Brake Electronics Long Coding lost..
Danny
Ireland
C?ID=123028
Hi Guys,
It's been a while since I last posted and it was still in yahoo groups... Good to see a new forum ( well for me...)
And I have a problem I was wondering if you can help me.. :
We have a volkswagen Caddy on which we disconnected instrument panel. And when you do that 03 Brake Electronics - long coding disappears... Unfortunately nobody kept the scan before they start removing things..
I wonder if long coding for brake el. can be generated? I do have a long coding figure from exactly the same caddy if it's any help. Is there a digit in the coding to correspond to chassi number? Any help appreciated in recreating code appreciated. Thank You
Tuesday,08,December,2015,13:29:14:16151
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WV1ZZZ2KZBX230249   License Plate:
Mileage: 71520km-44440mi   Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZBX230249   Mileage: 71520km-44440miles
Address 01: Engine (J623-CAYE)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 CT    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9970
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023CT 003007
   ROD: EV_ECM16TDI02103L906023AQ.rod
   VCID: 7AF10F5EFDE04EEE25-802E
Readiness: 1110 1000
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Shop #: WSC 35110 377 00156
   VCID: 75EB1C62DCFE219648-8020
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.08
                    Time: 00:09:06
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 4161
                    Count: 41984
                    Count: 256
            000 -  -
                    Reset counter: 218
                    Date: 2015.12.04
                    Time: 00:09:36
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 41472
                    Fault Status: 01100101
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.04
                    Time: 00:09:27
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 279
                    Count: 41472
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.04
                    Time: 00:09:27
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 295
                    Count: 41472
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.04
                    Time: 00:09:27
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 270
                    Count: 41472
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A583A8025186A088000829000006443017288524F0160648000000040
   VCID: 72E1277EAD9036AE6D-8026
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.08
                    Time: 00:06:23
                    Voltage: 9.70 V
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL00253NV
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 356BDC62947E619688-8060
   Part No SW: 5K0 953 507 AR    HW: 5K0 953 549 C
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JJR000FL
   Coding: 1080060000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 00057DB69B3C143E6B-8054
   Part No SW: 2K0 920 865 A    HW: 2K0 920 865 A
   Component: KOMBI         H04 0404
   Coding: 180000
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 2C5DF9064734205EE7-8078
   Coding: 180000
   Coding: 180000
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 021110F1000356
   Coding: 357401
   VCID: 3065ED76631C44BEDB-8064
   Component: IMMO          H04 0404
   VCID: 6AD13F1E8D40FE6ED5-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 4895A5963B8CEC7EE3-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 140    3001
   Revision: 00H17000
   VCID: 3163E872A8164DB6D4-8064
                    Fault Status: 11100101
                    Mileage: 71521 km
                    Date: 2015.12.08
                    Time: 00:06:18
                    Battery Volts: 9.8 V
                        DD
                    Temperature: 12.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 4797A6AA3692E306EA-8012
   Part No SW: 5K0 035 156     HW: 5K0 035 156
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1K0654280
   Coding: 0000020001
   VCID: 64CD51266764A81EEF-8030
End-------------------------(Elapsed Time: 01:33)--------------------------
Gone But Not Forgotten
Very good post ....just no code tags ......yes please post the identical coding of other units you are sure or close in the thread.
Please also verify the VIN is the same in cluster/Immo as in gateway from engine ecu......
What size brakes you have front and rear?
Right or left hand drive?
Hill hold?
Regen braking?
Off road switch?
I am not done...... this is with stripped functions and guessing....... see if base coding takes and report back faults or missing options.
113b200d092500fa280d04e890220002300000
If they PERFORMED a scan, with 15.7.x, it's automagically saved to the SCANS sub-folder. Check there. If they didn't perform a scan before starting work on the car, please use an appropriate tool (perhaps a cricket bat?) to re-educate them.
Danny, check the Scans folder on that PC for any instances of that VIN. Auto-Scans save to Logs but if someone ran one without clicking [Save] it would be backed-up in Scans.
Ah! See what happens when you don't refresh the browser before Saving :-) Ignore me, Uwe already covered it.
Danny: It's also worth looking at the readme.txt file in the scans directory. It speaks volumes about the culture at Ross Tech. It's refreshing to see a message in a modern piece of software written in quite this way; with honestly and with a touch of humour!
Danny
Ireland
C?ID=123028
Thank you for replies!
The identical VW Caddy ( Ordered by the same company with completely the same specs) long coding : 433C200D092503FAC20F04E7901AC081300000
I will try your one on the caddy as well.
It's right hand drive and don't know about other features , but can find out
Thank You
Danny
Ireland
C?ID=123028
good advise , no scan to be seen though :)
Danny
Ireland
C?ID=123028
Ha sometimes even cricket bat doesn't straighten things up. Thank you for advice!
433C200D092503FAC20F04E7901AC081300000 <<<<<<<<< YOUR CODE SUPPLIED
1K0 907 379 BD <<<<<<<<<<<< SEARCH!
TRY THESE BELOW PLEASE.
433C200D092500FAC80D04E892220081300000
433C200D092500FAC80D04E890220082300000
144B200D492500FAC80D04E892220081300000
113B200D092500FA280D04E890220002300000
Please report back if these take or what ones do take.
I came up with something slightly different. Do you happen to have the VIN (or scan) from the Caddy with the above factory coding?
automech
Poland
C?ID=14925
423C000D092500FA420D00E89022C081300000
Try and report, VIN coded.
Although I would still like to dig into the PR codes, or complete scan, from the known good Caddy Niels (NEtech) and I worked separately on this and came up with the same result:
433C200D092503FAC20D04E89022C081300000
I can't guarantee the above coding is correct but any feedback you have would be highly appreciated.
Our concerns were with Bytes 0 and 8 and automech's deviates from our final value in Byte 2 as well. For that reason I would consider sending this to the dealer for online SVM coding and if you do please run/post the final scan config here so we can see what's what.
Danny
Ireland
C?ID=123028
Hi Jack,
Thank you for those codes.
None of these worked , the same error - out of range..
Not sure how to get correct coding now.. I will report back If I come across with a solution .. In the meantime if you have any more codes I am more than happy to try them!
OK Danny,
The VW Dealer may be the best option here but please double check the VIN (WV1ZZZ2KZBX230249) matches the Advanced ID data shown in both addresses 01 and 25 with VCDS.
Danny
Ireland
C?ID=123028
Hi Dana , your code was actually correct!
Thank You very much, I actually thought that I had entered this one before..
All working, I only have to do basic settings on the units.
Guys thank you for the help really appreciated
The full scan :
Wednesday,16,December,2015,17:47:48:16151
VIN: WV1ZZZ2KZBX230249   License Plate: VWCADDY2011
Mileage: 71530km-44446mi   Repair Order:
VIN: WV1ZZZ2KZBX230249   Mileage: 71530km-44446miles
Readiness: 0110 0000
   Revision: 00H31001
   Coding: 433C200D092503FAC20D04E89022C081300000
   Shop #: WSC 56770 001 1048576
                    Reset counter: 219
                    Mileage: 71538 km
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 279
                    Count: 43776
                    Reset counter: 219
                    Mileage: 71538 km
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 295
                    Count: 43776
                    Reset counter: 219
                    Mileage: 71538 km
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 270
                    Count: 43776
   Revision: BB011001
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.12
                    Time: 00:06:23
                    Voltage: 9.70 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 218
                    Mileage: 71521 km
                    Date: 2015.12.12
                    Time: 00:00:05
                    Voltage: 11.95 V
   Coding: 1080060000
   Coding: 180000
   Coding: 180000
   Coding: 357401
   Coding: 0000560
   Revision: 00H17000
                    Mileage: 71521 km
                    Date: 2015.12.12
                    Time: 00:06:18
                        DD
                    Temperature: 12.0°C
                    Count: 3
                        SteerAng n.Init
   Coding: 0000560
   Coding: 0000020001
End-------------------------(Elapsed Time: 01:31)--------------------------
