Adblue count down
   #21
Joe900
Nw Ontario, Canada
C?ID=182267
Since you're using a HEX+CAN, I don't think you're using an iPad to scan your car. ;)
Laptop in car, no wifi out in garage. I put it on a usb to print inside it so i could reference the codes while on the phone. Thought i could quickly take a pic on the ipad and post it.
   #23
Joe900
Nw Ontario, Canada
C?ID=182267
LOLz @ this whole train-wreck!
Sorry, i have never needed to post logs anywhere and do not post on forums regularly so my set up is not perfect and my experience doing all this is extremely low compared to yours. Judging me from a couple posts. If that make you feel good.
   #24
Joe900
Nw Ontario, Canada
C?ID=182267
Bring laptop inside, within WiFi range. Complete scan will be in Scans sub-folder:
C:\Ross-Tech\VCDS\Scans
Yes i’ll do that, I am not set up perfect for this. Things were already hectic then the car goes no start warning when you need it the most.
   #25
Two dead NOx sensors ~$3k
DEF system attempting to just dump DEF like it's going out of style.... could be another $1k+ due to failed heater and possible pump.....
You see why I said "get it to the dealer" yet?
   #26
Joe900
Nw Ontario, Canada
C?ID=182267
I would agree but if you live in the bush in Northern Ontario where it takes you 2 days to drive 700kms , which may be the case here? You may end up on the side of the road with help a long ways off, and no heat.
I don’t live in the north, I just drove on Monday from Ottawa to Mahone Bay in 1 day, 1525kms. Never far from help and no loss of cel service for my trip. I’ll be 72 soon, Canada is a big place😁.
You’re from ON, so you know about the size of it.
Sorry I worded that poorly, 7 hrs one way to the dealer, 6-8 hrs in the shop, 7 hrs home. You could do it one day if you drive that hwy at night but there are a ton of deer on it then. Safely its two day trip, if it gets fixed in a day. Last time it was two weeks+, they ordered the wrong part, new one came in broken after waiting 2 nights at $200 per night + meals. Then an Extra trip to go back and get it, cost us well over a grand and lost 8 days of work between us.
  • Disagree
Reactions: TTT
   #27
The one time I've been through that part of Canada, we were told moose were a bigger threat than deer. :)
I hate to say this because a Q5 3.0 TDI is a very nice car, but I think that car is an unwise choice if the nearest dealer is 7 hours away.
Dr Sheldon
Windsor UK
C?ID=334979
Are you being deliberately obtuse ?
   #30
Joe900
Nw Ontario, Canada
C?ID=182267
well living here for all my life I have only had 1 close call with a moose, But 1 deer hit, one close enough to leave fur in a trim piece another.... 5 instances needing new undewear total. sightings beside the road per year, moose 0-1, deer 2 dozen easy. moose are the "bigger" threat but more likely you'll smoke a deer. forestry has destroyed the moose population.
dieselgate price was nice, phoned around got the color and options wife wanted, and vw dealership owner here thought he was going to get an audi deal. took a chance. Audi should be a quality car, you would think? Our VW has been great. 270k miles and still going strong. pretty sad when your new car is laid up more in a couple years than your other car has been in 21. i don't go to dealers unless absolutly have to, do all my own work.
   #31
Joe900
Nw Ontario, Canada
C?ID=182267
Saturday,08,February,2025,18:12:25:63384
VCDS Version: 24.7.1.0 (x64)
VIN: WA1MV   License Plate:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72 AC
VIN: WA1MV   Mileage: 80770km-50188miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 AC    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0010
   Revision: 58H14---    CVN: 861DD310C19C777138D3FF82755A21130E1FC39E
   Coding: 2A2A4012052603050000
   Shop #: WSC 17236 004 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401AC 002010
   ROD: EV_ECM30TDI0118K5907401AC_002.rod
   VCID: 71E90F57A05E821E34-8024
   VINID: 9D105D9915A0197440101009185A43C365
9954 - NOx Reductant Consumption too Low
          P20F4 00 [10101111] - -
                    Mileage: 80632 km
                    Date: 2025.01.20
                    Time: 11:19:30
                    Engine RPM: 2124.50 /min
                    Normed load value: 73.3 %
                    Vehicle speed: 42 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: -17 °C
                    Voltage terminal 30: 14.540 V
                    Long-term adaptation of reduction agent dosage: 1.81
                    Measured NOx conversion range 1: 0.000
                    Efficiency threshold of NOx conversion range 1: 0.000
                    Mean temperature of SCR catalyst: 240.8 °C
                    NOx sensor 1: NOx concentration: 677 ppm
                    NOx sensor 2: NOx concentration: 891 ppm
                    Particle filter: unburned fuel calculated: 0.123
9645 - Reductant
          P20E8 00 [01100000] - Pressure too Low
9953 - Reductant Quality Performance
          P207F 00 [11101101] - -
                    Mileage: 80632 km
                    Date: 2025.01.20
                    Time: 11:19:30
                    Engine RPM: 2128.50 /min
                    Normed load value: 72.9 %
                    Vehicle speed: 43 km/h
                    Voltage terminal 30: 14.560 V
                    Mean temperature of SCR catalyst: 240.9 °C
                    NOx sensor 2: NOx concentration: 885 ppm
Readiness: 1 2 0 0 0
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1007
   Revision: --H19---    CVN: 65368DFB
   VCID: 4B95BDBFE23288CE6E-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23150C03
   Shop #: WSC 06335 000 00000
   VCID: 11296FD7C89EE21E54-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0DA54040000000000000
   VCID: 081F42B3BBC4A3D683-805C
   Serial number: 3215000121876006
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 211
                    Mileage: 80420 km
                    Date: 2025.01.08
                    Time: 08:20:24
                    Fault Status: 00101101
                    Reset counter: 0
                    Mileage: 80590 km
                    Date: 2025.01.20
                    Time: 10:43:03
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01010820150725
   Coding: 3621228080
   VCID: 77FD314FC63ADC2EFA-8022
                    Reset counter: 1
                    Mileage: 80362 km
                    Date: 2025.01.02
                    Time: 11:13:29
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001125644802
   Coding: 26000096863CAFE00100488300003D0D0F9CC708A6090221000008004400010200040034000000
   Shop #: WSC 51027 003 1048576
   VCID: 7AFB287BF528C14685-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150729  H12 0050
   Serial number: 90243014150715115723
   Coding: 01DD13
   Serial number: 20494190
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002107150054
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01FF2F35
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 5398CDB7000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Fault Status: 00101110
                    Reset counter: 1
                    Mileage: 80362 km
                    Date: 2025.01.02
                    Time: 11:13:33
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H53 0812
   Serial number: 003NED157CH9   Dataset Number: 8R0909602K  0001
   Coding: 303635313832383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4C97BEA3E73C8FF667-8018
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R150000R2BP
   Serial number: 6334MSME53090E24A
   Serial number: 6344MSME53085A51B
   Serial number: 6352QSME7D523D4C-
   Serial number: 6362QSME6E520852K
   Serial number: 63732SME7F520C6CF
   Serial number: 63832SME7852195A4
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OH2000FM
   Coding: 000037
   VCID: 489F82B3FB4463D643-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 932     HW: 8R0 920 932
   Component: KOMBIINSTR.   H36 0567
   Revision: 00200000    Serial number: 037344Y7G
   Coding: 8BA622000A010008020000
   VCID: 73E5055FD242B00EC6-8026
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z15713034C
   Coding: 80CF07FF00
   VCID: 7EF3246BE900ED66B9-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 5318847303
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 15205000732021200410
                    Fault Frequency: 11
                    Reset counter: 242
                    Mileage: 80171 km
                    Date: 2024.12.12
                    Time: 07:54:12
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 7
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 3
                    Mileage: 80733 km
                    Date: 2025.01.21
                    Time: 10:49:30
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 11
                    Bin. Bits:    00000
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000158959729
   Coding: 01581B00000000000000
   VCID: 428B909BDD7849869D-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0375913819 Dataset Number: 8R0909535F  0021
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3F8D996FA68A246EF2-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0376002051
   Coding: 010211
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000160080335
   Coding: 011D13215E00440004
   VCID: 4FADA9AF1E2AB4EE02-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0022056526 Dataset Number: 8R0909852J  0022
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 45818B87C4567EBEB8-8010
   Revision: 00002001    Serial number: 0375355256
   Coding: 0126023A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Serial number: 00000000000001032921
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
00926 - Terminal 30
                    Reset counter: 0
                    Mileage: 80590 km
                    Date: 2025.01.20
                    Time: 10:43:03
   Revision: 00005001    Serial number: 94813047859807
   VCID: 2D51D32774E6A6FE50-8078
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 3
                    Voltage: 11.80 V
                    Temperature: 4.0°C
                    Temperature: 7.0°C
                    Bin. Bits: 00000100
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000159864464
   VCID: 4E93B4AB1920BDE609-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001697122
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7BE87BBDA80146C5-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156G 0F8301376
   Coding: 020007010000000001
   VCID: 24473603272C67B68F-8070
   Part No SW: 8R1 035 664 H    HW: 8R1 035 664 G
   Component: H-BN-NA       H43 0937
   Revision: --------    Serial number: 522G30F7518945
   Coding: 16020006000581EF55028B4E00000403F40000020000000000
   VCID: 3B75ED7FBA92384EDE-806E
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Serial number: A130G.0F3426884
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002327166
   Component: CD-Database  6208
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 3
                    Mileage: 80733 km
                    Date: 2025.01.21
                    Time: 10:28:04
                    Voltage: 11.60 V
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000160496732
   Coding: 010C13204000240004
   VCID: 46838C8BF15075A6B1-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA5A6CE
   Coding: 1020010
   VCID: 3467C64357CCF7361F-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D71E367A486367EE0-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000160496731
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151900776 Dataset Number: 8R0909571G  0019
   ROD: EV_RDCMA00100.rod
   VCID: 2F6DC92F76EAD4EE62-807A
End-------------------------(Elapsed Time: 04:27)--------------------------
Count-down Reset procedure is here:
You need the last one under 3.0L V6 TDI engines: Generation 2 (UDS protocol)
However, given the fault codes you have, I don't have much hope that this is going to be anything resembling a fix.
I'm a bit surprised by the combination of "Reductant Consumption too Low" and "Reductant Quality Performance". I would think that poor quality DEF would increase consumption, not decrease it.
Joe900
Nw Ontario, Canada
C?ID=182267
my grams consumed shows as 95xxx, i think that is 88 litres and it should be 1-3 litres per 1000 km so i think that falls in range? the tank level does funny things, stuck on 75.7% even after filling right up. then at 22.7% after fully draining the tank. it creeps from 9% to 22.7% with the tank right empty when you first turn it on.
   #35
Joe900
Nw Ontario, Canada
C?ID=182267
in Basic settings does engine need to be warmed up and doors closed....... to do those checks? looking at the IDE08722 Check Reduction med quality.
   #36
Joe900
Nw Ontario, Canada
C?ID=182267
if you reset learned values for reduction.... IDE03402, and get "finished correctly/finish routine: routine not OK". What does that mean? how did it finish correctly but the value never reset?
Joe900
Nw Ontario, Canada
C?ID=182267
so if this does not reset to 1.00 and you do a metering quantity test, the volume it puts out will be porportional to the long term adaptation value with 1 being 25-35 ml. Injector had some build up and adaptation value of 2.18. i have zero knowledge on this scr system but going to guess it is at 2.18 because it is not getting enough reductant to lower NOX readings and its trying add more but isn't getting any/enough. I just want to see if it sprays properly or at all, process of elimination.
   #38
Everything is properly explained in the link that you were directed to. Did you read that info?
   #39
Joe900
Nw Ontario, Canada
C?ID=182267
Got it all fixed up last Monday, hasn't been any trouble since.
