ESP lost long coding vw MOVE UP AUTO
Purdy
C?ID=91911
Hi I have a VW MOVE UP the customer has removed the dash while performing crash repairs and has lost the long coding from ESP.
is there any way to obtain this other than online.
many thanks
david
Wednesday,09,December,2015,14:19:03:27945
VCDS Version: 15.7.2.0
Data version: 20151124
VIN: WVWZZZAAZFD008584   License Plate: LS64CAA
Mileage: 8950km-5561mi   Repair Order: vitalij
Chassis Type: AA (6N0)
Scan: 01 02 03 09 15 17 19 25 44 56
VIN: WVWZZZAAZFD008584   Mileage: 8950km-5561miles
Address 01: Engine (J623-CHYA)       Labels: 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 AM    HW: 04C 907 309 N
   Component: 1.0l R3 MPI   H23 6701
   Revision: UOH23---
   Coding: 00140012020400000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020AM 001009
   ROD: EV_ECM10MPI01104C906020AM.rod
   VCID: 66C7EE0A990AE40EF1-8032
Readiness: 0100 0000
Address 02: Auto Trans (J514)       Labels: None
   Part No SW: 0CT 927 750 A    HW: 0CT 927 750 A
   Component: SQ100         H10 0013
   Coding: 010020
   ASAM Dataset: EV_TCMSQ101011 004010
   ROD: EV_TCMSQ101011.rod
   VCID: 46870E8AF9CAC40E11-8012
19947 - Clutch Position Not Learned
          P080A 00 [109] - -
                    Mileage: 8887 km
                    Date: 2015.12.09
                    Time: 15:38:03
21122 - Clutch Temperature Too High
          P2787 00 [040] - -
                    Mileage: 8887 km
                    Date: 2015.12.09
                    Time: 15:39:41
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 F    HW: 1S0 614 517 F
   Component: EBC 460 ESP   H16 0022
   Serial number: A00LJHV
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_SE12.rod
   VCID: 326F425A654248AEAD-8066
0361 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
0362 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
0363 - Turn Rate Sensor
          C107D 54 [137] - Missing Calibration / Basic Setting
0485 - Control module not coded
          U1013 00 [137] - -
Address 09: Cent. Elect. (J519)       Labels: 1S0-937-08x-09.clb
   Part No SW: 1S0 937 087 D    HW: 1S0 937 087 D
   Component: PQ25 BCM      H30 0561
   Revision: -9------    Serial number: --------------
   Coding: 64B8290000010000000008042C28AC800040400C60020000200000400000
   VCID: 3A7F6A7AB532B0EE65-806E
            000 -  -  - Intermittent
                    Reset counter: 242
                    Mileage: 8887 km
                    Date: 2015.12.09
                    Time: 15:14:19
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag00M H03 0006
   Revision: --------    Serial number: 003MY0096U1J
   Coding: 00000000000000000000000000000000304D
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 3D756166AC1C87D640-8068
   Serial number: 3575HRB40552LFGMDHO4
   Serial number: 3585HRB40672BDFS78UZ
   Serial number: 3555NRB405N197FIIPJ8
Address 17: Instruments (J285)       Labels: 1Sx-920-xxx-17.clb
   Part No SW: 1S0 920 961 C    HW: 1S0 920 961 C
   Component: KOMBI         H43 0304
   Revision: X0043017    Serial number: 00000000000000
   Coding: 414201
   ASAM Dataset: EV_KombiUDSMM9RM10 A04802
   ROD: EV_KombiUDSMM9RM10_SE12.rod
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 1S0 937 087 D
   Component: GW-K-CAN TP20 H30 0561
   Revision: -9------
   Coding: 001100
   VCID: 70EB8852A3CE3ABE9B-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 961 C
   Component: IMMO          H43 0304
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_SE12.rod
   VCID: 6ADF9A3A8D12C06ED5-803E
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6R2 909 144 R    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  322 3111
   Serial number: CE650575
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_SE12.rod
   VCID: 4799038EFEC0DD06EA-8012
   Part No SW: 1S0 035 156 E    HW: 1S0 035 156 E
   Component: Radio         H04 0027
   Revision: R0000000    Serial number: VWZAZ1P0308296
   Coding: 0000020001
   VCID: 2D555126747C1756F0-8078
End-------------------------(Elapsed Time: 01:53)--------------------------
DrPeter
16.4905° S, 151.7375° W
- Did you or the customer happen to perform an Auto-Scan on the vehicle prior to any work being completed?
If so, please have a look in the directory where VCDS.exe lives and check the [Logs] and/or [Scans] folders for a log of the Auto-Scan.
...Ross-Tech\VCDS\Logs
...Ross-Tech\VCDS\Scans
Auto-Scans are save by VIN number by default, and if there, hopefully, you can find the original coding.
Other than that online coding is the only other way that I am aware of for a 2015 VW.
Message:
PRO-Tip... Get in the habit of performing Auto-Scan of every vehicle prior to doing any work,
even when disconnecting a battery, it can save you so much time and aggravation and expense (typical dealer SVM re-coding = 1-hour/$80-$120us+).
hope this helps,
drpeter
automech
Poland
C?ID=14925
I might be able to calculate the coding for you. Look for the scan as DrPeter said first, because I can't ensure to you that my coding will be 100% same as the original (only up to 80-90%). VIN number and some other most important elements will be proper for sure. Only codings that I'm 100% sure of is Bosch 8.2i found in Polo/Ibiza etc. and MK60EC1's. I will do some research at the weekend since this is 2015 model so I can see if VW changed something during last years of production.
Gone But Not Forgotten
This is not correct just for ref only ..........me taking notes and using forum to do it.
43CC48788AAE00F9C2FD12FD51A90040490B00
Part No SW: 1S0 614 517 F HW: 1S0 614 517 FComponent: EBC 460 ESP H16 0022
Coding: 93CC487889AD00F5C9FD12F891AC00404F0D00 ( 03L /6N0 )
HSC 38_10000000010100010100000110010000010100 <<<<<<<<
Purdy
C?ID=91911
No log performed. This is the first time I have seen the car.. Not my mistake this time. been there and got the tea shirt with a seat Ibiza a couple of years ago with dash change. I now take full logs.
Auto mech do you need any additional info. To work thic coding out.
P
Start searching the web for same platform and coding tables of that controller platform to compare........
Post them here.
The reason for auto-scans and why they help the collective later.......... for a fraction of time spent.
Purdy
C?ID=91911
Thanks all for your time and advice. off to the dealer they go for a bit of SVM.
Purdy
Please report back the correction and if you have time beforehand to post the other vehicle with identical attributes.....
Purdy
C?ID=91911
came across a working VW UP today full scan. enclosed
where is the best place to post scans ??
purdy
Wednesday,16,December,2015,12:54:07:27945
VIN: WVWZZZAAZED015165   License Plate: DV63KBJ
Mileage: 47250km-29359mi   Repair Order: up no faults
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZAAZED015165   Mileage: 47250km-29359miles
Address 01: Engine (------CHYA)       Labels: 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 AK    HW: 04C 907 309 N
   Component: 1.0l R3 MPI   H23 5971
   Revision: UOH23---
   Coding: 00110010000400000000
   ASAM Dataset: EV_ECM10MPI01104C906020AK 001006
   ROD: EV_ECM10MPI01104C906020AK.rod
   VCID: 64C3F4026F36961EEF-8030
   Part No SW: 1S0 614 117 L    HW: 1S0 614 117 L
   Component: EBC 460 MABS  H09 0012
   Serial number: A00BXRB
   Coding: 11BF247189AE00F688FB24FB91AE0080580100
   ASAM Dataset: EV_Brake1ABSMP1TRWVW120 012031
   ROD: EV_Brake1ABSMP1TRWVW120.rod
   VCID: 346344429F56469EBF-8060
   Part No SW: 1S0 937 086 D    HW: 1S0 937 086 D
   Revision: -A------    Serial number: --------------
   Coding: 40202B0000000008000000042C28AC800040400C60020000200008400000
   VCID: 397D7576B034BBF66C-806C
   Component: VW10Airbag00R H02 0006
   Revision: --------    Serial number: 003MY003DA87
   Coding: 000000000000000000000000000000003052
   Serial number: 3495RRB401650JHK4HJQ
   Serial number: 3505RRB401850JHKBP4K
   Serial number: 3555NRB401C50IU6G8HO
   Part No SW: 1S0 920 960 J    HW: 1S0 920 960 J
   Component: KOMBI         H31 0205
   Revision: X0031012    Serial number: 00000000000000
   Coding: 414200
   ASAM Dataset: EV_KombiUDSMM9RM10 A04752
   VCID: 387B7072833EA2FE93-806C
   Part No SW: 6N0 909 901     HW: 1S0 937 086 D
   Revision: -A------
   Coding: 001300
   Part No SW: 5K0 953 234     HW: 1S0 920 960 J
   Component: IMMO          H31 0205
Address 44: Steering Assist (J792)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 L    HW: 1S2 909 144 G
   Component: EPS_ECU       H45 1503
   Coding: 0001000001010000
   ASAM Dataset: EV_SteerAssisNSK 009004
   ROD: EV_SteerAssisNSK_SE12.rod
   Part No SW: 1S0 035 156     HW: 1S0 035 156
   Component: Radio         567 5543
   Revision: AA001001    Serial number: VWZ8Z1N5108542
   Coding: 0000020001
   VCID: 68DBE0329B1EF27EC3-803C
End-------------------------(Elapsed Time: 01:35)--------------------------
Address 17:1S0 920 960 J recoded (ADP-ESI: Resetting ESI) from Warning active  to Reset
Address 09:1S0 937 086 D recoded (Long Coding) from 40202B0000000008000000042C28AC800040400C60020000200008400000 to 40202B0000000008000000042C28AC800040400C60020040200008400000  (12345/123/12345)
