- Feb 11, 2025
- 5
- 1
- North Carolina, USA
- C?ID=583815
I have been trying to figure this problem out for 5 days now and just now learned about the forum. I have the traction control light, the ABS light, and the BRAKE light. When I go to brake forward and reverse, the ABS constantly goes off, and it doesn't go away with time. I have replaced the brake booster vacuum sensor, performed a vacuum leak test (held a vacuum without problems), and tested how much vacuum the system is pulling at idle (nearly 30 inches of Mercury). While I waiting to get verified I was looking at other posts but all of them with this problem only got the lights in reverse so that made me even more confused. Thank you in advance.
Tuesday,11,February,2025,20:31:22:56604
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WA1CMAFPXFA080660 License Plate:
Mileage: 206140km-128089mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72 AC
VIN: WA1CMAFPXFA080660 Mileage: 206140km-128089miles
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI FSA X14 0010
Revision: 58X14--- CVN: F2E9EFCB00000000000000000000000000000000
Coding: 2A2A4012052602050000
Shop #: WSC 23116 035 12345
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002010
ROD: EV_ECM30TDI0118K5907401AC_002.rod
VCID: 71BFC3DB7124CB42A05-8024
VINID: 9D10537515A0A1644020018600DEDD0092
Readiness: 0 0 0 1 X
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1007
Revision: --H19--- CVN: 91114E86
VCID: 4BC371333348C192FA9-801E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 231D1C03
Shop #: WSC 06335 000 00000
VCID: 117FA35B1164AB42C05-8044
03366 - Vacuum Sensor
Reset counter: 66
Mileage: 206138 km
Date: 2025.02.11
Time: 19:11:33
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x0034
Hex Value: 0x01A4
Hex Value: 0x0000
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0D854040000000000000
Shop #: WSC 06335 123 12345
VCID: 08498E3F623EEA8A17B-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3214000154992016
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01211120142680
Coding: 3621228000
VCID: 77ABFDC31FC095726E1-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000950993301
Coding: 26000091813C8FE0D520588300003D0D0F9C4608A6090221000008004001030100000034000000
VCID: 78A9FEFF12DE9A0A67B-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 141107 H12 0050
Serial number: 90243014141101013647
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23490149
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001411145243
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01CFEBAD
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 1A094C57000000000001
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:40
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12WW0Y Dataset Number: 8R0909602F 0002
Coding: 303634313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC1722F3646C6AAF33-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000HKCG
Serial number: 6334MSME4A596978V
Serial number: 6344MSME4C5D283EZ
Serial number: 6352QSME774B0A42M
Serial number: 6362QSME5C484176P
Serial number: 63732SME7F4943705
Serial number: 63832SME094A0546
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NKP000QH
Coding: 000017
VCID: 48C94E3F22BE2A8AD7B-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 03K398JCF
Coding: 8BB722000301D705020000
VCID: 392F3BFB69544302585-806C
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z14B190536
Coding: 80CF07FF00
VCID: 4CC1722F36C6C6AAF33-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 8462665003
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 14189002048021200410
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000124844237
Coding: 01581B00000000000000
VCID: 42DD5C17048200DA09F-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0352507840 Dataset Number: 8R0909535F 0021
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3FDB55E377F06D32661-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0351610681
Coding: 010211
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [00001001] - Automatic Calibration Not Possible
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:41
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000126841151
Coding: 011D13215E00440004
VCID: 4FFB6523C7D0FDB2961-801A
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0009186321 Dataset Number: 8R0909852H 0021
Coding: 100000010001
Shop #: WSC 06334 123 12345
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
Revision: 00002001 Serial number: 0352432400
Coding: 0126063A20FA709587A0053600040047
Component: GTO BF H01 0080
Serial number: 00000000000000916979
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813037519606
VCID: 2D071FABAD1CEFA2C4D-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000126933340
VCID: 4EC57827C0DAF4BA9D7-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000543980
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D24F76CD2481A51F-806E
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156K00E8117913
Coding: 020007010000000001
VCID: 2411FA8FFED62EEA1B3-8070
Part No SW: 8R1 035 746 G HW: 8R1 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 523K50E7507882
Coding: 160200060005A1EF55028B5E00000403140000000000000000
VCID: 3B2321F3636871124A9-806E
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130K/0E3199166
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002061579
Component: CD-Database 5950
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000126976513
Coding: 010C13204000240004
VCID: 46D5400728AA3CFA257-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J49A7F0
Coding: 1020010
VCID: 34310ACF4236BE6A8B3-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D272FEB7D7C7F2274D-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000126881373
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143010083 Dataset Number: 8R0909571G 0019
ROD: EV_RDCMA00100.rod
VCID: 2D071FABAD9CEFA2C4D-8078
65545 - Reductant Level Sensor
P203A 00 [00001001] - Electrical Malfunction
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:43
Voltage terminal 30A: 12.1 V
Voltage terminal 30B: 12.1 V
Voltage terminal 87: 12.0 V
Reductant_pwm_duty_cycle: 0.0 %
Reductant_speed_pump_motor: 0 /min
Reductant_pump_output_stage_temperature: 10 C
Reductant_heater_control_1_output_stage_temperature: 10 C
Reductant_tank_temperature_sensor_actual_value: -50 C
Reductant_temperature_ambient: 7 C
Reductant_current_pump_motor_A: 0.0 A
Reductant_current_pump_motor_B: 0.0 A
Reductant_current_pump_motor_C: 0.0 A
Reductant_heater_control_1_actual_power_value: 0.0 A
Reductant_heater_control_2_actual_power_value: 0.0 A
Reductant_transfer_pump_current: 0.0 A
Reductant_pressure_sensor_actual_value: -200 mbar
Reductant_voltage_sensor_supply: 5.0 V
Reductant_voltage_sensor_gnd: 0.0 V
Reductant_level_sensor_actual_raw_voltage: 0.0 V
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
MO_SCR_Dosierpumpe_Zustand: 00
MO_SCR_Tankheizung: OFF
MO_SCR_Leitungsheizung: OFF
MO_SCR_Transferpumpe: OFF
reserviert 1 0: On
Reserviert 2: OFF
Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
65801 - Reductant Pressure Sensor Circuit
P204A 00 [00001001] - Electrical Malfunction
[SCR-Drucksensor AktivtankKurzschluss nach Masse / Leitungsunterbrechung]
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:43
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
reserviert 1 0: On
Reserviert 2: OFF
66064 - Reductant Tank Temperature Sensor
P205A 00 [00001001] - Electrical Malfunction
[SCR-Temperatursensor AktivtankKurzschluss nach 5V-Versorgung / Leitungsunterbrechung]
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:43
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
reserviert 1 0: On
Reserviert 2: OFF
262403 - Control Circuit for Reductant Heating 1
P20B9 00 [00001001] - Open Circuit
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:43
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
reserviert 1 0: On
Reserviert 2: OFF
262659 - Control Circuit for Reductant Heating 2
P20BD 00 [00001001] - Open Circuit
[SCR-Leitungsheizung (Heizkreis 2)Leitungsunterbrechung]
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:43
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
reserviert 1 0: On
Reserviert 2: OFF
196867 - Control Circuit for Reductant Pump 1
P208A 00 [00001001] - Open Circuit
Reset counter: 26
Mileage: 206138 km
Date: 2025.02.11
Time: 19:10:44
Reductant_pump_output_stage_temperature: 9 C
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: OFF
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
reserviert 1 0: On
Reserviert 2: OFF
End----------(Elapsed Time: 02:16, VBatt start/end: 12.3V
