I’m new in the forum. I need your help please.
I replaced the engine of my Audi Q3 1.5tfsi two months ago. After replacement I got immediately the check engine error and the following codes:
37320 - Capteur de pression 1 des gaz d'échappt (G450) Signal implausible
P0471 00 [0363--
Intermittent - Non Confirmé - Testé depuis RaZ mémoire
2822 - Banc1
P2178 00 [0391 - Syst. de dosage du carburant trop riche à partir du ralenti
Non Confirmé - Testé depuis Raz mémoire
4105 - Banc1
P2187 00 [101] - Syst de dosage du carburant trop pauvre au ralenti
Non Confirmé - Testé depuis Räz mémoire
I already went to Audi and they replaced the G450 sensor but still getting the same errors/ check engine.
Is any one have an idea about this ?
Here bellow the auto-scan I did yesterday:
Le ven. 14 févr. 2025 à 23:29, Tawfik HALLAOUI <hallaoui.tawfik@gmail.com> a écrit :
P0471 00 [0363--
2822 - Banc1
4105 - Banc1
Removed. Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
