P2196 - 004 - Signal too High (Rich) - Intermittent - MIL ON
webosb
C?ID=162759
Need help figuring out what's causing this fault. Car is a 2007 VW GTI 2.0 FSI DSG with APR Stage 1 tune (was tuned a couple years ago). I replaced the sensor (front) but the fault keeps coming back with P2196 - 004 - Signal too High (Rich) - Intermittent - MIL ON.
VCDS Version: Release 15.7.2 (x64) Running on Windows 7 x64
Data version: 20151124
Wednesday,09,December,2015,01:33:17:22069
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: #############   Mileage: 190440km-118333miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH14---    Serial number: VWZ7Z0F8162556
   Coding: 0403010A1C070160
   Shop #: WSC 01017 444 70027
   VCID: 2B5F3EAB8A530566EE-807E
008598 - Oxygen (Lambda) Sensor B1 S1
             Freeze Frame:a
                    Fault Status: 10100100
                    Fault Frequency: 8
                    Mileage: 189852 km
                    Time: 18:34:55
                    RPM: 832 /min
                    Load: 22.7 %
                    Temperature: 69.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1158
   Revision: 04507000    Serial number: 00000608190831
   Shop #: WSC 01279 785 00200
   VCID: 142D8557372DBA9EDF-8040
   Revision: 00H11001
   Coding: 0021122
   VCID: 73EFE6CB12E31DA666-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70E5E9C763F526BE9B-8024
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000006151033
   Coding: 878F8F214004150000140000001400000028770B1E0000
   Shop #: WSC 01424 444 82190
   VCID: 377712DB461BB1869A-8062
   Component: Wischer 300806 020  0501
   Coding: 00038805
   Shop #: WSC 01424
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS     H03 0120
   Revision: 00000000    Serial number: AUZ4Z7F3032676
   VCID: 2C5D3DB78F5D025EE7-8078
            000 -  -
                    Reset counter: 15
                    Mileage: 181209 km
                    Time: 01:17:21
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D06ZBVU
   Coding: 0013644
   VCID: 6CDDFDB74FDDC25EA7-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME136A3B35D
   Subsystem 3 - Serial number: 6342MSME12461D234
   Subsystem 4 - Serial number: 6352QSME1412301D2
   Subsystem 5 - Serial number: 6362QSME11112D377
   Subsystem 6 - Serial number: 63727SME0B22416D%
   Subsystem 7 - Serial number: 63827SME0B23447B3
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0012122
   VCID: 7AF1CBEF35896CEE25-802E
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0F8162556
   Coding: 0005207
   Shop #: WSC 01287 785 00200
   VCID: 31632CC3A87F6FB6D4-8064
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 3100106A1008F0
   Coding: 7F8F03600F000000
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1225223T1KC402
   VCID: 7DFBC0F324A75BD600-8028
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0967
   Coding: 0001077
   VCID: 387511E74B05BEFE93-806C
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 346D25D7576D5A9EBF-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 1390068851030C3E2904058FB0080A04889C00
   VCID: 74EDE5D717ED1A9E7F-8020
   Coding: 0001076
   VCID: 397314E3700FA7F66C-806C
   Part No: 1T0 907 357
   Coding: 0000003
Address 56: Radio
   Component:    RDK              0420
   Coding: 0100101
End-------------------------(Elapsed Time: 01:42)--------------------------
