05 A6 with shuddering transmission
Barnes80
Helena, MT USA
C?ID=128676
I have an 05 A6 3.2 with 119,000 miles that is in need of some maintenance. I have it parked for now making space in the garage for it and gathering parts. It has a couple of leaks at the valve covers I need to take care of, and a seeping power steering connection. I did the front brakes this past summer in a 105 degree hotel parking lot in Texas while on a road trip. The rear pads didn't trip the indicator until after I got back home so I have those to do also.
Since I bought it 50K miles ago, it has had an issue with the accessory belt riding partially off of the tensioner. I spent considerable time on it a couple years ago and have been unable to figure out how to correct it - or if it's actually a problem.
My main issue I am trying to solve though, is a shuddering transmission that is slowly getting worse. It used to just be noticeable at operating temperature at part throttle going up a slight incline - if the RPM was up over @2000 it wouldn't do it. Dropping down a gear with the selector was the easiest way to make it quit, or giving it about half throttle. It quits as soon as you lift off the throttle too, but who does that in an Audi, lol? Even at highway speeds, with or without cruise control, it has a barely noticeable "hiccup", where every 3-5 seconds the tach dips about 25 rpm. At first I thought it was missing, but I have no misfires logged, no MIL light, etc. I did run a few logs earlier this spring and I can see the TQ slips occasionally while in lockup, but I don't know enough about this tool yet to know exactly what i should be looking for to get an accurate diagnosis. I figured I would start with an autoscan, your suggestions are greatly appreciated.
Monday,07,December,2015,18:20:01:15632
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Dealer/Shop Name: monkeywrench
VIN: WAUDG74F05N081741   License Plate: VGL&T
Mileage: 191980km-119290mi   Repair Order: 12715
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 77
VIN: WAUDG74F05N081741   Mileage: 191980km-119290miles
0E-Media Player 1 -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
65-Tire Pressure -- Status: Cannot be reached 1100
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F1 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 01050106190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2A510ABE85C2396E23-807E
18975 - Low Pressure Fuel Sensor (G410)
            P2543 - 009 - Intermittent
                    Fault Frequency: 183
                    Mileage: 186863 km
                    Date: 2015.07.21
                    Time: 20:01:01
                    RPM: 1824 /min
                    Mass Air / Rev.: 294.3 mg/str
                    Temperature: 69.0°C
                        Part Throttle
                    Pressure: 4.9 bar
                    Speed: 90.0 km/h
18613 - Performance Malfunction in Cooling System
            P2181 - 008 -  - Intermittent
                    Fault Status: 00001000
                    Reset counter: 24
                    Mileage: 191391 km
                    Date: 2015.09.03
                    Time: 17:31:00
                    RPM: 2080 /min
                    Mass Air / Rev.: 299.8 mg/str
                    Temperature: 70.5°C
                        Part Throttle
                    Temperature: 9.0°C
                    Speed: 81.0 km/h
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        0079252
   Coding: 0001002
   Shop #: WSC 02331 785 00200
   VCID: 2953F5B280C432762A-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0020895
   VCID: 2649FE8E91DA1D0E07-8072
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0150
   Revision: 27070401    Serial number: 10600300101808
   Coding: 0000015
   Shop #: WSC 02323 785 00200
   VCID: 63CFA79AA268A82620-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H43 0070
   Component: FBSAUDIC6 KSG   H25 0070
01049 - Supply Voltage Term 50
            006 - Short to Plus
                    Fault Status: 01100110
                    Fault Frequency: 204
                    Reset counter: 10
                    Mileage: 186863 km
                    Date: 2015.07.21
                    Time: 20:01:02
02072 - Control Module for Energy Management (J644)
                    Reset counter: 50
                    Mileage: 191693 km
                    Date: 2015.09.17
                    Time: 17:12:54
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 9
                    Reset counter: 10
                    Mileage: 187925 km
                    Date: 2015.08.13
                    Time: 18:55:36
02764 - Access/Start Authorization Switch (E408)
                    Mileage: 191104 km
                    Date: 2015.08.18
                    Time: 07:56:50
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 730 E    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 360KK047511730
   Coding: 0000003
   VCID: 234FE79AE2E8E82660-8076
   Subsystem 1 - Part No: 4F0 910 609
   Component: Bedienteil MMIC6H07 0870
   Subsystem 2 - Serial number: 00000000084001
   Subsystem 3 - Serial number: 0123.11.040000000100010279ÿ
   Subsystem 4 - Serial number: 010279ÿ
                    Reset counter: 175
                    Mileage: 186863 km
                    Date: 2015.07.22
                    Time: 17:10:59
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 10
                    Mileage: 191985 km
                    Date: 2015.12.07
                    Time: 19:13:34
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 H
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000024    Serial number: 00000000090182
   Coding: 0524326
   VCID: 5BBF9F7A9A1890E668-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   Shop #: WSC 02335 785 00200
   VCID: 66C9BE8E515ADD0EC7-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBD7101393
   VCID: 1B3FDF7ADA98D0E6A8-804E
            000 -  -  - Intermittent
                    Reset counter: 46
                    Mileage: 191901 km
                    Date: 2015.09.27
                    Time: 14:22:27
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 E    HW: 4E0 035 593 A
   Serial number: AUZ4Z7D80
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0310
   Revision: 10H29000    Serial number: 00359D082DW%
   Coding: 0013622
   Shop #: WSC 22302 444 58728
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME081D0163-
   Subsystem 3 - Serial number: 6342CSME081C59344
   Subsystem 4 - Serial number: 6351HSME055B4D4DM
   Subsystem 5 - Serial number: 6361HSME055F577FR
   Subsystem 6 - Serial number: 6371VSME050C0E32J
   Subsystem 7 - Serial number: 6381VSME047A5736Q
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026043290327
   Coding: 0002041
   Component: Lenkradmodul    H06 0080
                    Reset counter: 50
                    Mileage: 191693 km
                    Date: 2015.09.17
                    Time: 17:12:55
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H09 0510
   Revision: 00400000    Serial number: 4I233CUC4
   Coding: 0081263
   Shop #: WSC 19400 444 64063
   VCID: 1E39D66EC98AC5CE4F-804A
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 0800804B20031C
   Coding: 6CFE73CD1B7904
   Shop #: WSC 19400 444 53412
   VCID: 2757F38A96D004063C-8072
                    Reset counter: 175
                    Mileage: 186863 km
                    Date: 2015.07.21
                    Time: 20:01:02
                    Reset counter: 46
                    Mileage: 191853 km
                    Date: 2015.09.27
                    Time: 13:22:10
                    Reset counter: 33
                    Mileage: 191693 km
                    Date: 2015.09.17
                    Time: 17:12:56
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 61C3AD92B874BA3632-8034
                    Reset counter: 50
                    Mileage: 191692 km
                    Date: 2015.09.17
                    Time: 17:12:57
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H43 0570
   Revision: 00000000    Serial number: 378KZ047508073
   VCID: 356B29C25C7C6696BE-8060
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Mileage: 186863 km
                    Date: 2015.07.22
                    Time: 17:10:14
                    Bin. Bits:     0100
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: by5
   Coding: 0051947
   Shop #: WSC 02327 785 00200
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 50
                    Mileage: 191985 km
                    Date: 2015.11.04
                    Time: 10:45:07
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01001783650000
   Coding: 0423997
   VCID: 2C5D0CA68F36275ED1-8078
   Component: LIN BACKUP HORN H02 1301
                    Reset counter: 50
                    Mileage: 191693 km
                    Date: 2015.09.17
                    Time: 17:12:56
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
   Component: DSP-High C6     H14 0310
   Revision: PROD_01     Serial number: 00000000018012
   Coding: 0000026
   VCID: 244DE486E7E6EF1E19-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000050924
   Coding: 0001114
   VCID: 5EB9966E890A85CE0F-800A
                    Reset counter: 50
                    Mileage: 191820 km
                    Date: 2023.06.06
                    Voltage: 12.500 V
                    Temperature: 12.0°C
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: –
   Coding: 0051947
                    Reset counter: 50
                    Mileage: 191985 km
                    Date: 2015.11.04
                    Time: 10:45:07
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DBB9162840C9ED616-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000016
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394LR047502306
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000087283
   Shop #: WSC 00000 384 00290
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2411290208
   Coding: 344630393135313035432056413032343131323930323038
02272 - Quiescent Current Stage 1
                    Mileage: 191985 km
                    Date: 2015.11.24
                    Time: 23:53:08
02273 - Quiescent Current Stage 2
                    Mileage: 191985 km
                    Date: 2015.11.26
                    Time: 06:46:35
02276 - Quiescent Current Stage 5
                    Mileage: 191985 km
                    Date: 2015.11.26
                    Time: 07:03:14
02274 - Quiescent Current Stage 3
                    Mileage: 191985 km
                    Date: 2015.11.26
                    Time: 07:03:24
02277 - Quiescent Current Stage 6
                    Mileage: 191985 km
                    Date: 2015.11.26
                    Time: 07:03:34
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0051754
   VCID: 69D3B5B24044F276EA-803C
                    Reset counter: 50
                    Mileage: 191985 km
                    Date: 2015.11.04
                    Time: 10:45:07
Address 65: Tire Pressure
   Part No SW: 4E0 910 753 S    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0550
   Revision: 00000000    Serial number: 00000411170163
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0051754
                    Reset counter: 50
                    Mileage: 191985 km
                    Date: 2015.11.04
                    Time: 10:45:07
   Part No SW: 4F0 910 336 A    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007509120
   Coding: 0010900
   VCID: 2143ED92F8F4FA3672-8074
End-------------------------(Elapsed Time: 02:45)--------------------------
Other_Erik
Northern VA (DC Area)
C?ID=192416
Sounds very reminiscent of the issues I had with my '05 A6 right after I got her (with 190k miles on the clock)
Transmission flush, filter, fill
Differential fluid changes
500 mile break-in
No more shudder (well, significantly reduced, anyway) - still having a bit of lag on acceleration, but otherwise is much smoother.
O_E
Barnes80
Helena, MT USA
C?ID=128676
Thank you getlemen. I plan on fluid and filter replacements once I get it pulled inside, just wasn't sure how far into the transmission I was going to have to go.
I was troubleshooting the fuel code DTC using this guideline from the Wiki -
"Special Notes
When found on FSI engines, MVB 106.2 shows the duty cycle of the lift pump, this value should be below 60% at idle. The higher the number, the more the lift pump has to run to maintain fuel pressure to the High Pressure Fuel Pump."
I didn't take it for a drive, but I checked address 106-20 and my lift pump is running high 80% from as soon as it starts up. It's cold here so I let it get up to operating temp with no change.
Sunday,13,December,2015,13:22:48:15632
VIN:    License Plate: VGL&TE
Mileage: 119319   Repair Order: 121315
                Address 01: Engine  (4F1 910 559 B)
13:22:18
  67.5°C   Coolant Temperature (G62)
  6.29 bar   Current Fuel Pressure
  0.0 %   Fuel Pressure Regulator
  22.2 %   Adaptation Value elect. Fuel Pump
  OFF   Fuel Pump Adapt. Status
  6.30 bar   Fuel Rail Pressure
  87.7 %   Electrical Fuel Pump
  696 /min   Engine Speed (G28)
What do I need to do in order to diagnose this further? Obviously I'm a bit of a noob here. Thanks in advance!
Gone But Not Forgotten
W
That is a good question and the first thing you must have is the repair manual.
www.erwin.audi.com
Please get a script and print the book to PDF so you can ref later and then ask questions based on logs with tool or manual so we can bounce stuff back at you.
You may want to observe the obvious first such as filters and pump volume.........
