- Jun 28, 2014
- 4,714
- 3,143
- Northern NJ USA
- C?ID=208579
I would be checking that wire if it made it that far chances are that wire is loose ready to break or broken touching another wire.
I'd suspect its a result of the tuna that was previously in thereInteresting. Given the module is horizontal in the car, does water usually seep in from the connector side, or from the circuit side?
(I know OP might not know, this is a question to all)
Thursday,13,February,2025,16:20:28:19073
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VWPL7AJ2BM602384 License Plate:
Mileage: 271670km-168807mi Repair Order: Thursday at 4pm
Chassis Type: AJ-VW36 (7N0)
77
VIN: 3VWPL7AJ2BM602384 Mileage: 271670km-168807miles
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H07--- Serial number:
Coding: 0050078
Shop #: WSC 84224 676 534632
VCID: 2D00D69F61159672C4D-8078
VINID: 0E69E070745A0927460020C8107A12589C
008518 - Supply Voltage for Fuel Injector Group A
P2146 - 000 - Open Circuit
Mileage: 271676 km
Date: 2019.07.07.
Time: 19:59:21
RPM: 2415 /min
Speed: 123.0 km/h
Voltage: 13.76 V
Temperature: 1.8 C
Temperature: 0.9 C
Inj. Quantity: 27.5 mg/str
Bin. Bits: 0011100
000278 - Engine Coolant Temp. Sensor (G62)
P0116 - 000 - Implausible Signal
Mileage: 271676 km
Date: 2019.07.07.
Time: 20:00:39
Temperature: -90.0 C
Temperature: 65.7 C
Temperature: -6.3 C
Temperature: 11.7 C
Temperature: 0.9 C
Readiness: 0 0 0 X 0
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05151112 Serial number: 00001005210211
Shop #: WSC 00066 000 00000
VCID: 186E174BFE9703DA87B-804C
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B600C492200FC880E06EC921D0042B70000
VCID: 74B603FBCEBF87BA4B3-8020
Reset counter: 104
Mileage: 271615 km
Date: 2019.07.07.
Time: 00:01:06
Count: 2
Count: 12
Count: 20480
Count: 16390
Count: 41472
Count: 765
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B03EFFC5459EB27CD-8020
9477872 - AC Compressor First Run-In
B109E F0 [00001001] - Not Performed
Reset counter: 62
Mileage: 271599 km
Date: 2025.02.13.
Time: 02:35:07
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00AC6V Dataset Number: 1KM003v__B_ 0027
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3928F2CFA9DD3AD2585-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005AJGB00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME08655052ZZZO
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME7D025152ZZZT
Serial number: 3511HSME0D5C7B21ZZZW
Serial number: 3521HSME1A205121ZZZ4
Serial number: 35527SME66455821ZZZD
Serial number: 35627SME26297821ZZZE
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JEB000LG Dataset Number: 5K0953507AH D005
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B239F3D84395AA757-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0003527
Coding: 820000
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Coding: 270F01
VCID: 2F3CCC976799E462F61-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 0602
Revision: H25 Serial number: 01071001201285
Coding: ED807F0600161300002002
Shop #: WSC 09046 002 1048576
VCID: 2E02D1936C13ED6AFD7-807A
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R93EB06
Coding: 0000002
VCID: 7EA221D3FCF3DDEA2D7-802A
Component: IMMO H03 0406
VCID: 6A8A1D839CFB414AE1F-803E
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669873792
VCID: 280E278B42F7B35A37B-807C
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 63
Mileage: 271614 km
Date: 2019.07.07.
Time: 03:07:27
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001120854
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide_VW32.rod
VCID: 270C24B74F69BC223E1-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005036246
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3138CAEF7D2DF292E05-8064
Address 46: Central Conv.
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 0602
Coding: 050B0500
VCID: 6FBC0C97A799A462B61-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001109334
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 280E278B4277B35A37B-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005054569
Coding: 000490
67589 - Turn Signal in Exterior Mirror
B11FD 01 [00001001] - Electrical Failure
Reset counter: 62
Mileage: 271600 km
Date: 2025.02.13.
Time: 02:39:41
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3472379
Coding: 01000400040007
VCID: 649673BB7E5F173ADB3-8030
Reset counter: 62
Mileage: 271599 km
Date: 2019.07.07.
Time: 02:35:36
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668139124 Dataset Number: 7P6035730C 0001
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323AC5E374ABC98A99F-8066
13635840 - Supply voltage
U1011 00 [00000000] - Voltage too Low
[Terminal 30: lower limit value not reached]
U1400 00 [00000000] - -
End----(Elapsed Time: 01:21, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
If we knew, we'd have described them already.there are variables listed for the cylinders that aren't described or have units on them. Any idea what they mean?
What's the WD tell you? Are the four injectors you're dealing with separated into groups?I gotta figure out what "Group A" is for the fuel injectors, hoping to find that out with wiring harness.
Anyone got advice?
Sadly the wiring diagram doesn't mention Groups of injectors, it just shows the injector wiring colors and labels. Sigh.What's the WD tell you? Are the four injectors you're dealing with separated into groups?
P2146pend "Fuel Injector Group A Supply Voltage Circuit/Open"
I only get this code after driving the car for a bit, and it isn't consistent. Usually 10 miles or so, engine just getting up to temp in our cold MN weather. -10*F this morning.
What pin was it ?there was one pin with a lot of corrosion on it.
Really you need to look at Injector Voltage and Current with a good scope.
Another thing is an insulation test on the Injectors - Shove a good 250 or 500 Volts into them.
8astard is not STOCK then !! Is it ? Far from it !!More background on the car:
1) It has the EOC performance kit for exhaust and MRTuning Econo Tune installed on it.
Otherwise it is stock.
This is good info. I wish I had a oscilloscope but I do not. Just a multimeter. Is there a scope you recommend buying? Sounds like a good add to the toolkit.That could be an injector going bad when warmed up. If the wiring is intact - All you got to do is load test the wires with a 55w bulb and measure Volt Drop.
If I was able to confidently say "Group A is Cylinder 1 and 2", then I would like to swap both those injectors to cylinders 3 and 4, but without being confident about grouping, I am diagnosing in the dark. I appreciate your strategy here, but was hoping someone who knew these cars a bit more had some knowledge, not just chewing me out for asking. Is this why nobody uses forums anymore?Let us throw some sense and Logic at this !! Ok we dont know what Group A is !!
For sure it would be Injector "1" and at least one other ?
1 & 2 or 1 & 3 or 1 & 4 Maybe Group A is Bank 1 so 1,2,3 & 4.
FFS there is only 4 of them Nobody is asking you to dig roads with a shovel or carry bricks up a ladder all day ?
The car is tuned with MRTuning. There are no other modifications. In the US, it is common for folks to say "Otherwise it is stock." I apologize your highness!8astard is not STOCK then !! Is it ? Far from it !!
How !! Where !! do you get your terminology !!
Your accuracy is pivitol if you want accurate help !!
Wiring diagram doesn't tell me about the groups as far as I can tell. It calls out the wiring to each injector back to the ECM but no grouping.What's the WD tell you? Are the four injectors you're dealing with separated into groups?
That is not on me.Hey Dr Sheldon, thank you for making me feel like an idiot today!![]()
I use the Pico Automotive 4 and 8 channel versions.This is good info. I wish I had a oscilloscope but I do not. Just a multimeter. Is there a scope you recommend buying? Sounds like a good add to the toolkit.
With an Insulation Tester.I have not heard of an insulation test before but sounds like a good idea for injectors, however, how do you get 250 or 500 volts safely?!
Injectors & Wiring - If not then an ECU -- IF ECU Powers and Grounds are Load tested and robust.
Move the injectors around - See if you can get the DTC to change. That helps to eliminate an ECU fault ?? Worth a pop ??If I was able to confidently say "Group A is Cylinder 1 and 2", then I would like to swap both those injectors to cylinders 3 and 4, but without being confident about grouping,
The corroded Pin - Which one was it ????What pin was it ?
Have you referenced it to the Wiring Diagram to KNOW what that Pin does ?? Very Silly if you have not !!
Thank you. I will find something similar.I use the Pico Automotive 4 and 8 channel versions.
Pin #2 on the 60 pin connector, so it was for injector #2. (T60/2)The corroded Pin - Which one was it ????
I will pick up one of these as well for testing injectors.Lose the grouping from your thought process !!
As I said - Pretend it is all 4. Test all 4 !! Find the fault and cure it !!
Yes, I can try this before or after the insulation test, just want to be "strategic" about it since it'll take a bit of disassembly, tuning for changed positions, bleeding the air, etc.Move the injectors around - See if you can get the DTC to change. That helps to eliminate an ECU fault ?? Worth a pop ??
I would drill down on that !!!!! Is that any coincidence ??Pin #2 on the 60 pin connector, so it was for injector #2. (T60/2)
Great points! I will open it back up and see what the female pin looks like and get a new one ordered.I would drill down on that !!!!! Is that any coincidence ??
In fact I would now replace the Female Pin in the Connector. These are available from VW.
You may have cleaned the ECU male pin but you cannot get access to the female socket to clean it - If you try you will just loosen / spread it. Corrosion will likely have weakened it anyway taking away its tension that is needed to grip the male pin !!
If that does not improve things then perhaps pull the casing off the ECU, Locate Pin 2 and solder a wire in there to Wire 2. So a parallel by pass across the connector.
That one connector may be the root cause of the Group A Fault ??
Any Household or Commercial will have one - Basic equipment for them.I will pick up one of these as well for testing injectors.
I figure you're probably right about your ealier message in that Group A is probably #1 and #2 or #1 and #3, it wouldn't make much sense for it to be #1 and #4.
Why not ?? With a firing order of 1-3-4-2 it makes sense !!it wouldn't make much sense for it to be #1 and #4.
Dont bother looking and making judgements - Replace the Female Pin !! Cheap and Easy !! Eliminate that from the equation !!Great points! I will open it back up and see what the female pin looks like and get a new one ordered.
Corrosion on just one pin ?? Not likely to be water /moisture Ingress - Or is it ??Alright, checked out the ECM plugs and sure enough, there was one pin with a lot of corrosion on it. Used electrical contact cleaner, small metal brush, and compressed air to blast everything out.
Photo here: https://photos.app.goo.gl/7P7P94v1qWhghiPM9
Looks like to me that you cleaned it up and repaired the fault ? For sure you promoted change ??Cleaned off the corrosion, got everything back together, drove the car for 10 miles and no issues!
No CEL and when I did an auto-scan, no sporadic communication issues.
