VW Transporter T5.1 2010
pgmabley
C?ID=397127
Hi
I get 3 beeps from dash when shutting ignition followed by EML, airbag, ABS, TC warning lights. Centre message brake fault visit workshop. All gone on restart.
Doesn't seem to affect driving
I retrofitted cruise control, MFSW, new cluster and all work. I was using VCDS to try and code out lamp warning and I lost big speedo which was coded by guy I had sort out the EPROM for my vehicle. I got it back by doing the AUS/ROW coding but these warnings seemed to appear at the same time as I was messing about with this.
See log, fault shows up in 17
Any help appreciated, thank you.
Saturday,15,February,2025,15:18:12:55670
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WV1ZZZ7HZAH256000   License Plate: WP10ZHF
Mileage: 183060km-113748mi   Repair Order: Brakes workshop warning
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZAH256000   Mileage: 183060km-113748miles
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CB    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X33 9116
   Revision: 26X33---    Serial number: 00000000000000 CVN: 37925B27
   Coding: 01114010232400080000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
   ROD: EV_ECM20TDI01103L906022CB_002.rod
   VCID: 679E5B6E9EB4A2AE6A-8032
   VINID: 9E606AAAA1D8A916021460000030F4E54F
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 508724AD89A90A9B24A29171A95E10
   Shop #: WSC 02736 790 49152
   VCID: 3424FC2297E219361F-8060
   Part No SW: 7E5 907 047 T    HW: 7E5 907 047 T
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 40CCA0F2DB5AB5968B-8014
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 324120174
   Coding: A0A029380E212001002800C03C2B8CDC0F80432F60030040300000010000
   Shop #: WSC 00788 648 00255
   VCID: 6B96275E8A5C86CE0E-803E
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 10000000000000227728
   Coding: E20000
03303 - Response Closing Status of Rear Left Door
                    Fault Status: 01101000
                    Reset counter: 117
                    Mileage: 183068 km
                    Date: 2019.07.09.
                    Time: 15:07:59
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00Y H05 0011
   Revision: --------    Serial number: 003E5001H2VU Dataset Number: 7E0003v____ 0403
   Coding: 000000000000000000000000000000003059
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3424FC229FE219361F-8060
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160A00
   Shop #: WSC 02756 790 50316
   VCID: 2E10EE4A71CE33E669-807A
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Steuerger t f r Motor: keine Kommunikation]
                    Reset counter: 157
                    Mileage: 183068 km
                    Date: 2025.02.15.
                    Time: 15:01:45
12656896 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Bremse: keine Kommunikation]
                    Reset counter: 157
                    Mileage: 183068 km
                    Date: 2025.02.15.
                    Time: 15:01:44
12669184 - Function Restricted due to Missing Message(s)
          [Steuerger t f r Airbag: keine Kommunikation]
                    Reset counter: 157
                    Mileage: 183068 km
                    Date: 2025.02.15.
                    Time: 15:01:45
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 042300
   VCID: 70AC3032A37A65163B-8024
   Component: IMMO          H06 0605
   VCID: 6A98225A8DA69FC675-803E
Address 56: Radio
End----------(Elapsed Time: 01:50, VBatt start/end: 12.4V/12.4V)-----------
Address 09: DTCs cleared
Dr Sheldon
Windsor UK
C?ID=334979
[Steuerger t f r Motor: keine Kommunikation] = Translates to Engine Control Unit - No Communication
[Steuerger t f r Bremse: keine Kommunikation] = Translates to Brake Control Unit - No Communication
[Steuerger t f r Airbag: keine Kommunikation]= Translates to Airbag Control Unit - No Communication
Would SVM to instrument cluster work ?
Go try !
pgmabley
C?ID=397127
Sorry what is SVM?
Sorry what is SVM?
See how SVM is bold, green, with a broken underline? Hover your cursor over it.
VCDS keeps logs of your changes. See the following and try to revert your changes.
