K1 907 468 C
   Component: Gateway       H04 0362
   Serial number: 14F03078613301 Dataset Number: 4KE909515B  0027
   Coding: 02010005000100C000810000005B01328C8A0007180000000900009E00000000
   GVL: 01503C0008000200949C08008000481801080000000080010000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 0D5241CDDC9E40FEB0-8058
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 76749602001910010102
131687 - Control Module for Emergency Call and Communications
          U1421 00 [00001000] - No Communication
          [Timeout_Node_0x67_DiagAdress_0075_ConBox]
                    Reset counter: 127
                    Mileage: 112473 km
                    Date: 2024.11.28
                    Time: 22:01:16
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_BatteryControl]
                    Reset counter: 150
                    Mileage: 111065 km
                    Date: 2024.11.15
                    Time: 11:04:55
8531970 - Quiescent Current
          U1406 00 [00001001] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 15:51:57
                    EM_vehicle_state: 00 00
                    Total static current-current total quiescent current: 632 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
8978692 - Activatable Functions
          B18D3 F3 [00001000] - Faulty Vehicle Configuration
                    Reset counter: 150
                    Mileage: 114841 km
                    Date: 2024.12.26
                    Time: 18:20:50
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000291420003
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 3424F4299FF471361F-8060
   Serial number: 00000393494248 Dataset Number: 4KE909856B  0005
   Coding: 005812400000B4010003010101010000000000000000000000000000004000
   VCID: 79BA051DF8164C5E8C-802C
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        010 0387
   Serial number: 0000395159238  Dataset Number: 4KE909872B  0013
   Coding: 001FDB0052000480A001B002
   VCID: 46C0BEE1F968F3A6B1-8012
196665 - Switch for Central Locking
          B122D 29 [00001000] - Signal Implausible
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 09:46:15
   Dataset Number: 4KE909852E  0003
   Coding: 94110101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3228F23165E07F060D-8066
   Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0530
   Dataset Number: 4KE909501D  0027
   Coding: 01740000AFB100E16309A0000400C80200000000804B06582F04000000040030001F0100000F13
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU58.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY193001MVJ
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047852190
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W70000V8Q
   left tail lamp 2:
   Subsystem 4 - Part No SW: 4KE 945 429 D    HW: 4KE 945 429 D
   Component: T2 LH ECE HD  H12 0503
   Serial number: A1WK0004WPM
   Right rear tail lamp 1:
   Subsystem 5 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000VBX
   Right rear tail lamp 2:
   Subsystem 6 - Part No SW: 4KE 945 430 D    HW: 4KE 945 430 D
   Component: T2 RH ECE HD  H12 0503
   Serial number: A1WL0004WPP
Address 51: Electric Drive (J841)       Labels: 0EF-907-XXX-V1.clb
   Part No SW: 0EF 907 080 H    HW: 0EF 907 080 C
   Component: CUFZD68570AD0 H03 1005
   Revision: --------    Serial number: -00129.06.19000
   Coding: 01000000000000000000
   Shop #: WSC 13734 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3B36DF15B2AABE4EDE-806E
36890 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [00101111] - -
          [SIGERRBCM1_10]
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       010 0387
   Serial number: 0000395167507  Dataset Number: 4KE909873B  0013
   Coding: 001FDB005E000480A001B000
196663 - Motor for Window Regulator
          B1487 4B [00001000] - Over Temperature
                    Reset counter: 124
                    Mileage: 113482 km
                    Date: 2024.12.07
                    Time: 21:10:06
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 D    HW: 4KE 035 063
   Component: MU-H-LND-EU   054 2711
   Dataset Number: 4KE909545C  0015
   Coding: 01157601FF0A000043111101C00802102F0001E403700800CE
   VCID: 240404692F14E1B68F-8070
   Subsystem 1 - Part No: V03 959 807 SK
   Component: MIB2P_EU_Q122  0600
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00118081900130352
   Compact disc data bank:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000122005059
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00123081900140420
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900674527014
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789,,+''. Dataset Number: v12400160G0 0016
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2 Dataset Number: 4KE909541B  0007
   Coding: 3390
   VCID: 4AD88AD1ED7017C655-801E
0066 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4KE 907 777 AH    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2320
   Serial number: 0611190665  Dataset Number: 4KE909576T  0008
   Coding: 90D8607BDA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 126852B1C5A09F066D-8046
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130765092
   Coding: 303030
4456450 - Implausible Data Received from Diagnostic Gateway Module
          U0447 00 [00001001] - -
          [Function_restriction_due_to_communication_interruption_AmbientTemperature]
                    Fault Frequency: 8
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:24
                    Internal DTC: 127
4456460 - Implausible Data Received from Diagnostic Gateway Module
          [Function_restriction_due_to_communication_interruption_AmbientTemperatureFiltered]
                    Fault Frequency: 8
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
                    Internal DTC: 131
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120875 Dataset Number: 4KE909612B  0014
   Coding: 01C0E0FEC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 281C1059533C05D6A3-807C
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SHE00035
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C34DC09B7A4B976D7-8068
9004 - Databus
          [MESSAGE_GE_16_TIMEOUT]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:31:59
                    Freeze_frame_common-Internal_fault_code: 0C 06
                    Temperatures-Inside temperature: 15.00 °C
                    Temperatures-Control Module temperature: 26.00 °C
                    Voltage terminal 30: 12.40 V
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4KE 915 233 S    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0468
   CVN: 9DDFAF83B5D9CDDC9F3843E89F3843E89F3843E89F3843E89F3843E89F3843E8
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 4ED086C111183BE609-801A
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H13 0370
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AK    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0293
   Dataset Number: 4KE909466G  0024
   Coding: 0421840000000000000006000040462C189C57000000000000000000000000000019000000000000000000000000000000000000000000000000800000000000000078D80000009000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 085C70D9B3FC25D683-805C
13 Faults Found:
2114853 - Databus
          [LWR_Soll_Fkt_SOL_FehlPos_L]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.01.31
                    Time: 14:39:49
2114597 - Databus
          [TIMEOUT_LED_Feh_LM_L_03]
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:32
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 13.50 V
                    Supply voltages-Terminal 30 local: 14.30 V
2114598 - Databus
          [TIMEOUT_LED_Feh_LM_R_03]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:33
                    Supply voltages-Terminal 30: 11.90 V
2114605 - Databus
          [TIMEOUT_LWR_Sta_LM_L]
                    Reset counter: 110
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:30
                    Supply voltages-Terminal 30: 11.60 V
2114606 - Databus
          [TIMEOUT_LWR_Sta_LM_R]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:32
2113925 - Databus
          [APS_03_US_Fehler_VS]
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113926 - Databus
          [APS_03_US_Fehler_HS]
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113927 - Databus
          [APS_Master_US_Sende_Modus]
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113928 - Databus
          [APS_Master_US_Sende_Modus_hinten]
                    Fault Frequency: 11
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114007 - Databus
          [Klima_Sensor_02_BCM1_Aussen_Temp_ungef]
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114009 - Databus
          [Kombi_02_KBI_Aussen_Temp_gef]
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114644 - Databus
          [Parkhilfe_01_PH_Visualisierung]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:26:17
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [00001000] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 150
                    Mileage: 115031 km
                    Date: 2025.01.08
                    Time: 08:32:27
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 8 °C
                    Vehicle speed: 89.43 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: Yes
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: Yes
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: Yes
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: Yes
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: Yes
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: No
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       010 0387
   Serial number: 0000395541172  Dataset Number: 4KE909897B  0013
   Coding: 000FD90000000480A000B000
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 48DCB0D9F37CE5D643-801C
   Component: TSG HBFS      010 0387
   Serial number: 0000395541493  Dataset Number: 4KE909896B  0013
   ROD: EV_DCU2RearPasseMAXHCONT_VW41.rod
196650 - Motors for Central Locking
          B122B 12 [00001000] - Short to Plus
                    Reset counter: 131
                    Mileage: 114595 km
                    Date: 2024.12.22
                    Time: 11:12:22
                    Reset counter: 130
                    Mileage: 114595 km
                    Date: 2024.12.22
                    Time: 11:16:10
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0102165 Dataset Number: 4KE909476VD 0001
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_002_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 F    HW: 3Q0 963 231 F
   Serial number: -00104.1B.2A20370138
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019102400060
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151109993
   Shut-off valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000131018572
   Shut-off valve 3 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000131018550
   Shut-off valve 4 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000131018576
   Shut-off valve 5 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000131018588
   Radiator shutter:
   Subsystem 10 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
H12 0109
   Coolant valve 1:
   Subsystem 11 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000424652
   Coolant valve 2:
   Subsystem 12 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000402618
   Coolant valve 3:
   Subsystem 13 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000433366
   Coolant valve 4:
   Subsystem 14 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000437565
16 Faults Found:
32903 - Enable Line for Radiator Fan 1
          P1A75 00 [00101000] - Open Circuit
                    Mileage: 115395 km
                    Date: 2025.02.13
                    Time: 06:09:14
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-System status: Control unit in overrun
                    Expanded ambient data 1-Power quota setting by energy management: 00
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine off or drive is not ready
                    Expanded ambient data 1-Ambient temperature: Malfunction
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 00
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 00
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 00
                    Coolant fan activation: specified value: 10.00 %
                    Coolant fan 1: activation: 10.00 %
59188 - Active Radiator Shutter 1
          P05A3 00 [00101110] - Implausible Signal
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 14:02:59
                    Expanded ambient data 1-System status: Control operation: ignition on
                    Expanded ambient data 1-Power quota setting by energy management: 1D
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine start
                    Expanded ambient data 1-current state of battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 04
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 0E
                    Radiator shutter 1: status referencing-Initialization: initialized
                    Radiator shutter 1: status referencing-blockage: not active
                    Radiator shutter 1: status referencing-Direction of rotation: clockwise
                    Radiator shutter 1: status referencing-excessive temperature: not active
                    Radiator shutter 1: status referencing-Temperature in control module: -50 °C
                    Radiator shutter 1: status referencing-Internal malfunction: not active
                    Radiator shutter 1: status referencing-Supply voltage: 0.00 V
                    Radiator shutter 1: status referencing-Free run: not active
                    Radiator shutter 1: status referencing-Adapting: completed successfully
                    Radiator shutter 1: status referencing-Position: 127 %
                    Radiator shutter 1: status referencing-operational: not active
                    Radiator shutter 1: status referencing-Response error: Malfunction
                    Radiator shutter 1: status referencing-Torque: Measuring value not available
                    Radiator shutter 1: status referencing-Reference value: OK
                    Radiator shutter 1: status referencing-Position_Textual: Malfunction
                    Activation radiator shutter result-Initialization: not active
                    Activation radiator shutter result-LIN node- address: 0
                    Activation radiator shutter result-Target value: 0 %
                    Activation radiator shutter result-Direction of rotation: clockwise
                    Activation radiator shutter result-Set reference level: not active
                    Activation radiator shutter result-Torque: up
                    Activation radiator shutter result-LIN_node_adress_Textual: numerical value: no text
                    Activation radiator shutter result-set_value_Textual: numerical value: no text
32794 - Coolant Fan Control Circuit 1
          P0480 00 [00101000] - Electrical Malfunction
                    Mileage: 115395 km
                    Date: 2025.02.13
                    Time: 06:09:14
32807 - Radiator Fan 1
          U0632 00 [00101000] - No Communication
                    Mileage: 115395 km
                    Date: 2025.02.14
                    Time: 12:56:09
                    Expanded ambient data 1-Vehicle speed: 255 km/h
                    Expanded ambient data 1-System status: not active
                    Expanded ambient data 1-Status of drive readiness hybrid: Initialization
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 2D
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 2E
32845 - Coolant Pump 2
          P261A 00 [00101000] - Open circuit
                    Mileage: 115395 km
                    Date: 2025.02.12
                    Time: 21:33:07
                    Expanded ambient data 1-Ambient temperature: Initialization
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 01
                    Coolant circulation pump 2-Act.val.: 0
                    Coolant circulation pump 2-Target value: 10
36891 - Implausible Data Received from Body Control Module (Central Electric)
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:23:12
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 02
40959 - Expansion Valve for A/C Refrigerant
          U062E 00 [00101000] - No Communication
                    Mileage: 115395 km
                    Date: 2025.02.12
                    Time: 21:33:11
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 05
                    Expansion valve 2 for refrigerant-LIN node- address: Shut-off valve 1 for refrigerant
                    Expansion valve 2 for refrigerant-Act.val.: 0 %
                    Expansion valve 2 for refrigerant-Target value: 100 %
                    Expansion valve 2 for refrigerant-Temperature: -50 °C
                    Expansion valve 2 for refrigerant-Raw value: Malfunction
                    Coolant expansion valve 2: internal status-Temperature: -50 °C
                    Coolant expansion valve 2: internal status-Position: Malfunction
37187 - No Communication With Active Grille Air Shutter Module
          U0284 00 [00101100] - -
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
                    Expanded ambient data 1-System status: Drive readiness
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 05
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 4D
                    Radiator shutter 1: status referencing-Response error: OK
                    Radiator shutter 1: status referencing-Reference value: not OK
                    Activation radiator shutter result-Torque: low
59316 - No Communication With Active Grille Air Shutter Module 2
          U0285 00 [00101111] - -
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 11:29:19
                    Expanded ambient data 1-Status of drive readiness hybrid: Electrical travel
                    Expanded ambient data 1-Ambient temperature: 5.50 °C
                    Expanded ambient data 1-current state of battery cold circuit: 05
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 04
                    Radiator shutter 2: status referencing-Initialization: initialized
                    Radiator shutter 2: status referencing-blockage: not active
                    Radiator shutter 2: status referencing-Direction of rotation: clockwise
                    Radiator shutter 2: status referencing-excessive temperature: not active
                    Radiator shutter 2: status referencing-Temperature in control module: -50 °C
                    Radiator shutter 2: status referencing-Internal malfunction: not active
                    Radiator shutter 2: status referencing-Supply voltage: 0.00 V
                    Radiator shutter 2: status referencing-Free run: not active
                    Radiator shutter 2: status referencing-Adapting: completed successfully
                    Radiator shutter 2: status referencing-Position: 127 %
                    Radiator shutter 2: status referencing-operational: not active
                    Radiator shutter 2: status referencing-Response error: OK
                    Radiator shutter 2: status referencing-Torque: Measuring value not available
                    Radiator shutter 2: status referencing-Reference value: not OK
                    Radiator shutter 2: status referencing-Position_Textual: Malfunction
                    Activation of radiator shutter 2-Initialization: not active
                    Activation of radiator shutter 2-LIN node- address: 1
                    Activation of radiator shutter 2-Target value: 0 %
                    Activation of radiator shutter 2-Direction of rotation: clockwise
                    Activation of radiator shutter 2-Set reference level: not active
                    Activation of radiator shutter 2-Torque: low
                    Activation of radiator shutter 2-LIN_node_adress_Textual: numerical value: no text
                    Activation of radiator shutter 2-set_value_Textual: numerical value: no text
59317 - No Communication With Active Grille Air Shutter Module 2
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 11:29:22
                    Expanded ambient data 1-Vehicle speed: 1 km/h
                    Expanded ambient data 1-previous state of battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 07
                    Expanded ambient data 1-previous state of battery cold circuit: 05
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 06
37263 - No Communication With Active Grille Air Shutter Module
          U0284 00 [00101000] - -
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:28
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 50
60016 - Interior Pre-Conditioning
          P13F1 00 [00101111] - Not Started
                    Fault Frequency: 187
                    Mileage: 115394 km
                    Date: 2025.01.13
                    Time: 20:44:09
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 07
                    Switch-off conditions for pre-conditioning of interior-HV energy management: not active
                    Switch-off conditions for pre-conditioning of interior-Function canceled: entry in DTC memory: active
                    Switch-off conditions for pre-conditioning of interior-Communication malfunction: not active
                    Switch-off conditions for pre-conditioning of interior-Switch-off due to energy management: not active
                    Switch-off conditions for pre-conditioning of interior-No release by coordinator: not active
                    Switch-off conditions for pre-conditioning of interior-Fuel supply low: not active
                    Switch-off conditions for pre-conditioning of interior-Over The Air Update: not active
                    Switch-off conditions for pre-conditioning of interior-Critical component temperature: not active
                    Switch-off conditions for pre-conditioning of interior-Parking heater error value received: not active
60019 - Basic Setting for Coolant Fill
          P1A81 00 [00101111] - Not Ended
                    Fault Frequency: 32
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 14:41:16
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: FF
60009 - Refrigerant Pressure for Heating of Passenger Compartment
          B16A3 84 [01101101] - Signal Below Allowable Range
                    Mileage: 115394 km
                    Date: 2025.01.11
                    Time: 23:21:12
                    Expanded ambient data 1-Vehicle speed: 7 km/h
                    Expanded ambient data 1-Ambient temperature: 1.00 °C
                    Expanded ambient data 1-current state of battery low temp.circ.: 06
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 29
                    Expanded ambient data 1-current state of battery cold circuit: 02
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 32
                    A/C pressure/temperature sensor 1-Refrigerant pressure: 0.99 bar
                    A/C pressure/temperature sensor 1-Communication: OK
                    A/C pressure/temperature sensor 1-Malfunction status: OK
                    A/C pressure/temperature sensor 1-Response error: OK
                    A/C pressure/temperature sensor 1-Inside temperature: 10.90 °C
                    A/C pressure/temperature sensor 1-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 1-Refrigerant temperature: 8.80 °C
                    A/C pressure/temperature sensor 2-Refrigerant pressure: 1.00 bar
                    A/C pressure/temperature sensor 2-Communication: OK
                    A/C pressure/temperature sensor 2-Malfunction status: OK
                    A/C pressure/temperature sensor 2-Response error: OK
                    A/C pressure/temperature sensor 2-Inside temperature: 9.20 °C
                    A/C pressure/temperature sensor 2-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 2-Refrigerant temperature: 7.10 °C
                    A/C pressure/temperature sensor 3-Refrigerant pressure: Malfunction
                    A/C pressure/temperature sensor 3-Communication: OK
                    A/C pressure/temperature sensor 3-Malfunction status: OK
                    A/C pressure/temperature sensor 3-Response error: OK
                    A/C pressure/temperature sensor 3-Inside temperature: Malfunction
                    A/C pressure/temperature sensor 3-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 3-Refrigerant temperature: Malfunction
                    Refrigerant pressure: 36.02 bar
                    Compressor status: global-A/C compressor release status: not transmitted
                    Compressor status: global-A/C compressor: target speed: 0 /min
                    Compressor status: global-A/C compressor: actual speed: 0 /min
                    Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                    Compressor status: global-A/C compressor error indicator: not active
                    Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                    Compressor status: global-A/C compressor: inverter temperature: -127 °C
60001 - Refrigerant Pressure for Cooling of Passenger Compartment
          B16A2 84 [01101101] - Signal Below Allowable Range
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 10:31:38
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 24
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 23
                    A/C pressure/temperature sensor 1-Refrigerant pressure: 0.97 bar
                    A/C pressure/temperature sensor 1-Inside temperature: 8.40 °C
                    A/C pressure/temperature sensor 1-Refrigerant temperature: 6.00 °C
                    A/C pressure/temperature sensor 2-Refrigerant pressure: 1.01 bar
                    A/C pressure/temperature sensor 2-Inside temperature: 8.10 °C
                    A/C pressure/temperature sensor 2-Refrigerant temperature: 5.70 °C
61073 - Coolant Level Sensor
          P139B 00 [00101100] - Coolant Level Low
          [EE91 Sensor for inadequate coolant level display Low fluid level]
                    Fault Frequency: 181
                    Mileage: 115394 km
                    Date: 2025.01.13
                    Time: 20:44:07
                    Expanded ambient data 1-Ambient temperature: 0.50 °C
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: --------------- Dataset Number: 4KE909811F  0001
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56E06EA129C84326C1-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190819030206081877
2097680 - Charging Socket B
          P33E4 00 [00100000] - Communications Error
13705549 - Databus
          U1121 00 [00100000] - Missing Message
          [DCDC_01_Timeout]
3276827 - Discrepancy between Specified and Measured Current
          P33E0 00 [00101000] - Too High
          [exceedance_max.current_deviation_rail1]
                    Fault Frequency: 9
                    Reset counter: 33
                    Mileage: 111409 km
                    Date: 2024.11.18
                    Time: 15:43:01
3276828 - Discrepancy between Specified and Measured Current
          [exceedance_max.current_deviation_rail2]
                    Fault Frequency: 31
                    Mileage: 111076 km
                    Date: 2024.11.15
                    Time: 13:52:13
3276829 - Discrepancy between Specified and Measured Current
          [exceedance_max.current_deviation_rail3]
                    Fault Frequency: 34
                    Mileage: 111076 km
                    Date: 2024.11.15
                    Time: 13:52:13
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 K    HW: 0EF 907 180 C
   Component: CUBZE68570AD0 H03 1005
   Revision: --------    Serial number: -00122.06.19000
   ASAM Dataset: EV_DMCM2HITACAU516 003009
   VCID: 3FCEAB05A6B2A26EF2-806A
          [SIGERRBCM1_10]
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
51005 - Inverter Cooling System
          P0A93 00 [00101000] - Inadequate Performance
          [PlausAccInletCoolantTemp_8]
                    Mileage: 115394 km
                    Date: 2025.01.11
                    Time: 23:21:58
Address D6: Light Ctrl Left 2
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   Dataset Number: 4KE909472E  0011
   VCID: 71AA3D3DA066041E34-8024
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
End----------(Elapsed Time: 03:04, VBatt start/end: 13.1V/13.1V)-----------
superfries
C?ID=321926
To recap the issue: I'm trying to bleed the cooling circuit after a front-end repair post-crash.
I downloaded the original maintenance instruction from Audi (through erWin) - see here (in german, sorry) , which says to 'Activate "deairation of cooling system" with vehicle diagnosis tester' . It also points to ' Rep.Gr. 00 ; Diagnoseeinsteige' see here which loosely translates to 'Diagnosis settings' and contains a section with cooling systems references (page 2 bottom: 4. Kuhlsystem entluften).
From googling I gather this opens up all valves and pumps. However, I'm unsure how to activate this bleed mode through VCDS, I can't find any logical section. Any help would be very mich appreciated!!
superfries
C?ID=321926
I did find control module C5 - Therm. mgt. pic
Within that I found 2 logical options under basic settings pic:
- Test - bleed cooling circuit
- Filling coolant circuit
The bleed option says 2 fields require input when hitting 'Go!' and I've no idea what should be entered pic
The filling option jumps to 'running' for a few secs and then jumps back to 'not running'. Nothing happens when it is running, no audible activation of any pumps or valves and no change in reservoir fluid level (and I know there's tons of air in the system) pic
@superfries , thanks for the detailed information with screen shots. We do not have an answer at the moment but are looking into this to see if we can add any clarity.
This isn't our final answer (we may find more info) but I started looking into this and arrived at a similar conclusion in this old thread:
I have not tested an e-tron, but looking at the basic settings it looks very similar to the ID.3 and ID.4
That basic setting is not used, even you could think so.
Use "IDE10179-ENG114972 Fill refrigerant circuit - Routine Control Option"
But before you activate it, load measurement values, search for 1447 and choose/mark them, when all valves show 100%, start your Refrigerant filling machine program.
After filling machine program is done, press [Stop] for the basic setting.
That one was never marked solved but I think @NEtech was correct.
I dug into the test plan using a combination of your German repair info and our data. It appears as if the steps are 2-part and this coolant versus refrigerant thing may be lost in translation.
The steps are in Address C5: Therm. mgt. (J1024) under Basic Settings:
1) Start-up_Refrigerant_circuit_filling
Using VCDS this is BS [*IDE10179-ENG114972*] Fill refrigerant circuit​
The behind the scenes text for IDE10179-ENG114972 is identical to the instructions: [Start-up_Refrigerant_circuit_filling]​
2) Stop_routine_coolant_circuit_filling_flushing
Using VCDS this is BS [*IDE13606-ENG114972*] Stop Routine coolant circuit charging/flushing​
The behind the scenes text for IDE13606-ENG114972 is also identical to: [Stop_routine_coolant_circuit_filling_flushing]​
I realize it sounds silly to call something Start > Refrigerant and then End > Coolant all in the same 2-step procedure but I think that's correct.
NEtech
Denmark
C?ID=56995
OP, have you fixed errors in [C5], delete DTC and post Autoscan.
superfries
C?ID=321926
Thanks!! My wife is out so having to manage 3 little ones, will follow these and check back in.
I did manage to borrow a professional OBD diagnotics tool from my local garage, but when going through the menu's I came to the same place and the tool could not start the cooling bleed either
Dr Sheldon
Windsor UK
C?ID=334979
I would have a bash at Bleeding it the old fashioned way !! How hard or complex can it be !!
Some times the internet and these stupid procedures are just that - Stupid !!
Fill the bastard with coolant, pour it in as slowly as possible taking breaks, run it to remove any air - Job done !!
@Dr Sheldon , I disagree in this instance. That's a large battery cooling system and it may not even go into a Ready state (i.e. similar to running an engine) when it knows air is in the system.
I looked into an ID.4 inquiry a few weeks ago and rather than the old-school shop air to vacuum type of coolant filler VW called out this fancy electric assist device:
https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=46480163
My guess is the ID.4 cooling system is so large that a basic ICE engine coolant filler (like the conventional shop air to vacuum ones) may not be sufficient at all.
superfries
C?ID=321926
And also; the cooling liquid is shared between the battery pack, charging circuit and motors. None of which I'd like to run the risk of overheating. Replaced petrol engines many a time and know the bleeding procedure for these can typically be skipped if run and refilled with care. But not taking any chances on this stuff as a small bubble trapped in the wrong place can wreak havoc to the electrics
Dr Sheldon
Windsor UK
C?ID=334979
Living in that ideal world is fine and I am all for it !!
When the bleed procedure dont work then what is your option other than to scrap the car ?? "Oh well it was not to be"
We have a previous thread that remains unsolved :popcorn:
Your car - Your Problem so do it your way. I am just promoting a discussion. I have spent a lifetime in Dealerships - All Marques and seen how they get past these issues. Quite often they either do not have the Special tools or cannot find them but the work goes on.
Surely that coolant system can be filled even if it involves running the pump manually (the procedure will not do much more than that -Perhaps open a valve here or there) and removing hoses to release air and so on. That will be full of temp sensors that can be monitored !!
Really !
In your shoes, in the absence of the correct procedure, I would make that my Guinee Pig and go for it. Take my sweet time, nurse it, with the aim of getting it right first time.
Even better and more secure if it detects air and wont fire up - Ready Mode !
More so the VCDS team are not likely to waiver from the official line - They have a reputation to keep up. As have I but that does not mean I have to have a car in my bay hanging around like a bad smell !!
There are threads in this forum referring to Brake Bleed Procedures not working - The end result is often to do it manually !
superfries
C?ID=321926
Thanks a lot for your effort Dana! No luck, though.
I gave it a try. When hitting Go! on 'Fill' , i hear very slight hiss for about 3 secs, not water running or a pump running but more like air depressurizing, other than nothing appears to happen. After a few secs more it jumps back from 'running' to 'not running' .
Whatever it may do, it doesn't run the pumps of the cooling circuit so no bleeding this way. Interestingly, when running ' stop' afterwards, I hear the same thing and this also jumps back to ' not running' in about 7 secs.
I got fed up and hooked the car up to a granny charger (2kW), which did start part of the cooling system (for charging circuits) and bled at least a bit. Think I'll take the car for a very delicate spin and check the reservoir every few hundred meters now.
Thanks for the update. Please post a new scan at some point so we can see which (if any) DTCs are stored at this point.
The weather is much nicer now and I have VCDS testing to do anyway so I'll give this a try on ours over the next few days:
The results on a vehicle with a full cooling system may not be fully conclusive but I'll reply here with any feedback that may be useful.
Edit, these are notes for future-self when on the car. I don't expect any of the ones that report "not coded/not installed" to magically show data but some may change. My MAS01447 results in the most recent key on, ready off blockmap were:
;SW:4KE-965-429-C   HW:4KE-965-429 ---  Therm. mgt.
;Component:TME-Max       H08 0312, Coding:00
;EV_ThermContrVISAU49X,002036,EV_ThermContrVISAU49X_002_AU58.rod
;Sunday,23,February,2025,16:42:38:44768
;VCDS Version: Beta 25.1.1 (x64)  Data version: 20250221 DS362.2
    Line 34: IDE01236-MAS01447,Coolant recirculation pump-Act.val.,Measuring value not available,
    Line 86: IDE06578-MAS01447,Coolant pump for low-temperature circuit-Act.val.,Measuring value not available,
    Line 88: IDE06806-MAS01447,Coolant circulation pump 3-Act.val.,Measuring value not available,
    Line 103: IDE08802-MAS01447,Coolant circulation pump 2-Act.val.,Measuring value not available,
    Line 168: IDE10942-MAS01447,Expansion valve 1 for refrigerant-Act.val.,not coded/not installed,
    Line 173: IDE10943-MAS01447,Expansion valve 2 for refrigerant-Act.val.,100, %
    Line 178: IDE10944-MAS01447,Expansion valve 3 for refrigerant-Act.val.,not coded/not installed,
    Line 183: IDE10946-MAS01447,Shut-off valve 2 for refrigerant-Act.val.,not coded/not installed,
    Line 188: IDE10947-MAS01447,Shut-off valve 3 for refrigerant-Act.val.,99, %
    Line 193: IDE10948-MAS01447,Shut-off valve 4 for refrigerant-Act.val.,not coded/not installed,
    Line 198: IDE10949-MAS01447,Shut-off valve 5 for refrigerant-Act.val.,50, %
    Line 309: IDE13587-MAS01447,Valve 1 for coolant-Act.val.,84, %
    Line 314: IDE13588-MAS01447,Valve 2 for coolant-Act.val.,0, %
    Line 319: IDE13589-MAS01447,Valve 3 for coolant-Act.val.,0, %
    Line 324: IDE13591-MAS01447,Valve 4 for coolant-Act.val.,0, %
    Line 329: IDE14149-MAS01447,Valve 5 for coolant-Act.val.,not coded/not installed,
    Line 334: IDE14150-MAS01447,Valve for coolant-Act.val.,not coded/not installed,
    Line 379: IDE14530-MAS01447,Valve 6 for coolant-Act.val.,not coded/not installed,
    Line 384: IDE14531-MAS01447,Valve 7 for coolant-Act.val.,not coded/not installed,
superfries
C?ID=321926
Prior to reset:
Thursday,27,February,2025,09:10:13:53022
   CVN: 7D75D4C5
   Parking lock:
                    Fault Frequency: 17
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:24
39233 - Control Module for Electric Drive Power Output
          U0411 00 [00101000] - Implausble Message
                    Mileage: 115395 km
                    Date: 2025.02.24
                    Time: 09:28:01
                    Voltage terminal 30: 14.121 V
                    BSOC: 68.500 %
                    CUR_DCHA_MAX_DYN_2: -1100.0 A
                    Driver intention torque: 0.0 Nm
                    TQ_EM_1: -0.50000 Nm
                    TQ_EM_2: -0.50000 Nm
                    Current speed of electric motor: 24.0 /min
                    N_EM_6: 31.0 /min
38996 - Control Module for Electric Drive Power Output
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:37:22
                    BSOC: 68.500 %
                    TQ_EM_1: 0.00000 Nm
                    Current speed of electric motor: -244.0 /min
                    N_EM_6: 192.0 /min
38998 - Control Module for Electric Drive Power Output
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:37:22
                    BSOC: 68.500 %
                    TQ_EM_1: 0.00000 Nm
                    N_EM_6: 192.0 /min
33294 - Control Module for Electric Drive Power Output
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:57
                    BSOC: 68.500 %
                    N_EM_6: 31.0 /min
32271 - Control Module for Electric Drive Power Output
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:57
                    BSOC: 68.500 %
                    Current speed of electric motor: 16.0 /min
                    N_EM_6: 31.0 /min
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:27
                    Fault Frequency: 17
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
   Coding: 7DC727
   Coding: 02005E
   Coding: 0D0104
15 Faults Found:
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:20:31
67686 - Databus
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:35
67687 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:36
                    Fault Frequency: 17
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:26:12
196898 - Databus
          [Engine control module: received error value in signal TSK_status_PLA]
                    Fault Frequency: 8
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:59
                    interior_temperature: 11.50 °C
                    Reset counter: 137
                    Mileage: 114857 km
                    Date: 2025.01.04
                    Time: 12:05:03
196913 - Databus
                    Fault Frequency: 39
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:37:32
          B1217 15 [00001000] - Open or Short to Plus
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:31
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:37:33
          B121F 15 [00001000] - Open or Short to Plus
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:32
          U116E 00 [00001000] - No Communications
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:21:40
                    Fault Frequency: 80
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:33:36
          U1170 00 [00001000] - No Communications
                    Fault Frequency: 31
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:35
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:36
   Coding: 03F002
   Coding: 03F002
1065477 - Databus
                    Fault Frequency: 91
                    Reset counter: 150
                    Mileage: 111204 km
                    Date: 2024.11.16
                    Time: 22:45:46
1061381 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:23
13639936 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
                    Reset counter: 150
                    Mileage: 112473 km
                    Date: 2024.11.28
                    Time: 22:01:16
                    Reset counter: 150
                    Mileage: 111065 km
                    Date: 2024.11.15
                    Time: 11:04:55
          U1406 00 [00001000] - Too High
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 15:51:57
                    Reset counter: 150
                    Mileage: 114841 km
                    Date: 2024.12.26
                    Time: 18:20:50
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 09:46:15
   ID - sensor:
   left tail lamp 1:
   Subsystem 4 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429 D    HW: 4KE 945 429 D
   Subsystem 6 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Subsystem 7 - Part No SW: 4KE 945 430 D    HW: 4KE 945 430 D
49154 - Inverter for Electric Drive Motor 1
          P0A3C 00 [00101000] - Over Temperature
          [OverTempINVIGBTSW_1]
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:57
          [SIGERRBCM1_10]
                    Fault Frequency: 15
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
          P0A93 00 [10101000] - Inadequate Performance
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:37:12
51017 - Inverter Cooling System
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:49
                    Reset counter: 124
                    Mileage: 113482 km
                    Date: 2024.12.07
                    Time: 21:10:06
   Volume Control 1:
   Media socket:
   Coding: 3390
0066 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
   Coding: 303030
                    Fault Frequency: 24
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:24
                    Internal DTC: 127
                    Fault Frequency: 22
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
                    Internal DTC: 131
15462408 - All Wheel Drive System Failure
          C137E 00 [00001000] - -
          [ETCFkt_SysVerb_Error]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:57
                    Internal DTC: 399
                    quattro_torque_control: -15.00 rad
                    quattro_torque_control: 6
                    quattro_torque_control: 0
                    quattro_torque_control: -10000
                    quattro_torque_control: 3
                    quattro_torque_control: 255
                    quattro_torque_control: 0 m/s
                    Dynamic all wheel drive: overall system status-Status dynamic steering: Initialization
                    Dynamic all wheel drive: overall system status-Rear axle steering: status: Normal operating mode
                    Dynamic all wheel drive: overall system status-Dynamic all wheel drive: regulator status: Initialization
                    Dynamic all wheel drive: overall system status-Rear axle steering: status of dynamic all wheel drive: Initialization
                    Dynamic all wheel drive: overall system status-Dynamic steering: status of dynamic all wheel drive: Initialization
                    System group diagnosis-QSP Status: 0
                    System group diagnosis-Electric drivetrain 1: actual mode: 0
                    System group diagnosis-Electric drivetrain 2: actual mode: 0
                    System group diagnosis-Electric drivetrain 3: actual mode: 0
                    System group diagnosis-Moving prohibited: No prohibition
                    System group diagnosis-Torque request: total: -50000 Nm
                    System group diagnosis-eAWS Status: 0
                    System group diagnosis-Air suspension: status: 0
                    System group diagnosis-Straight line running factor: 0.000
15417390 - Control Module for Electric Drive Power Output
          U0411 00 [00001000] - Implausble Message
          [Function restriction due to invalid signal EM1_HYB_06:EM1_IstModus]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:57
                    Internal DTC: 439
15417391 - Control Module 2 for Electric Drive Power
          U0593 00 [00001000] - Implausible Signal
          [Function restriction due to invalid signal EM2_HYB_06:EM2_IstModus]
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:37:22
                    Internal DTC: 440
9004 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:31:59
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
H06 0112
13 Faults Found:
2114853 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.01.31
                    Time: 14:39:49
2114597 - Databus
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:32
2114598 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:33
2114605 - Databus
                    Reset counter: 150
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 12:23:30
2114606 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 14:36:32
2113925 - Databus
                    Fault Frequency: 39
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113926 - Databus
                    Fault Frequency: 39
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113927 - Databus
                    Fault Frequency: 39
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2113928 - Databus
                    Fault Frequency: 39
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114007 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114009 - Databus
                    Reset counter: 110
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:22
2114644 - Databus
                    Reset counter: 150
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:26:17
                    Reset counter: 150
                    Mileage: 115031 km
                    Date: 2025.01.08
                    Time: 08:32:27
                    Reset counter: 131
                    Mileage: 114595 km
                    Date: 2024.12.22
                    Time: 11:12:22
                    Reset counter: 130
                    Mileage: 114595 km
                    Date: 2024.12.22
                    Time: 11:16:10
   Coding: 00
   Shop #: WSC 13524 004 1048576
   A/C compressor sub:
   Radiator shutter:
   Component: V544KJS1  H12 0109
   Coolant valve 1:
   Coolant valve 2:
   Coolant valve 3:
   Coolant valve 4:
17 Faults Found:
                    Mileage: 115395 km
                    Date: 2025.02.13
                    Time: 06:09:14
          P05A3 00 [00101000] - Implausible Signal
                    Fault Frequency: 14
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 14:02:59
                    Mileage: 115395 km
                    Date: 2025.02.13
                    Time: 06:09:14
                    Mileage: 115395 km
                    Date: 2025.02.14
                    Time: 12:56:09
                    Mileage: 115395 km
                    Date: 2025.02.12
                    Time: 21:33:07
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:23:12
                    Mileage: 115395 km
                    Date: 2025.02.12
                    Time: 21:33:11
                    Fault Frequency: 17
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:26
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 11:29:19
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 11:29:22
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:28
                    Fault Frequency: 207
                    Mileage: 115394 km
                    Date: 2025.01.13
                    Time: 20:44:09
          P1A81 00 [00101000] - Not Ended
                    Fault Frequency: 61
                    Mileage: 115395 km
                    Date: 2025.02.15
                    Time: 14:41:16
60012 - Basic Setting for Coolant Fill
          P10E6 00 [00101000] - Not Completed
                    Fault Frequency: 26
                    Mileage: 115395 km
                    Date: 2025.02.19
                    Time: 17:07:18
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: FF
                    Expanded ambient data 1-current state of battery cold circuit: 1E
                    Mileage: 115394 km
                    Date: 2025.01.11
                    Time: 23:21:12
                    Mileage: 115394 km
                    Date: 2025.01.16
                    Time: 10:31:38
          P139B 00 [00101000] - Coolant Level Low
                    Mileage: 115394 km
                    Date: 2025.01.13
                    Time: 20:44:07
7 Faults Found:
13705549 - Databus
          [DCDC_01_Timeout]
16711691 - Coolant Inlet Temp Sensor
          P31C5 00 [01101101] - Over-Temp
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 18:04:29
                    Fault Frequency: 9
                    Reset counter: 33
                    Mileage: 111409 km
                    Date: 2024.11.18
                    Time: 15:43:01
                    Fault Frequency: 31
                    Mileage: 111076 km
                    Date: 2024.11.15
                    Time: 13:52:13
                    Fault Frequency: 34
                    Mileage: 111076 km
                    Date: 2024.11.15
                    Time: 13:52:13
2097286 - Intelligent Charging
          U15A9 00 [00101000] - Functional Restriction
          [VoKo_characterictic_false]
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 16:15:24
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:37:22
          [SIGERRBCM1_10]
                    Fault Frequency: 15
                    Mileage: 115395 km
                    Date: 2025.02.08
                    Time: 13:24:20
                    Mileage: 115394 km
                    Date: 2025.01.11
                    Time: 23:21:58
                    Fault Frequency: 19
                    Mileage: 115395 km
                    Date: 2025.02.21
                    Time: 15:34:42
   Dataset Number: 4KE909471E  0011
   ROD: EV_LMSLeftHELLAAU58X.rod
End----------(Elapsed Time: 03:16, VBatt start/end: 13.1V/13.1V)-----------
Thanks. Please post the newest one as well but most of the Intermittent DTCs should clear. I think these need to be dealt with as a priority:
1) Several control modules are complaining about Ambient Temperature. I did not check wiring diagrams but J519 handled that on MLB cars, and these are the evo versions of that MLB BCM type, so I would focus on correcting:
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb​
Part No SW: 4N0 907 063 KG HW: 4N0 907 063 AG​
Component: BCM1 MLBevo H10 0691​
65801 - Outside temperature sensor
B103F 15 [00001001] - Open or Short to Plus
2) This is also in the front of the car and related to the thermal management so I'd dig into it as well:
Address C5: Therm. mgt. (J1024) Labels:* None​
Part No SW: 4KE 965 429 C HW: 4KE 965 429​
Component: TME-Max H08 0312​
With any luck both of those are simply wiring issues in the front rather than faulty parts.
Next, I poked around in my e-tron 55 last night and got 2 of the 4 Selective Output Test selections in my SOT log to work. The pumps that were supported were very quiet on a full system.
Address 0xC54KE 965 429 CUDS Selective Output TestsIDE01236-Coolant recirculation pumpWednesday
26​
February
2025​
19:23:54:44768WA1AAAGE3NB032133
Address 0xC54KE 965 429 CUDS Selective Output TestsIDE06578-Coolant pump for low-temperature circuitWednesday
26​
February
2025​
19:24:07:44768WA1AAAGE3NB032133
Address 0xC54KE 965 429 CUDS Selective Output TestsIDE06806-Coolant circulation pump 3Wednesday
26​
February
2025​
19:24:25:44768WA1AAAGE3NB032133
Address 0xC54KE 965 429 CUDS Selective Output TestsIDE08802-Coolant circulation pump 2Wednesday
26​
February
2025​
19:24:35:44768WA1AAAGE3NB032133
I ran a handful of Basic Settings and believe this is the correct order:
Address 0xC54KE 965 429 CUDS Basic SettingsMAS13022-ENG136917-Filling coolant circuitsWednesday
26​
February
2025​
19:20:36:44768WA1AAAGE3NB032133
Address 0xC54KE 965 429 CUDS Basic SettingsIDE13606-ENG114972-Stop Routine coolant circuit charging/flushingWednesday
26​
February
2025​
19:21:23:44768WA1AAAGE3NB032133
I initially tested the Basic Setting steps in post #7 and moved onto those so my logging is messy but the changes were found here:
Loc. IDE13587-MAS01447Loc. IDE13588-MAS01447Loc. IDE13591-MAS01447
Valve 1 for coolant-Act.val.Valve 2 for coolant-Act.val.Valve 4 for coolant-Act.val.
84​
0​
0​
84​
0​
0​
84​
0​
0​
14​
42​
70​
14​
42​
70​
14​
42​
70​
Similar to your observations there was only clicking. The electric pumps did not run when running any of basic settings.
That may be perfectly normal because activating MAS13022-ENG136917-Filling coolant circuits on an empty system with a vacuum applied followed by opening the valve on the vacuum assist filler device should get the system to fill and be free of any air. This 3rd party device works like the official VAG ones in that regard: https://www.amazon.com/UView-550000-Airlift-Cooling-Checker/dp/B0002SRH5G
Then, after the coolant filler is finished it would be logical to use IDE13606-ENG114972-Stop Routine coolant circuit charging/flushing.
Fault codes I managed to set and clear were:
Address 0xC5,4KE 965 429 C,UDS Basic Settings,MAS13022-ENG136917-Filling coolant circuits
Address 0xC5,4KE 965 429 C,UDS Basic Settings,IDE13606-ENG114972-Stop Routine coolant circuit charging/flushing
                Address C5: Therm. mgt.       Labels: NONE
Control Module Part Number: 4KE 965 429 C    HW: 4KE 965 429
  Component and/or Version: TME-Max       H08 0312
           Software Coding: 00
            Work Shop Code: WSC 00046 412 00046
              ASAM Dataset: EV_ThermContrVISAU49X 002036 (AU58)
                      VCID: 4ACAB8D32C35E75A156-801E
          P1A81 00 [00101110] - Not Ended
                    Mileage: 19461 km
                    Date: 2025.02.26
                    Time: 19:18:25
                    Expanded ambient data 1-Ambient temperature: 5.00 °C
                    Expanded ambient data 1-previous state of battery cold circuit: 1E
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 51
          P10E6 00 [00101110] - Not Completed
                    Mileage: 19461 km
                    Date: 2025.02.26
                    Time: 19:16:16
In hindsight I did not try Basic Settings MAS13022-ENG136917-Filling coolant circuits and then try to exit and use Selective Output Tests. If the valves stay in the service position after exiting Basic Settings that may be effective ... but if they go back to the normal positions it may fail to move air.
I haven't given up on researching [*IDE08087-MAS13044*] Test - bleed cooling circuit as per your earlier photo here. I'll report back if I have success in that area because it looks more like a group that would open valves -and- run pumps on a system with coolant in it already.
superfries
C?ID=321926
Hi Dana, sorry for the delay, had to fix a leak in the AC system which took a while. Back on the cooling system now :)
This makes sense, I had the front bumber removed as it was toast - I think the temp sensor is located somewhere in there. This also triggered a range of errors, apparently the Tire Pressure Mgt Syst (TPMS) also uses amb temp for tire pressure indication so that was throwing faults in the dash. I fitted another bumper and these are now gone from the dash.
Yes, there are two separate coolers, one above and one below the aluminium crashbar behind the bumper cover. One is for coolant, one for AC, and both have shutters operated by stepper-motors to regulate airflow. One of the wires was torn, should be fixed now.
Yep, never did get the coolant bleed to work. I did just refill and drive, kept getting intermittant error messages on dash about cooling and drive train, but only yellow ones so kept going while checking reservoir levels. If reservoir drops below sensor level the dash message turn red and calls for immediate stop.
Have driven about 10 km (6mi) now without any messages so fingers crossed.
Turning the car in for AC refill today at local garage, they indicated coolant bleed might be troublesome without AC charged as the systems work in sync. So they'll give bleeding ago after refill with their non-official ODB system. Will keep you posted.
Lastly: see here my latest autoscan after reset. I did notice that some fault-codes do not clear, not sure what's up with that.
Friday,14,March,2025,09:53:39:53022
VCDS Version: 25.3.0.3 (x64)  HEX-NET CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WAUZZZGE4LB016291   License Plate:
Chassis Type: GE-AU58 (4KL)
Scan: 01 03 09 15 16 17 19 2B 36 42 44 46 51 52 5F 69 6D 74 75 81
          8C A5 BB BC C5 C6 CE D6 D7 8104
VIN: WAUZZZGE4LB016291   Mileage: 115445km-71734miles
51-Electric Drive -- Status: Malfunction 0010
74-Chassis Control -- Status: Malfunction 0010
8C-HV Battery -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: Malfunction 0010
Address 01: Engine (J623-    )       Labels: Redir Fail!
   Part No SW: 4KE 907 558 C    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   CVN: 7D75D4C5
   Coding: 2A0A0012002E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558C 001003
   ROD: EV_VCU00XXX0204KE907558C.rod
   VCID: 49DAB5DDE8761CD357-801C
   VINID: 9D196AAAA5D511C480046089043C0EF240
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2019.10.09.000000304
8 Faults Found:
23075 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [00101000] - -
                    Fault Frequency: 12
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:20
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 11.210 V
                    LF_MVB_PDU_INTC_DIAG_8: 16384
                    LF_MVB_PDU_INTC_DIAG_9: 195
                    LF_MVB_PDU_INTC_DIAG_10: 64512
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 12288
                    LF_MVB_BUS_INTC_DIAG: 12544
                    Mileage: 115406 km
                    Date: 2025.02.27
                    Time: 17:51:46
                    Vehicle speed: 3 km/h
                    Voltage terminal 30: 14.023 V
                    BSOC: 49.500 %
                    Current speed of electric motor: 122.0 /min
                    N_EM_6: 179.0 /min
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:09
                    Vehicle speed: 41 km/h
                    Voltage terminal 30: 14.355 V
                    BSOC: 59.000 %
                    TQ_EM_1: 13.00000 Nm
                    TQ_EM_2: -1.50000 Nm
                    Current speed of electric motor: 2707.0 /min
                    N_EM_6: 2474.0 /min
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:09
                    Voltage terminal 30: 14.335 V
                    BSOC: 59.000 %
                    TQ_EM_1: 12.00000 Nm
                    Current speed of electric motor: 2709.0 /min
                    N_EM_6: 2513.0 /min
                    Mileage: 115406 km
                    Date: 2025.02.27
                    Time: 17:51:46
                    BSOC: 49.500 %
                    N_EM_6: 179.0 /min
                    Mileage: 115406 km
                    Date: 2025.02.27
                    Time: 17:51:46
                    BSOC: 49.500 %
                    N_EM_6: 179.0 /min
39000 - Control Module for Electric Drive Power Output
                    Fault Frequency: 8
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:12
                    Vehicle speed: 14 km/h
                    Voltage terminal 30: 14.062 V
                    BSOC: 62.000 %
                    TQ_EM_1: 0.00000 Nm
                    TQ_EM_2: -1.00000 Nm
                    Current speed of electric motor: 946.0 /min
                    N_EM_6: 938.0 /min
33304 - Control Module for Electric Drive Power Output
                    Fault Frequency: 8
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:12
                    BSOC: 62.000 %
                    TQ_EM_1: 0.00000 Nm
                    N_EM_6: 938.0 /min
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4KE 909 059 AF    HW: 4KE 909 059 G
   Component: ESC           H09 0242
   Revision: 00000000    Serial number: 63139000005382 Dataset Number: 4KE909504AH 0003 CVN: D4D7BE22
   Coding: 008800BA3D950A9F9352087A1878D2D025BEA00000BC50C910184B0BA47D05
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_011.rod
   VCID: 0B564FD5A28A4EC3A5-805E
8366 - Control Module for Instrument Cluster
          U1018 00 [00101100] - Missing Signal for Ambient Temperature
          [CCan_kbi_qbit_aussen_temp_gef_qualifier]
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:19
                    Unlearning counter according OBD-OBD unlearning counter: 40
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 23: 00
                    History Data-History data 24: 00
                    History Data-History data 25: 00
                    History Data-History data 26: 00
                    History Data-History data 27: 00
                    History Data-History data 28: 00
                    History Data-History data 29: 00
                    History Data-History data 30: 00
                    History Data-History data 31: 00
                    History Data-History data 0: 00
8367 - Control Module for Instrument Cluster
          [CCan_kbi_aussen_temp_gef_failure]
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:22
   Dataset Number: 4KE909514C  0021
   Coding: 07000143C1F900DD0740870898BF8C68130B33100806009701010800792216810A4509B362B6220B000001000009101A0000800000010000000000000000000000
   Shop #: WSC 24534 004 1048576
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DB2110DEC3E7073AB-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001910040400696
   Coding: 7DC727
   Serial number: 23882783X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 17S19.11.1900300726
   Serial number: GX1CE109081923811641
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0416
   Serial number: B01482557
   Coding: 0D0104
11 Faults Found:
          B103F 15 [00001000] - Open or Short to Plus
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:17:07
                    average_Voltage_terminals: 12.10 V
                    Outside air temperature sensor-Resistance: 120.32 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: Malfunction
                    interior_temperature: Temperature not available
                    Vehicle speed: Initialization
                    Terminal activation-Terminal 75 status: Not available
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: Not available
67686 - Databus
          [MxB left high beam: faulty]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:19
                    average_Voltage_terminals: 11.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: Initialization
                    interior_temperature: 5.50 °C
                    Vehicle speed: 0.00 km/h
196609 - Voltage Supply for Front Parking Aid Sensors
          B14BD 16 [00001000] - Voltage Too Low
                    Fault Frequency: 54
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:54:56
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 10.50 °C
                    interior_temperature: 14.50 °C
196720 - Front Parking Aid Sensor(s)
          B10FC 13 [00001000] - Open Circuit
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:15
196898 - Databus
                    Fault Frequency: 19
                    Reset counter: 150
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:10
                    average_Voltage_terminals: 14.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 9.00 °C
                    interior_temperature: 17.00 °C
                    Vehicle speed: 29.02 km/h
196913 - Databus
          [Instrument cluster control module: received error value in signal IC_outside_temp_filt]
                    Fault Frequency: 12
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:20
                    average_Voltage_terminals: 12.20 V
65619 - Bulb for Low Beam Headlamp Left
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:15
65634 - Bulb for Left Fog Lamp
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:16
65826 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [00001000] - Performance
          [Comfort data bus: No communication]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.12
                    Time: 13:17:31
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
66672 - Control Module for Light Activation/Adjustment; Left
          [Left LCM: no signal/communication]
                    Fault Frequency: 78
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:17:05
131353 - Power Output Module for LED Headlamps; Left
          [Left LED headlamp power output module: no communication]
                    Fault Frequency: 9
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:19
                    System run time-Engine running time: 65535 s
                    System run time-Terminal 15 on: 0 s
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H42 3122
   Serial number: 003XPM01D5HX Dataset Number: 4KE909602K  0003
   Coding: AACCF0C0002000009A5400FFF80D40A800C5
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   Left seat belt tensioner:
   Serial number: 00AI2019310410200000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2019287017700000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: 35700000000A1B44D04J
   Subsystem 4 - Part No SW: -----------    HW: 480 000 511 19
   Serial number: 3580000000098244D04H
   Subsystem 5 - Part No SW: -----------    HW: 480 031 311 19
   Serial number: 351002C0054A78A099DC
   Subsystem 6 - Part No SW: -----------    HW: 480 031 311 19
   Serial number: 352002C0054A317098B$
   Subsystem 7 - Part No SW: -----------    HW: 480 020 811 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500012C62ED2C10451
   Subsystem 8 - Part No SW: -----------    HW: 480 020 811 19
   Component: FrontSensor_P  000 0149
   Serial number: 35600012A62ED2C70434
   Crash sensor high-voltage system 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 020 811 19
   Component: HVSensor_gSat  000 0149
   Serial number: 35100012A62ED2C0F4AE
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 020 811 19
   Component: SideSens_B_Df  000 0149
   Serial number: 35200012A62ED2C3322$
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 020 811 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500012A62ED2C196CH
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Reset counter: 150
                    Mileage: 115400 km
                    Date: 2025.02.27
                    Time: 13:39:14
1061381 - Databus
          [NWD: 0x5E1 Klima_Sensor_02 error value BCM1_Aussen_Temp_ungef]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:19
   Part No SW: 4N0 907 129 AH    HW: 4N0 907 129 AH
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 77BE0325CE025A23F1-8022
Address 17: Instruments (J285)       Labels:| 4KE-920-KOM-V1.clb-SRI2
   Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
   Component: FHybRDWACC--- H13 0105
   Coding: 852400C8788000080D26E170B284280008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 45C2B9EDC46EF8B3B3-8010
   Part No SW: 4KL 907 468     HW: 4K1 907 468 C
   Component: Gateway       H04 0362
   Serial number: 14F03078613301 Dataset Number: 4KE909515B  0027
   Coding: 02010005000100C000810000005B01328C8A0007180000000900009E00000000
   GVL: 01503C0008000200949C08008000481801080000000080010000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 0D5241CDDC9E40F3BB-8058
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 76749602001910010102
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [00001000] - -
          [Timeout_Node_0x47_DiagAdress_69_AAG]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.02.28
                    Time: 09:15:45
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [BAP_Timeout_BatteryControl]
                    Fault Frequency: 32
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 10:00:36
16711692 - Databus
          [HVK_Fault_2_Isolation_BMS]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 17:19:15
                    H-V activ. restriction-HV charge management: not active
                    H-V activ. restriction-H-V power transformers: prohibition on turning-on H-V: not active
                    H-V activ. restriction-High-voltage charge booster: high-voltage activation prohibitions: not active
                    H-V activ. restriction-Heater for exhaust gas catalytic converter: HV activ. restriction: not active
                    H-V activ. restriction-Electrical turbocharger: HV activ. restriction: not active
                    H-V activ. restriction-Airbag control module: not active
                    H-V activ. restriction-Thermal management: not active
                    H-V activ. restriction-Engine Electronics: not active
                    H-V activ. restriction-Transformer for electrical drive: not active
                    H-V activ. restriction-Hybrid Battery Management: not active
                    H-V activ. restriction-Control module for wireless charging: not active
                    H-V activ. restriction-High-voltage battery charger: not active
                    H-V activ. restriction-HV activation prohibited due to accident: not active
                    H-V activ. restriction-HV activation prohibited due to de-activation: not active
                    H-V activ. restriction-HV activation prohibited due to blocking: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 3: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 4: not active
                    H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 5: not active
                    H-V activ. restriction-Electrical turbocharger 1: not active
                    H-V activ. restriction-Electric drive 3: not active
                    H-V activ. restriction-Electric drive 2: not active
                    H-V activ. restriction-HV battery charging unit 2: not active
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000291420003
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 3424F4299FF4713B14-8060
   Serial number: 00000393494248 Dataset Number: 4KE909856B  0005
   Coding: 005812400000B4010003010101010000000000000000000000000000004000
   VCID: 79BA051DF8164C5387-802C
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        010 0387
   Serial number: 0000395159238  Dataset Number: 4KE909872B  0013
   Coding: 001FDB0052000480A001B002
   VCID: 46C0BEE1F968F3ABBA-8012
   Dataset Number: 4KE909852E  0003
   Coding: 94110101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3228F23165E07F0B06-8066
   Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0530
   Dataset Number: 4KE909501D  0027
   Coding: 01740000AFB100E16309A0000400C80200000000804B06582F04000000040030001F0100000F13
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU58.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY193001MVJ
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047852190
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W70000V8Q
   left tail lamp 2:
   Subsystem 4 - Part No SW: 4KE 945 429 D    HW: 4KE 945 429 D
   Component: T2 LH ECE HD  H12 0503
   Serial number: A1WK0004WPM
   Right rear tail lamp 1:
   Subsystem 5 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000VBX
   Right rear tail lamp 2:
   Subsystem 6 - Part No SW: 4KE 945 430 D    HW: 4KE 945 430 D
   Component: T2 RH ECE HD  H12 0503
   Serial number: A1WL0004WPP
65667 - Databus
          [Trailer detection control module: Anhaenger_01: no signal/communication]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.02.28
                    Time: 09:15:44
                    Supply voltages-Terminal 30 power supply: 12.229 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.256 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.229 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
Address 51: Electric Drive (J841)       Labels: 0EF-907-XXX-V1.clb
   Part No SW: 0EF 907 080 H    HW: 0EF 907 080 C
   Component: CUFZD68570AD0 H03 1005
   Revision: --------    Serial number: -00129.06.19000
   Coding: 01000000000000000000
   Shop #: WSC 13734 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3B36DF15B2AABE43D5-806E
                    Mileage: 115406 km
                    Date: 2025.02.27
                    Time: 17:51:46
36890 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [00101000] - -
          [SIGERRBCM1_10]
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:17
36909 - Invalid Data Received from Control Module for Thermal Management
          U0456 00 [00101000] - -
          [SIGERRTME_3]
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:12
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:07
                    Mileage: 115402 km
                    Date: 2025.02.27
                    Time: 13:43:30
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       010 0387
   Serial number: 0000395167507  Dataset Number: 4KE909873B  0013
   Coding: 001FDB005E000480A001B000
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 D    HW: 4KE 035 063
   Component: MU-H-LND-EU   054 2711
   Dataset Number: 4KE909545C  0015
   Coding: 01157601FF0A000043111101C00802102F0001E403700800CE
   VCID: 240404692F14E1BB84-8070
   Subsystem 1 - Part No: V03 959 807 SK
   Component: MIB2P_EU_Q122  0600
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00118081900130352
   Compact disc data bank:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000122005059
   Multimedia display unit 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00123081900140420
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900674527014
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789,,+''. Dataset Number: v12400160G0 0016
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2 Dataset Number: 4KE909541B  0007
   Coding: 3390
   VCID: 4AD88AD1ED7017CB5E-801E
0066 - Databus
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:23
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4KE 907 777 AH    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2320
   Serial number: 0611190665  Dataset Number: 4KE909576T  0008
   Coding: 90D8607BDA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 126852B1C5A09F0B66-8046
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130765092
   Coding: 303030
4456450 - Diagnostic Gateway Module
          U0447 00 [00001000] - Implausible Signal
          [Function_restriction_due_to_communication_interruption_AmbientTemperature]
                    Fault Frequency: 12
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:15
                    Internal DTC: 127
4456460 - Diagnostic Gateway Module
          [Function_restriction_due_to_communication_interruption_AmbientTemperatureFiltered]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:17
                    Internal DTC: 131
15462404 - Development code 1
          B2F01 00 [00001000] - -
          [ETCFkt_AllWheelDist_Ignored]
                    Reset counter: 150
                    Mileage: 115430 km
                    Date: 2025.03.12
                    Time: 20:34:49
                    Internal DTC: 395
                    quattro_torque_control: -170 m/s
                    quattro_torque_control: -78
                    Reset counter: 150
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:09
                    Internal DTC: 399
                    Reset counter: 150
                    Mileage: 115406 km
                    Date: 2025.02.27
                    Time: 17:51:46
                    Internal DTC: 439
                    Reset counter: 150
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:09
                    Internal DTC: 440
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120875 Dataset Number: 4KE909612B  0014
   Coding: 01C0E0FEC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 281C1059533C05DBA8-807C
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SHE00035
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C34DC09B7A4B97BDC-8068
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4KE 915 233 S    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0468
   CVN: 9DDFAF83B5D9CDDC9F3843E89F3843E89F3843E89F3843E89F3843E89F3843E8
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   VCID: 4ED086C111183BEB02-801A
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H13 0370
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
20493 - Control Circuit for HV Battery Pack Coolant Pump
          P0C4A 00 [11101101] - Implausible Signal
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:20
                    High-volt. battery mode: spec. value: Driving mode
                    Mode HV battery actual value: Driving mode
                    H-V battery voltage: 395.50 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 395.50 V
                    Current of H-V / hybrid battery: -1.65 A
                    Battery temperature: 11 °C
                    Battery charge level: 48 %
                    Terminal 30 power supply: 14.80 V
                    Voltage terminal 30C: 14.60 V
                    Power reduction status: active
                    Malfunction Indicator Lamp-Start request: active
                    Service Disconnect: Status: connected
                    Pilot line: closed
                    Status of voltage freedom: High voltage power off not recognized
                    Crash signal: not active
                    Protection of posit. terminal of high voltage / hybrid battery: closed
                    Protection of neg. terminal of high voltage / hybrid battery: closed
                    Status pre-loader: Open
                    HV battery: cool. level requirement: no cooling request
                    Pump for HV battery coolant: specified speed value: 97.00 %
                    Pump for HV battery coolant: status: RPM limitation: dry run protection
                    HV battery positive terminal insulation resistance-Status: Initialization
                    HV battery positive terminal insulation resistance: 20470 kOhm
                    HV battery minus terminal insulation resistance-Status: Initialization
                    HV battery minus terminal insulation resistance: 20470 kOhm
                    Entire HV system positive terminal insulation resistance-Status: Initialization
                    Entire HV system positive terminal insulation resistance: 3990 kOhm
                    Entire HV system minus terminal insulation resistance-Status: Initialization
                    Entire HV system minus terminal insulation resistance: 3950 kOhm
                    maximum voltage for battery cells-Index 1: 0
                    maximum voltage for battery cells-Value: 3.662 V
                    minimum voltage for battery cells-Index 1: 0
                    minimum voltage for battery cells-Value: 3.659 V
                    Highest measured temperature-Temperature sensor: 0
                    Highest measured temperature-Value: 13 °C
                    Lowest measured temperature-Temperature sensor: 0
                    Lowest measured temperature-Value: 11 °C
                    Air temperature of H-V / hybrid battery-Intake: -100 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 10 °C
                    Maximum charge level-Index 1: 0
                    Maximum charge level-Value: 49 %
                    Minimum charge level-Index 1: 0
                    Minimum charge level-Value: 48 %
                    Dynamic limit for charge current-Limit for charge current: 600 A
                    Predictive limit for charge current-Limit for charge current: 247 A
                    Dynamic limit for discharge current-Limit for discharge current: 1100 A
                    Predictive limit for discharge current-Limit for discharge current: 400 A
                    Maximum charging voltage: 459.00 V
                    Minimum discharge voltage: 225.00 V
                    Minimum dynamic charging voltage: 420.10 V
                    Minimum predictive charging voltage: 405.60 V
                    Minimum dynamic discharge voltage: 350.90 V
                    Minimum predictive discharge voltage: 379.30 V
40966 - HV Battery Voltage System Isolation Fault
          P0AA6 00 [00101000] - -
          [Diag_F_Leakage2_Neg_HVBATtotal]
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 17:19:13
                    H-V battery voltage: 402.70 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 402.70 V
                    Current of H-V / hybrid battery: -5.05 A
                    Battery temperature: 13 °C
                    Battery charge level: 56 %
                    Power reduction status: not active
                    Pilot line: closed
                    Pump for HV battery coolant: specified speed value: 12.00 %
                    Pump for HV battery coolant: status: No malfunction
                    Entire HV system positive terminal insulation resistance: 0 kOhm
                    Entire HV system minus terminal insulation resistance: 0 kOhm
                    maximum voltage for battery cells-Value: 3.730 V
                    minimum voltage for battery cells-Value: 3.724 V
                    Highest measured temperature-Value: 14 °C
                    Lowest measured temperature-Value: 13 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 14 °C
                    Maximum charge level-Value: 56 %
                    Minimum charge level-Value: 55 %
                    Predictive limit for charge current-Limit for charge current: 254 A
                    Minimum dynamic charging voltage: 425.50 V
                    Minimum predictive charging voltage: 412.40 V
                    Minimum dynamic discharge voltage: 359.80 V
                    Minimum predictive discharge voltage: 387.10 V
40967 - HV Battery Voltage System Isolation Fault
          [Diag_F_Leakage2_Pos_HVBATtotal]
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 17:19:13
                    Pilot line: closed
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AK    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0293
   Dataset Number: 4KE909466G  0024
   Coding: 0421840000000000000006000040462C189C57000000000000000000000000000019000000000000000000000000000000000000000000000000800000000000000078D80000009000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 085C70D9B3FC25DB88-805C
11 Faults Found:
2114853 - Databus
          [LWR_Soll_Fkt_SOL_FehlPos_L]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:23
2114597 - Databus
          [TIMEOUT_LED_Feh_LM_L_03]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:15
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 11.90 V
                    Supply voltages-Terminal 30 local: 14.30 V
2114605 - Databus
          [TIMEOUT_LWR_Sta_LM_L]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:14
2113925 - Databus
          [APS_03_US_Fehler_VS]
                    Fault Frequency: 65
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:33
2113926 - Databus
          [APS_03_US_Fehler_HS]
                    Fault Frequency: 65
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:33
2113927 - Databus
          [APS_Master_US_Sende_Modus]
                    Fault Frequency: 65
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:33
2113928 - Databus
          [APS_Master_US_Sende_Modus_hinten]
                    Fault Frequency: 65
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:33
2114007 - Databus
          [Klima_Sensor_02_BCM1_Aussen_Temp_ungef]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:17
2114009 - Databus
          [Kombi_02_KBI_Aussen_Temp_gef]
                    Reset counter: 150
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:17
2114644 - Databus
          [Parkhilfe_01_PH_Visualisierung]
                    Reset counter: 150
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:33
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [00001000] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 150
                    Mileage: 115425 km
                    Date: 2025.03.12
                    Time: 20:24:28
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 14 °C
                    Vehicle speed: 60.79 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       010 0387
   Serial number: 0000395541172  Dataset Number: 4KE909897B  0013
   Coding: 000FD90000000480A000B000
   ROD: EV_DCU2RearDriveMAXHCONT_AU38.rod
   VCID: 48DCB0D9F37CE5DB48-801C
   Component: TSG HBFS      010 0387
   Serial number: 0000395541493  Dataset Number: 4KE909896B  0013
   ROD: EV_DCU2RearPasseMAXHCONT_AU38.rod
   Serial number: 0102165 Dataset Number: 4KE909476VD 0001
   Coding: 00
   ROD: EV_ThermContrVISAU49X_002_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 F    HW: 3Q0 963 231 F
   Serial number: -00104.1B.2A20370138
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019102400060
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151109993
   Shut-off valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000131018572
   Shut-off valve 3 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000131018550
   Shut-off valve 4 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000131018576
   Shut-off valve 5 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000131018588
   Coolant valve 1:
   Subsystem 10 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000424652
   Coolant valve 2:
   Subsystem 11 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000402618
   Coolant valve 3:
   Subsystem 12 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000433366
   Coolant valve 4:
   Subsystem 13 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000437565
15 Faults Found:
61010 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [01101101] - -
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:25
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 29 km/h
                    Expanded ambient data 1-System status: Drive readiness
                    Expanded ambient data 1-Power quota setting by energy management: 1D
                    Expanded ambient data 1-Status of drive readiness hybrid: Electrical travel
                    Expanded ambient data 1-Ambient temperature: 9.00 °C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 01
                    Expanded ambient data 1-previous state of battery low temp.circ.: 03
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 0D
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: FF
59188 - Active Radiator Shutter 1
          P05A3 00 [00101110] - Implausible Signal
                    Fault Frequency: 45
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:59:37
                    Expanded ambient data 1-Vehicle speed: 2 km/h
                    Expanded ambient data 1-Ambient temperature: 11.00 °C
                    Expanded ambient data 1-current state of battery low temp.circ.: 02
                    Expanded ambient data 1-previous state of battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 05
                    Radiator shutter 1: status referencing-Initialization: initialized
                    Radiator shutter 1: status referencing-blockage: not active
                    Radiator shutter 1: status referencing-Direction of rotation: clockwise
                    Radiator shutter 1: status referencing-excessive temperature: not active
                    Radiator shutter 1: status referencing-Temperature in control module: -50 °C
                    Radiator shutter 1: status referencing-Internal malfunction: not active
                    Radiator shutter 1: status referencing-Supply voltage: 0.00 V
                    Radiator shutter 1: status referencing-Free run: not active
                    Radiator shutter 1: status referencing-Adapting: completed successfully
                    Radiator shutter 1: status referencing-Position: 127 %
                    Radiator shutter 1: status referencing-operational: active
                    Radiator shutter 1: status referencing-Response error: OK
                    Radiator shutter 1: status referencing-Torque: Measuring value not available
                    Radiator shutter 1: status referencing-Reference value: OK
                    Radiator shutter 1: status referencing-Position_Textual: Malfunction
                    Activation radiator shutter result-Initialization: not active
                    Activation radiator shutter result-LIN node- address: 0
                    Activation radiator shutter result-Specified value: 0 %
                    Activation radiator shutter result-Direction of rotation: clockwise
                    Activation radiator shutter result-Set reference level: not active
                    Activation radiator shutter result-Torque: low
                    Activation radiator shutter result-LIN_node_adress_Textual: numerical value: no text
                    Activation radiator shutter result-set_value_Textual: numerical value: no text
59128 - Load Signal from A/C Compressor
          P0531 00 [00101000] - Implausible Signal
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 10:55:09
                    Expanded ambient data 1-Vehicle speed: 255 km/h
                    Expanded ambient data 1-System status: not active
                    Expanded ambient data 1-Status of drive readiness hybrid: Initialization
                    Expanded ambient data 1-Ambient temperature: 8.50 °C
                    Expanded ambient data 1-current state of battery low temp.circ.: 00
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 03
                    A/C pressure/temperature sensor 1-Refrigerant pressure: 0.00 bar
                    A/C pressure/temperature sensor 1-Communication: OK
                    A/C pressure/temperature sensor 1-Malfunction status: OK
                    A/C pressure/temperature sensor 1-Response error: OK
                    A/C pressure/temperature sensor 1-Inside temperature: 10.70 °C
                    A/C pressure/temperature sensor 1-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 1-Refrigerant temperature: 12.30 °C
36891 - Implausible Data Received from Body Control Module (Central Electric)
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:17:03
                    Expanded ambient data 1-Ambient temperature: Initialization
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 02
40959 - Expansion Valve for A/C Refrigerant
          U062E 00 [00101000] - No Communication
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 14:52:54
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine off or drive is not ready
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 04
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 05
                    Expansion valve 2 for refrigerant-LIN node- address: Shut-off valve 1 for refrigerant
                    Expansion valve 2 for refrigerant-Act.val.: 0 %
                    Expansion valve 2 for refrigerant-Specified value: 100 %
                    Expansion valve 2 for refrigerant-Temperature: -50 °C
                    Expansion valve 2 for refrigerant-Raw value: Malfunction
                    Coolant expansion valve 2: internal status-Temperature: -50 °C
                    Coolant expansion valve 2: internal status-Position: Malfunction
37187 - No Communication With Active Grille Air Shutter Module
          U0284 00 [00101111] - -
                    Fault Frequency: 26
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 10:02:36
                    Expanded ambient data 1-Vehicle speed: 3 km/h
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 07
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 17
                    Radiator shutter 1: status referencing-operational: not active
                    Radiator shutter 1: status referencing-Response error: Malfunction
                    Activation radiator shutter result-Torque: up
59316 - No Communication With Active Grille Air Shutter Module 2
          U0285 00 [00101111] - -
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:56:24
                    Expanded ambient data 1-System status: Control operation: ignition on
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine start
                    Expanded ambient data 1-Ambient temperature: 10.50 °C
                    Radiator shutter 2: status referencing-Initialization: initialized
                    Radiator shutter 2: status referencing-blockage: not active
                    Radiator shutter 2: status referencing-Direction of rotation: clockwise
                    Radiator shutter 2: status referencing-excessive temperature: not active
                    Radiator shutter 2: status referencing-Temperature in control module: -50 °C
                    Radiator shutter 2: status referencing-Internal malfunction: not active
                    Radiator shutter 2: status referencing-Supply voltage: 0.00 V
                    Radiator shutter 2: status referencing-Free run: not active
                    Radiator shutter 2: status referencing-Adapting: completed successfully
                    Radiator shutter 2: status referencing-Position: 127 %
                    Radiator shutter 2: status referencing-operational: not active
                    Radiator shutter 2: status referencing-Response error: OK
                    Radiator shutter 2: status referencing-Torque: Measuring value not available
                    Radiator shutter 2: status referencing-Reference value: not OK
                    Radiator shutter 2: status referencing-Position_Textual: Malfunction
                    Activation of radiator shutter 2-Initialization: not active
                    Activation of radiator shutter 2-LIN node- address: 1
                    Activation of radiator shutter 2-Specified value: 0 %
                    Activation of radiator shutter 2-Direction of rotation: clockwise
                    Activation of radiator shutter 2-Set reference level: not active
                    Activation of radiator shutter 2-Torque: low
                    Activation of radiator shutter 2-LIN_node_adress_Textual: numerical value: no text
                    Activation of radiator shutter 2-set_value_Textual: numerical value: no text
37261 - Expansion Valve for A/C Refrigerant
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 16:36:56
                    Expanded ambient data 1-Ambient temperature: Malfunction
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 0C
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 1C
59317 - No Communication With Active Grille Air Shutter Module 2
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:56:28
37263 - No Communication With Active Grille Air Shutter Module
          U0284 00 [00101000] - -
                    Fault Frequency: 8
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 10:08:33
                    Expanded ambient data 1-Ambient temperature: 8.00 °C
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 11
60016 - Interior Pre-Conditioning
          P13F1 00 [00101000] - Not Started
                    Fault Frequency: 28
                    Mileage: 115403 km
                    Date: 2025.02.27
                    Time: 17:28:32
                    Expanded ambient data 1-Ambient temperature: 6.00 °C
                    Expanded ambient data 1-previous state of battery cold circuit: 05
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 01
                    Switch-off conditions for pre-conditioning of interior-HV energy management: not active
                    Switch-off conditions for pre-conditioning of interior-Function canceled: entry in DTC memory: active
                    Switch-off conditions for pre-conditioning of interior-Communication malfunction: not active
                    Switch-off conditions for pre-conditioning of interior-Switch-off due to energy management: not active
                    Switch-off conditions for pre-conditioning of interior-No release by coordinator: not active
                    Switch-off conditions for pre-conditioning of interior-Fuel supply low: not active
                    Switch-off conditions for pre-conditioning of interior-Over The Air Update: not active
                    Switch-off conditions for pre-conditioning of interior-Critical component temperature: not active
                    Switch-off conditions for pre-conditioning of interior-Parking heater error value received: not active
54018 - Coolant Pump for Low-Temp Circuit
          P2B2A 00 [01101101] - Running Dry
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:11
                    Expanded ambient data 1-Vehicle speed: 26 km/h
                    Coolant fan 1: activation: 10.00 %
                    Coolant fan 2: activation: Measuring value not available
                    Engine Coolant Temperature Sensor 1: 8.60 °C
                    Engine Coolant Temperature Sensor 5: 8.80 °C
                    Coolant pump for low-temperature circuit-Act.val.: 0
                    Coolant pump for low-temperature circuit-Specified value: 95
                    Coolant recirculation pump-Act.val.: 0
                    Coolant recirculation pump-Specified value: Measuring value not available
                    Coolant circulation pump 2-Act.val.: 0
                    Coolant circulation pump 2-Specified value: 10
                    HV heater temperature-Temperature 1: 12.00 °C
                    HV heater temperature-Temperature 2: 11.00 °C
60009 - Refrigerant Pressure for Heating of Passenger Compartment
          B16A3 84 [01101101] - Signal Below Allowable Range
                    Mileage: 115402 km
                    Date: 2025.02.27
                    Time: 17:23:14
                    Expanded ambient data 1-Ambient temperature: 7.00 °C
                    Expanded ambient data 1-current state of battery low temp.circ.: 06
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 20
                    Expanded ambient data 1-current state of battery cold circuit: 02
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 23
                    A/C pressure/temperature sensor 1-Refrigerant pressure: 0.97 bar
                    A/C pressure/temperature sensor 1-Inside temperature: 12.30 °C
                    A/C pressure/temperature sensor 1-Refrigerant temperature: 9.70 °C
                    A/C pressure/temperature sensor 2-Refrigerant pressure: 0.99 bar
                    A/C pressure/temperature sensor 2-Communication: OK
                    A/C pressure/temperature sensor 2-Malfunction status: OK
                    A/C pressure/temperature sensor 2-Response error: OK
                    A/C pressure/temperature sensor 2-Inside temperature: 11.50 °C
                    A/C pressure/temperature sensor 2-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 2-Refrigerant temperature: 9.00 °C
                    A/C pressure/temperature sensor 3-Refrigerant pressure: Malfunction
                    A/C pressure/temperature sensor 3-Communication: OK
                    A/C pressure/temperature sensor 3-Malfunction status: OK
                    A/C pressure/temperature sensor 3-Response error: OK
                    A/C pressure/temperature sensor 3-Inside temperature: Malfunction
                    A/C pressure/temperature sensor 3-Test Result: Tested in current operating cycle
                    A/C pressure/temperature sensor 3-Refrigerant temperature: Malfunction
                    Refrigerant pressure: 36.02 bar
                    Compressor status: global-A/C compressor release status: not transmitted
                    Compressor status: global-A/C compressor: target speed: 0 /min
                    Compressor status: global-A/C compressor: actual speed: 0 /min
                    Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                    Compressor status: global-A/C compressor error indicator: not active
                    Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                    Compressor status: global-A/C compressor: inverter temperature: -127 °C
60001 - Refrigerant Pressure for Cooling of Passenger Compartment
          B16A2 84 [01101101] - Signal Below Allowable Range
                    Mileage: 115403 km
                    Date: 2025.02.27
                    Time: 17:28:30
                    Expanded ambient data 1-previous state of battery low temp.circ.: 06
                    Expanded ambient data 1-current state of battery cold circuit: 05
                    Expanded ambient data 1-previous state of battery cold circuit: 02
                    A/C pressure/temperature sensor 1-Refrigerant pressure: 0.98 bar
                    A/C pressure/temperature sensor 1-Inside temperature: 12.20 °C
                    A/C pressure/temperature sensor 1-Refrigerant temperature: 9.50 °C
                    A/C pressure/temperature sensor 2-Inside temperature: 11.40 °C
                    A/C pressure/temperature sensor 2-Refrigerant temperature: 8.90 °C
61073 - Coolant Level Sensor
          [EE91 Sensor for inadequate coolant level display Low fluid level]
                    Fault Frequency: 15
                    Mileage: 115412 km
                    Date: 2025.03.09
                    Time: 16:36:34
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: --------------- Dataset Number: 4KE909811F  0001
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56E06EA129C8432BCA-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190819030206081877
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 K    HW: 0EF 907 180 C
   Component: CUBZE68570AD0 H03 1005
   Revision: --------    Serial number: -00122.06.19000
   ASAM Dataset: EV_DMCM2HITACAU516 003009
   VCID: 3FCEAB05A6B2A263F9-806A
49154 - Inverter for Electric Drive Motor 1
          P0A3C 00 [00101000] - Over Temperature
          [OverTempINVIGBTSW_1]
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:41:09
          [SIGERRBCM1_10]
                    Mileage: 115412 km
                    Date: 2025.03.01
                    Time: 10:19:17
          [SIGERRTME_3]
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:12
51005 - Inverter Cooling System
          P0A93 00 [10101000] - Inadequate Performance
          [PlausAccInletCoolantTemp_8]
                    Fault Frequency: 8
                    Mileage: 115398 km
                    Date: 2025.02.27
                    Time: 09:57:20
51017 - Inverter Cooling System
          P0A93 00 [00101000] - Inadequate Performance
                    Mileage: 115408 km
                    Date: 2025.02.28
                    Time: 08:30:00
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71AA3D3DA06604133F-8024
   Dataset Number: 4KE909472E  0011
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
12583949 - Databus
          [TME_NT_Kreis_Status "Fehler"]
                    Reset counter: 150
                    Mileage: 115401 km
                    Date: 2025.02.27
                    Time: 13:42:14
End----------(Elapsed Time: 02:58, VBatt start/end: 15.2V/15.2V)-----------
------------------------------74 Faults Found------------------------------
